[General] Reliable CMMC-CCA Braindumps Files & Latest CMMC-CCA Exam Experience
89
General Reliable CMMC-CCA Braindumps Files & Latest CMMC-CCA Exam Experience
Posted at 1/15/2026 08:34:27      View186 | Replies2        Print      Only Author   [Copy Link] 1#
Up to now, there are three versions of CMMC-CCA exam materials for your choice. So high-quality contents and flexible choices of CMMC-CCA learning mode will bring about the excellent learning experience for you. Though the content of these three versions of our CMMC-CCA study questions is the same, their displays are totally different. And you can be surprised to find that our CMMC-CCA learning quiz is developed with the latest technologies as well.
Cyber AB CMMC-CCA Exam Syllabus Topics:
  • CMMC Level 2 Assessment Scoping: This section of the exam measures skills of cybersecurity assessors and revolves around determining the proper scope of a CMMC assessment. It involves analyzing and categorizing Controlled Unclassified Information (CUI) assets, interpreting the Level 2 scoping guidelines, and making accurate judgments in scenario-based exercises to define what assets and systems fall within assessment boundaries.
  • Evaluating Organizations Seeking Certification (OSC) against CMMC Level 2 Requirements: This section of the exam measures skills of cybersecurity assessors and focuses on evaluating the environments of organizations seeking certification at CMMC Level 2. It covers understanding differences between logical and physical settings, recognizing constraints in cloud, hybrid, on-premises, single, and multi-site environments, and knowing what environmental exclusions apply for Level 2 assessments.
  • CMMC Assessment Process (CAP): This section of the exam measures skills of compliance professionals and tests knowledge of the full assessment lifecycle. It covers the steps needed to plan, prepare, conduct, and report on a CMMC Level 2 assessment, including the phases of execution and how to document and follow up on findings in alignment with DoD and CMMC-AB expectations.
  • Assessing CMMC Level 2 Practices: This section of the exam measures skills of cybersecurity assessors in evaluating whether organizations meet the required practices of CMMC Level 2. It emphasizes applying CMMC model constructs, understanding model levels, domains, and implementation, and using evidence to determine compliance with established cybersecurity practices.
Latest CMMC-CCA Exam Experience | CMMC-CCA Useful DumpsTaking practice exams teaches you time management so you can pass the Certified CMMC Assessor (CCA) Exam (CMMC-CCA) exam. Itcerttest's CMMC-CCA practice exam makes an image of a real-based examination which is helpful for you to not feel much pressure when you are giving the final examination. You can give unlimited practice tests and improve yourself daily to achieve your desired destination.
Cyber AB Certified CMMC Assessor (CCA) Exam Sample Questions (Q88-Q93):NEW QUESTION # 88
When a new employee is issued a laptop, only the user's credentials need to be set up. According to the IT department, the IT manager is the only person who can change laptop setup and user privileges. What documentation should be examined to determine if this is the case?
  • A. System audit logs
  • B. Acceptable use policy
  • C. Inventory records
  • D. Remote access procedures
* Applicable Requirement: AC.L2-3.1.5 - "Employ the principle of least privilege, including for specific security functions and privileged accounts."
* Why A is Correct: Audit logs document when privileged functions (such as account creation, privilege changes, or configuration changes) occur, who performed them, and whether access control restrictions are enforced. Reviewing logs is the only way to confirm the IT manager alone has the capability.
Why Other Options Are Insufficient:
* B (Inventory records): Shows ownership, not privilege changes.
* C (Acceptable use): Policy guidance, not enforcement evidence.
* D (Remote access): Deals with remote connections, not privilege management.
References (CCA Official Sources):
* NIST SP 800-171 Rev. 2 - AC.L2-3.1.5
* NIST SP 800-171A - AC.L2-3.1.5 Assessment Methods
* CMMC Assessment Guide - Level 2
NEW QUESTION # 89
During a CMMC assessment, the Lead Assessor discovers that the OSC has outsourced its incident response to a third-party provider. The OSC provides a contract with the provider but no detailed evidence of the provider's processes. What should the Lead Assessor do?
  • A. Score the incident response practice as "NOT MET" due to insufficient evidence.
  • B. Accept the contract as sufficient evidence of incident response compliance.
  • C. Request detailed evidence from the third-party provider demonstrating how they meet the CMMC incident response practice objectives.
  • D. Terminate the assessment until the OSC implements incident response internally.
Comprehensive and Detailed in Depth Explanation:
The CAP requires specific evidence from third parties for inherited practices (Option B). Options A, C, and D do not follow CAP evidence rules.
Extract from Official Document (CAP v1.0):
* Section 2.2 - Conduct Assessment (pg. 25):"Request detailed evidence from third-party providers to verify inherited practice objectives." References:
CMMC Assessment Process (CAP) v1.0, Section 2.2.
NEW QUESTION # 90
In ensuring it meets its mandates to protect CUI under CMMC, a contractor has implemented a robust, dynamic session lock with pattern-hiding displays to prevent access and viewing of data. After every 5 minutes of inactivity, the current session is locked and a blank, black screen with a battery life indicator is displayed. How is Session Lock typically initiated?
  • A. Automatically, after a predefined period of inactivity
  • B. Only when manually triggered by the user before leaving their workstation
  • C. Through user authentication processes
  • D. By the system administrator manually
Comprehensive and Detailed In-Depth Explanation:
CMMC practice AC.L2-3.1.10 - Session Lock mandates that organizations "initiate a session lock after a defined period of inactivity" to prevent unauthorized access to systems handling CUI. The typical and required initiation method is automatic, triggered by a predefined inactivity threshold (e.g., 5 minutes in this case), ensuring consistent protection without relying on user or admin intervention. Manual initiation by a system administrator or user is less effective and not scalable, while user authentication processes relate to unlocking, not initiating the lock. The CMMC guide emphasizes automation to enforce this control uniformly across systems.
Extract from Official CMMC Documentation:
* CMMC Assessment Guide Level 2 (v2.0), AC.L2-3.1.10: "Initiate session lock after an organization- defined time period of inactivity (e.g., 15 minutes or less)."
* NIST SP 800-171A, 3.1.10: "Test mechanisms to ensure session lock occurs automatically after a specified period of inactivity." Resources:
* https://dodcio.defense.gov/Porta ... L_202112016_508.pdf
NEW QUESTION # 91
When interviewing a contractor's CISO, they inform you that they have documented procedures addressing security assessment planning in their security assessment and authorization policy. The policy indicates that the contractor undergoes regular security audits and penetration testing to assess the posture of its security controls every ten months. The policy also states that after every four months, the contractor tests its incident response plan and regularly updates its monitoring tools. Impressed by the contractor's policy implementation, you decide to chat with various personnel involved in security functionalities. You realize that although it is documented in the policy, the contractor has not audited their security systems in over two years. How many points would you score the contractor's implementation of the practice CA.L2-3.12.1 - Security Control Assessment?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
CA.L2-3.12.1 requires "periodically assessing security controls to determine effectiveness." The policy defines a 10-month cycle, but no audits have occurred in over two years, failing the implementation objective.
Per the DoD Scoring Methodology, this 5-point practice scores -5 (Not Met) when not fully implemented, as partial compliance isn't recognized. The CMMC guide stresses actual execution over documented intent.
* CMMC Assessment Guide Level 2 (v2.0), CA.L2-3.12.1: "Assess controls at defined frequency."
* DoD Scoring Methodology: "5-point practice: Met = +5, Not Met = -5."
Resources:
* https://dodcio.defense.gov/Porta ... AG_Level2_MasterV2.
0_FINAL_202112016_508.pdf
NEW QUESTION # 92
A company has multiple sites with employees at each site that must access the company's CUI network from their remote locations. The company has set up a single access point for all employees to access the network.
What is the MOST significant factor in determining whether the security on this single access point is adequate?
  • A. Physical access is monitored and controlled.
  • B. The remote personnel have notification procedures regarding connection issues.
  • C. Remote access is secured and monitored.
  • D. The security requirements for CUI and FCI are documented.
* Applicable Requirement: AC.L2-3.1.12 and AC.L2-3.1.14 - "Monitor and control remote access sessions" and "Route remote access through managed access control points."
* Why A is Correct: For a single centralized access point, the most critical control is that remote access sessions are properly secured and monitored to prevent unauthorized access to CUI systems. This ensures both confidentiality and integrity of remote connections.
* B: Physical access controls protect on-site systems but do not address remote connection security.
* C: Documentation alone is not sufficient; actual monitoring and security enforcement are required.
* D: Notification procedures relate to incident handling, not adequacy of access point security.
* NIST SP 800-171 Rev. 2 - AC.L2-3.1.12, AC.L2-3.1.14
* NIST SP 800-171A - Remote Access Assessment Objectives
* CMMC Assessment Guide - Level 2, Remote Access Guidance
NEW QUESTION # 93
The browser-based version has all features of the desktop CMMC-CCA practice exam. You don't need special plugins or software installations to operate the web-based Certified CMMC Assessor (CCA) Exam (CMMC-CCA) practice exam. This Certified CMMC Assessor (CCA) Exam (CMMC-CCA) practice test is compatible with every browser such as MS Edge, Chrome, Internet Explorer, Firefox, Opera, and Safari. Itcerttest's web-based CMMC-CCA practice exam promotes self-assessment and self-study.
Latest CMMC-CCA Exam Experience: https://www.itcerttest.com/CMMC-CCA_braindumps.html
Posted at 1/23/2026 23:55:14        Only Author  2#
Your article was truly inspiring, thank you for sharing it with me. CTFL-AcT valid exam blueprint was crucial for my career advancement and salary boostI'm giving them away for free today!
Posted at 1/27/2026 01:51:12        Only Author  3#
ϡ٤ƤYߤԇY˺g˺ϸǤ褦Analytics-Arch-201¤ξ̲Ĥ_k뤳ȤˌƤꡢ10Ϥ_k˴󤭤ʳɹϤƤޤJYϷdzˁߤᡢmФAnalytics-Arch-201ԇYɤϡХ`ͨ^ۥåȥʥդΤ褦Analytics-Arch-201ԇY˺ϸ񤹤뤿ΏMȤʤޤơAnalytics-Arch-201ԇYɤ|θߤAnalytics-Arch-201ѧɤϡ98Ϥθߤϸʤˤä^Ƥ뤿ᡢAnalytics-Arch-201ԇY}ϤޤˤʤˤȤäΤǤ
