[General] HPE6-A78 Certification Training | Exam HPE6-A78 Simulations
81
General HPE6-A78 Certification Training | Exam HPE6-A78 Simulations
Posted at 1/15/2026 09:19:59      View208 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free & New HPE6-A78 dumps are available on Google Drive shared by SureTorrent: https://drive.google.com/open?id=1MeQ-dEJYTkxezg60rzsHIu4_B9Q13Hxt
Here our HPE6-A78 exam braindumps are tailor-designed for you. Unlike many other learning materials, our Aruba Certified Network Security Associate Exam guide torrent is specially designed to help people pass the exam in a more productive and time-saving way, and such an efficient feature makes it a wonderful assistant in personal achievement as people have less spare time nowadays. On the other hand, HPE6-A78 Exam Braindumps are aimed to help users make best use of their sporadic time by adopting flexible and safe study access.
HP HPE6-A78 Certification Exam covers a range of topics related to network security, including network access control, wireless security, VPN technologies, and firewall technologies. HPE6-A78 exam is designed to test a candidate's ability to implement and configure network security solutions using Aruba technologies. Aruba Certified Network Security Associate Exam certification exam is an excellent way for network security professionals to demonstrate their skills and knowledge to potential employers.
Exam HPE6-A78 Simulations & Valid HPE6-A78 Test VceTry to have a positive mindset, keep your mind focused on what you have to do. Self- discipline is important if you want to become successful. Learn to reject temptations. As old saying goes, no pains no gains. Learning our HPE6-A78 preparation materials will help you calm down. What you have learned will finally pay off. With the HPE6-A78 Certification, you can have more oppotunities to the bigger companies. And our HPE6-A78 exam guide is condersidered the best aid to obtain the certification.
Earning the HPE6-A78 Certification demonstrates to employers that you have the skills and knowledge needed to secure enterprise networks using Aruba products. Aruba Certified Network Security Associate Exam certification is highly regarded in the IT industry and can open up new career opportunities for individuals who hold it. Additionally, this certification is a prerequisite for more advanced certifications in the Aruba certification program.
HP Aruba Certified Network Security Associate Exam Sample Questions (Q155-Q160):NEW QUESTION # 155
What is a benefit of Opportunistic Wireless Encryption (OWE)?
  • A. It provides protection for wireless clients against both honeypot APs and man-in-the-middle (MUM) attacks
  • B. It allows anyone lo connect, but provides better protection against eavesdropping than a traditional open network
  • C. It offers more control over who can connect to the wireless network when compared with WPA2-Personal
  • D. It allows both WPA2-capabie and WPA3-capable clients to authenticate to the same WPA-Personal WLAN
The benefit of Opportunistic Wireless Encryption (OWE) is that it allows anyone to connect, but it provides better protection against eavesdropping than a traditional open network. OWE is a type of wireless security specified in the WPA3 standard that offers encrypted communication without the complexity of a full authentication process, thereby securing data on networks that would otherwise be open and unencrypted.
Wi-Fi Alliance specifications for WPA3 and Opportunistic Wireless Encryption (OWE).
Security whitepapers and industry articles discussing the advantages of WPA3, including OWE.
NEW QUESTION # 156
You have deployed a new Aruba Mobility Controller (MC) and campus APs (CAPs). One of the WLANs enforces 802.IX authentication lo Aruba ClearPass Policy Manager {CPPM) When you test connecting the client to the WLAN. the test falls You check Aruba ClearPass Access Tracker and cannot find a record of the authentication attempt You ping from the MC to CPPM. and the ping is successful.
What is a good next step for troubleshooting?
  • A. Check connectivity between CPPM and a backend directory server
  • B. Renew CPPM's RADIUS/EAP certificate
  • C. Reset the user credentials
  • D. Check CPPM Event viewer.
When dealing with a failed 802.1X authentication attempt to a WLAN enforced by Aruba ClearPass Policy Manager (CPPM) where no record of the attempt is seen in ClearPass Access Tracker, a good next troubleshooting step is to check the CPPM Event Viewer. Since you are able to successfully ping from the Mobility Controller to CPPM, this indicates that there is network connectivity between these two devices. The lack of a record in Access Tracker suggests that the issue may not be with the RADIUS/EAP certificate or user credentials, but possibly with the ClearPass service itself or its reception of authentication requests. The Event Viewer can provide detailed logs that might reveal internal errors or misconfigurations within CPPM that could prevent it from processing authentication attempts properly.
NEW QUESTION # 157
What is another setting that you must configure on the switch to meet these requirements?
  • A. Disable SSH on the default VRF and enable it on the mgmt VRF instead.
  • B. Create port-access roles with the same names of the roles that CPPM will send in Aruba-Admin-Role VSAs.
  • C. Configure a CPPM username and password that match a CPPM admin account.
  • D. Set the aaa authentication login method for SSH to the "radius" server-group (with local as backup).
To meet the requirements for configuring an ArubaOS-CX switch for integration with ClearPass Policy Manager (CPPM), it is necessary to set the AAA authentication login method for SSH to use the "radius" server-group, with "local" as a backup. This ensures that when an admin attempts to SSH into the switch, the authentication request is first sent to CPPM via RADIUS. If CPPM is unavailable, the switch will fall back to using local authentication12.
Here's why the other options are not correct:
Option B is incorrect because configuring a CPPM username and password on the switch that matches a CPPM admin account is not required for SSH login; rather, the switch needs to be configured to communicate with CPPM for authentication.
Option C is incorrect because while CPPM will send Aruba-Admin-Role Vendor-Specific Attributes (VSAs), the switch does not need to have port-access roles created with the same names; it needs to interpret the VSA to assign the correct role.
Option D is incorrect because disabling SSH on the default VRF and enabling it on the mgmt VRF is not related to the authentication process with CPPM.
Therefore, the correct answer is A, as setting the AAA authentication login method for SSH to the "radius" server-group with "local" as backup is a key step in ensuring that the switch can authenticate admins through CPPM while providing a fallback method12.
NEW QUESTION # 158
Which is an accurate description of a type of malware?
  • A. Malvertising can only infect a system if the user encounters the malware on an untrustworthy site.
  • B. A Trojan is any type of malware that replicates itself and spreads to other systems automatically.
  • C. Worms are usually delivered in spear-phishing attacks and require users to open and run a file.
  • D. Rootkits can help hackers gain elevated access to a system and often actively conceal themselves from detection.
Malware (malicious software) is a broad category of software designed to harm or exploit systems. HPE Aruba Networking documentation often discusses malware in the context of network security threats and mitigation strategies, such as those detected by the Wireless Intrusion Prevention (WIP) system.
Option A, "Worms are usually delivered in spear-phishing attacks and require users to open and run a file," is incorrect. Worms are a type of malware that replicate and spread automatically across networks without user interaction (e.g., by exploiting vulnerabilities). They are not typically delivered via spear-phishing, which is more associated with Trojans or ransomware. Worms do not require users to open and run a file; that behavior is characteristic of Trojans.
Option B, "Rootkits can help hackers gain elevated access to a system and often actively conceal themselves from detection," is correct. A rootkit is a type of malware that provides hackers with privileged (elevated) access to a system, often by modifying the operating system or kernel. Rootkits are designed to hide their presence (e.g., by concealing processes, files, or network connections) to evade detection by antivirus software or system administrators, making them a stealthy and dangerous type of malware.
Option C, "A Trojan is any type of malware that replicates itself and spreads to other systems automatically," is incorrect. A Trojan is a type of malware that disguises itself as legitimate software to trick users into installing it. Unlike worms, Trojans do not replicate or spread automatically; they require user interaction (e.g., downloading and running a file) to infect a system.
Option D, "Malvertising can only infect a system if the user encounters the malware on an untrustworthy site," is incorrect. Malvertising (malicious advertising) involves embedding malware in online ads, which can appear on both trustworthy and untrustworthy sites. For example, a legitimate website might unknowingly serve a malicious ad that exploits a browser vulnerability to infect the user's system, even without the user clicking the ad.
The HPE Aruba Networking Security Guide states:
"Rootkits are a type of malware that can help hackers gain elevated access to a system by modifying the operating system or kernel. They often actively conceal themselves from detection by hiding processes, files, or network connections, making them difficult to detect and remove. Rootkits are commonly used to maintain persistent access to a compromised system." (Page 22, Malware Types Section) Additionally, the HPE Aruba Networking AOS-8 8.11 User Guide notes:
"The Wireless Intrusion Prevention (WIP) system can detect various types of malware. Rootkits, for example, are designed to provide hackers with elevated access and often conceal themselves to evade detection, allowing the hacker to maintain control over the infected system for extended periods." (Page 421, Malware Threats Section)
HPE Aruba Networking Security Guide, Malware Types Section, Page 22.
HPE Aruba Networking AOS-8 8.11 User Guide, Malware Threats Section, Page 421.
NEW QUESTION # 159
What is a correct guideline for the management protocols that you should use on ArubaOS-Switches?
  • A. Disable Telnet and use TFTP instead.
  • B. Disable HTTPS and use SSH instead
  • C. Disable SSH and use https instead.
  • D. Disable Telnet and use SSH instead
In managing ArubaOS-Switches, the best practice is to disable less secure protocols such as Telnet and use more secure alternatives like SSH (Secure Shell). SSH provides encrypted connections between network devices, which is critical for maintaining the security and integrity of network communications. This guideline is aligned with general security best practices that prioritize the use of protocols with strong, built-in encryption mechanisms to prevent unauthorized access and ensure data privacy.
NEW QUESTION # 160
Exam HPE6-A78 Simulations: https://www.suretorrent.com/HPE6-A78-exam-guide-torrent.html
2026 Latest SureTorrent HPE6-A78 PDF Dumps and HPE6-A78 Exam Engine Free Share: https://drive.google.com/open?id=1MeQ-dEJYTkxezg60rzsHIu4_B9Q13Hxt
Posted at 2/3/2026 02:52:36        Only Author  2#
I truly appreciate your article; the content really left me in awe! Its time for the Analytics-Con-201 exam details exam! Wish me good fortune!
Posted at 2/22/2026 19:45:17        Only Author  3#
Thank you for your article, it truly caught my attention. The NPPE test questions vce test played a big part in my career growth, and Im offering it to you for free today!
