[General] Confluent CCAAK Test Dump & CCAAK Dumps Collection
93
【General】 Confluent CCAAK Test Dump & CCAAK Dumps Collection
Posted at 1/15/2026 09:34:48      View:120 | Replies:2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Actual4dump CCAAK dumps for free: https://drive.google.com/open?id=1aNH6luVeOGs4krkf9ATKOMLQcG8nXDFn
CCAAK Guide Torrent compiled by our company is definitely will be the most sensible choice for you. In this website, you can find three different versions of our CCAAK guide torrent which are prepared in order to cater to the different tastes of different people from different countries in the world since we are selling our Confluent Certified Administrator for Apache Kafka test torrent in the international market. Most notably, the simulation test is available in our software version. With the simulation test, all of our customers will have an access to get accustomed to the Confluent Certified Administrator for Apache Kafka exam atmosphere and get over all of bad habits which may influence your performance in the real Confluent Certified Administrator for Apache Kafka exam.
Confluent CCAAK Exam Syllabus Topics:
  • Apache Kafka® Fundamentals: This section of the exam measures skills of a Kafka Administrator and covers core concepts such as Kafka architecture, components, and data flow. It assesses the candidate’s understanding of topics like topics and partitions, brokers, producers, consumers, and message retention.
  • Deployment Architecture: This section of the exam measures skills of a Kafka Administrator and covers different Kafka deployment topologies. It evaluates understanding of high availability, disaster recovery, multi-data center replication, and the roles of Zookeeper or KRaft in the cluster architecture.
  • Observability: This section of the exam measures skills of a Site Reliability Engineer and focuses on monitoring Kafka clusters. It assesses knowledge of metrics, logging, and alerting tools, including how to use them to maintain cluster health and performance visibility.
  • Apache Kafka® Security: This section of the exam measures skills of a Site Reliability Engineer and focuses on securing Kafka environments. It includes authentication mechanisms such as TLS and SASL, authorization using ACLs, and encrypting data at rest and in transit to ensure secure communication and access control.
Topic 5
  • Apache Kafka® Cluster Configuration: This section of the exam measures skills of a Kafka Administrator and includes configuring broker properties, tuning for performance, managing topic-level settings, and applying best practices for production-grade environments.
Excellent CCAAK Test Dump Provide Prefect Assistance in CCAAK PreparationIf you are confusing while preparing for your test, you can choose to trust our information resource and experienced experts rather than waste a lot of time on learning aimlessly. Our Confluent CCAAK exam guide materials are edited by professional experts based on latest and exact information about the real test. Generally the passing rate is high up to 99.79%. If you want to pass exam as soon as possible, our CCAAK Exam Guide Materials will be most useful product for you.
Confluent Certified Administrator for Apache Kafka Sample Questions (Q27-Q32):NEW QUESTION # 27
You are using Confluent Schema Registry to provide a RESTful interface for storing and retrieving schemas.
Which types of schemas are supported? (Choose three.)
  • A. Thrift
  • B. Protobuf
  • C. JSON
  • D. gRPC
  • E. Avro
Answer: B,C,E
Avro is the original and most commonly used schema format supported by Schema Registry.
Confluent Schema Registry supports JSON Schema for validation and compatibility checks.
Protocol Buffers (Protobuf) are supported for schema management in Schema Registry.
NEW QUESTION # 28
You are managing a cluster with a large number of topics, and each topic has a lot of partitions. A team wants to significantly increase the number of partitions for some topics.
Which parameters should you check before increasing the partitions?
  • A. Check the max open file count on brokers.
  • B. Check if compression is being used.
  • C. Check if acks=all is beina used.
  • D. Check the producer batch size and buffer size.
Each Kafka partition maps to multiple log segment files, and each segment results in open file descriptors on the broker. When the number of partitions increases significantly, it can exceed the OS-level limit for open files per broker process, leading to failures or degraded performance. Therefore, it is essential to check and possibly increase the ulimit -n (max open files) setting on the broker machines.
NEW QUESTION # 29
Which use cases would benefit most from continuous event stream processing? (Choose three.)
  • A. End-of-day financial settlement processing
  • B. Fraud detection
  • C. Context-aware product recommendations for e-commerce
  • D. Log monitoring/application fault detection
  • E. Historical dashboards
Answer: B,C,D
Real-time analysis of transactions helps detect suspicious activity instantly.
Context-aware product recommendations for e-commerce requires real-time user behavior tracking to serve personalized recommendations.
Log monitoring/application fault detection needs immediate processing to alert on system issues or failures.
NEW QUESTION # 30
In certain scenarios, it is necessary to weigh the trade-off between latency and throughput. One method to increase throughput is to configure batching of messages.
In addition to batch.size, what other producer property can be used to accomplish this?
  • A. sendbufferbytes
  • B. delivery.timeout.ms
  • C. compression
  • D. linger.ms
The linger.ms property sets the maximum time the producer will wait before sending a batch, even if the batch isn't full. By increasing linger.ms, you allow more records to accumulate in the batch.
NEW QUESTION # 31
Which property in broker configuration specifies that a broker belongs to a particular rack?
  • A. client.rack
  • B. broker.rack
  • C. kafka.rack
  • D. zookeeper.rack
The broker.rack property is used in a Kafka broker's configuration to specify the rack or availability zone the broker belongs to. This is important for rack-aware replica placement, allowing Kafka to distribute replicas across different racks for fault tolerance.
NEW QUESTION # 32
We have free demo for CCAAK learning materials, we recommend you to have a try before buying, so that you can have a deeper understanding of what you are going to buy. In addition, CCAAK exam dumps contain both questions and answers, they will be enough for you to pass your exam and get the certificate successfully. In order to build up your confidence for CCAAK Learning Materials, we are pass guarantee and money back guarantee if you fail to pass the exam, and the money will be returned to your payment account.
CCAAK Dumps Collection: https://www.actual4dump.com/Confluent/CCAAK-actualtests-dumps.html
Posted at 1/20/2026 09:16:38        Only Author  2#
Thank you for sharing such a positive and motivating article! Examcode materials are available free of charge. Best of luck to everyone! New C_TB120_2504 test sample online
Posted at 1/25/2026 10:18:14        Only Author  3#
Your article is brilliant beyond measure, thank you for sharing! The HPE7-A01 pdf version materials are first-rate, and they’re available for free.
