100% Pass Newest Microsoft - MB-820 - Pass Microsoft Dynamics 365 Business Centr
Posted at 1/15/2026 09:46:54
View211
Replies2
P.S. Free 2026 Microsoft MB-820 dumps are available on Google Drive shared by PassLeaderVCE: https://drive.google.com/open?id=1bpvBQr1nT1z4LA2P-fqkSi4geq72zdtK
We all know the effective diligence is in direct proportion to outcome, so by years of diligent work, our experts have collected the frequent-tested knowledge into our Microsoft MB-820 practice materials for your reference. So our Microsoft Dynamics 365 Business Central Developer training materials are triumph of their endeavor.
It is known to us that our MB-820 learning dumps have been keeping a high pass rate all the time. There is no doubt that it must be due to the high quality of our study materials. It is a matter of common sense that pass rate is the most important standard to testify the MB-820 training files. The high pass rate of our study materials means that our products are very effective and useful for all people to pass their exam and get the related certification. So if you buy the MB-820 study questions from our company, you will get the certification in a shorter time.
Practice Microsoft MB-820 Exam Online | MB-820 Reliable Test SampleOnline test version is the best choice for IT person who want to feel the atmosphere of Microsoft real exam. And you can practice latest MB-820 exam questions on any electronic equipment without any limit. Besides, there is no need to install any security software because our MB-820 Vce File is safe, you just need to click the file and enter into your password.
Microsoft MB-820 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Describe Business Central: Describing the components and capabilities of Business Central, and describing the core solution and extensions approach for Business Central are focal points of this topic. It also explains the difference between Business Central Online and Business Central on-premises features.
| | Topic 2 | - Work with development tools: Implementing semi-automated test processes and managing and assessing telemetry are its sub-topics.
| | Topic 3 | - Integrate Business Central with other applications: Accessing Representational State Transfer (REST) services is discussed in this topic. It also explains implementation of APIs.
Microsoft Dynamics 365 Business Central Developer Sample Questions (Q57-Q62):NEW QUESTION # 57
You are developing a test application to test the posting process of a sales order. You must provide the following implementation:
* Specify the value of post options (dialog: Ship, Invoice, Ship & Invoice) as Invoice.
* Perform calculations and values checking.
You need to complete the development of the test codeunit.
Which methods should you use? To answer, move the appropriate methods to the correct implementation. You may use each method once, more than once, or not at all. You may need to move the split bar between panes or scroll to view content.
NEW QUESTION # 58
A company plans to meet new regulatory requirements.
The regulator has issued new tax tiers.
You need to update the base application table by using a table extension.
Which table field property can you change?
- A. BlankZero
- B. CalcFormula
- C. DecimalPlaces
- D. AutoFormatType
When updating the base application table using a table extension in Microsoft Dynamics 365 Business Central, certain properties of table fields can be modified to meet new requirements, such as regulatory changes. The DecimalPlaces property (B) is one such property that can be adjusted in a table extension. This property determines the number of decimal places that are displayed and stored for decimal fields in the table. Adjusting the DecimalPlaces property can be particularly useful when dealing with financial data and tax calculations that require precision to meet new tax tiers set by a regulator. It's important to note that not all properties can be modified in a table extension; for example, the CalcFormula property (A) cannot be changed as it affects how the field's value is calculated, which could have significant implications on the base application's logic.
NEW QUESTION # 59
You create an 'AddltemsToJson" procedure and publish it.
The procedure fails to run.
You need to fix the errors in the code.
* In line 13, replace the Add method with Insert. = NO
* In line 15, replace the WriteTo method with ReadFrom. = NO
* Change the ItemObject variable type from JsonObject to JsonToken. = NO
* Move line 08 in the beginning of REPEAT .. UNTIL. = YES
The provided code is intended to serialize a list of items from the Item table into a JSON array format. Here is a breakdown of the code and the necessary corrections:
* In line 13, "ItemsArray.Add(ItemObject)": This line is correctly using the Add method to add the ItemObject to the ItemsArray. The Add method is the correct method to use for adding items to a JsonArray. Therefore, there is no need to replace Add with Insert.
* In line 15, "ItemsArray.WriteTo(RequestText)": The WriteTo method is used correctly to serialize the ItemsArray into a JSON formatted string and store it in the RequestText variable. The ReadFrom method is used for the opposite operation, i.e., to deserialize a JSON formatted string into a JsonArray, which is not the goal in this context. Hence, no change is needed here.
* Change the ItemObject variable type from JsonObject to JsonToken: The ItemObject variable is intended to hold JSON objects representing individual items, making JsonObject the appropriate type.
JsonToken is not a type used in this context within AL for Business Central, and thus the variable type should remain as JsonObject.
* Move line 08, "Clear(ItemObject)": This line should be moved inside the repeat loop to ensure that the ItemObject is cleared for each item in the loop. Placing it before the repeat would only clear it once before the loop starts, which could lead to incorrect serialization as the previous item's properties would not be cleared from the ItemObject.
The logic for serializing records into JSON is a common operation when interfacing with APIs or web services in Business Central, and the pattern shown in the code is typical for such operations.
NEW QUESTION # 60
A company is setting up a custom telemetry trace signal to send traces on failed customer statement emails.
NEW QUESTION # 61
A company is deploying Business Central on-premises.
The company plans to use a single-tenant deployment architecture.
You need to describe how the data is stored and how the Business Central Server is configured.
In which two ways should you describe the single-tenant architecture? Each correct answer presents a complete solution.
- A. Each customer has their own Business Central Server.
- B. Multiple customers share multiple Business Central Server instances.
- C. The application and the business data are stored in the same database.
- D. The application and business data are stored in separate databases.
- E. Multiple customers share a single Business Central Server.
In a single-tenant deployment architecture of Business Central on-premises, the following characteristics describe how the data is stored and how the Business Central Server is configured:
* The application and the business data are stored in the same database (B): In a single-tenant architecture, each tenant (which typically corresponds to a single customer) has its own dedicated database. This database contains both the application objects (such as pages, reports, codeunits, etc.) and the business data (such as customer, vendor, and transaction records). This setup ensures that each tenant's data is isolated and can be managed independently.
* The application and business data are stored in separate databases (D): While (B) is a characteristic of a single-tenant deployment, it's important to clarify that in some configurations, the application objects can be stored in a separate database from the business data. This approach can be used for easier maintenance and upgrades of the application code without affecting the business data. However, each tenant still has its own set of databases, maintaining the single-tenancy model.
The other options provided do not accurately describe a single-tenant architecture:
* Each customer has their own Business Central Server (A): This statement might be misleading. In a single-tenant deployment, while each customer has their own database, they do not necessarily have their own Business Central Server instance. Multiple databases (tenants) can be hosted on a single server instance, although they are not shared across customers.
* Multiple customers share a single Business Central Server (C) and Multiple customers share multiple Business Central Server instances (E): These options describe a multi-tenant architecture rather than a single-tenant one. In a multi-tenant setup, multiple customers (tenants) can share the same server instance and even the same application database, with data isolation ensured at the application level.
NEW QUESTION # 62
In order to provide the most effective MB-820 exam materials which cover all of the current events for our customers, a group of experts in our company always keep an close eye on the changes of the MB-820 exam even the smallest one, and then will compile all of the new key points as well as the latest types of exam questions into the new version of our MB-820 Practice Test, and you can get the latest version of our MB-820 study materials for free during the whole year. Do not lose the wonderful chance to advance with times.
Practice MB-820 Exam Online: https://www.passleadervce.com/Microsoft-Dynamics-365/reliable-MB-820-exam-learning-guide.html
- MB-820 Valid Test Cost 🛕 MB-820 Valid Test Cost 🧝 Valid Test MB-820 Braindumps 🕉 Copy URL [url]www.exam4labs.com open and search for ⇛ MB-820 ⇚ to download for free 🔺MB-820 Valid Test Discount[/url]
- Pass MB-820 Guaranteed | Reliable Microsoft Practice MB-820 Exam Online: Microsoft Dynamics 365 Business Central Developer 🟩 Search for ➥ MB-820 🡄 and download it for free immediately on ➤ [url]www.pdfvce.com ⮘ 🤔MB-820 Valid Test Discount[/url]
- MB-820 Exam Overviews 📍 MB-820 Valid Test Discount 🎮 Valid Test MB-820 Braindumps 🅰 Search for ➤ MB-820 ⮘ and easily obtain a free download on { [url]www.validtorrent.com } 😗MB-820 Exam Forum[/url]
- How to Prepare For Microsoft MB-820 Exam Questions? 🔧 Simply search for ➥ MB-820 🡄 for free download on [url]www.pdfvce.com 🚉MB-820 Latest Exam Simulator[/url]
- MB-820 Exam Forum 🕌 Latest MB-820 Braindumps Pdf 🏐 MB-820 Valid Exam Guide ⚠ Easily obtain ➤ MB-820 ⮘ for free download through [url]www.vceengine.com ✋Latest MB-820 Braindumps Pdf[/url]
- MB-820 Exam Forum 🎱 MB-820 Exam Overviews 🎫 Prep MB-820 Guide 🚗 Download MB-820 for free by simply entering ➡ [url]www.pdfvce.com ️⬅️ website 😾Valid MB-820 Exam Vce[/url]
- 2026 High Pass-Rate Microsoft Pass MB-820 Guaranteed 🕙 ▷ [url]www.prep4away.com ◁ is best website to obtain ⇛ MB-820 ⇚ for free download 🔎Latest MB-820 Exam Answers[/url]
- Cost Effective MB-820 Dumps 🔵 MB-820 Valid Exam Guide 🧭 Valid MB-820 Exam Vce 📪 Search for ⇛ MB-820 ⇚ and download it for free immediately on [url]www.pdfvce.com 🎬MB-820 Valid Test Discount[/url]
- Prep MB-820 Guide 🐳 Latest MB-820 Braindumps Pdf ⚽ MB-820 Braindumps Downloads 🛑 ▛ [url]www.examcollectionpass.com ▟ is best website to obtain ⮆ MB-820 ⮄ for free download 🤎MB-820 Test Papers[/url]
- MB-820 exam practice material - MB-820 study training pdf - MB-820 online test engine 🧮 Easily obtain ➠ MB-820 🠰 for free download through ▛ [url]www.pdfvce.com ▟ 🏈Valid MB-820 Exam Vce[/url]
- 100% Pass Trustable Microsoft - Pass MB-820 Guaranteed ➰ Download ➡ MB-820 ️⬅️ for free by simply searching on ▶ [url]www.easy4engine.com ◀ 🐂MB-820 Latest Dumps Ebook[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, pathshala.digitalproductszones.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New MB-820 dumps are available on Google Drive shared by PassLeaderVCE: https://drive.google.com/open?id=1bpvBQr1nT1z4LA2P-fqkSi4geq72zdtK
