[General] 1z0-1124-25 Valid Test Guide | 1z0-1124-25 Actual Dumps
65
General 1z0-1124-25 Valid Test Guide | 1z0-1124-25 Actual Dumps
Posted at 1/15/2026 09:49:20      View228 | Replies5        Print      Only Author   [Copy Link] 1#
2026 Latest LatestCram 1z0-1124-25 PDF Dumps and 1z0-1124-25 Exam Engine Free Share: https://drive.google.com/open?id=1TJcX3qCk3PRawXusTGj6v-ZewMX7GZSw
It is well known that certificates are not versatile, but without a 1z0-1124-25 certification you are a little inferior to the same competitors in many ways. Compared with the people who have the same experience, you will have the different result and treatment if you have a 1z0-1124-25 Certification. Without doubt, you will get a higher salary if you have a 1z0-1124-25 certification or you can enter into a bigger company. And our 1z0-1124-25 exam materials can make your dream come true.
Oracle 1z0-1124-25 Exam Syllabus Topics:
  • Transitive Routing: This section of the exam measures the skills of a Network Security Engineer and focuses on the interpretation and synthesis of transitive routing configurations. It includes understanding how DRG, Local Peering Gateways (LPG), and network appliances interact in a routed network and implementing those configurations effectively.
  • Design and Deploy OCI Virtual Cloud Networks (VCN): This section of the exam measures the skills of a Cloud Network Engineer and covers the design and configuration of Virtual Cloud Networks in Oracle Cloud Infrastructure. It includes understanding VCN and subnet characteristics, implementing both IPv4 and IPv6 addressing, identifying the distinct roles of OCI gateways, and recognizing endpoint types and their application within networking architectures. Knowledge of Object Storage endpoints is also referenced.
  • Migrate Workloads to OCI: This section of the exam measures the skills of a Cloud Migration Specialist and focuses on identifying the best networking connectivity strategies when migrating workloads to Oracle Cloud. It includes scenarios involving on-premises infrastructure, other cloud providers, and multicloud environments, ensuring proper connectivity and minimal downtime during transitions.
  • OCI Networking Best Practices: This section of the exam measures the skills of a Cloud Solutions Architect and covers essential best practices for designing secure, efficient, and scalable networking solutions in OCI. It includes architectural design, connectivity setup, security hardening, and monitoring and logging standards that align with industry and Oracle-recommended guidelines.
Topic 5
  • Implement and Operate Secure OCI Networking and Connectivity Solutions: This section of the exam measures the skills of a Cloud Security Specialist and centers around securing networking configurations and interconnectivity in OCI. It involves applying IAM policies for tenancy communication, using bastion services in multi-tier setups, exploring CloudShell capabilities, and evaluating network security layers like OCI Network Firewall, Web Application Firewall (WAF), edge services, and certificates. This section also references obsolete content related to IaC and OKE in networking architectures while touching on zero-trust packet routing models.
Oracle 1z0-1124-25 Actual Dumps, Authorized 1z0-1124-25 CertificationNowadays in this information-based world the definition of the talents has changed a lot and the talents mean that the personnel boost both the knowledge in 1z0-1124-25 area and the practical abilities now. So if you want to be the talent the society actually needs you must apply your knowledge into the practical working and passing the test 1z0-1124-25 Certification can make you become the talent the society needs. If you buy our 1z0-1124-25 study materials you will pass the 1z0-1124-25 exam successfully and realize your goal to be the talent.
Oracle Cloud Infrastructure 2025 Networking Professional Sample Questions (Q48-Q53):NEW QUESTION # 48
When migrating workloads from another cloud provider to OCI, what is a key consideration when choosing a connectivity strategy to ensure optimal network performance?
  • A. Only considering managed connectivity solutions to avoid the complexity of configuring VPNs or direct interconnects
  • B. Ignoring the geographical proximity of the cloud regions being interconnected
  • C. Factoring in the bandwidth requirements of the applications being migrated and choosing a connection that can accommodate peak traffic loads
  • D. Prioritizing the lowest possible initial setup cost, even if it results in higher ongoing operational expenses
* Goal: Ensure optimal performance in connectivity strategy.
* Option A: Low setup cost may compromise performance-incorrect.
* Option B: Proximity affects latency; ignoring it harms performance-incorrect.
* Option C: Matching bandwidth to app needs ensures performance-correct.
* Option D: Limiting to managed solutions restricts options-incorrect.
* Conclusion: Option C is the key consideration.
Oracle advises:
* "Consider application bandwidth requirements and peak loads when selecting a connectivity strategy for optimal performance during migration."This supports Option C. Reference:Network Planning for Migration - Oracle Help Center(docs.oracle.com/en-us/iaas/Content/Network/Concepts/migration.
htm#planning).
NEW QUESTION # 49
Your company needs to connect an on-premises data center to an OCI Virtual Cloud Network (VCN) to extend their existing infrastructure to the cloud. The connection MUST be secure, reliable, and provide consistent, low-latency access to resources in both environments. Resources in the OCI VCN need access to the on-premises servers, and resources in the on-premises data center need to access the compute instances located in a private subnet within the OCI VCN. Which is the MOST appropriate architectural design for establishing connectivity in this hybrid cloud environment, considering the available endpoints and gateway options in OCI?
  • A. Establish a FastConnect connection between the on-premises network and the OCI VCN, utilizing a Dynamic Routing Gateway (DRG) in OCI.
  • B. Implement a Site-to-Site VPN connection between the on-premises network and the OCI VCN, utilizing a Dynamic Routing Gateway (DRG) in OCI.
  • C. Configure a public endpoint for each resource in the OCI VCN that needs to be accessed from the on- premises network.
  • D. Implement a FastConnect connection from the on-premises network to the OCI VCN utilizing a Dynamic Routing Gateway (DRG) in OCI and implement a Site-to-Site VPN connection as backup.
* Requirements: Secure, reliable, low-latency, bidirectional access with redundancy.
* Option A: VPN via DRG is secure but lacks low latency and redundancy-insufficient.
* Option B: FastConnect via DRG offers low latency and security but no redundancy-partial fit.
* Option C: Public endpoints are insecure and high-latency-incorrect.
* Option D: FastConnect for primary low-latency access, VPN as backup for redundancy-correct and most appropriate.
* Conclusion: Option D meets all criteria.
Oracle states:
* "FastConnect with DRG provides secure, low-latency hybrid connectivity. Add a Site-to-Site VPN for redundancy to ensure reliability."This supports Option D. Reference:Hybrid Cloud Connectivity - Oracle Help Center(docs.oracle.com/en-us/iaas/Content/Network/Tasks/hybridcloud.htm).
NEW QUESTION # 50
You are designing a hybrid cloud environment where multiple VCNs in OCI need to communicate with your on-premises network. You are using a single Dynamic Routing Gateway (DRG) to connect to your on- premises network via FastConnect. You want to ensure that each VCN is isolated from the others and that traffic between VCNs must pass through your on-premises security appliances for inspection. How should you configure the DRG attachments and route tables to enforce this security policy?
  • A. Attach each VCN directly to the FastConnect using IPSec VPN tunnels, bypassing the DRG entirely to ensure all traffic flows through the on-premises security appliances.
  • B. Attach each VCN to the DRG using a Local Peering Gateway (LPG) and then attach one VCN to FastConnect. Configure routes so that traffic traverses from LPG to LPG through the on-premises network.
  • C. Attach all VCNs and the FastConnect to the DRG. Configure the DRG route table associated with each VCN attachment to route all traffic destined for other VCNs to the FastConnect attachment. Configure the FastConnect DRG route table to route traffic destined to each VCN to the corresponding VCN attachment.
  • D. Attach all VCNs and the FastConnect to the DRG. Configure static routes on each VCN's route table pointing to the DRG for any subnet not within the VCN. Enable the "Transit Routing" feature on the DRG to allow inter-VCN communication.
* Requirements:VCN isolation, inter-VCN traffic via on-premises appliances.
* DRG Role:Central hub for VCN and FastConnect connectivity.
* Evaluate Options:
* ARG routes inter-VCN traffic via FastConnect to on-premises; meets isolation and inspection needs.
* B:Transit Routing allows direct VCN-to-VCN communication, bypassing on-premises; incorrect.
* C:Bypassing DRG with VPNs is complex and unsupported; incorrect.
* DPG is for intra-region peering, not DRG-to-FastConnect; incorrect.
* Conclusion:Option A enforces the policy via DRG route tables.
DRG route tables control traffic flow. The Oracle Networking Professional study guide states, "To force inter- VCN traffic through an on-premises network via FastConnect, configure DRG route tables to route VCN- destined traffic to the FastConnect attachment, ensuring isolation and inspection" (OCI Networking Documentation, Section: DRG Routing). This setup leverages a single DRG effectively.
NEW QUESTION # 51
You are designing a highly available web application on OCI. The application needs to be accessible globally with traffic being routed to the nearest region based on user location. Additionally, you need to implement sophisticated traffic management policies, such as A/B testing and weighted traffic distribution based on application version. You also require protection against DDoS attacks. Which OCI load balancing solution is best suited for these requirements?
  • A. Regional Load Balancer
  • B. Flexible Load Balancer
  • C. Network Load Balancer
  • D. Global Load Balancer with Traffic Management Steering Policies
* Requirements:Global access, geo-routing, advanced traffic management, DDoS protection.
* Load Balancer Options:
* Regional LB:Single-region, no global routing or advanced policies.
* NLBayer 4, no HTTP-based traffic management or DDoS features.
* Global LB with Steering Policiesayer 7, supports geo-routing and policies.
* Flexible LB:Not a specific OCI service.
* Assess Fit:
* Aacks global and advanced features; unsuitable.
* B:No Layer 7 or DDoS protection; incorrect.
* C:Meets all requirements with geo-routing, steering policies, and WAF integration; best fit.
* D:Non-existent service; incorrect.
* Conclusion:Global LB with steering policies is the best solution.
The Global Load Balancer with Traffic Management Steering Policies supports global applications. The Oracle Networking Professional study guide explains, "Global Load Balancer enables geo-based routing and advanced traffic policies like A/B testing and weighted distribution, integrating with OCI WAF for DDoS protection" (OCI Networking Documentation, Section: Load Balancing - Traffic Management). This aligns with all specified requirements.
NEW QUESTION # 52
Your company is migrating its legacy application to OCI. This application uses self-signed certificates. As part of the migration, you want to replace these with certificates issued by a trusted Certificate Authority (CA) managed through OCI Certificates. What is the most secure and recommended method to handle this transition?
  • A. Obtain certificates from OCI Certificates, gradually replace self-signed certificates on application servers, and update the truststores on client systems to include the OCI Certificates CA.
  • B. Import the self-signed certificates into OCI Certificates and continue using them until they expire.
  • C. Immediately replace the self-signed certificates on all application servers with certificates issued by OCI Certificates, without any gradual rollout.
  • D. Configure OCI WAF to bypass certificate validation for the legacy application.
* Objective: Securely transition from self-signed to trusted CA certificates.
* Option A: Importing self-signed certificates into OCI Certificates doesn't improve security-incorrect.
* Option B: Immediate replacement risks outages if clients don't trust the new CA-unrecommended.
* Option C: Gradual replacement with OCI Certificates, updating client truststores, ensures security and minimizes disruption-correct.
* Option D: Bypassing validation via WAF weakens security-incorrect.
* Conclusion: Option C is the most secure and recommended method.
Oracle advises:
* "Replace self-signed certificates with OCI Certificates from a trusted CA. Perform a phased rollout and update client truststores to avoid disruptions."This validates Option C. Reference:OCI Certificates Overview - Oracle Help Center(docs.oracle.com/en-us/iaas/Content/Security/Certificates/overview.
htm).
NEW QUESTION # 53
To address the problems of Oracle Cloud Infrastructure 2025 Networking Professional (1z0-1124-25) exam candidates who are busy, LatestCram has made the Oracle Cloud Infrastructure 2025 Networking Professional (1z0-1124-25) dumps PDF format of real Oracle Cloud Infrastructure 2025 Networking Professional (1z0-1124-25) exam questions. This format's feature to run on all smart devices saves your time. Because of this, the portability of Oracle Cloud Infrastructure 2025 Networking Professional (1z0-1124-25) dumps PDF aids in your preparation regardless of place and time restrictions.
1z0-1124-25 Actual Dumps: https://www.latestcram.com/1z0-1124-25-exam-cram-questions.html
P.S. Free & New 1z0-1124-25 dumps are available on Google Drive shared by LatestCram: https://drive.google.com/open?id=1TJcX3qCk3PRawXusTGj6v-ZewMX7GZSw
Posted at 1/20/2026 14:37:42        Only Author  2#
Die Schulungsunterlagen zur SAP C-SEC-2405 Zertifizierungsprfung aus unserem Fast2test kann Ihren Traum - die C-SEC-2405 Prfung bestehen - verwirklichen, denn sie alle Dinge fr den Durchlauf der SAP C-SEC-2405 Zertifizierungsprfung enthalten. Wählen Sie Fast2test, können sie bestimmt die SAP C-SEC-2405 Zertifizierungsprfung bestehen, so werden Sie auch ein Mitglied der Eliten im IT-Bereich. Worauf warten Sie? Bitte beeilen Sie sich!
Posted at 1/31/2026 16:30:21        Only Author  3#
Thank you for sharing such an insightful and uplifting article! Level up your IT abilitiesfree Google-Workspace-Administrator valid exam prep for you! Wishing you all the best!
Posted at 2/5/2026 20:59:16        Only Author  4#
This article has helped me understand related concepts better, and Ive gained a lot. Upgrade your IT knowledge with free Valid InsuranceSuite-Analyst soft simulations. Wishing you success in your exams!
Posted at 2/19/2026 10:01:44        Only Author  5#
The content of this article has been very helpful to my personal growth. The extensive content in New L5M10 test topics pdf is offered free of charge to support you.
Posted at 2/20/2026 05:37:31        Only Author  6#
Itexamdump 에서 제공해드리는 Palo Alto Networks CloudSec-Pro덤프는 아주 우수한 IT인증덤프자료 사이트입니다. IT업계엘리트한 강사들이 퍼펙트한 Palo Alto Networks CloudSec-Pro 덤프문제집을 제작하여 디테일한 시험문제와 답으로 여러분이 아주 간단히alo Alto Networks CloudSec-Pro시험을 패스할 수 있도록 최선을 다하고 있습니다.
