[General] Oracle 1Z0-1084-25 Pdf Exam Dump & 1Z0-1084-25 Latest Exam Online
94
【General】 Oracle 1Z0-1084-25 Pdf Exam Dump & 1Z0-1084-25 Latest Exam Online
Posted at 1/15/2026 10:47:45      View:131 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Oracle 1Z0-1084-25 dumps are available on Google Drive shared by FreeDumps: https://drive.google.com/open?id=1ZAuH3-3NHNyt3X-JKB_VhC1Y5D6Pk703
You may now download the 1Z0-1084-25 PDF documents in your smart devices and lug it along with you. You can effortlessly yield the printouts of 1Z0-1084-25 exam study material as well, PDF files make it extremely simple for you to switch to any topics with a click. While the Practice Software creates is an actual test environment for your 1Z0-1084-25 Certification Exam. All the preparation material reflects latest updates in 1Z0-1084-25 certification exam pattern.
Oracle 1Z0-1084-25 Exam Syllabus Topics:
  • Monitoring & Troubleshooting Cloud-Native Applications: This section of the exam focuses on monitoring and troubleshooting cloud-native applications. It covers using OCI Monitoring to track metrics, OCI Logging for managing logs and performing tasks related to monitoring, logging, and tracing for better observability and issue resolution.
  • Leveraging Serverless Technologies for Cloud Native Development: This section of the exam measures the skills of professionals in serverless development within OCI. It covers creating serverless applications using Oracle Functions, building API gateways for routing traffic, and integrating systems through OCI Streaming Service. Additionally, it explores event-driven architectures using OCI Event Service and how OCI Queue enables asynchronous messaging between microservices.
  • Testing and Securing Cloud-Native Applications: This section focuses on testing strategies and security for cloud-native applications. It discusses different testing methodologies, securing sensitive information using OCI Vault, and implementing security measures to address cloud-native development challenges.
  • Cloud Native Applications and Containerization: This section of the exam covers containerization technologies for cloud-native applications. It explains Docker architecture, its components, and the process of pulling and pushing container images using Oracle Cloud Infrastructure Registry (OCIR). It also explores container orchestration, deploying applications on Oracle Kubernetes Engine (OKE), and using OCI Service Mesh for Kubernetes deployments.
Topic 5
  • Cloud Native Fundamentals: This section of the exam measures the skills of target audience and covers the essential principles of cloud-native development. It explains the core concepts, key pillars, and advantages of cloud-native applications. The section also focuses on microservices architecture, including its design methodology and how it supports scalable, distributed applications.
1Z0-1084-25 Latest Exam Online & Reliable 1Z0-1084-25 Test NotesAs the saying goes, knowledge has no limits. You may be old but the spirit of endless learning won’t be old. If you attend the test of 1Z0-1084-25 certification you will update your stocks of knowledge and improve your actual abilities, buying our 1Z0-1084-25 Study Materials can help you pass the test smoothly. You will acquire a lot of knowledge to make you more learned and enhance your working abilities in some certain area.
Oracle Cloud Infrastructure 2025 Developer Professional Sample Questions (Q23-Q28):NEW QUESTION # 23
A developer using Oracle Cloud Infrastructure (OCI) API Gateway needs to authenticate the API requests to their web application. The authentication process must be implemented using a custom scheme which accepts string-based parameters from the API caller. Which approach should the developer use in this scenario?
  • A. Create an authorizer function using request header authorization.
  • B. Create an authorizer function using OCI Identity and Access Management 91AM) based authentication.
  • C. Create a cross account functions authorizer.
  • D. Create an authorizer function using token-based authorization.
In the given scenario, the developer should use the approach of creating an authorizer function using token-based authorization. Token-based authorization is a commonly used approach for authenticating API requests. It involves generating and issuing tokens to API callers, which they can then include in the requests they make to the API. The tokens serve as proof of authentication and are validated by the server to ensure the caller's identity and access rights. By creating an authorizer function using token-based authorization, the developer can implement a custom scheme that accepts string-based parameters from the API caller. This allows the developer to define their own authentication logic and validate the provided tokens according to their requirements. The authorizer function can be configured in the OCI API Gateway to be invoked before forwarding the request to the web application. It will perform the necessary token validation and authentication checks, allowing only authorized requests to access the protected resources of the web application.
NEW QUESTION # 24
Which statement accurately describes the Oracle Cloud Infrastructure (OCI) Load Balancer integration with OCI Container Engine for Kubernetes (OKE)?
  • A. OKE service provisions an OCI Load Balancer instance for each Kubernetes service with LoadBalancer type in the YAML configuration.
  • B. OCI Load Balancer instance provisioning is triggered by the OCI Events service for each Kubernetes service with LoadBalancer type in the YAML configuration.
  • C. OCI Load Balancer instance must be manually provisioned for each Kubernetes service that requires traffic balancing.
  • D. OKE service provisions a single OCI Load Balancer instance shared with all the Kubernetes services with LoadBalancer type in the YAML configuration.
The statement that accurately describes the Oracle Cloud Infrastructure (OCI) Load Balancer integration with OCI Container Engine for Kubernetes (OKE) is: "OKE service provisions an OCI Load Balancer instance for each Kubernetes service with LoadBalancer type in the YAML configuration." When you define a Kubernetes service in your YAML configuration with the LoadBalancer type, the OKE service automatically provisions an OCI Load Balancer instance specifically for that service. This Load Balancer instance is dedicated to the Kubernetes service and provides traffic balancing functionality. Each Kubernetes service that requires load balancing will have its own OCI Load Balancer instance provisioned by OKE.
NEW QUESTION # 25
Your organization has deployed their e-commerce application on Oracle Container Engine for Kubernetes (OKE) and they are using the Oracle Cloud Infrastructure Registry (OCIR) service as their Docker image repository. They have deployed the OKE cluster using the 'custom create' option, and their Virtual Cloud Network (VCN) has three public subnets with associated Route Tables, Security Lists, and Internet Gateway. However, their application containers are failing to deploy. On investigation, they discover that the images are not being pulled from the designated OCIR repository, even though the YAML configuration has the correct path to the images. What is a valid concern here that needs to be further investigated?
  • A. OKE cluster needs to have a secret with the credentials of their OCIR repository and use that secret in the Kubernetes deployment manifest.
  • B. Security List rule for TCP port 22 needs to be added to connect to the OCIR service.
  • C. VCN hosting the OKE cluster worker nodes needs to have a NAT gateway to access OCIR repositories.
  • D. Identity and Access Management (IAM) credentials need to be added for each user that deploys applications to the OKE cluster.
A valid concern that needs to be further investigated in this scenario is whether the OKE cluster has a secret with the credentials of the Oracle Cloud Infrastructure Registry (OCIR) repository and if that secret is being used in the Kubernetes deployment manifest. Here's why this concern is relevant: Access to the OCIR repository: In order for the OKE cluster to pull images from the OCIR repository, it needs proper authentication credentials. These credentials are typically provided in the form of a secret, which contains the necessary information to authenticate with the registry. Secret in the deployment manifest: The Kubernetes deployment manifest defines how the application containers should be deployed. It includes specifications such as the container image, resource requirements, and environment variables. To pull images from a private repository like OCIR, the deployment manifest needs to reference the appropriate secret that contains the registry credentials. If the images are not being pulled from the designated OCIR repository, it suggests that either the secret with the OCIR credentials is missing or it is not properly referenced in the deployment manifest. Further investigation should focus on verifying the presence and correctness of the secret, as well as confirming that it is correctly referenced in the deployment manifest for the application containers. By ensuring the presence of the secret and proper configuration in the deployment manifest, the OKE cluster will have the necessary credentials to access the OCIR repository and successfully deploy the application containers.
NEW QUESTION # 26
Which TWO are required to access the Oracle Cloud Infrastructure (OCI) Container Engine for Kubernetes (OKE) cluster from the kubectl CLI? (Choose two.)
  • A. OCI Identity and Access Management (IAM) Auth Token.
  • B. An SSH key pair with the public key added to the cluster worker nodes.
  • C. Install and configure the OCI CLI.
  • D. A configured OCI API signing key pair.
  • E. Tiller enabled on the OKE cluster.
The correct options are: A configured OCI API signing key pair: The API signing key pair is used for authentication and authorization to access OCI resources, including the OKE cluster. The private key should be configured on your local machine to authenticate API requests. An SSH key pair with the public key added to the cluster worker nodes: This is required for secure SSH access to the worker nodes in the OKE cluster. You need to generate an SSH key pair and add the public key to the cluster's worker node pool during cluster creation or update. Therefore, the correct options are having a configured OCI API signing key pair and an SSH key pair with the public key added to the cluster worker nodes.
NEW QUESTION # 27
You developed a microservices-based application that runs in an Oracle Cloud Infrastructure (OCI) Container Engine for Kubernetes (OKE) cluster. It has multiple endpoints that need to be exposed to the public internet. What is the most cost-effective way to expose multiple application endpoints without adding unnecessary complexity to the application?
  • A. Use a ClusterIP service type in Kubernetes for each of your service endpoints using a load balancer to expose the endpoints.
  • B. Use a NodePort service type in Kubernetes for each of your service endpoints using the node's public IP address to access the applications.
  • C. Create a separate load balancer instance for each service using the lowest 100 Mbps option.
  • D. Deploy an Ingress Controller and use it to expose each endpoint with its own routing endpoint.
An Ingress Controller is a Kubernetes resource that provides advanced routing and load balancing for your applications running on a Kubernetes cluster1. An Ingress Controller allows you to define rules that specify how to route traffic to different services in your cluster based on the host name or path of the incoming request1. By deploying an Ingress Controller and using it to expose multiple application endpoints, you can achieve the following benefits1:
Cost-effectiveness: You only need to create one load balancer instance per cluster, instead of one per service, which reduces the cost of exposing your applications.
Simplicity: You only need to manage one set of routing rules for all your services, instead of configuring each service separately, which simplifies the application deployment and maintenance.
Flexibility: You can use different types of Ingress Controllers, such as NGINX or Traefik, that offer various features and customization options for your routing needs.
NEW QUESTION # 28
In today's society, everyone wants to find a good job and gain a higher social status. As we all know, the internationally recognized 1Z0-1084-25 certification means that you have a good grasp of knowledge of certain areas and it can demonstrate your ability. This is a fair principle. But obtaining this 1Z0-1084-25 certificate is not an easy task, especially for those who are busy every day. We do not charge extra service fees, but the service quality is high. Your satisfaction is the greatest affirmation for us and we sincerely serve you. Our 1Z0-1084-25 Exam Guide deliver the most important information in a simple, easy-to-understand language that you can learn efficiently learn with high quality. Whether you are a student or an in-service person, our 1Z0-1084-25 exam torrent can adapt to your needs.
1Z0-1084-25 Latest Exam Online: https://www.freedumps.top/1Z0-1084-25-real-exam.html
P.S. Free & New 1Z0-1084-25 dumps are available on Google Drive shared by FreeDumps: https://drive.google.com/open?id=1ZAuH3-3NHNyt3X-JKB_VhC1Y5D6Pk703
Posted at 1/31/2026 04:56:28        Only Author  2#
I’m in total awe of your article, thank you for letting us read it! Get free H19-410_V1.0 examcollection vce to improve your IT knowledge. Wishing you all the best!
Posted at 2/3/2026 20:30:09        Only Author  3#
Your article is truly outstanding, thank you for sharing it with us! Valid exam CPOA simulator fee test papers shared for free—get them now to boost your career!
