Hardware
Mule-Dev-202ԇ} & Mule-Dev-202}YӍ
Posted at 1/15/2026 12:18:32
View159
Replies2
⣬@ЩTestpdf Mule-Dev-202ԇ}IJփݬFMģhttps://drive.google.com/open?id=12lsjLH8hA5S1PZ8J_WiakNQiGcmoLSxe
TestpdfһԳɾͺܶITʿĉľWվTestpdfܞ酢ITPJCԇĿṩҪYρͨ^ԇ߀ڞͨ^Salesforce Mule-Dev-202JCԇ^ُISalesforce Mule-Dev-202JCԇPńoTestpdfԞṩ@TestpdfṩӖYϿЧ؎ͨ^JCԇTestpdfṩľ}}һӵġTestpdfṩľ_Salesforce Mule-Dev-202JCԇľ}ʹ𰸣Ը߷ͨ^Salesforce Mule-Dev-202JCԇ
TestpdfһSalesforceИIӢMɵĈFꠡSalesforceИIкܸߵęÌI֪Rͽ؞ʂ䅢Mule-Dev-202PJCԇṩӖϡTestpdfṩĿԇ}ʹ𰸜ʴ_ʺܸߣ100%CMule-Dev-202ԇһԳɹ߀Mṩһĸ·ա
Mule-Dev-202}YӍ & Mule-Dev-202}YӍ@ Salesforce Salesforce JC춿кܶ̎ڿҹԣһ Salesforce Mule-Dev-202 JC㱶AIΠõĹCҪͨ^JCW^ҪעⷽҪҪPĹWpһctԒҪĄڄӡSalesforce Mule-Dev-202 CȫITI Salesforce C֮һSITIx˲Ř˜ʵıl
µ Salesforce MuleSoft Mule-Dev-202 Mԇ} (Q10-Q15):} #10
Northern Trail Outfitters wants to create an automation which runs on a fixed schedule to enter sales data into NetSuite running as a process in the background. The business product owner chose MuleSoft Composer as the tool for this task.
The Salesforce admin wants to advise the product owner about how the MuleSoft Composer scheduling functionality works.
Which two options are available for use as the time mechanism within MuleSoft Composer? (Choose two.)
- A. Every 30 days
- B. Every 5 minutes
- C. Schedule based on a formula
- D. Every 30 minutes
𰸣B,D
}f
MuleSoft Composer provides scheduling functionality that allows you to set up automated flows to run at specified intervals. The available options for scheduling within MuleSoft Composer include:
Every 30 minutes:
This option allows you to set up a flow to run every half hour, ensuring that your automation process is executed at regular intervals throughout the day.
Every 5 minutes:
This option enables the flow to run at a higher frequency, executing the automation process every 5 minutes, which is useful for scenarios that require more frequent updates or processing.
These scheduling options ensure that you can automate tasks at the desired frequency without manual intervention.
MuleSoft Composer Documentation
} #11
An AnyAirlines employee determines that an RPA process is a strong candidate for automation. When approving the process, the employee needs to specify a group of potential users to manage the RPA process throughout its lifecycle.
According to best practices, which group should the employee choose?
- A. Center for Enablement
- B. Scrum team
- C. Multiple project managers
- D. Center of Excellence
𰸣D
}f
When approving an RPA process and specifying a group of potential users to manage it throughout its lifecycle, the best practice is to choose the Center of Excellence (CoE):
The CoE is a team of experts who are responsible for overseeing the implementation, governance, and management of RPA processes within the organization.
They ensure that best practices are followed, provide guidance and support to project teams, and manage the overall RPA strategy and roadmap.
Lifecycle Management:
The CoE is well-equipped to manage the RPA process from initial development through deployment and ongoing maintenance. They have the expertise to handle any issues that arise and ensure the process remains efficient and effective.
Best Practices:
By involving the CoE, the organization ensures that the RPA process adheres to established best practices, maintains high quality, and delivers the expected benefits.
MuleSoft RPA Documentation
RPA Center of Excellence Best Practices
} #12
Northern Trail Outfitters is building a hyperautomation solution using Salesforce and MuleSoft. They need to use Salesforce Flow to automate a multi-departmental process in an external system and capture the outcome in Salesforce.
How should the Salesforce Flow solution be structured to meet this requirement?
- A. Parent and subflows invoked by REST API to capture user inputs and update Salesforce records
- B. An autolaunched flow invoked by REST API to update Salesforce after the process is completed
- C. A Flow Orchestration to automate the multi-departmental process and update Salesforce records
- D. An evaluation flow which evaluates when the process is completed and updates Salesforce records
𰸣C
}f
Salesforce Flow Orchestration is designed to manage complex, multi-step business processes that span multiple departments and systems. Here's how it can be structured to meet the requirement:
Automate Multi-Departmental Process:
Use Flow Orchestration to define and manage the steps involved in the multi-departmental process. It allows you to break down the process into stages and define the sequence of actions and approvals required.
Capture Outcome in Salesforce:
After completing the external process, Flow Orchestration can be configured to update Salesforce records with the outcome. This ensures that the results of the automated process are reflected within Salesforce.
Orchestration Capabilities:
Salesforce Flow Orchestration provides features such as task assignments, decision elements, and complex branching logic, which are ideal for managing multi-departmental workflows.
Salesforce Flow Orchestration Documentation
} #13
Which MuleSoft deployment strategy consists of the control plane and runtime plan hosted by the client?
- A. Runtime Fabric
- B. CloudHub
- C. Hybrid
- D. IPrivate Cloud Edition
𰸣C
}f
A hybrid deployment strategy in MuleSoft involves hosting the control plane (Anypoint Platform management and design tools) in the cloud, while the runtime plane (where Mule applications run) is hosted by the client, either on-premises or in their own private cloud:
Hybrid Deployment:
The control plane is managed by MuleSoft and provides centralized management, monitoring, and deployment capabilities.
The runtime plane is hosted by the client, providing flexibility and control over where and how the Mule applications are executed, whether on-premises or in a private cloud environment.
Benefits:
This approach combines the advantages of cloud-based management with the control and customization available in on-premises or private cloud deployments, making it suitable for organizations with specific hosting and compliance requirements.
MuleSoft Hybrid Deployment Documentation
} #14
The MuleSoft team at Northern Trail Outfitters wants to create a project skeleton that developers can use as a starting point when creating API implementations with Anypoint Studio. This will help drive consistent use of best practices within the team.
Which type of Anypoint Exchange artifact should be added to Exchange to publish the project skeleton?
- A. RAML trail definitions to be reused across API implementations
- B. A custom asset with the default API implementation
- C. An example of an API implementation following best practices
- D. A MuleSoft application template with key components
𰸣D
}f
To create a project skeleton that developers can use as a starting point for API implementations with Anypoint Studio, the best approach is to use a MuleSoft application template:
MuleSoft Application Template:
A MuleSoft application template includes key components and configurations that follow best practices. It provides a consistent starting point for new projects, ensuring that all developers adhere to the same standards.
Benefits:
Using a template helps enforce best practices, reduces the setup time for new projects, and ensures consistency across different implementations.
Publishing to Anypoint Exchange:
Once the template is created, it can be published to Anypoint Exchange where it is accessible to the entire development team. Developers can then use this template to kickstart their API projects, ensuring a uniform approach across the organization.
Anypoint Exchange Templates Documentation
} #15
TestpdfĮaƷُ܇ɣ㌢100%ȥӿԇһͨ^Salesforce Mule-Dev-202 JCԇ㌢xġ
Mule-Dev-202}YӍ: https://www.testpdf.net/Mule-Dev-202.html
Testpdf Mule-Dev-202}YӍDZྀӖWվ֮һҵҪTestpdf酢Mule-Dev-202ԇĿTаlһNЧʵČWSalesforce Mule-Dev-202ԇ} ŗˣDZِͬrҲͽYˣ@ӿԹsĕrgͽXĿx@ӵķʽ@Mule-Dev-202JCʡ˺ܶĕrgŬ쾚 Mule-Dev-202 }еăݣЧČWɱԼԇɱ ͨ^ԇTestpdfÿҪͨ^SalesforceMule-Dev-202ԇJCĿṩһ_ԽĽQ҂ṩSalesforceMule-Dev-202ԇԔĆ}𰸣 ҂F꠵ITнYģ҂Ŀԇyԇ}𰸎挍ÿԇһӣ@ӵĴ_˲𣬸Ҫ҂TestpdfWվȫȈ@헿ԇӖͨ^ԓnMule-Dev-202 Salesforce Certified MuleSoft Hyperautomation DeveloperN߹ܡ
Ҽأ~`Ȼo⣬^̫sǶμΨҼҼλ쾳H̫ƹμңTestpdfDZྀӖWվ֮һҵҪTestpdf酢Mule-Dev-202ԇĿTаlһNЧʵČW
µSalesforce Mule-Dev-202JCԇ}ŗˣDZِͬrҲͽYˣ@ӿԹsĕrgͽXĿx@ӵķʽ@Mule-Dev-202JCʡ˺ܶĕrgŬ쾚 Mule-Dev-202 }еăݣЧČWɱԼԇɱ ͨ^ԇ
- µMule-Dev-202JCԇ} 🦛 ⇛ [url]www.newdumpspdf.com ⇚➤ Mule-Dev-202 ⮘pȡMdMule-Dev-202yԇ}[/url]
- Mule-Dev-202C 🎵 Mule-Dev-202}YԴ 🤩 Mule-Dev-202} 🐡 _➠ [url]www.newdumpspdf.com 🠰ݔ⇛ Mule-Dev-202 ⇚K@ȡMdMule-Dev-202ھ}[/url]
- Mule-Dev-202ԇ}죺Salesforce Certified MuleSoft Hyperautomation DeveloperԇɿJCSalesforce Mule-Dev-202}YӍ 💈 ^➤ [url]www.vcesoft.com ⮘p@ȡ✔ Mule-Dev-202 ️✔️MdMule-Dev-202}[/url]
- Mule-Dev-202ԇ}YԇеIȲϹ̣Mule-Dev-202}YӍ 🤷 ԾWվ➠ [url]www.newdumpspdf.com 🠰_K Mule-Dev-202 MdMule-Dev-202Y[/url]
- Mule-Dev-202yԇ 🚲 Mule-Dev-202Y 🩺 Mule-Dev-202T} 🤐 _▛ [url]www.kaoguti.com ▟ݔ✔ Mule-Dev-202 ️✔️K@ȡMdMule-Dev-202d[/url]
- Mule-Dev-202} 🐧 Mule-Dev-202JC ⏩ Mule-Dev-202}YӍ 🤽 ^⇛ [url]www.newdumpspdf.com ⇚p@ȡ☀ Mule-Dev-202 ️☀️MdMule-Dev-202}[/url]
- õMule-Dev-202JCԇYυR 🏫 _⮆ [url]www.newdumpspdf.com ⮄ь➽ Mule-Dev-202 🢪MdԇYMule-Dev-202}YԴ[/url]
- [url=https://bergenudd.net/?s=%e9%81%b8%e6%93%87%e6%88%91%e5%80%91%e6%9c%89%e6%95%88%e7%9a%84Mule-Dev-202%e8%80%83%e8%a9%a6%e9%a1%8c%e5%ba%ab:%20Salesforce%20Certified%20MuleSoft%20Hyperautomation%20Developer%ef%bc%8cSalesforce%20Mule-Dev-202%e7%95%b6%e7%84%b6%e5%be%88%e7%b0%a1%e5%96%ae%e9%80%9a%e9%81%8e%20%f0%9f%91%ad%20%e5%9c%a8%e2%9e%a5%20www.newdumpspdf.com%20%f0%9f%a1%84%e4%b8%8a%e6%90%9c%e7%b4%a2[%20Mule-Dev-202%20]%e4%b8%a6%e7%8d%b2%e5%8f%96%e5%85%8d%e8%b2%bb%e4%b8%8b%e8%bc%89%e6%9c%80%e6%96%b0Mule-Dev-202%e8%80%83%e9%a1%8c]x҂ЧMule-Dev-202ԇ}: Salesforce Certified MuleSoft Hyperautomation DeveloperSalesforce Mule-Dev-202Ȼܺͨ^ 👭 ➥ www.newdumpspdf.com 🡄[ Mule-Dev-202 ]K@ȡMdMule-Dev-202}[/url]
- xMule-Dev-202ԇ}ζѽͨ^Salesforce Certified MuleSoft Hyperautomation Developerһ 🗼 ➠ [url]www.newdumpspdf.com 🠰Wվ⏩ Mule-Dev-202 ⏪KMdMule-Dev-202}[/url]
- Mule-Dev-202yԇ} 🥌 Mule-Dev-202yԇ 🌼 Mule-Dev-202} 👵 [url]www.newdumpspdf.com ➥ Mule-Dev-202 🡄p@ȡMdMule-Dev-202}YӍ[/url]
- Mule-Dev-202ԇ}죺Salesforce Certified MuleSoft Hyperautomation DeveloperԇɿJCSalesforce Mule-Dev-202}YӍ 😑 ▷ tw.fast2test.com ◁⏩ Mule-Dev-202 ⏪pȡMdMule-Dev-202}
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, cursos.confrariadotiro.com.br, www.stes.tyc.edu.tw, dorahacks.io, confengine.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, genai-training.com, Disposable vapes
혱һ£ԏ녴惦dTestpdf Mule-Dev-202ԇ}棺https://drive.google.com/open?id=12lsjLH8hA5S1PZ8J_WiakNQiGcmoLSxe
