Linux
install wireguard on ubuntu minimal fails
Posted at 9/21/2022 17:07:13
View3152
Replies4
When I try to install wireguard as follows I get an error:
- root@firefly:~# apt-get install wireguard
- Reading package lists... Done
- Building dependency tree
- Reading state information... Done
- The following additional packages will be installed:
- wireguard-dkms wireguard-tools
- Suggested packages:
- openresolv | resolvconf
- The following NEW packages will be installed:
- wireguard wireguard-dkms wireguard-tools
- 0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
- Need to get 0 B/344 kB of archives.
- After this operation, 2093 kB of additional disk space will be used.
- Do you want to continue? [Y/n] y
- Selecting previously unselected package wireguard-dkms.
- (Reading database ... 101021 files and directories currently installed.)
- Preparing to unpack .../wireguard-dkms_1.0.20201112-1~20.04.1_all.deb ...
- Unpacking wireguard-dkms (1.0.20201112-1~20.04.1) ...
- Selecting previously unselected package wireguard-tools.
- Preparing to unpack .../wireguard-tools_1.0.20200513-1~20.04.2_arm64.deb ...
- Unpacking wireguard-tools (1.0.20200513-1~20.04.2) ...
- Selecting previously unselected package wireguard.
- Preparing to unpack .../wireguard_1.0.20200513-1~20.04.2_all.deb ...
- Unpacking wireguard (1.0.20200513-1~20.04.2) ...
- Setting up wireguard-dkms (1.0.20201112-1~20.04.1) ...
- Loading new wireguard-1.0.20201112 DKMS files...
- Building for 5.10.66
- Building initial module for 5.10.66
- Error! The /var/lib/dkms/wireguard/1.0.20201112/5.10.66/aarch64/dkms.conf for module wireguard includes a BUILD_EXCLUSIVE directive which
- does not match this kernel/arch. This indicates that it should not be built.
- Skipped.
- Setting up wireguard-tools (1.0.20200513-1~20.04.2) ...
- wg-quick.target is a disabled or a static unit, not starting it.
- Setting up wireguard (1.0.20200513-1~20.04.2) ...
Copy the code
How can I solve the problem? |
