[General] Pass Guaranteed Cisco - The Best Associate 350-701 Level Exam
85
【General】 Pass Guaranteed Cisco - The Best Associate 350-701 Level Exam
Posted at 1/15/2026 13:40:31      View:142 | Replies:3        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Prep4King 350-701 dumps from Cloud Storage: https://drive.google.com/open?id=1y_tY-bbcXNrKd-WmOIwJ-yUA-nJ0-rYs
I believe that a lot of people working in the IT industry hope to pass some IT certification exams to obtain the corresponding certifications. Some IT authentication certificates can help you promote to a higher job position in this fiercely competitive IT industry. Now the very popular Cisco 350-701 authentication certificate is one of them. Although passing the Cisco certification 350-701 exam is not so easy, there are still many ways to help you successfully pass the exam. While you can choose to spend a lot of time and energy to review the related IT knowledge, and also you can choose a effective training course. Prep4King can provide the pertinent simulation test,which is very effective to help you pass the exam and can save your precious time and energy to achieve your dream. Prep4King will be your best choice.
Understanding functional and technical aspects of Implementing and Operating Cisco Security Core Technologies (SCOR 350-701) Secure Network Access, Visibility, and EnforcementThe following will be discussed in CISCO 350-701 Exam Dumps:
  • Describe the benefits of device compliance and application control
  • Describe the benefits of network telemetry
  • Configure and verify network access device functionality such as 802.1X, MAB, WebAuth
  • Describe network access with CoA
Cisco 350-701 Reliable Source, 350-701 Dump CollectionUsing free Cisco 350-701 dumps is a great way to prepare for the exam. Implementing and Operating Cisco Security Core Technologies 350-701 dumps are updated regularly and contain an excellent course of action material. Cisco experts carefully design the dumps to help you pass the exam. If you want to be successful in your exam, you need to have a good understanding of the Implementing and Operating Cisco Security Core Technologies 350-701 Certification.
Cisco Implementing and Operating Cisco Security Core Technologies Sample Questions (Q274-Q279):NEW QUESTION # 274
Which two actions does the Cisco Identity Services Engine posture module provide that ensures endpoint security? (Choose two.)
  • A. Patch management remediation is performed.
  • B. The latest antivirus updates are applied before access is allowed.
  • C. Assignments to endpoint groups are made dynamically, based on endpoint attributes.
  • D. Endpoint supplicant configuration is deployed.
  • E. A centralized management solution is deployed.
NEW QUESTION # 275
A network engineer has been tasked with adding a new medical device to the network. Cisco ISE is being used as the NAC server, and the new device does not have a supplicant available. What must be done in order to securely connect this device to the network?
  • A. Use MAB with profiling
  • B. Use 802.1X with posture assessment.
  • C. Use MAB with posture assessment.
  • D. Use 802.1X with profiling.
As the new device does not have a supplicant, we cannot use 802.1X.
MAC Authentication Bypass (MAB) is a fallback option for devices that don't support 802.1x. It is virtually always used in deployments in some way shape or form. MAB works by having the authenticator take the connecting device's MAC address and send it to the authentication server as its username and password. The authentication server will check its policies and send back an Access-Accept or Access-Reject just like it would with 802.1x.
Cisco ISE Profiling Services provides dynamic detection and classification of endpoints connected to the network. Using MAC addresses as the unique identifier, ISE collects various attributes for each network endpoint to build an internal endpoint database. The classification process matches the collected attributes to prebuilt or user-defined conditions, which are then correlated to an extensive library of profiles. These profiles include a wide range of device types, including mobile clients (iPads, Android tablets, Chromebooks, and so on), desktop operating systems (for example, Windows, Mac OS X, Linux, and others), and numerous non- user systems such as printers, phones, cameras, and game consoles.
Once classified, endpoints can be authorized to the network and granted access based on their profile. For example, endpoints that match the IP phone profile can be placed into a voice VLAN using MAC Authentication Bypass (MAB) as the authentication method. Another example is to provide differentiated network access to users based on the device used. For example, employees can get full access when accessing the network from their corporate workstation but be granted limited network access when accessing the network from their personal iPhone.
Reference: https://community.cisco.com/t5/s ... -guide/ta-p/3739456
NEW QUESTION # 276
Which Cisco DNA Center Intent API action is used to retrieve the number of devices known to a DNA Center?
  • A. GET https://fqdnOrlPofDnaCenterPlatform/dna/intent/api/v1/networkdevice?
    parameter1=value&parameter2=value&....
  • B. GET https://fqdnOrlPofDnaCenterPlatform/dna/intent/api/v 1/networkdevice/startIndex
    /recordsToReturn
  • C. GET https://fqdnOrlPofDnaCenterPlatform/dna/intent/api/v1/network-device/count
  • D. GET https://fqdnOrlPofDnaCenterPlatform/dna/intent/api/v1/network-device
NEW QUESTION # 277
A network administrator needs to find out what assets currently exist on the network. Third-party systems need to be able to feed host data into Cisco Firepower. What must be configured to accomplish this?
  • A. a Network Analysis policy to receive NetFlow data from the host
  • B. a File Analysis policy to send file data into Cisco Firepower
  • C. a Threat Intelligence policy to download the data from the host
  • D. a Network Discovery policy to receive data from the host
You can configure discovery rules to tailor the discovery of host and application data to your needs.
The Firepower System can use data from NetFlow exporters to generate connection and discovery events, and to add host and application data to the network map.
A network analysis policy governs how traffic is decoded and preprocessed so it can be further evaluated, especially for anomalous traffic that might signal an intrusion attempt
NEW QUESTION # 278
An administrator enables Cisco Threat Intelligence Director on a Cisco FMC. Which process uses STIX and allows uploads and downloads of block lists?
  • A. consumption
  • B. sharing
  • C. editing
  • D. authoring
NEW QUESTION # 279
n modern society, whether to obtain 350-701 certification has become a standard to test the level of personal knowledge. Many well-known companies require the 350-701 certification at the time of recruitment. Whether you're a student or a white-collar worker, you're probably trying to get the certification in order to get more job opportunities or wages. If you are one of them, our 350-701 Exam Guide will effectively give you a leg up.
350-701 Reliable Source: https://www.prep4king.com/350-701-exam-prep-material.html
2026 Latest Prep4King 350-701 PDF Dumps and 350-701 Exam Engine Free Share: https://drive.google.com/open?id=1y_tY-bbcXNrKd-WmOIwJ-yUA-nJ0-rYs
Posted at 1/17/2026 20:10:59        Only Author  2#
Die Schulungsunterlagen zur Google Professional-Cloud-Security-Engineer Zertifizierungsprüfung von ZertPruefung werden die größte Erfolgsquote erzielen. Naben den Büchern sind heutztage das Internet als ein Wissensschatz angesehen. In ZertPruefung können Sie Ihren Wissensschatz finden. Das ist eine Website, die Ihnen sehr helfen können. Sie werden sicher komplizierte Übungen treffen, Unser ZertPruefung wird Ihnen helfen, die Prüfung ganz einfach zu bestehen, weil es alle erforderlichen Kenntnisse zur Google Professional-Cloud-Security-Engineer Zertifizierungsprüfung enthält.
Posted at 2/16/2026 04:28:48        Only Author  3#
What an impressive article, thank you for sharing your wisdom! HPE7-A01 new braindumps free provides a variety of useful content, freely offered to support your learning.
Posted at 2/19/2026 11:43:33        Only Author  4#
Great stuff, I’m liking this without question. Here’s the C-S4FCF-2023 valid test forum test that helped me secure my promotion and salary raise. It’s free today for all. Good luck in your career growth!
