[General] Reliable EAEP2201 Test Vce & EAEP2201 Valid Exam Answers
87
【General】 Reliable EAEP2201 Test Vce & EAEP2201 Valid Exam Answers
Posted at 1/15/2026 18:29:54      View:118 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Exams-boost EAEP2201 dumps for free: https://drive.google.com/open?id=1a6Kd7e8XwCwW2G4-k57HNC5E5_ERsOod
To address the problems of EAEP2201 exam candidates who are busy, Exams-boost has made the EAEP2201 dumps PDF format of real Enterprise Administration Professional 2201 (EAEP2201) exam questions. This format's feature to run on all smart devices saves your time. Because of this, the portability of EAEP2201 dumps PDF aids in your preparation regardless of place and time restrictions. The second advantageous feature of the EAEP2201 Questions Pdf document is the ability to print Enterprise Administration Professional 2201 (EAEP2201) exam dumps to avoid eye strain due to the usage of smart devices.
We hope this article has given you a good overview of the Esri EAEP2201 Exam and what you can expect from it. As always, we recommend you start preparing for your exam as early as possible to give yourself the best chance of success. Exams-boost offers a wide range of study materials and resources to help you prepare, including practice questions, dumps, and a study guide.
Pass Guaranteed 2026 Esri EAEP2201 Marvelous Reliable Test VceThree versions of EAEP2201 test materials are available. You can choose the one you prefer to have a practice. EAEP2201 PDF version is printable, and if you prefer to practice on paper, this version will be your best choice. You can print them into hard one, and take them with you. EAEP2201 Soft test engine can stimulate the real exam environment, and this version will help you to relieve your nerves. EAEP2201 Online test engine supports all web browsers, with this version you can have a brief review of what you have finished last time.
Esri EAEP2201 (Enterprise Administration Professional 2201) Exam is a certification exam offered by Esri, a leading provider of geographic information system (GIS) software and solutions. EAEP2201 exam is designed for professionals who work with or manage enterprise-level GIS implementations and are responsible for administering and maintaining these systems. It is intended to test the candidate's knowledge and skills in various aspects of enterprise GIS administration, including installation and configuration, database management, security, and performance tuning.
Esri Enterprise Administration Professional 2201 Sample Questions (Q45-Q50):NEW QUESTION # 45
An ArcGIS analyst is curating a series of basemaps for field crews editing utility infrastructure in the field.
The analyst must ensure optimal performance.
Which type of service should be published?
  • A. Vector tile service
  • B. Dynamic map service
  • C. Cached map service
For field operations,Vector Tile Servicesare highly efficient and suitable for basemaps. They offer fast rendering, smaller file sizes, and are easily scalable across various devices, including those with limited bandwidth or processing capabilities. Vector tiles also support dynamic styling and are ideal for offline use, which is often necessary for field crews working in areas with limited connectivity.
Cached map services (Option A) are raster-based and can be larger in size, making them less optimal for mobile use. Dynamic map services (Option C) require real-timedata rendering, which can be resource- intensive and may not perform well in field conditions with limited connectivity.
Reference Source:ArcGIS Enterprise documentation on customizing basemaps
NEW QUESTION # 46
A GIS administrator is analyzing the usage statistics of ArcGIS Enterprise. The administrator needs to pull tabular statistics on various groups and users about the type of content that they produce and consume.
Which action should the administrator perform?
  • A. Open ArcGIS Server statistics to create a report for commonly used items.
  • B. Run usage reports in Portal for ArcGIS to determine the effect on the organization.
  • C. Use ArcGIS Monitor to capture desired information over a period of time in a report.
Portal for ArcGIS provides built-in usage reports that allow administrators to monitor how members are using, sharing, and contributing resources. These reports offer insights into content creation, usage patterns, and group activities. Administrators can generate and export these reports in tabular formats for further analysis.
ArcGIS Server statistics focus on service-level metrics and do not provide detailed user or group content statistics. ArcGIS Monitor captures system performance metrics but is not designed for detailed content usage analysis by users or groups.
Reference Source:ArcGIS Enterprise documentation on usage reports in Portal for ArcGIS.
NEW QUESTION # 47
A GIS administrator must determine which type of service to use when publishing a new basemap for the organization. The basemap must meet several requirements:
* Support offline workflows
* Use as little storage space as possible
* High-resolution display
* Easily incorporate data updates periodically made to a feature service Which service type should be used?
  • A. Dynamic map service
  • B. Vector tile service
NEW QUESTION # 48
An ArcGIS Enterprise administrator wants to publish their feature classes as layers in bulk from a registered geodatabase.
  • A. Register as a hosted layer in ArcGIS Data Store
  • B. Create a data store item in the ArcGIS Enterprise portal
  • C. Import an SDE connection file into ArcGIS Server Administrator Directory
  • D. Register the geodatabase in ArcGIS Server Manager
To publish feature classes as services in bulk from an enterprise geodatabase, it must first beregistered with the ArcGIS Server site. This registration tells ArcGIS Server where to access the data directly for referenced service publishing. The proper way to do this is throughArcGIS Server Manager.
From ArcGIS Enterprise documentation:
"To publish layers directly from a registered enterprise geodatabase without copying data, you must register the geodatabase with your ArcGIS Server site using ArcGIS Server Manager."
* OptionBis used for hosted services, not referenced publishing.
* OptionCis not the correct interface for registering data sources.
* OptionDinvolves hosting data, which is not applicable for referenced layers from a geodatabase.
Reference:ArcGIS Server -Registering Data Stores for Publishing Referenced Services
NEW QUESTION # 49
An organization configures an ArcGIS Enterprise portal to allow single sign-on using Integrated Windows Authentication (IWA). Configuration includes:
* All accounts in the Active Directory group gisusers are added to the portal
* Existing users can sign in without entering credentialsHowever, new employees assigned to the same gisusers groupcannot log in, create content, or join groups.What is causing this issue for the new employees?
  • A. Their Active Directory accounts have been assigned an incompatible default user type
  • B. The Web Adaptor cache must be cleared
  • C. Their Active Directory accounts have not been added to the portal
  • D. Their Active Directory accounts have not had sufficient time to sync to the portal
ForIWA authentication, Active Directory users arenot automatically addedto the ArcGIS Enterprise portal.
They must either be:
* Manually added as members, or
* Automatically created at first loginif auto-creation is enabled.
Since the new users are assigned to the gisusers group but cannot sign in or create content, it's clear that their accounts have not yet been added to the portal.
"Integrated Windows Authentication (IWA) allows users to sign in with their Windows credentials. However, users must still be members of the portal. You can manually add users or enable automatic account creation during login."
* OptionBis invalid since default user type settings do not prevent login.
* OptionCis incorrect because synchronization is not time-based-it's account-creation dependent.
Reference:ArcGIS Enterprise -Managing Portal Members and Identity Store Integration
NEW QUESTION # 50
You only need 20-30 hours to learn our EAEP2201 test braindumps and then you can attend the exam and you have a very high possibility to pass the exam. For many people whether they are the in-service staff or the students they are busy in their job, family lives and other things. But you buy our EAEP2201 prep torrent you can mainly spend your time energy and time on your job, the learning or family lives and spare little time every day to learn our Enterprise Administration Professional 2201 exam torrent. Our answers and questions are compiled elaborately and easy to be mastered. Because our EAEP2201 Test Braindumps are highly efficient and the passing rate is very high you can pass the exam fluently and easily with little time and energy needed.
EAEP2201 Valid Exam Answers: https://www.exams-boost.com/EAEP2201-valid-materials.html
