[Hardware] NSE7_SSE_AD-25Tȥ`󥰡NSE7_SSE_AD-25ꥢѥ
85
Hardware NSE7_SSE_AD-25Tȥ`󥰡NSE7_SSE_AD-25ꥢѥ
Posted at 1/15/2026 20:18:19      View264 | Replies4        Print      Only Author   [Copy Link] 1#
NSE7_SSE_AD-25ΌgHԇYُ뤷ṩ͘ä줿ǩ`ϡߤϸʤ98100Ǥ뤳ȤʾƤޤϡЈҊĤƱ^ΤyǤơShikenPASS饤ȤζΟҤʥե`ɥХåϡNSE7_SSE_AD-25㏊μǤʤ饤NSE7_SSE_AD-25ԇY}v\g24rgΥީ``ӥˤߤu뤨ƤޤϤ٤ơ˽ΥꥢߤΥ٥`ǤꡢNSE7_SSE_AD-25ԇYԇФdzɹ򅧤ޤ뤳Ȥ^Ƥޤ
һĤԇYǤ϶यΕrgojˤҪޤNSE7_SSE_AD-25JԇYyȸФơयΕrgȡʤФʤʤȤ顢ĩ`ȤShikenPASSNSE7_SSE_AD-25}äۤǤΆ}Ϥʤ˕rg򹝼s뤳ȤǤޤ顣äҪʤΤϡΆ}ϤʤԇY˺ϸ񤹤뤳Ȥ^Ǥޤ顣Ά}äĩ`ϺһĤޤԇYΜʂ򤹤ΤˤΕrgojˤꡢʕrgäƤäxʤȤ򤷤ۤǤǤ顢Ϥ䤯ShikenPASSΥȤФäƤäȶयiߤޤ礦餷󥹤Ӥ餭äڤޤ衣
NSE7_SSE_AD-25ꥢѥ & NSE7_SSE_AD-25ձZԇYNSE7_SSE_AD-25JԇYˤĤƤΤȤǤShikenPASS餷Y|֤äƤơmǤ륽`ˤʤ뤳ȤǤޤǧεh줿TΥե`ɥХåˤäơ˴ͻzͨơҡϤɤΥץ饤`͘ˤä¤ĸƷ|NSE7_SSE_AD-25YϤṩǤ뤫_ڤǤShikenPASS FortinetNSE7_SSE_AD-25ȥ`˥YϤϽ~gʤåץǩ`Ȥ졢Ƥޤ顢FortinetNSE7_SSE_AD-25ԇYΥȥ`˥󥰽UY֤äƤޤFڡJ^ԇY˺ϸ񤷤ΤʤShikenPASS FortinetNSE7_SSE_AD-25ȥ`˥YϤäƤ¤ShikenPASS FortinetNSE7_SSE_AD-25}˥åԥ󥰥`Ȥޤ礦ʤҊޤ顣
Fortinet NSE 7 - FortiSASE 25 Enterprise Administrator J NSE7_SSE_AD-25 ԇY} (Q73-Q78):| # 73
Your FortiSASE customer has a small branch office in which ten users will be using their personal laptops and mobile devices to access the internet. Which deployment should they use to secure their internet access with minimal configuration? (Choose one answer)
  • A. SD-WAN on-ramp to secure internet access
  • B. FortiAP to secure internet access
  • C. FortiClient endpoint agent to secure internet access
  • D. FortiGate as a LAN extension to secure internet access
⣺B
h
For small branch offices (thin edges) where users utilize unmanaged personal devices (BYOD) like laptops and mobile phones, the most efficient way to provide Secure Internet Access (SIA) with minimal configuration is by deploying a FortiAP.
* Thin Edge Integration: FortiSASE includes expanded integrations with the Fortinet WLAN portfolio, allowing FortiAP wireless access points to function as "thin edge" devices. These access points intelligently offload and steer traffic from the branch directly to the nearest FortiSASE Security Point of Presence (PoP).
* No Endpoint Agents Required: Because the devices are personal and unmanaged, installing the FortiClient agent (Option A) is often not feasible or desirable. The FortiAP deployment secures all client devices at the location without requiring any endpoint agents.
* Minimal Configuration & Zero-Touch: This solution is specifically designed for small office locations with limited budgets and no local IT staff. FortiSASE offers cloud-delivered management with zero-touch provisioning for FortiAP. Once the AP is connected, it automatically establishes a secure CAPWAP or IPsec tunnel to FortiSASE, ensuring all connected users are protected by the cloud security stack (Antivirus, Web Filtering, etc.) with almost no manual setup on the end-user side.
* Why other options are less ideal:
* Option C and D: SD-WAN on-ramp and FortiGate LAN extensions typically require a physical FortiGate appliance at the branch. For a small office with only ten users and personal devices, this adds unnecessary hardware costs and configuration complexity compared to a simple, cloud- managed FortiAP.
| # 74
When deploying FortiSASE agent-based clients, which three features are available compared to an agentless solution? (Choose three.)
  • A. Anti-ransomware protection
  • B. Vulnerability scan
  • C. SSL inspection
  • D. ZTNA tags
  • E. Web filter
⣺BCE
h
When deploying FortiSASE agent-based clients, several features are available that are not typically available with an agentless solution. These features enhance the security and management capabilities for endpoints.
* Vulnerability Scan:
* Agent-based clients can perform vulnerability scans on endpoints to identify and remediate security weaknesses.
* This proactive approach helps to ensure that endpoints are secure and compliant with security policies.
* SSL Inspection:
* Agent-based clients can perform SSL inspection to decrypt and inspect encrypted traffic for threats.
* This feature is critical for detecting malicious activities hidden within SSL/TLS encrypted traffic.
* Web Filter:
* Web filtering is a key feature available with agent-based clients, allowing administrators to control and monitor web access.
* This feature helps enforce acceptable use policies and protect users from web-based threats.
FortiOS 7.6 Administration Guide: Explains the features and benefits of deploying agent-based clients.
FortiSASE 23.2 Documentation: Details the differences between agent-based and agentless solutions and the additional features provided by agent-based deployments.
| # 75
In the Secure Private Access (SPA) use case, which two FortiSASE features facilitate access to corporate applications? (Choose two answers)
  • A. zero trust network access (ZTNA)
  • B. SD-WAN
  • C. cloud access security broker (CASB)
  • D. thin edge
⣺AB
h
In a FortiSASE deployment, the Secure Private Access (SPA) use case is specifically designed to provide remote users with secure, high-performance connectivity to internal corporate applications hosted in private data centers or public clouds.5 This is achieved through two primary architectural methods:
* SD-WAN Integration (A): FortiSASE integrates natively with existing Fortinet Secure SD-WAN networks.6 In this architecture, the FortiSASE global PoPs act as spokes that establish automated IPsec tunnels to the organization's FortiGate SD-WAN hubs. This allows the platform to use intelligent application steering and dynamic routing to find the shortest, most efficient path to private resources, ensuring a superior user experience.
* Zero Trust Network Access (ZTNA) (B): FortiSASE provides Universal ZTNA to enforce granular, per-session access control.7 Unlike traditional VPNs that grant broad network access, ZTNA verifies the user's identity and the endpoint's security posture (via ZTNA tags) before every application session.
This ensures that users only have access to the specific corporate applications they are authorized to use, significantly reducing the attack surface.
* Analysis of Other Options: * Thin Edge (C) is a connectivity method used to secure branch offices and micro-branches (typically using FortiExtender), rather than a specific feature for facilitating private corporate application access for individual remote users.
* CASB (D) is used for Secure SaaS Access (SSA) to provide visibility and control over third- party cloud applications like Office 365, rather than private applications hosted on-premises.
| # 76
A customer wants to ensure secure access for private applications for their users by replacing their VPN.
Which two SASE technologies can you use to accomplish this task? (Choose two.)
  • B. secure web gateway (SWG) and cloud access security broker (CASB)
  • C. SD-WAN on-ramp
  • D. secure SD-WAN
⣺AC
h
ZTNA replaces traditional VPNs by enforcing identity- and posture-based access to private applications. SD-WAN on-ramp integrates with FortiSASE to securely route traffic from branch users to private applications over the SASE fabric, ensuring secure and optimized access.
| # 77
Refer to the exhibits. A FortiSASE administrator has configured FortiSASE as a spoke to a FortiGate hub. The tunnel is up to the FortiGate hub. However, the remote FortiClient is not able to access the web server hosted behind the FortiGate hub.
Based on the exhibits, what is the reason for the access failure?
  • A. The hub is not advertising the required routes.
  • B. The hub firewall policy does not include the FortiClient address range.
  • C. A private access policy has denied the traffic because of failed compliance
  • D. The server subnet BGP route was not received on FortiSASE.
⣺D
h
The FortiSASE BGP learned routes do not include the 10.160.160.0/24 subnet (server network).
Although the FortiGate hub is advertising this route (10.160.160.0/24) to FortiSASE, it is not visible in the FortiSASE BGP route table - indicating a routing issue. Without this route, FortiSASE cannot forward traffic from FortiClient to the server.
| # 78
ʤϾγƤFortinetNSE7_SSE_AD-25JԇYܤrJԇY˺ϸ񤷤ShikenPASSǤϡ˽ϾΤ٤ƤΉҶơ礤rgFortinetNSE7_SSE_AD-25JԇY˺ϸ񤹤ȤȤ^ޤShikenPASSFortinetNSE7_SSE_AD-25ԇYȥ`˥YϤNʽUY֤äƤITTҤоΤǡ}Ƚ𤬾oܤ˽YǤΤǤShikenPASSx֤ʤ顢~ڤޤ
NSE7_SSE_AD-25ꥢѥ: https://www.shikenpass.com/NSE7_SSE_AD-25-shiken.html
Fortinet NSE7_SSE_AD-25Tȥ` यˡԇYǰΤNyΤᤢᡢKĤԼߤCʧޤ˽NSE7_SSE_AD-25ꥢѥ - Fortinet NSE 7 - FortiSASE 25 Enterprise AdministratorԇYʂpdfϡޤޤѧߤȤ|ѥ`о`बޤFortinet NSE7_SSE_AD-25Tȥ` Ϥʤҡξ}ʹäԇY˺ϸ񤷤ʤȫ~^ޤNSE7_SSE_AD-25ԇYYϤ3ĤΥЩ`ݤϤޤäͬǤʤNSE7_SSE_AD-25}ʹä_Ͽڤ򤭤Ƥۤ᤿ޤNSE7_SSE_AD-25ѧ̲Ĥϸߤϸʤȥҥåʤߤ뤿ᡢƥȤˤޤϸ񤷤ʤƤ䤹ҪϤޤ
⤦R⤪ܤˤʤä褦ǤʤŮ`ΤϤ֪äNSE7_SSE_AD-25ձZԇYǣ褯LƤϡ`󥰥ک`Щ`ָvĤٶȤ鷺٤ӤƤ뤳Ȥζޤ
gõĤ-ΤNSE7_SSE_AD-25Tȥ`ԇY-ԇYΜʂ䷽NSE7_SSE_AD-25ꥢѥयˡԇYǰΤNyΤᤢᡢKĤԼߤCʧޤNSE7_SSE_AD-25˽Fortinet NSE 7 - FortiSASE 25 Enterprise AdministratorԇYʂpdfϡޤޤѧߤȤ|ѥ`о`बޤϤʤҡξ}ʹäԇY˺ϸ񤷤ʤȫ~^ޤ
Posted at 1/19/2026 22:45:19        Only Author  2#
]紪֮޹PV֮kA£׌ĵСڲ韵гLˣֱ溣βܵ_ãݏֻһǾʹKaoGuTi SAPC_ARCON_2508ԇӖYϡ@҂ÿλITҸ棬ϣܵ_á
Posted at 1/28/2026 11:16:32        Only Author  3#
Im truly amazed by this article, thank you for sharing it. Enhance your IT expertise by downloading free EMEA-Advanced-Support exam forum. Wishing you all the best!
Posted at 2/9/2026 13:11:12        Only Author  4#
The article is so amazing, Im grateful for your share! Improve your IT skills and grab the free Rev-Con-201 valid test pass4sure. Best of luck with everything!
Posted at 2/13/2026 21:22:59        Only Author  5#
Im grateful for your article, it really left a lasting impression. This is the Test PL-200 dumps free test that helped me secure my promotion and pay raise, now shared with you at no cost. Hope you succeed in your career!
