[General] Certification FCP_FCT_AD-7.4 Test Answers - FCP_FCT_AD-7.4 Reliable Test Topics
96
【General】 Certification FCP_FCT_AD-7.4 Test Answers - FCP_FCT_AD-7.4 Reliable Test Topics
Posted at 1/15/2026 23:05:47      View:112 | Replies:2        Print      Only Author   [Copy Link] 1#
We are impassioned, thoughtful team. So our FCP_FCT_AD-7.4 exam torrents will never put you under great stress but solve your problems with efficiency. Otherwise if you fail to pass the exam unfortunately with our FCP_FCT_AD-7.4 test braindumps, we will return your money fully or switch other versions for you. So by using our FCP_FCT_AD-7.4 exam torrents made by excellent experts, the learning process can be speeded up to one week. They have taken the different situation of customers into consideration and designed practical FCP_FCT_AD-7.4 Test Braindumps for helping customers save time. As elites in this area they are far more proficient than normal practice materials’ editors, you can trust them totally.
While making revisions and modifications to the Fortinet FCP_FCT_AD-7.4 practice exam, our team takes reports from over 90,000 professionals worldwide to make the Fortinet FCP_FCT_AD-7.4 Exam Questions foolproof. To make you capable of preparing for the FCP_FCT_AD-7.4 exam smoothly, we provide actual Fortinet FCP_FCT_AD-7.4 exam dumps.
FCP_FCT_AD-7.4 Reliable Test Topics | Reliable FCP_FCT_AD-7.4 Exam BraindumpsThis way you can save money even if Fortinet FCP_FCT_AD-7.4 introduces fresh Fortinet FCP_FCT_AD-7.4 exam updates. So why are you delaying? Purchase the Fortinet FCP_FCT_AD-7.4 Preparation material to get certified on the first attempt.
Fortinet FCP - FortiClient EMS 7.4 Administrator Sample Questions (Q58-Q63):NEW QUESTION # 58
Based on the settings shown in the exhibit, which two actions must the administrator take to make the endpoint compliant? (Choose two.)
  • A. Run Calculator application on the endpoint.
  • B. Integrate FortiSandbox tor infected file analysis
  • C. Enable the web filter profile.
  • D. Patch applications that have vulnerability rated as high or above.
* Observation of Compliance Profile:
* The compliance profile shown in the exhibit includes rules for vulnerability severity level and running process (Calculator.exe).
* Evaluating Actions for Compliance:
* To make the endpoint compliant, the administrator needs to ensure that the vulnerability severity level is medium or higher is patched (D).
* Additionally, the Calculator.exe application must be running on the endpoint (B).
* Eliminating Incorrect Options:
* Enabling the web filter profile (A) is not related to the compliance rules shown.
* Integrating FortiSandbox (C) is not a requirement in the given compliance profile.
* Conclusion:
* The correct actions are to run the Calculator application on the endpoint (B) and patch applications with vulnerabilities rated as high or above (D).
FortiClient EMS compliance profile configuration documentation from the study guides.
NEW QUESTION # 59
An administrator must deploy FortiClient for an organization that has BYOD and remote users.
What can the administrator use to deploy FortiClient? (Choose one answer)
  • A. Microsoft Intune
  • B. FortiClient zero-touch provisioning
  • C. Microsoft System Center Configuration Manager (SCCM)
  • D. Group Policy Object (GPO)
According to theFortiClient EMS Administrator Study Guideand theFortinet Document Library (7.2/7.4 versions), the most effective method for deploying FortiClient toBYOD (Bring Your Own Device)and remote usersis usingMicrosoft Intune(or other supported Mobile Device Management - MDM solutions).
1. Why Microsoft Intune (Answer C) is the Correct Choice:
* Cloud-Based Accessibility:Unlike GPO or SCCM, which traditionally require a direct connection to the local Active Directory (AD) domain or a VPN to reach the on-premises infrastructure, Microsoft Intune is a cloud-based MDM. This makes it the native choice forremote userswho may not always be on the corporate network.
* BYOD Management:Intune is specifically designed to manage a variety of operating systems (Windows, macOS, iOS, Android) that are common in BYOD environments. It allows administrators to push the FortiClient installation package and enrollment configuration (such as the invitation_code or ems_server details) directly to the user's device via the cloud.
* Integration with EMS:FortiClient EMS 7.2/7.4 provides specific documentation forIntune Integration. Administrators can create a custom MSI or .pkg installer in EMS, upload it to Intune, and use Intune's app configuration policies to automate the Telemetry connection to EMS.
2. Why Other Options are Incorrect for this Scenario:
* A. FortiClient zero-touch provisioning:While FortiClient supports zero-touch provisioning (particularly for mobile or through FortiCloud), in the context of a "deployment tool" for an organization's broad BYOD and remote fleet, it is typically afeatureorprocessfacilitated by an MDM like Intune rather than the standalone deployment mechanism for the initial software package on third- party remote devices.
* B. Microsoft SCCM:SCCM (now part of Microsoft Configuration Manager) is heavily reliant on on- premises infrastructure and is generally used for corporate-owned, domain-joined devices. It is less flexible than Intune for managing "unmanaged" BYOD devices belonging to remote users.
* D. Group Policy Object (GPO):GPO requires the device to be joined to theActive Directory (AD) Domain. BYOD devices are typically not domain-joined, and remote devices cannot receive GPO updates unless they are connected via VPN at the time of the policy refresh, making it unsuitable for this specific use case.
3. Curriculum References:
* EMS Administration Guide (Deployment Section):Specifies that for endpoints not reachable via AD
/Workgroups (which covers remote and BYOD), administrators should use theInstaller Linkmethod or anMDM (like Microsoft Intune).
* Intune Deployment Guide for FortiClientetail the specific use ofConfiguration Keys(e.g., cloud_invite_code, ems_server) that are passed from Intune to the FortiClient app to ensure that once the remote user installs the app, it automatically registers to the correct EMS instance.
NEW QUESTION # 60
An administrator has a requirement to add user authentication to the ZTNA access for remote or off-fabric users Which FortiGate feature is required m addition to ZTNA?
  • A. C. FortiGate explicit proxy
  • B. FortiGate FSSO
  • C. FortiGate endpoint control
  • D. FortiGate certificates
For adding user authentication to the ZTNA access for remote or off-fabric users, the following FortiGate feature is required in addition to ZTNA:
* FortiGate explicit proxyallows FortiGate to intercept web traffic for authentication purposes.
* ZTNA integrates with various FortiGate features to provide secure access and ensure that users are authenticated before accessing resources.
* By using an explicit proxy, FortiGate can handle web traffic and enforce authentication policies for remote users who are not directly on the corporate network (off-fabric).
Thus, the correct feature to use for this requirement is the FortiGate explicit proxy.
References
* FortiGate Security 7.2 Study Guide, ZTNA and Proxy Configuration Sections
* Fortinet Documentation on FortiGate Explicit Proxy and ZTNA Integration
NEW QUESTION # 61
Which statement about the FortiClient enterprise management server is true?
  • A. It receives the CA certificate from FortiGate to validate client certrficates.
  • B. It receives the configuration information of endpoints from ForuGate.
  • C. It enforces compliance on the endpoints using tags
  • D. It provides centralized management of multiple endpoints running FortiClient software.
NEW QUESTION # 62
An administrator has lost web access to the FortiClient EMS console, and the web page to access to the console is timing out.
How can the administrator gather information to investigate the issue? (Choose one answer)
  • A. Download the log generator from the support site and run it on the EMS server.
  • B. Use the diagnostic logs option from the FortiClient EMS GUI.
  • C. Use the CLI diagnostic tool on the EMS server.
  • D. Download the webserver logs from the PostgreSQL server.
According to theFortiClient EMS Administrator Study Guideand officialTechnical Tipsfrom Fortinet, when the web console is inaccessible (e.g., timing out), the administrator must use tools available directly on the server's operating system (CLI) to gather diagnostic information.
1. Why the CLI Diagnostic Tool (Answer A) is the Correct Choice:
* Availability during Outage:When the GUI is unreachable, the standard "Generate Diagnostic Logs" option within the EMS interface is also unavailable.
* Windows-based EMS:The administrator can manually run the EMSDiagnosticTool.exe located at C:
Program Files (x86)FortinetFortiClientEMS. This tool collects server information, Windows events, and EMS-specific logs into a compressed file for investigation.
* Linux-based EMS (v7.4+):For newer versions running on Linux, the administrator can use the CLI command: sudo /opt/forticlientems/bin/diagnostic_tool -o /tmp/diag to generate a diagnostic package.
* Service Verification:The CLI also allows administrators to verify if critical services (like fcems, apache2, or postgres) are running or if remote access has been disabled using the emscli utility.
2. Why Other Options are Incorrect:
* B. Download webserver logs from PostgreSQLostgreSQL is the database engine for EMS, not the web server. While database logs are useful, they are not the primary method for gathering general
"diagnostic information" and would typically be collected as part of the CLI diagnostic tool output rather than downloaded directly from the DB.
* C. Diagnostic logs option from the GUI:This option is impossible to use if the administrator has lost web access and the page is timing out.
* D. Download log generator from support site:While Fortinet provides various tools on their support site, theEMS Diagnostic Toolis natively installed with the FortiClient EMS software and is the primary, documented method for troubleshooting the EMS server itself.
NEW QUESTION # 63
If you doubt the high pass rate of our customers is as 98% to 100% with the help of our FCP_FCT_AD-7.4 exam questions, you can free download the demos to check it out. You have to believe that the quality content and scientific design of FCP_FCT_AD-7.4 learning guide can really do this. You can easily find out that there are many people who have benefited from FCP_FCT_AD-7.4 Actual Exam. In this field, let me tell you our excellent FCP_FCT_AD-7.4 study materials are in the position that can't be ignored.
FCP_FCT_AD-7.4 Reliable Test Topics: https://www.testinsides.top/FCP_FCT_AD-7.4-dumps-review.html
Only 20-30 hours on our FCP_FCT_AD-7.4 learning guide are needed for the client to prepare for the test and it saves our client’s time and energy, Fortinet Certification FCP_FCT_AD-7.4 Test Answers People also benefit a lot from these changes, With FCP_FCT_AD-7.4 study guide, you only need to spend 20 to 30 hours practicing to take the exam, If you want to check the quality and validity of our FCP_FCT_AD-7.4 exam questions, then you can click on the free demos on the website.
Virtualization Infrastructure Requirements FCP_FCT_AD-7.4 and Recommendations, Evaluating Cybersecurity Policies, Only 20-30 hours on our FCP_FCT_AD-7.4 learning guide are needed for the client to prepare for the test and it saves our client’s time and energy.
FCP_FCT_AD-7.4 Actual Test & FCP_FCT_AD-7.4 Exam Quiz & FCP_FCT_AD-7.4 Training MaterialsPeople also benefit a lot from these changes, With FCP_FCT_AD-7.4 study guide, you only need to spend 20 to 30 hours practicing to take the exam, If you want to check the quality and validity of our FCP_FCT_AD-7.4 exam questions, then you can click on the free demos on the website.
Our FCP_FCT_AD-7.4 study tool can help you obtain the FCP_FCT_AD-7.4 certification and own a powerful weapon for your interview.
Posted at 2/14/2026 07:19:04        Only Author  2#
I found the article to be incredibly beneficial to my understanding. Ready to crush the New CNPA test camp exam. Wish me luck!
Posted at 2/20/2026 06:39:14        Only Author  3#
Thank you for this article, it’s left a lasting impression on me. Free L4M3 latest exam simulator free exam questions—best of luck to all exam candidates!
