1z0-1077-25JCY & 1z0-1077-25JC
Posted at 1/15/2026 23:34:07
View212
Replies0
cеľxжhPIģʹQ־ԏtߣֿɼ 㑪ԓ@ӵ˰ɡȻxҪͨ^Oracle1z0-1077-25JCԇȻ͵ñͨ^Fast2test Oracle1z0-1077-25ԇӖYǎͨ^ԇxҲDZF־ԏһNʽFast2testWվṩӖYڻWǪһoƷ|ãҪͨ^Oracle1z0-1077-25ԇJCُIFast2test Oracle1z0-1077-25ԇӖYϡ
ҲSľWվϣҲԛ]tPӖYϡֻҪFast2testĮaƷЩY^͕lF҂ĮaƷwVҲFast2testľWվMdPOracle 1z0-1077-25 JCԇIJֿԇ}ʹ𰸁ԇãzy҂aƷƷ|Fast2test֮܉һoṩȫƷ|Yϵԭ҂ЌIČ҈FꠡԼIT֪RSĽоOracle 1z0-1077-25 JCԇĿ}ƳOracle 1z0-1077-25 JCԇĿԇ}ʹ𰸡Fast2testOracle 1z0-1077-25 JCԇ¿ԇ}ʹ܅Oracle 1z0-1077-25 JCԇĿĚgӭ
1z0-1077-25JC & 1z0-1077-25ԇcFast2testĮaƷɺܶYITS֪RͽᘌITPJCԇоġҪDžOracle 1z0-1077-25 JCԇKx҂Fast2testFast2testHԱCṩһݸwVƷ|ܺõĿԇYρÜʂ挦@dzIĿԇҎͨ^Oracle 1z0-1077-25 JCԇõJCC
µ Order Management Cloud 1z0-1077-25 Mԇ} (Q48-Q53):} #48
You created a pricing strategy, but notice that it is still showing the status as "In progress".
What action will change the status to "Approved"?
- A. The approvers in the approval life cycle need to review and approve the strategy.
- B. You need to save the pricing strategy.
- C. You must first assign your pricing strategy to a pricing segment.
- D. You must first add a discount list to the pricing strategy. After you save it, the pricing strategy will show it has been approved.
- E. You must click the Approve button.
𰸣E
}f
To change the status of a pricing strategy from "In progress" to "Approved", you must click the Approve button on the Edit Pricing Strategy page. The Approve button is only enabled when the pricing strategy is complete and valid. A pricing strategy is complete when it has at least one pricing segment and one pricing rule.A pricing strategy is valid when it has no errors or conflicts1. By clicking the Approve button, you submit the pricing strategy for approval. The approval process depends on the approval life cycle that you have defined for the pricing strategy. The approval life cycle can include one or more approvers, who can approve or reject the pricing strategy.Once the pricing strategy is approved by all the approvers, the status changes to "Approved" and the pricing strategy becomes effective2.
How You Modify Pricing Strategies
How You Approve Pricing Strategies
} #49
Your company wants to revise an existing sales order in Order Management Cloud to compensate the downstream legacy fulfillment system that does not allow any update to the already interfaced fulfillment lines.
What type of compensation pattern rule would you need to de#ne for the orchestration process fulfillment step?
- A. Define two rules: one of type CANCEL and another of type CREATE.
- B. Define one rule of type UPDATE.
- C. Define one rule of type CANCEL_CREATE.
- D. Define one rule of type CREATE.
𰸣A
}f
A rule that you can set on an orchestration process step that specifies the adjustments to make when an order changes.
Undo, Redo, Update, Cancel, and None are each an example of a compensation pattern. For example, assume the compensation pattern for a Create Shipment step is Redo, and that this step calls the Cancel service and the Create service.
If Order Management receives a change order that includes a new warehouse for this step, then it runs the Cancel service and the Create service again.
} #50
Which two activities can you perform by using Global Order Promising's stand-alone work area? (Choose two.)
- A. You can initiate back-to-back orders to expedite fulfillment of lines with a delayed schedule ship date.
- B. You can re-schedule order lines that are already scheduled.
- C. You can split quantities against a Sales Order Line to perform what-if simulations and evaluate better ways of promising an order.
- D. You can simulate the Capable-to-Promise option in place of the Available-to-Promise option for quicker fulfillment.
𰸣B,C
} #51
Your company is in the business of selling kitchen appliances.
Which three entities can you include while defining pricing rules that control how Oracle Pricing Cloud calculates the price for each time? (Choose three.)
- A. Shipping change lists
- B. Cost List
- C. Discount List
- D. Pricing Strategy
- E. Pricing Profile
𰸣A,B,C
} #52
You have scheduled a group of 60 sales order lines on a single order and have received promising results from Global Order Promising. Using the Sales Order Fulfillment View, you perform a Check Availability for all lines after 10 minutes and now get a revised promising result. You want to compare the two results to check which option was closer to your promising results.
Which option is NOT a built-in metric for comparisons?
- A. Substitute item usage
- B. Total fulfillment cost
- C. On-time results (example: number of lines promised on time)
- D. Delay results
- E. Total margin
𰸣E
}f
Oracle Order Management Cloud Order to Cash provides several built-in metrics for comparing promising results, such as substitute item usage, total fulfillment cost, on-time results, and delay results1. However, total margin is not one of them. Total margin is a financial metric that measures the profitability of a sales order, but it is not directly related to the availability or fulfillment of the order.
How Order-to-Cash Works in Order Management
} #53
ˆɹҸV㣬ɹFast2testxFast2testxɹFast2test Oracle1z0-1077-25ԇӖYǎITJCĿͨ^JCģᘌOracle1z0-1077-25ԇJCģ^ӳFast2test Oracle1z0-1077-25ԇӖYڿеõ˺ܴķ푣˺ܺõĿڱfxFast2test Oracle1z0-1077-25ԇӖYϾxɹ
1z0-1077-25JC: https://tw.fast2test.com/1z0-1077-25-premium-file.html
҂1z0-1077-25JC}ĿԇYeOӋһɌIITӢFꠌTゃ1z0-1077-25JC}Yϣᘌe@õijɿԼͻıhoָʾĶ˱hOracle 1z0-1077-25 - Oracle Order Management Cloud Order to Cash 2025Implementation Professional ԇӖYBͬĺ߉}@㲻HW߀tNgͿĿ҂C҂ Oracle 1z0-1077-25 ӖYͨ^`z˵ģ҂Ŀԇ˳ֵĜʂ䣬҂Ć}ȫģrǺģACMT 1z0-1077-25JCԇ{ReͽQҊMac OS XĆ}KʹAppleպ֧ԮaƷЧޏOӲwFast2test Oracle1z0-1077-25ԇӖYnjTITʿӖYϣǞͨ^ԇġ
OS͵MĘСã҂1z0-1077-25JC}ĿԇYeOӋһɌIITӢFꠌTゃ1z0-1077-25JC}Yϣᘌe@õijɿԼͻıhoָʾĶ˱hOracle 1z0-1077-25 - Oracle Order Management Cloud Order to Cash 2025Implementation Professional ԇӖYBͬĺ߉}@㲻HW߀tNgͿĿ҂C҂ Oracle 1z0-1077-25 ӖYͨ^`z˵ģ҂Ŀԇ˳ֵĜʂ䣬҂Ć}ȫģrǺġ
ܚgӭ1z0-1077-25JCYϣMd1z0-1077-25ԇ}õҪOracleCACMT 1z0-1077-25JCԇ{ReͽQҊMac OS XĆ}KʹAppleպ֧ԮaƷЧޏOӲwFast2test Oracle1z0-1077-25ԇӖYnjTITʿӖYϣǞͨ^ԇġ
ֻҪҵµ1z0-1077-25ԇC}죬ͨ^ԇԓ]І}
- Cͨ^1z0-1077-25JCYϣYԇIߺͿdOracle Oracle Order Management Cloud Order to Cash 2025Implementation Professional ⬇ ^▷ [url]www.pdfexamdumps.com ◁p@ȡ{ 1z0-1077-25 }Md1z0-1077-25[/url]
- Ч1z0-1077-25JCYϣµĿԇ}ͨ^1z0-1077-25ԇ 🤱 M루 [url]www.newdumpspdf.com ь⏩ 1z0-1077-25 ⏪Md1z0-1077-25[/url]
- ]1z0-1077-25JCYϣOracle Order Management CloudJC1z0-1077-25ԇ}ṩMd 🔘 Md 1z0-1077-25 ֻ⇛ [url]www.newdumpspdf.com ⇚1z0-1077-25}[/url]
- T1z0-1077-25JCYϣMd1z0-1077-25WYϵõҪOracleC 🍐 ▶ [url]www.newdumpspdf.com ◀ṩM 1z0-1077-25 }ռ1z0-1077-25TC[/url]
- T1z0-1077-25JCYϣMd1z0-1077-25WYϵõҪOracleC 🦈 ▶ tw.fast2test.com ◀ǫ@ȡ 1z0-1077-25 MdѾWվ1z0-1077-25JC}
- 1z0-1077-25TC 🍎 1z0-1077-25WPӛ 📎 1z0-1077-25} 🙍 _☀ [url]www.newdumpspdf.com ️☀️ݔ☀ 1z0-1077-25 ️☀️K@ȡMd1z0-1077-25ָ[/url]
- 1z0-1077-25}d 🕙 1z0-1077-25yԇ 😝 1z0-1077-25 🔜 { [url]www.newdumpspdf.com }WվdM➥ 1z0-1077-25 🡄}ռ1z0-1077-25}YӍ[/url]
- 1z0-1077-25}d 🩳 1z0-1077-25TC 🏝 1z0-1077-25JC} 😤 ⇛ [url]www.newdumpspdf.com ⇚WվdM✔ 1z0-1077-25 ️✔️}ռ1z0-1077-25ԇC[/url]
- 1z0-1077-25}YӍ 🧺 1z0-1077-25ָ 🍺 1z0-1077-25 ⏪ ▷ [url]www.vcesoft.com ◁ь 1z0-1077-25 KMd1z0-1077-25}[/url]
- 1z0-1077-25}YӍ 👰 1z0-1077-25}d 🐣 1z0-1077-25}YԴ 🚌 _➽ [url]www.newdumpspdf.com 🢪K 1z0-1077-25 ԫ@ȡMd1z0-1077-25TC[/url]
- 1z0-1077-25} 💁 1z0-1077-25TC 🏤 1z0-1077-25b 😳 tw.fast2test.com ϵMd 1z0-1077-25 _1z0-1077-25}YӍ
- giphy.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.jamieholroydguitar.com, hhi.instructure.com, courses.sspcphysics.com, www.stes.tyc.edu.tw, Disposable vapes
