[General] Quiz Nokia - 4A0-D01 - Valid Nokia Data Center Fabric Fundamentals Exam Test Sim
【General】 Quiz Nokia - 4A0-D01 - Valid Nokia Data Center Fabric Fundamentals Exam Test Sim
Posted at 1/16/2026 00:45:46      View:158 | Replies:5        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of DumpsQuestion 4A0-D01 dumps for free: https://drive.google.com/open?id=1FvI_aD0WZkLQpiiqzb5_CjKGK7EteODh
Have you signed up for Nokia 4A0-D01 Exam? Will masses of reviewing materials and questions give you a headache? DumpsQuestion can help you to solve this problem. It is absolutely trustworthy website. Only if you choose to use exam dumps DumpsQuestion provides, you can absolutely pass your exam successfully. You spend lots of time on these reviewing materials you don't know whether it is useful to you, rather than experiencing the service DumpsQuestion provides for you. So, hurry to take action.
Nokia 4A0-D01 Exam Syllabus Topics:
  • SR Linux User and System Management: This section of the exam measures skills of a Network Automation Specialist and includes managing user roles, TLS configurations for secure communication, and automation features like Zero-Touch Provisioning (ZTP). It covers ZTP setup, configuration processes, and common issues that may arise during deployment.
  • This section of the exam measures skills of a Network Automation Specialist and introduces the principles of Event Driven Automation in SR Linux environments. It covers integration with Kubernetes and explores core use cases such as intent-based automation for fabrics and services, as well as enhanced network observability.
  • Nokia DC Fabric Solution: This section of the exam measures skills of a Data Center Network Engineer and covers the architecture and benefits of modern Layer 3 data center networks. It includes an overview of BGP-based routing, VXLAN and EVPN overlays for multi-tenant environments, and key features of the SR Linux operating system. The section also explains how APIs are used for external configuration and introduces the Fabric Services System's management capabilities.
  • SR Linux Configuration and Routing: This section of the exam measures skills of a Network Automation Specialist and focuses on configuring and managing SR Linux systems. It examines the YANG-driven CLI, JSON output, environment variables, and static and dynamic routing. Learners also explore BGP, ECMP, IP-VRF, MAC-VRF, and the use of VXLAN with EVPN to implement both Layer 2 and Layer 3 overlays, including symmetric and asymmetric models.
Free PDF Quiz Nokia - 4A0-D01 - Nokia Data Center Fabric Fundamentals Exam Fantastic Test Simulator FreeWe are in a constant state of learning new knowledge, but also a process of constantly forgotten, we always learned then forget, how to solve this problem, the answer is to have a good memory method, our 4A0-D01 study materials will do well on this point. Our 4A0-D01 Study Materials have their own unique learning method, abandon the traditional rote learning, adopt diversified memory patterns, such as the combination of text and graphics memory method, to distinguish between the memory of knowledge.
Nokia Data Center Fabric Fundamentals Exam Sample Questions (Q18-Q23):NEW QUESTION # 18
A static route is configured in two steps in Nokia's SR Linux. Which of the following items CANNOT be configured in the static-routes container?
  • A. blackhole
  • B. Next-hop group
  • C. IPv4 destination prefix
  • D. Preference value
The static-routes container in Nokia SR Linux does not support configuring a blackhole route directly; it is used to configure destination prefixes, preference values, and next-hop groups for static routing.
NEW QUESTION # 19
How does Nokia's Fabric Services System use a fabric intent to build the DC switch fabric?
  • A. It uses a digital sandbox to connect workloads to the DC fabric.
  • B. It uses a digital sandbox to build the configuration files for the DC fabric.
  • C. It uses telemetry data to build the configuration files for the DC fabric.
  • D. It uses a YAML file that defines the intended configuration state of the DC fabric.
Nokia's Fabric Services System uses a fabric intent defined in a declarative YAML file to specify the desired state of the data center fabric, which is then used to build and configure the fabric accordingly.
NEW QUESTION # 20
Which of the following Nokia's SR Linux ACLs is instantiated on all line cards to copy incoming packets to the CPM?
  • A. Ingress ACL
  • B. Capture-filter ACL
  • C. CPM-filter ACL
  • D. Egress ACL
The CPM-filter ACL is instantiated on all line cards in Nokia's SR Linux to copy incoming packets to the Control Plane Manager (CPM) for processing.
NEW QUESTION # 21
Which of the following statements about the data center's leaf-spine topology (clos network) is FALSE?
  • A. It uses ECMP to distribute traffic across duplicate links.
  • B. It uses the spanning tree protocol to avoid forwarding loops.
  • C. Each leaf router is connected to all the spine routers in the cluster.
  • D. It provides a consistent path for east-west traffic.
The leaf-spine (Clos) topology does not use the spanning tree protocol because it relies on equal-cost multipath (ECMP) routing to prevent loops and efficiently utilize all available paths. Spanning tree is typically avoided in modern data center fabrics to enable full bandwidth utilization.
NEW QUESTION # 22
Which of the following is NOT one of the reasons why BGP is used as the routing protocol in the data center?
  • A. BGP neighbors automatically discover each other.
  • B. It supports both IPv4 and IPv6.
  • C. It is more efficient than link-state protocols like IS-IS and OSPF.
  • D. It is a well understood and mature routing protocol.
BGP is not chosen because it is more efficient than link-state protocols; in fact, link-state protocols like IS-IS and OSPF generally provide faster convergence and more efficient route calculation. BGP is used in data centers mainly because it is mature, well understood, supports both IPv4 and IPv6, and offers flexible policy control.
NEW QUESTION # 23
If you want to pass the exam smoothly buying our 4A0-D01 study materials is your ideal choice. They can help you learn efficiently, save your time and energy and let you master the useful information. Our passing rate of 4A0-D01 study materials is very high and you needn’t worry that you have spent money and energy on them but you gain nothing. We provide the great service after you purchase our 4A0-D01 Study Materials and you can contact our customer service at any time during one day.
4A0-D01 Exam Cram Review: https://www.dumpsquestion.com/4A0-D01-exam-dumps-collection.html
BTW, DOWNLOAD part of DumpsQuestion 4A0-D01 dumps from Cloud Storage: https://drive.google.com/open?id=1FvI_aD0WZkLQpiiqzb5_CjKGK7EteODh
Posted at 1/24/2026 03:03:29        Only Author  2#
This content is outstanding, and my like is locked in. I reached my career goals thanks to the Updated Analytics-DA-201 CBT exam, and now you can access it for free!
Posted at 1/26/2026 21:41:46        Only Author  3#
GES-C01認定資格を取得して認定資格を取得すると、将来の雇用と開発がある程度決まるため、GES-C01試験ガイドは競争力のある従業員になるために尽力しています。家に戻っても問題ありません。実際、GES-C01試験に合格するための最良の方法は近視であるとGES-C01のテスト準備を考えてください。彼らはこれを達成できるだけでなく、より多くのコンテンツを同時に覚えることができます。
Posted at 2/1/2026 09:26:01        Only Author  4#
I can’t express how much I appreciate your article, it was truly memorable. About to take the SY0-701 test notes exam! Let’s hope everything goes smoothly!
Posted at 2/6/2026 20:18:24        Only Author  5#
Die Ausbildungsmaterialien zur SAP C_BCWME_2504 Zertifizierungsprüfung aus EchteFrage verfügen über hohe Genauigkeiten und große Reichweite, sie können nicht nur Ihre Kenntnisse, sondern auch Ihre Operationsfähigkeiten verbessern, so dass Sie zu einem Eliten in der IT-Branche werden und eine gut bezahlte Arbeit bekommen können. Bevor Sie unsere Ausbildungsmaterialien zur SAP C_BCWME_2504 Zertifizierungsprüfung kaufen, können Sie einige kostenlosen Prüfungsfragen und Antworten als Testversion herunterladen.
Posted at 2/22/2026 23:55:11        Only Author  6#
This article is amazing, thank you for sharing! Wishing everyone good luck with their exams—free New study NCSF-CPT questions pdf questions are now available!
