[General] Why the Palo Alto Networks NGFW-Engineer Certification Matters
100
【General】 Why the Palo Alto Networks NGFW-Engineer Certification Matters
Posted at 1/16/2026 01:47:01      View:185 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free & New NGFW-Engineer dumps are available on Google Drive shared by Itexamguide: https://drive.google.com/open?id=19kmLIY66QqhSK3d74LXOUN19rvTtl6Tq
When asked about the opinion about the exam, most people may think that it’s not a quite easy thing, and some people even may think that it’s a difficult thing. NGFW-Engineer learning materials of us include the questions and answers, which will show you the right answers after you finish practicing. NGFW-Engineer Online Test engine can record the test history and have a performance review, with this function you can have a review of what you have learned.
Palo Alto Networks NGFW-Engineer Exam Syllabus Topics:
  • Integration and Automation: This section measures the skills of Automation Engineers in deploying and managing Palo Alto Networks NGFWs across various environments. It includes the installation of PA-Series, VM-Series, CN-Series, and Cloud NGFWs. The use of APIs for automation, integration with third-party services like Kubernetes and Terraform, centralized management with Panorama templates and device groups, as well as building custom dashboards and reports in Application Command Center (ACC) are key topics.
  • PAN-OS Device Setting Configuration: This section evaluates the expertise of System Administrators in configuring device settings on PAN-OS. It includes implementing authentication roles and profiles, and configuring virtual systems with interfaces, zones, routers, and inter-VSYS security. Logging mechanisms such as Strata Logging Service and log forwarding are covered alongside software updates and certificate management for PKI integration and decryption. The section also focuses on configuring Cloud Identity Engine User-ID features and web proxy settings.
  • PAN-OS Networking Configuration: This section of the exam measures the skills of Network Engineers in configuring networking components within PAN-OS. It covers interface setup across Layer 2, Layer 3, virtual wire, tunnel interfaces, and aggregate Ethernet configurations. Additionally, it includes zone creation, high availability configurations (active
  • active and active
  • passive), routing protocols, and GlobalProtect setup for portals, gateways, authentication, and tunneling. The section also addresses IPSec, quantum-resistant cryptography, and GRE tunnels.
NGFW-Engineer Visual Cert Test & Advanced NGFW-Engineer Testing EnginePeople around you are improving their competitiveness in various ways. Haven't you started to move? You must be more efficient than others before you can do more and get more pay! Our NGFW-Engineer study materials will tell you that in a limited time, you can really do a lot of things. Of course, the quality of our NGFW-Engineer Exam Questions is also very high. As you can say that with the help of our NGFW-Engineer practice guide, the pass rate for our loyal customers is high as 98% to 100%. It is unique in the market.
Palo Alto Networks Next-Generation Firewall Engineer Sample Questions (Q58-Q63):NEW QUESTION # 58
Which two actions in the IKE Gateways will allow implementation of post-quantum cryptography when building VPNs between multiple Palo Alto Networks NGFWs? (Choose two.)
  • A. Select IKE v2 Preferred, enable the Advanced Options - PQ KEM, then add one or more
    "Rounds."
  • B. Select IKE v2, enable the Advanced Options - PQ KEM, then create an IKE Crypto Profile with Advanced Options adding one or more "Rounds."
  • C. Select IKE v2, enable the Advanced Options - PQ PPK, then set a 64+ character string for the post-quantum pre shared key.
  • D. Ensure Authentication is set to "certificate," then import a post-quantum derived certificate.
To implement post-quantum cryptography (PQC) in VPNs between Palo Alto Networks NGFWs, you would enable the PQ KEM (Post-Quantum Key Encapsulation Mechanism) in the IKE gateway configuration. This enables the firewall to use quantum-resistant encryption for key exchange, which is an essential part of securing communications against the potential future threats posed by quantum computing.
By selecting IKE v2 Preferred and enabling the PQ KEM option under Advanced Options, you can add specific Rounds for the post-quantum cryptography process, which will help in implementing quantum-resistant key exchange methods.
This option similarly selects IKE v2 and enables PQ KEM while also creating a dedicated IKE Crypto Profile with the necessary Rounds configured for post-quantum cryptography.
NEW QUESTION # 59
How does a Palo Alto Networks NGFW respond when the preemptive hold time is set to 0 minutes during configuration of route monitoring?
  • A. It does not accept the configuration.
  • B. It accepts the configuration but throws a warning message.
  • C. It removes the static route because 0 is a NULL value
  • D. It reinstalls the route into the routing information base (RIB) as soon as the path comes up.
When the preemptive hold time is set to 0 minutes in route monitoring, the firewall is configured to immediately reinstall the route into the Routing Information Base (RIB) as soon as the monitored path comes up. This essentially means that the firewall will not wait for any predefined hold time before reestablishing the route once the monitoring condition is met, ensuring a faster recovery of the route.
NEW QUESTION # 60
During an upgrade to the routing infrastructure in a customer environment, the network administrator wants to implement Advanced Routing Engine (ARE) on a Palo Alto Networks firewall.
Which firewall models support this configuration?
  • A. PA-7050, PA-1420, VM-Series, CN-Series
  • B. PA-5280, PA-7080, PA-3250, VM-Series
  • C. PA-455, VM-Series, PA-1410, PA-5450
  • D. PA-3260, PA-5410, PA-850, PA-460
The Advanced Routing Engine (ARE) is supported on Palo Alto Networks firewalls that utilize the PAN-OS 11.0+ software and have the required hardware architecture. The supported models include PA-3200 Series, PA-5400 Series, PA-800 Series, and PA-400 Series. These models provide enhanced routing capabilities, including BGP, OSPF, and more complex routing policies.
PA-3260 and PA-5410 are part of the PA-3200 and PA-5400 Series, which are known to support ARE.
PA-850 and PA-460 are within the PA-800 and PA-400 Series, which also support ARE
NEW QUESTION # 61
Which interface types should be used to configure link monitoring for a high availability (HA) deployment on a Palo Alto Networks NGFW?
  • A. HA, Virtual Wire, and Layer 2
  • B. HA, Layer 2. and Layer 3
  • C. Virtual Wire, Layer 2, and Layer 3
  • D. Tap, Virtual Wire, and Layer 3
When configuring link monitoring for high availability (HA) on a Palo Alto Networks NGFW, the following interface types are supported:
Virtual Wire: Used when you have a transparent mode firewall deployment, where the firewall operates at Layer 2 to monitor traffic between two network segments.
Layer 2: Also used in transparent mode, where the firewall operates as a Layer 2 device and can be configured for link monitoring.
Layer 3: Used in routed mode, where the firewall is involved in routing traffic and can also be configured to monitor links.
NEW QUESTION # 62
To maintain security efficacy of its public cloud resources by using native tools, a company purchases Cloud NGFW credits to replicate the Panorama, PA-Series, and VM-Series devices used in physical data centers. Resources exist on AWS and Azure:
- The AWS deployment is architected with AWS Transit Gateway, to which
all resources connect
- The Azure deployment is architected with each application
independently routing traffic
The engineer deploying Cloud NGFW in these two cloud environments must account for the following:
- Minimize changes to the two cloud environments
- Scale to the demands of the applications while using the least amount of compute resources
- Allow the company to unify the Security policies across all protected areas Which two implementations will meet these requirements? (Choose two.)
  • A. Deploy a VM-Series firewall in AWS in each VPC, create an IPSec tunnel between AWS and Azure, and manage the policy with Panorama.
  • B. Deploy Cloud NGFW for Azure in vNET/s, update the vNET/s routing to path traffic through the deployed NGFWs, and manage the policy with Panorama.
  • C. Deploy Cloud NGFW for Azure in vWAN, create a vWAN to route all appropriate traffic to the Cloud NGFW attached to the vWAN, and manage the policy with local rules.
  • D. Deploy Cloud NGFW for AWS in a centralized Security VPC, update the Transit Gateway to route all appropriate traffic through the Security VPC, and manage the policy with Panorama.
To meet the company's requirements - minimizing changes to the cloud environments, optimizing compute resources, and unifying security policies - the best approach is to deploy Cloud NGFW solutions natively for AWS and Azure while managing policies centrally with Panorama. In Azure, using Cloud NGFW for Azure deployed within vNETs allows traffic to be routed through security appliances efficiently without requiring a complete re-architecture. This approach aligns with Azure's existing routing mechanism while maintaining security. In AWS, deploying Cloud NGFW for AWS in a centralized Security VPC and integrating it with AWS Transit Gateway enables traffic inspection for all connected VPCs without modifying individual workloads. This method ensures efficient scaling and minimal infrastructure changes while maintaining security consistency.
NEW QUESTION # 63
For candidates who will attend an exam, some practice for it is necessary. NGFW-Engineer Exam Dumps of us will give you the practice you need. NGFW-Engineer exam dumps of us contain the knowledge point of the exam. Skilled professionals will verify the questions and answers, which will guarantee the correctness. Besides, we also offer you free update for one year after purchasing, and the update version will send to your email address automatically.
NGFW-Engineer Visual Cert Test: https://www.itexamguide.com/NGFW-Engineer_braindumps.html
BTW, DOWNLOAD part of Itexamguide NGFW-Engineer dumps from Cloud Storage: https://drive.google.com/open?id=19kmLIY66QqhSK3d74LXOUN19rvTtl6Tq
Posted at 1/26/2026 18:19:19        Only Author  2#
That article made a lasting impact on me. Upgrade your IT skills with free New PSE-Cortex exam labs. Best wishes for your success!
Posted at 3/6/2026 11:19:39        Only Author  3#
The content of the article is detailed, and I’ve learned many useful things. Free PEGACPBA24V1 reliable exam passing score materials—unlock promotions and higher salary potential!
