[General] 2026 Excellent NSE7_EFW-7.2 Free Pdf Guide Help You Pass NSE7_EFW-7.2 Easily
79
【General】 2026 Excellent NSE7_EFW-7.2 Free Pdf Guide Help You Pass NSE7_EFW-7.2 Easily
Posted at 1/16/2026 02:56:37      View:161 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Fortinet NSE7_EFW-7.2 dumps are available on Google Drive shared by Exams4sures: https://drive.google.com/open?id=1RWhBCfAocoC7fXaOszhLVwDovwg-wf1G
Our NSE7_EFW-7.2 test prep embrace latest information, up-to-date knowledge and fresh ideas, encouraging the practice of thinking out of box rather than treading the same old path following a beaten track. As the industry has been developing more rapidly, our NSE7_EFW-7.2 exam dumps have to be updated at irregular intervals in case of keeping pace with changes. To give you a better using environment, our experts have specialized in the technology with the system upgraded to offer you the latest NSE7_EFW-7.2 Exam practices. And you can enjoy free updates of our NSE7_EFW-7.2 learning prep for one year.
Fortinet NSE7_EFW-7.2 Exam Syllabus Topics:
  • VPN: Implementing IPsec VPN IKE version 2 is discussed in this topic. Additionally, it delves into implementing auto-discovery VPN (ADVPN) to enable on-demand VPN tunnels between sites.
  • System configuration: This topic discusses Fortinet Security Fabric and hardware acceleration. Furthermore, it delves into configuring various operation modes for an HA cluster.
  • Security profiles: Using FortiManager as a local FortiGuard server is discussed in this topic. Moreover, it delves into configuring web filtering, application control, and the intrusion prevention system (IPS) in an enterprise network.
  • Central management: The topic of Central management covers implementing central management.
Topic 5
  • Routing: It covers implementing OSPF to route enterprise traffic and Border Gateway Protocol (BGP) to route enterprise traffic.
Online NSE7_EFW-7.2 Bootcamps, Trustworthy NSE7_EFW-7.2 PdfYou can try NSE7_EFW-7.2 free demo before you decide to buy the full version practice test. NSE7_EFW-7.2 exam dumps details are researched and produced by our Professional Certification Experts who are constantly using industry experience to produce precise, and logical. Exams4sures NSE7_EFW-7.2 Exam Dumps will not only help you pass in one attempt, but also save your valuable time.
Fortinet NSE 7 - Enterprise Firewall 7.2 Sample Questions (Q50-Q55):NEW QUESTION # 50
Exhibit.
Refer to the exhibit, which shows a partial touting table
What two concisions can you draw from the corresponding FortiGate configuration? (Choose two.)
  • A. net-device is enabled in the tunnel IPSec phase 1 configuration
  • B. OSPI is configured to run over IPSec.
  • C. add-route is disabled in the tunnel IPSec phase 1 configuration.
  • D. IPSec Tunnel aggregation is configured
* Option B is correct because the routing table shows that the tunnel interfaces have a netmask of
255.255.255.255, which indicates that net-device is enabled in the phase 1 configuration. This option allows the FortiGate to use the tunnel interface as a next-hop for routing, without adding a route to the phase 2 destination1.
* Option D is correct because the routing table does not show any routes to the phase 2 destination networks, which indicates that add-route is disabled in the phase 1 configuration. This option controls whether the FortiGate adds a static route to the phase 2 destination network using the tunnel interface as the gateway2.
* Option A is incorrect because IPSec tunnel aggregation is a feature that allows multiple phase 2 selectors to share a single phase 1 tunnel, reducing the number of tunnels and improving performance3.
This feature is not related to the routing table or the phase 1 configuration.
* Option C is incorrect because OSPF is a dynamic routing protocol that can run over IPSec tunnels, but it requires additional configuration on the FortiGate and the peer device4. This option is not related to the routing table or the phase 1 configuration. References: =
* 1: Technical Tip: 'set net-device' new route-based IPsec logic2
* 2: Adding a static route5
* 3: IPSec VPN concepts6
* 4: Dynamic routing over IPsec VPN7
NEW QUESTION # 51
Exhibit.
Refer to the exhibit, which shows information about an OSPF interlace
What two conclusions can you draw from this command output? (Choose two.)
  • A. The interfaces of the OSPF routers match the MTU value that is configured as 1500.
  • B. The OSPF routers are in the area ID of 0.0.0.1.
  • C. The port3 network has more man one OSPF router
  • D. NGFW-1 is the designated router
From the OSPF interface command output, we can conclude that the port3 network has more than one OSPF router because the Neighbor Count is 2, indicating the presence of another OSPF router besides NGFW-1.
Additionally, we can deduce that the interfaces of the OSPF routers match the MTU value configured as 1500, which is necessary for OSPF neighbors to form adjacencies. The MTU mismatch would prevent OSPF from forming a neighbor relationship.
* Fortinet FortiOS Handbook: OSPF Configuration
NEW QUESTION # 52
Refer to the exhibit, which shows the output of a BGP summary.
What two conclusions can you draw from this BGP summary? (Choose two.)
  • A. External BGP (EBGP) exchanges routing information.
  • B. The neighbors displayed are linked to a local router with the neighbor-range set to a value of 4.
  • C. The BGP session with peer 10. 127. 0. 75 is established.
  • D. The router 100. 64. 3. 1 has the parameter bfd set to enable.
The output of the BGP (Border Gateway Protocol) summary shows details about the BGP neighbors of a router, their Autonomous System (AS) numbers, the state of the BGP session, and other metrics like messages received and sent.
From the BGP summary provided:
A: External BGP (EBGP) exchanges routing information.This conclusion can be inferred because the AS numbers for the neighbors are different from the local AS number (65117), which suggests that these are external connections.
B: The BGP session with peer 10.127.0.75 is established.This is indicated by the state/prefix received column showing a numeric value (1), which typically means that the session is established and a number of prefixes has been received.
C: The router 100.64.3.1 has the parameter bfd set to enable.This cannot be concluded directly from the summary without additional context or commands specifically showing BFD (Bidirectional Forwarding Detection) configuration.
D: The neighbors displayed are linked to a local router with the neighbor-range set to a value of 4.The neighbor-range concept does not apply here; the value 4 in the 'V' column stands for the BGP version number, which is typically 4.
NEW QUESTION # 53
How are bulk configuration changes made using FortiManager CLI scripts? (Choose two.)
  • A. When run on the Device Database, changes are applied directly to the managed FortiGate device.
  • B. When run on the All FortiGate in ADOM, changes are automatically installed without the creation of a new revision history.
  • C. When run on the Remote FortiGate directly, administrators do not have the option to review the changes prior to installation.
  • D. When run on the Policy Package, ADOM database, you must use the installation wizard to apply the changes to the managed FortiGate device.
NEW QUESTION # 54
Which two statements about IKE vision 2 are true? (Choose two.)
  • A. It supports the extensible authentication protocol (EAP)
  • B. Phase 1 includes main mode
  • C. It supports the XAuth protocol.
  • D. It exchanges a minimum of four messages to establish a secure tunnel
IKE version 2 supports the extensible authentication protocol (EAP), which allows for more flexible and secure authentication methods1. IKE version 2 also exchanges a minimum of four messages toestablish a secure tunnel, which is more efficient than IKE version 12. References: = IKE settings | FortiClient 7.2.2 - Fortinet Documentation, Technical Tip: How to configure IKE version 1 or 2 ... - Fortinet Community
NEW QUESTION # 55
NSE7_EFW-7.2 exam dumps will give you enough information that you don't requirement to seek out any other source. Exams4sures can save you valuable time and money, resulting in satisfying results. NSE7_EFW-7.2 exam dumps will increase your level of preparation in minimum time. It's the perfect time to take the right decision. Download Exams4sures Fortinet NSE7_EFW-7.2 Exam Dumps now to proceed successfully in your professional career.
Online NSE7_EFW-7.2 Bootcamps: https://www.exams4sures.com/Fortinet/NSE7_EFW-7.2-practice-exam-dumps.html
Posted at 1/27/2026 17:32:12        Only Author  2#
Als Anbieter des Salesforce AP-209 (Advanced Field Service Accredited Professional) IT-Prüfungskompendium bieten IT-Experten von Pass4Test ständig die Produkte von guter Qualität. Sie bieten den Kunden kostenlosen Online-Service rund um die Uhr und aktualisieren Salesforce AP-209 (Advanced Field Service Accredited Professional) Prüfungsfragen und Antworten auch am schnellsten.
Posted at 2/1/2026 14:15:11        Only Author  3#
I’m in awe of this article, thank you for sharing it with us! I’m offering the C-HRHPC-2505 valid exam format test that helped me advance in my career with a promotion and raise. It’s available for free today. I hope you succeed in your career!
