[Hardware] Practice VMware 2V0-15.25 Exam Online & 2V0-15.25 New Dumps Ppt
75
Hardware Practice VMware 2V0-15.25 Exam Online & 2V0-15.25 New Dumps Ppt
Posted at 1/16/2026 04:48:40      View175 | Replies0        Print      Only Author   [Copy Link] 1#
Our 2V0-15.25 learn materials include all the qualification tests in recent years, as well as corresponding supporting materials. Such a huge amount of database can greatly satisfy users' learning needs. Not enough valid 2V0-15.25 test preparation materials, will bring many inconvenience to the user, such as delay learning progress, these are not conducive to the user pass exam, therefore, in order to solve these problems, our 2V0-15.25 Certification material will do a complete summarize and precision of summary analysis to help you pass the 2V0-15.25 exam with ease.
VMware 2V0-15.25 Exam Syllabus Topics:
  • Plan and Design the VMware by Broadcom Solution: This domain addresses architectural planning and design principles for creating scalable, secure virtual environments aligned with business requirements.
  • Troubleshoot and Optimize the VMware by Broadcom Solution: This domain focuses on troubleshooting VCF deployment, upgrades, conversions, workload domains, fleet operations (certificates, passwords, identity), licensing, compute resources, storage (vSAN, supplemental storage), networking (VDS, NSX), VCF Operations tools, Identity Broker automation, and HCX workload migrations.
  • IT Architectures, Technologies, Standards: This domain covers fundamental frameworks, tools, and best practices for building scalable, secure, and interoperable enterprise IT systems.
  • Install, Configure, Administrate the VMware by Broadcom Solution: This area covers installing, configuring, and managing VMware solutions including VCF Fleet deployment, expansion, and reduction operations.
Topic 5
  • VMware by Broadcom Solution: This section focuses on understanding VMware by Broadcom's virtualization and cloud infrastructure platform for managing modern enterprise workloads.
2V0-15.25 New Dumps Ppt & Guaranteed 2V0-15.25 Questions AnswersOur 2V0-15.25 training quiz is the top selling products in the market. You will save a lot of preparation troubles if you purchase our 2V0-15.25 study materials. Our 2V0-15.25 exam braindumps are highly similar to the real test. Almost all questions of the real exam will be predicated accurately in our 2V0-15.25 Practice Questions, which can add you passing rate of the exam. And you will find that our prices for the exam products are quite favorable.
VMware Cloud Foundation 9.0 Support Sample Questions (Q56-Q61):NEW QUESTION # 56
A user wishes to publish a VMware Cloud Foundation (VCF) Operations Orchestrator workflow to their VCF Automation project catalog, but Is blocked from publishing any workflows.
The following information has been provided:
* In the VCF Automation Organization portal, the user cannot see the Workflows option under Content Hub.
* The organization is not a Provider Consumption Organization.
Which are the two likely causes of this issue? (Choose two.)
  • A. The user is logged in the Project Advanced User rights
  • B. The user is logged in with Project Administrator rights.
  • C. An embedded VCF Operations Orchestrator is not integrated with their Organization.
  • D. The user is logged in with Project User rights.
  • E. An external VCF Operations Orchestrator is not integrated with their Organization.
Answer: C,E
In VMware Cloud Foundation 9.0, publishing aVCF Operations Orchestratorworkflow to aVCF Automation project catalogrequires that the Organization has a valid integration withVCF Operations Orchestrator. The question states that the usercannot see the Workflows option under Content Hub, and theorganization is not a Provider Consumption Organization (PCO). According to the VCF 9.0 documentation, only organizations withVCF Operations Orchestrator integrationare allowed to publish workflows into the catalog. Both embedded and external orchestrator integrations must be configured depending on the environment. Ifno orchestrator (embedded or external)is integrated with the organization, workflows cannot be listed or published. This aligns with the documented VCF Automation and VCF Operations Orchestrator design requirements, which specify that workflow publishing is only available when the orchestrator instance is properly registered.
Additionally, user role permission issues could prevent workflow visibility, but the key blockers described in the scenario are the missing workflow section and the organization type. Because the organization isnot a PCO, advanced provider features-including workflow publishing-are disabled unless a proper orchestrator integration exists. Therefore, the two most likely causes are:
* A:An external VCF Operations Orchestrator is not integrated with their Organization.
* D:An embedded VCF Operations Orchestrator is not integrated with their Organization.
These two conditions directly match the documented behavior in VMware Cloud Foundation 9.0.
NEW QUESTION # 57
An administrator attempts to add a new user (provideradmin05) within the VMware Cloud Foundation (VCF) Automation Provider Management Portal, however provideradmin05 cannot be found for import.
The following information is provided:
* The existing VCF Fleet uses VMware Identity Broker (VIDB) for single sign-on.
* VIDB uses Active Directory as the identity provider.
* A group named VCFA_ProviderAdmins was created in Active Directory, populated with the appropriate user accounts and synchronized with VIDB.
* Five days later provideradmin05 was added to VCFA_ProviderAdmins.
What will resolve this issue?
  • A. In the VCF Automation Provider Management Portal, enable the Advanced Rights Bundle Mode.
  • B. In the VCF Automation Provider Management Portal, import provideradmin05 as an LDAP user.
  • C. In VCF Operations, disable VCF SSO for VCF Automation.
  • D. In VCF Operations, manually resync the directory.
VMware Cloud Foundation (VCF) 9.x usesVMware Identity Broker (VIDB)as the central identity provider for the entire VCF fleet. VIDB synchronizes user and group metadata from the connected enterprise identity source, in this caseActive Directory. When a user is added to an AD groupafterthe group was already synced into VIDB,VIDB does not automatically resync group membership on demandunless a directory synchronization is performed.
In this scenario, the groupVCFA_ProviderAdminswas synchronized five days earlier. When the new user provideradmin05was later added to the AD group, VIDB-and therefore the VCF Automation Provider Management Portal-does not recognize that new user until amanual directory resynchronizationoccurs fromVCF Operations.
This operation forces VIDB to:
* Requery Active Directory
* Update group membership information
* Repopulate available users for import into VCF Automation
Options B and D are incorrect because they donotinfluence Identity Broker directory synchronization. Option C (disable VCF SSO) would break authentication and is not a valid solution.
NEW QUESTION # 58
An administrator is attempting to log into the vCenter using the vSphere Client but receives an error stating
"no healthy upstream" What are two possible causes for this? (Choose two.)
  • A. The vmware-rbd-watchdog service is not running.
  • B. Port 443 is not opened between the local machine and the vCenter.
  • C. The SSO Service is not running.
  • D. The vpxd service is not running.
  • E. The administrator logged in with the root account.
The vSphere Client "no healthy upstream" error is a classic indicator that one or morevCenter backend services are not running or responding, preventing the reverse proxy layer (envoy / nginx) from routing requests to the appropriate upstream services.
Two services in particular are known root causes:
A). vpxd service not running
vpxd is the core vCenter Server service responsible for inventory, host management, and client interaction. If vpxd is stopped, crashed, or restarting, the vSphere Client cannot communicate with backend APIs, resulting in the "no healthy upstream" condition.
B). SSO (vmware-stsd / identity service) not running
Authentication in vCenter depends on the SSO/Identity service. If SSO is unavailable, login sessions cannot be validated, and vCenter marks the upstream service as unhealthy.
Other options donotmatch the behavior:
* C (Port 443 closed)would produce a connection failure, not the upstream error.
* D (logging in with root)is fully supported and does not trigger this message.
* E (vmware-rbd-watchdog)relates to backup/restore health, not core authentication/management planes.
NEW QUESTION # 59
An administrator is troubleshooting a problem with NSX.
Which command can be used to validate installed NSX VIBs on the ESX host?
  • A. nsxcli get version
  • B. esxtop -b -d 2 -n 100
  • C. esxcli software vib list
  • D. esxcfg software list
When troubleshooting NSX on an ESXi host, VMware requires verification that NSX VIBs (vSphere Installation Bundles) are installed and in the correct state. VIBs are responsible for NSX datapath, control- plane modules, and kernel extensions on ESXi. The authoritative and documented method to list VIBs on an ESXi host is the command:
This command displays all installed kernel modules, version numbers, NSX packages, and their installation status. For NSX-T (now part of VCF networking), administrators expect to see VIBs such asnsx-aggservice, nsx-bridge,nsx-esx-datapath, and others. If any required NSX VIBs are missing or inconsistent, the ESXi host will fail to join NSX transport nodes or will show "Not Ready." Option A (esxtop) is for performance monitoring and does not show VIB information.
Option C (nsxcli get version) checks NSX version on Edge Nodes or host transport nodes butdoes not list VIBs.
Option D (esxcfg software list) is an outdated and invalid command.
NEW QUESTION # 60
An administrator is automating the deployment of a new VMware Cloud Foundation (VCF) fleet using VCF Installer. The VCF fleet must include VCF Automation being deployed in a simple deployment model.
The administrator creates a JSON file, but during the installation attempt the VCF Installer returns an error indicating that the JSON validation has failed.
What is the cause of the errors?
  • A. Second IP address for VCF Automation is not specified.
  • B. NSX Manager size was defined as large.
  • C. A separate distributed switch was defined for vSAN traffic.
  • D. VCF components binaries are not downloaded.
In VCF 9.0, when deployingVCF Automationusing the VCF Installer in aSimple Deployment Model, the appliance requirestwo IP addresses:
* Primary IP- Management interface
* Secondary IP- Required for service separation and internal routing for Automation services VMware's JSON schema for VCF Installer enforces this requirement. If the second IP is missing, incorrectly formatted, or placed under the wrong JSON section, the installer validation will fail immediately with a JSON schema error before deployment begins.
This is one of themost common causesof validation failure for VCF Automation deployment.
Option A (component binaries missing) produces abundle downloaderror, not JSON schema failure.
Option C (NSX Manager size = large) is allowed and does not break JSON validation.
Option D (separate vDS for vSAN) is allowed if defined correctly and also does not cause JSON schema failure.
NEW QUESTION # 61
In the past few years, our 2V0-15.25 study materials have helped countless candidates pass the 2V0-15.25 exam. After having a related certification, some of them encountered better opportunities for development, some went to great companies, and some became professionals in the field. 2V0-15.25 Study Materials have stood the test of time and market and received countless praises. We will transfer our 2V0-15.25 test prep to you online immediately, and this service is also the reason why our 2V0-15.25 study torrent can win peoples heart and mind.
2V0-15.25 New Dumps Ppt: https://www.actualtests4sure.com/2V0-15.25-test-questions.html
