[General] C-THR81-2411考試備考經驗 & C-THR81-2411認證題庫
91
【General】 C-THR81-2411考試備考經驗 & C-THR81-2411認證題庫
Posted at 1/16/2026 05:40:16      View:227 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. NewDumps在Google Drive上分享了免費的2026 SAP C-THR81-2411考試題庫:https://drive.google.com/open?id=1R6Zf18mtbWtczs6Tf3IA-vIiVZogZu_j
SAP C-THR81-2411 認證試題庫學習資料根據最新的知識點以及輔導資料進行整編,覆蓋面廣,蘊含了眾多最新的 SAP 考試知識點。如果你正在準備 C-THR81-2411 考試並且像我一樣急需通過,那 C-THR81-2411 認證試題剛好可以幫助你。因為完善的 C-THR81-2411 學習資料資料覆蓋 SAP 考試所有知識點,減少你考試的時間成本和經濟成本,助你輕松通過考試
為了每位IT認證考試的考生切身利益,我們網站提供NewDumps SAP的C-THR81-2411考試培訓資料是根據考生的需要而定做的,由我們NewDumps資質深厚的IT專家專門研究出來的,他們的奮鬥結果不僅僅是為了幫助你們通過考試,而且是為了讓你們有一個更好的明天。
C-THR81-2411認證題庫 & C-THR81-2411信息資訊購買我們NewDumps SAP的C-THR81-2411考試認證的練習題及答案,你將完成你人生中最重要的考前準備問題,你將得到最高品質的培訓資料,今天購買我們的產品,是你為自己打開了新的大門,也是為了更美好的未來,也使你付出最小努力,獲得最大的成功。
最新的 SAP Certified Associate C-THR81-2411 免費考試真題 (Q42-Q47):問題 #42
Which clause meets the WFD_Address rule requirement?
  • A.
  • B.
  • C.
  • D.
答案:A
問題 #43
Fields in the termination screen are configured in which hris-element?
  • A. Employment Information
  • B. Compensation Information
  • C. Personal Information
  • D. Job Information
答案:A
問題 #44
The employee is changing their marital status. Once the workflow is approved, the manager gets a notification via e-mail that this change has been processed. The manager then goes into the system and checks the workflow, but notices that they can see more fields than the ones for which they should receive a notification (Name, Marital Status, and Nationality) Why is that?
  • A. There is a rule that sets up the visibility for the fields in Personal Information and this applies when checking the workflow.
  • B. The manager has transactions pending approval permission for Personal Information.
  • C. In the workflow, Respect Permissions was set to No for the notification line to the manager.
  • D. The manager's approver context is set to Source
答案:C
問題 #45
Which fields must be enabled for the HRIS element payComponentNonRecurring? Note: There are 3 correct answers to this question.
  • A. value
  • B. pay-component-code
  • C. pay-date
  • D. frequency
  • E. is-target
答案:A,B,C
解題說明:
In SAP SuccessFactors Employee Central, the payComponentNonRecurring HRIS element is used to record one-time payments or bonuses for employees. The following fields are mandatory and must be enabled for this element:
* A. value
* This field captures the monetary amount of the non-recurring payment.
* B. pay-component-code
* This field specifies the type of payment, such as a bonus or commission, by referencing predefined pay components.
* C. pay-date
* This field indicates the date on which the non-recurring payment is made.
These fields are essential for accurately processing and recording non-recurring payments within the system.
It's important to note that other fields like frequency and is-target are not applicable to non-recurring pay components and are therefore not required.
問題 #46
You need to create a one-to-many association from Location to Legal Entity. You also need toconfigure filtering of the Location field based on the Company field in the Job Information block.
What do you need to add to the data models? Note: There are 2 correct answers to this question.
  • A. <association> as part of <hris-element id="location">
  • B. <field-criteria> as part of <hris-field="company">
  • C. <association> as part of <hris-element id="jobInfo">
  • D. <field-criteria> as part of <hris-field="location">
答案:A,D
解題說明:
To establish a one-to-many association from Location to Legal Entity and enable filtering of the Location field based on the Company field in the Job Information block, the following configurations are necessary:
* Define the Association in the Location Object:
* In thelocationobject definition, add an<association>element to link it to thelegalEntityobject. This association should be defined within the<hris-element id="location">section.
* Configure Field Criteria for the Location Field:
* Within the Job Information (jobInfo) element, add a<field-criteria>element as part of the<hris- field id="location">. This configuration ensures that the Location field is filtered based on the selected Company (Legal Entity) in the Job Information block.
Therefore, the correct answers are:
* B:<field-criteria>as part of<hris-field id="location">
* D:<association>as part of<hris-element id="location">
These configurations align with the standard practices for setting up associations and field criteria in SAP SuccessFactors Employee Central.
問題 #47
如果你想成功通過C-THR81-2411認證考試,不要錯過閱讀NewDumps最新的C-THR81-2411考古題資料,100%保證通過,所有的題庫都會及時更新。使用我們軟件版本的C-THR81-2411題庫可以幫您評估自己掌握的知識點,從而在考試期間增加問題的回憶,幫助快速完成考試。SAP C-THR81-2411考題具備了覆蓋率很高,能夠消除考生對考試的疑慮。C-THR81-2411是一個很難通過的認證考試,要想通過考試必須為考試做好充分的準備,而NewDumps是您最佳的選擇!
C-THR81-2411認證題庫: https://www.newdumpspdf.com/C-THR81-2411-exam-new-dumps.html
考試內容:主要為SAP C-THR81-2411認證題庫 C-THR81-2411認證題庫 - SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Employee Central Core,考生都推薦NewDumps考題網的C-THR81-2411題庫,因其覆蓋了真實的SAP SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Employee Central Core認證指南,已經説明很多考生順利通過考試,SAP C-THR81-2411考試備考經驗 夢想還是要有的,萬一實現了呢,您會發現這是當前考古題提供者中的佼佼者,我們的 SAP C-THR81-2411 題庫資源不斷被修訂和更新,具有很高的通過率,SAP C-THR81-2411考試備考經驗 這個考古題是最近剛更新的資料,包括了真實考試中可能出現的所有問題,保證你一次就可以通過考試,與其盲目地學習C-THR81-2411 考試要求的相關知識,不如做一些有價值的試題。
我相信楚天唯不會拿自己的妹妹開玩笑,也不會拿自己開玩笑,段言這番話說出來絲毫不覺得臉紅,考試內容:主要為SAP SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Employee Central Core,考生都推薦NewDumps考題網的C-THR81-2411題庫,因其覆蓋了真實的SAP SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Employee Central Core認證指南,已經説明很多考生順利通過考試。
使用正確的C-THR81-2411 {Keyword1確定您一定能通過您的SAP C-THR81-2411考試夢想還是要有的,萬一實現了呢,您會發現這是當前考古題提供者中的佼佼者,我們的 SAP C-THR81-2411 題庫資源不斷被修訂和更新,具有很高的通過率,這個考古題是最近剛更新的資料,包括了真實考試中可能出現的所有問題,保證你一次就可以通過考試。
P.S. NewDumps在Google Drive上分享了免費的、最新的C-THR81-2411考試題庫:https://drive.google.com/open?id=1R6Zf18mtbWtczs6Tf3IA-vIiVZogZu_j
Posted at 2/22/2026 12:16:36        Only Author  2#
This article is truly top-notch, thank you for sharing it with me. Free Reliable study guide DOP-C02 questions materials are the stepping stones to your career advancement and salary growth!
