[General] Certification F5CAB1 Torrent, Premium F5CAB1 Exam
79
【General】 Certification F5CAB1 Torrent, Premium F5CAB1 Exam
Posted at 1/16/2026 06:26:10      View:145 | Replies:0        Print      Only Author   [Copy Link] 1#
ExamDumpsVCE has designed ExamDumpsVCE which has actual exam Dumps questions, especially for the students who are willing to pass the F5 F5CAB1 exam for the betterment of their future. The study material is available in three different formats. F5 F5CAB1 Practice Exam are also available so the students can test their preparation with unlimited tries and pass BIG-IP Administration Install, Initial Configuration, and Upgrade (F5CAB1) certification exam on the first try.
F5 F5CAB1 Exam Syllabus Topics:
  • BIG IP Administration Data Plane Concepts: This section of the exam measures skills of Network Administrators and covers how BIG IP handles application traffic on the data plane. It includes understanding flow of traffic, key data path components, basic concepts of load balancing, and how security and performance features affect user traffic.
  • BIG IP Administration Data Plane Configuration: This section of the exam measures skills of System Administrators and covers configuring BIG IP objects that control data plane behavior. It focuses on setting up virtual servers, pools, nodes, monitors, and profiles so that applications are delivered reliably and efficiently according to design requirements.
  • BIG IP Administration Support and Troubleshooting: This section of the exam measures skills of Network Administrators and covers identifying and resolving common issues that affect BIG IP operation. It focuses on using logs, statistics, diagnostic tools, and basic troubleshooting methods to restore normal traffic flow and maintain stable application delivery.
  • BIG IP Administration Install Initial Configuration and Upgrade: This section of the exam measures skills of System Administrators and covers the lifecycle tasks for deploying and maintaining a BIG IP system. It includes installing the platform, performing initial setup, applying licenses, configuring basic networking, and planning and executing software upgrades and hotfixes.
Topic 5
  • BIG IP Administration Control Plane Administration: This section of the exam measures skills of System Administrators and covers managing the control plane where BIG IP is configured and administered. It includes working with user accounts, roles, device settings, configuration management, and using the graphical interface and command line for daily administrative tasks.
Premium F5 F5CAB1 Exam | F5CAB1 Latest Test VceYou will make progress and obtain your desired certification with our topping F5CAB1 exam dumps for we own the first-class quality as well as the first-class customer service online. We can promise that you will get the most joyful study experience. Our F5CAB1 learning guide is useful to help you make progress. Besides, the three version of F5CAB1 Test Quiz can be used in all kinds of study devices. Furthermore, the three version of F5CAB1 pass-sure torrent can promise your success on your coming exam.
F5 BIG-IP Administration Install, Initial Configuration, and Upgrade Sample Questions (Q42-Q47):NEW QUESTION # 42
What traffic will be permitted to reach the BIG-IP?
  • A. SSH
  • B. FTP
  • C. Telnet
The exhibit shows the configuration of aSelf IPwith:
* Port Lockdown: Allow Custom
* ACustom Listthat includes the following TCP ports:
* 443
* 22
Meaning of these ports:
* TCP 443# HTTPS (TMUI - web-based management)
* TCP 22# SSH (command-line remote access)
No other TCP, UDP, or protocol entries are listed; therefore, only these two services are allowed to reach the BIG-IP via this Self IP.
Evaluating the answer choices:
Option
Service
Port
Allowed?
FTP
TCP 21
Not listed
Not allowed
SSH
TCP 22
Listed
Allowed
Telnet
TCP 23
Not listed
Not allowed
Thus,SSHis the only traffic permitted through this Self IP configuration.
NEW QUESTION # 43
Which command will display thecurrent active volumeon a BIG-IP system?
  • A. tmsh list sys software update
  • B. tmsh show sys software status
  • C. tmsh show sys version
To identify which boot volume is currently active on a BIG-IP system, the correct command is:
This command displays:
* All installed boot volumes (HD1.1, HD1.2, HD1.3, etc.)
* The BIG-IP software version installed on each volume
* TheActivefield, indicating which volume the system is currently booted from
* The installation status ("complete", "in-progress", "allowed")
This is thestandard and authoritativeway to determine the active boot location.
A). tmsh show sys version
* Displays OS version, build, and date.
* Doesnotshow boot locations or which volume is active.
C). tmsh list sys software update
* Shows software update configurations, not boot volume status.
* Does not display which volume is active.
NEW QUESTION # 44
The monitoring team reports that the SNMP server is unable to poll data from a BIG-IP device.
What information will help the BIG-IP Administrator determine whether the issue originates from the BIG-IP system?
  • A. The "Traffic Group" setting must use a floating Traffic Group.
  • B. The "ort Lockdown" setting is preventing the SNMP server from polling data from the BIG-IP.
  • C. The "VLAN / Tunnel" setting must allow All Vlans.
  • D. The configuration on the exhibit is correct and other options should be explored.
The exhibit shows aSelf IPwith:
* VLANata
* Port Lockdown:Allow None
Impact of "Allow None" on SNMP
When a Self IP is configured with:
Port Lockdown: Allow None
the BIG-IP blocksallservices and ports except a few hardcoded HA communication ports.
This means:
* UDP/161 (SNMP)is blocked
* UDP/162 (SNMP traps)is blocked
* The SNMP server cannot poll or receive data from the BIG-IP through this Self IP SNMP relies on access through the Self IP if out-of-band (mgmt interface) is not used.
Thus, the issue is directly caused byPort Lockdown = Allow None, which prevents SNMP communication.
B). Traffic Group must use a floating Traffic Group
* SNMP polling doesnotrequire floating Self IPs.
* Floating groups apply to HA failover IPs, not SNMP functionality.
C). VLAN/Tunnel must allow All VLANs
* Self IPs are always bound to a VLAN; SNMP doesnotrequire All VLANs.
* As long as the Self IP belongs to a reachable VLAN, SNMP can work.
D). Configuration is correct
* It is not correct:Allow Noneblocks SNMP and is the problem.
NEW QUESTION # 45
For security reasons, a BIG-IP Administrator needs to specify allowable IP ranges for access to the Configuration Utility (WebUI).
The exhibit shows the User Administration section of the Configuration Utility.
The administrator could not find any setting that explicitly restricts access to the Configuration Utility.
Which one of the following is a reason for that?
  • A. The administrator needs to switch to the "Advanced" view mode in order to display the relevant setting
  • B. Restricting access to the Configuration Utility can only be done from the Command Line Interface
  • C. The administrator must restrict access by IP address for SSH, which will implicitly restrict access to the Configuration Utility
  • D. To avoid locking out the administrator, recent versions of BIG-IP no longer allow restricting administrator access to the Configuration Utility by source IP address
The screenshot shown is from theUser Administrationsection of the BIG-IP GUI.
This section controls:
* Root and Admin passwords
* SSH Access
* SSH IP Allow settings
However,it does not contain any controls for restricting access to the WebUI (TMUI).
BIG-IP does not provide TMUI access restrictions from this part of the GUI.
Access to the web-based Configuration Utility is controlled by thehttpd allow list, configured through TMSH:
tmsh modify /sys httpd allow { <IP/subnet> }
This setting is not displayed in the User Administration panel, and in many BIG-IP versions, the httpd allow list isonly configurable from the CLI, not the GUI.
Therefore, the administrator cannot find the setting in the screen shown because:
* TMUI access restriction isnotlocated in this GUI section
* It must be configured usingtmshunder/sys httpd allow
This is whyOption Ais correct.
NEW QUESTION # 46
The BIG-IP Administrator uses Secure Copy Protocol (SCP) to upload a TMOS image to the/shared/images/ directory in preparation for a TMOS upgrade.
After the upload is completed, what will the system dobeforethe image is shown in the GUI under:
System - Software Management - Image List?
  • A. The system performs a reboot into a new partition
  • B. The system copies the image to /var/local/images/
  • C. The system verifies the internal checksum
When a TMOS image (.iso file) is uploaded into the/shared/images/directory, the BIG-IP performs an internal validation step before the ISO appears in the GUI.
1. The system verifies the internal checksum
* BIG-IP automatically reads the embedded checksum inside the ISO file
* Verifies integrity of the uploaded image
* Confirms the file is not corrupted or incomplete
* Ensures the image is a valid F5 TMOS software image
Only after this checksum verification succeeds does the image appear under:
System # Software Management # Image List
A). The system performs a reboot into a new partition
* Uploading an ISO file never triggers a reboot.
C). The system copies the image to /var/local/images/
* All valid TMOS images remain in/shared/images/.
* No copying occurs.
NEW QUESTION # 47
There is always a fear of losing F5CAB1 exam and causes you loss of money and waste time on some unless materials. However, these risks will never exist in our F5CAB1 exam materials. Your money and exam attempt is bound to award you a sure and definite success with 100% money back guarantee. You can claim for the refund of money if you do not succeed and achieve your target. Our F5CAB1 exam materials have a most reliable guarantee. We ensure you that you will be paid back in full without any deduction and you can easily pass the F5CAB1 Exam by using our F5CAB1 dumps. Moreover, you will get all the updated F5CAB1 questions with verified answers. If you want to prepare yourself for the real exam, then it is one of the most effect ways to improve your F5CAB1 exam preparation level.
Premium F5CAB1 Exam: https://www.examdumpsvce.com/F5CAB1-valid-exam-dumps.html
