[Hardware] GitHub GitHub-Advanced-Security Test Sample Online: GitHub Advanced Security GHA
104
Hardware GitHub GitHub-Advanced-Security Test Sample Online: GitHub Advanced Security GHA
Posted at 1/16/2026 07:53:22      View216 | Replies3        Print      Only Author   [Copy Link] 1#
P.S. Free & New GitHub-Advanced-Security dumps are available on Google Drive shared by TestPassed: https://drive.google.com/open?id=118L9LGQCauFXQqMyQuByr5gKNc3Fekrl
Up to 1 year of free updates of GitHub GitHub-Advanced-Security exam questions are also available at TestPassed. To test the features of our product before buying, you may also try a free demo. It is not difficult to clear the GitHub-Advanced-Security certification exam if you have actual exam questions of at your disposal. Why then wait? Visit and download GitHub GitHub-Advanced-Security updated exam questions right away to start the process of cracking your test in one go.
GitHub GitHub-Advanced-Security Exam Syllabus Topics:
  • Use code scanning with CodeQL: This section of the exam measures skills of a DevSecOps Engineer and covers working with CodeQL to write or customize queries for deeper semantic analysis. Candidates should demonstrate how to configure CodeQL workflows, understand query suites, and interpret CodeQL alerts to uncover complex code issues beyond standard static analysis.
  • Configure and use code scanning: This section of the exam measures skills of a DevSecOps Engineer and covers enabling and customizing GitHub code scanning with built?in or marketplace rulesets. Examinees must know how to interpret scan results, triage findings, and configure exclusion or override settings to reduce noise and focus on high?priority vulnerabilities.
  • Configure and use dependency management: This section of the exam measures skills of a DevSecOps Engineer and covers configuring dependency management workflows to identify and remediate vulnerable or outdated packages. Candidates will show how to enable Dependabot for version updates, review dependency alerts, and integrate these tools into automated CI
  • CD pipelines to maintain secure software supply chains.
  • Describe GitHub Advanced Security best practices: This section of the exam measures skills of a GitHub Administrator and covers outlining recommended strategies for adopting GitHub Advanced Security at scale. Test?takers will explain how to apply security policies, enforce branch protections, shift left security checks, and use metrics from GHAS tools to continuously improve an organizations security posture.
Pass Guaranteed Quiz Perfect GitHub-Advanced-Security - GitHub Advanced Security GHAS Exam Test Sample OnlineTestPassed provides proprietary preparation guides for the certification exam offered by the GitHub-Advanced-Security exam dumps. In addition to containing numerous questions similar to the GitHub-Advanced-Security exam, the GitHub-Advanced-Security Exam Questions are a great way to prepare for the GitHub-Advanced-Security exam dumps. The GitHub GitHub-Advanced-Security mock exam setup can be configured to a particular style and arrive at unique questions.
GitHub Advanced Security GHAS Exam Sample Questions (Q27-Q32):NEW QUESTION # 27
Which of the following benefits do code scanning, secret scanning, and dependency review provide?
  • A. Search for potential security vulnerabilities, detect secrets, and show the full impact of changes to dependencies
  • B. Automatically raise pull requests, which reduces your exposure to older versions of dependencies
  • C. Confidentially report security vulnerabilities and privately discuss and fix security vulnerabilities in your repository's code
  • D. View alerts about dependencies that are known to contain security vulnerabilities
These three features provide a complete layer of defense:
* Code scanningidentifies security flaws in your source code
* Secret scanningdetects exposed credentials
* Dependency reviewshows the impact of package changes during a pull request Together, they give developers actionable insight into risk and coverage throughout the SDLC.
NEW QUESTION # 28
Which syntax in a query suite tells CodeQL to look for one or more specified .ql files?
  • A. qlpack
  • B. qls
  • C. query
In aquery suite(a .qls file), the **query** key is used to specify the paths to one or more .ql files that should be included in the suite.
Example:
- query: path/to/query.ql
* qls is the file format.
* qlpack is used for packaging queries, not in suite syntax.
NEW QUESTION # 29
Which of the following formats are used to describe a Dependabot alert? (Each answer presents a complete solution. Choose two.)
  • A. Common Vulnerabilities and Exposures (CVE)
  • B. Exploit Prediction Scoring System (EPSS)
  • C. Common Weakness Enumeration (CWE)
  • D. Vulnerability Exploitability exchange (VEX)
Dependabot alerts utilize standardized identifiers to describe vulnerabilities:
* CVE (Common Vulnerabilities and Exposures):A widely recognized identifier for publicly known cybersecurity vulnerabilities.
* CWE (Common Weakness Enumeration):A category system for software weaknesses and vulnerabilities.
These identifiers help developers understand the nature of the vulnerabilities and facilitate the search for more information or remediation strategies.
NEW QUESTION # 30
Which CodeQL query suite provides queries of lower severity than the default query suite?
  • A. github/codeql/cpp/ql/src@main
  • B. github/codeql-go/ql/src@main
  • C. security-extended
Thesecurity-extendedquery suite includes additional CodeQL queries that detectlower severity issuesthan those in the default security-and-quality suite.
It's often used when projects want broader visibility into code hygiene and potential weak spots beyond critical vulnerabilities.
The other options listed arepaths to language packs, not query suites themselves.
NEW QUESTION # 31
Which of the following workflow events would trigger a dependency review? (Each answer presents a complete solution. Choose two.)
  • A. trigger
  • B. pull_request
  • C. commit
  • D. workflow_dispatch
Dependency review is triggered by specific events in GitHub workflows:
pull_request: When a pull request is opened, synchronized, or reopened, GitHub can analyze the changes in dependencies and provide a dependency review.
workflow_dispatch: This manual trigger allows users to initiate workflows, including those that perform dependency reviews.
The trigger and commit options are not recognized GitHub Actions events and would not initiate a dependency review.
NEW QUESTION # 32
Our GitHub-Advanced-Security study braindumps for the overwhelming majority of users provide a powerful platform for the users to share. Here, the all users of the GitHub-Advanced-Security exam questions can through own ID number to log on to the platform and other users to share and exchange, each other to solve their difficulties in study or life. The GitHub-Advanced-Security Prep Guide provides user with not only a learning environment, but also create a learning atmosphere like home. And our GitHub-Advanced-Security exam questions will help you obtain the certification for sure.
Pdf GitHub-Advanced-Security Version: https://www.testpassed.com/GitHub-Advanced-Security-still-valid-exam.html
BTW, DOWNLOAD part of TestPassed GitHub-Advanced-Security dumps from Cloud Storage: https://drive.google.com/open?id=118L9LGQCauFXQqMyQuByr5gKNc3Fekrl
Posted at 1/24/2026 18:18:34        Only Author  2#
Great content, without a doubt, I'm clicking that like button. Wishing for a smooth Fire-Inspector-II latest exam papers exam ahead. Wish me luck!
Posted at 1/25/2026 16:03:33        Only Author  3#
This article is amazing, thank you for sharing it with us! Improve your IT skills and get free Reliable practice L4M1 exam online access. Wishing you the best of luck!
Posted at 2/23/2026 02:34:06        Only Author  4#
I really appreciate your article, it has made a big impression on me. With the Latest CY0-001 exam sample, I advanced in my career and earned a salary increase. Now, it's free for everyone. Wishing you quick promotions!
