[Hardware] ACD301} & ACD301ԇ俼
88
Hardware ACD301} & ACD301ԇ俼
Posted at 1/16/2026 08:38:17      View217 | Replies3        Print      Only Author   [Copy Link] 1#
P.S. KaoGuTiGoogle DriveϷMġµACD301ԇ}죺https://drive.google.com/open?id=1cLgKOCA4seA1HV-3VgD6vCXKDsc6-9_T
KaoGuTiһܞܶAppian ACD301JCԇITИIIʿṩPoYρõAppian ACD301JCCľWվKaoGuTiṩČWYKaoGuTiYҵSИI͌I֪RоĵģƷ|ǺܺãٶҲdz졣K҂ṩľ}ǺĿԇ}Ŀܽӽģ׺һӵġxKaoGuTi100%_ͨ^ĵһ΅ӵyȱ^ߵȘIPIAppian ACD301JCԇ
KaoGuTiṩACD301}ȫČWYϣ@һ׌Чٵ֪R}쌚䡣҂ṩAppian ACD301ģMyԇ}𰸺挍ԇ}Ŀ95%ԣܱC100%ͨ^ACD301JCԇMV󡣮˽҂aƷĿɿ֮qԥُIAppian ACD301õxδšIijɹȱٵġ
ACD301ԇ俼 & ACD301}YӍKaoGuTi Appian ACD301 }ȫ£ȫNx߹J Appian JCԇ؂䅢׌Mĵ挦 Appian ACD301 JCԇ@°淴ӳ Appian ԇ׃ӣ Hw˸Ҫ}, ߀µĿԇ֪Rĵһ·Lԇʹ҂ ACD301 Ӗϣ@ܕOشM˜I_µҕҰľ͘IC
µ Lead Developer ACD301 Mԇ} (Q14-Q19):} #14
You have 5 applications on your Appian platform in Production. Users are now beginning to use multiple applications across the platform, and the client wants to ensure a consistent user experience across all applications.
You notice that some applications use rich text, some use section layouts, and others use box layouts. The result is that each application has a different color and size for the header.
What would you recommend to ensure consistency across the platform?
  • A. In the common application, create one rule for each application, and update each application to reference its respective rule.
  • B. In each individual application, create a rule that can be used for section headers, and update each application to reference its respective rule.
  • C. In the common application, create a rule that can be used across the platform for section headers, and update each application to reference this new rule.
  • D. Create constants for text size and color, and update each section to reference these values.
𰸣C
}f
Comprehensive and Detailed In-Depth Explanation:As an Appian Lead Developer, ensuring a consistent user experience across multiple applications on the Appian platform involves centralizing reusable components and adhering to Appian's design governance principles. The client's concern about inconsistent headers (e.g., different colors, sizes, layouts) across applications using rich text, section layouts, and box layouts requires a scalable, maintainable solution. Let's evaluate each option:
* A. Create constants for text size and color, and update each section to reference these values:Using constants (e.g., cons!TEXT_SIZE and cons!HEADER_COLOR) is a good practice for managing values, but it doesn't address layout consistency (e.g., rich text vs. section layouts vs. box layouts).
Constants alone can't enforce uniform header design across applications, as they don't encapsulate layout logic (e.g., a!sectionLayout() vs. a!richTextDisplayField()). This approach would require manual updates to each application's components, increasing maintenance overhead and still risking inconsistency. Appian's documentation recommends using rules for reusable UI components, not just constants, making this insufficient.
* B. In the common application, create a rule that can be used across the platform for section headers, and update each application to reference this new rule:This is the best recommendation. Appian supports a
"common application" (often called a shared or utility application) to store reusable objects like expression rules, which can define consistent header designs (e.g., rule!CommonHeader(size:
"LARGE", color: "PRIMARY")). By creating a single rule for headers and referencing it across all 5 applications, you ensure uniformity in layout, color, and size (e.g., using a!sectionLayout() or a!
boxLayout() consistently). Appian's design best practices emphasize centralizing UI components in a common application to reduce duplication, enforce standards, and simplify maintenance-perfect for achieving a consistent user experience.
* C. In the common application, create one rule for each application, and update each application to reference its respective rule:This approach creates separate header rules for each application (e.g., rule!
App1Header, rule!App2Header), which contradicts the goal of consistency. While housed in the common application, it introduces variability (e.g., different colors or sizes per rule), defeating the purpose. Appian's governance guidelines advocate for a single, shared rule to maintain uniformity, making this less efficient and unnecessary.
* D. In each individual application, create a rule that can be used for section headers, and update each application to reference its respective rule:Creating separate rules in each application (e.g., rule!
App1Header in App 1, rule!App2Header in App 2) leads to duplication and inconsistency, as each rule could differ in design. This approach increases maintenance effort and risks diverging styles, violating the client's requirement for a"consistent user experience." Appian's best practices discourage duplicating UI logic, favoring centralized rules in a common application instead.
Conclusion: Creating a rule in the common application for section headers and referencing it across the platform (B) ensures consistency in header design (color, size, layout) while minimizing duplication and maintenance. This leverages Appian's application architecture for shared objects, aligning with Lead Developer standards for UI governance.
* Appian Documentation: "Designing for Consistency Across Applications" (Common Application Best Practices).
* Appian Lead Developer Certification: UI Design Module (Reusable Components and Rules).
* Appian Best Practices: "Maintaining User Experience Consistency" (Centralized UI Rules).
The best way to ensure consistency across the platform is to create a rule that can be used across the platform for section headers. This rule can be created in the common application, and then each application can be updated to reference this rule. This will ensure that all of the applications use the same color and size for the header, which will provide a consistent user experience.
The other options are not as effective. Option A, creating constants for text size and color, and updating each section to reference these values, would require updating each section in each application. This would be a lot of work, and it would be easy to make mistakes. Option C, creating one rule for each application, would also require updating each application. This would be less work than option A, but it would still be a lot of work, and it would be easy to make mistakes. Option D, creating a rule in each individual application, would not ensure consistency across the platform. Each application would have its own rule, and the rules could be different. This would not provide a consistent user experience.
Best Practices:
* When designing a platform, it is important to consider the user experience. A consistent user experience will make it easier for users to learn and use the platform.
* When creating rules, it is important to use them consistently across the platform. This will ensure that the platform has a consistent look and feel.
* When updating the platform, it is important to test the changes to ensure that they do not break the user experience.
} #15
You are the lead developer for an Appian project, in a backlog refinement meeting. You are presented with the following user story:
"As a restaurant customer, I need to be able to place my food order online to avoid waiting in line for takeout." Which two functional acceptance criteria would you consider 'good'?
  • A. The user will receive an email notification when their order is completed.
  • B. The user cannot submit the form without filling out all required fields.
  • C. The system must handle up to 500 unique orders per day.
  • D. The user will click Save, and the order information will be saved in the ORDER table and have audit history.
𰸣B,D
}f
Comprehensive and Detailed In-Depth Explanation:As an Appian Lead Developer, defining "good" functional acceptance criteria for a user story requires ensuring they are specific, testable, and directly tied to the user's need (placing an online food order to avoid waiting in line). Good criteria focus on functionality, usability, and reliability, aligning with Appian's Agile and design best practices. Let's evaluate each option:
* A. The user will click Save, and the order information will be saved in the ORDER table and have audit history:This is a "good" criterion. It directly validates the core functionality of the user story-placing an order online. Saving order data in the ORDER table (likely via a process model or Data Store Entity) ensures persistence, and audit history (e.g., using Appian's audit logs or database triggers) tracks changes, supporting traceability and compliance. This is specific, testable (e.g., verify data in the table and logs), and essential for the user's goal, aligning with Appian's data management and user experience guidelines.
* B. The user will receive an email notification when their order is completed:While useful, this is a
"nice-to-have" enhancement, not a core requirement of the user story. The story focuses on placing an order online to avoid waiting, not on completion notifications. Email notifications add value but aren't essential for validating the primary functionality. Appian's user story best practices prioritize criteria tied to the main user need, making this secondary and not "good" in this context.
* C. The system must handle up to 500 unique orders per day:This is a non-functional requirement (performance/scalability), not a functional acceptance criterion. It describes system capacity, not specific user behavior or functionality. While important for design, it's not directly testable for the user story's outcome (placing an order) and isn't tied to the user's experience. Appian's Agile methodologies separate functional and non-functional requirements, making this less relevant as a
"good" criterion here.
* D. The user cannot submit the form without filling out all required fields:This is a "good" criterion. It ensures data integrity and usability by preventing incomplete orders, directly supporting the user's ability to place a valid online order. In Appian, this can be implemented using form validation (e.g., required attributes in SAIL interfaces or process model validations), making it specific, testable (e.g., verify form submission fails with missing fields), and critical for a reliable user experience. This aligns with Appian's UI design and user story validation standards.
Conclusion: The two "good" functional acceptance criteria are A (order saved with audit history) and D (required fields enforced). These directly validate the user story's functionality (placing a valid order online), are testable, and ensure a reliable, user-friendly experience-aligning with Appian's Agile and design best practices for user stories.
* Appian Documentation: "Writing Effective User Stories and Acceptance Criteria" (Functional Requirements).
* Appian Lead Developer Certification: Agile Development Module (Acceptance Criteria Best Practices).
* Appian Best Practices: "Designing User Interfaces in Appian" (Form Validation and Data Persistence).
} #16
𰸣C
}f
A . Create constants for text size and color, and update each section to reference these values:
Using constants (e.g., cons!TEXT_SIZE and cons!HEADER_COLOR) is a good practice for managing values, but it doesn't address layout consistency (e.g., rich text vs. section layouts vs. box layouts). Constants alone can't enforce uniform header design across applications, as they don't encapsulate layout logic (e.g., a!sectionLayout() vs. a!richTextDisplayField()). This approach would require manual updates to each application's components, increasing maintenance overhead and still risking inconsistency. Appian's documentation recommends using rules for reusable UI components, not just constants, making this insufficient.
B . In the common application, create a rule that can be used across the platform for section headers, and update each application to reference this new rule:
This is the best recommendation. Appian supports a "common application" (often called a shared or utility application) to store reusable objects like expression rules, which can define consistent header designs (e.g., rule!CommonHeader(size: "LARGE", color: "PRIMARY")). By creating a single rule for headers and referencing it across all 5 applications, you ensure uniformity in layout, color, and size (e.g., using a!sectionLayout() or a!boxLayout() consistently). Appian's design best practices emphasize centralizing UI components in a common application to reduce duplication, enforce standards, and simplify maintenance-perfect for achieving a consistent user experience.
C . In the common application, create one rule for each application, and update each application to reference its respective rule:
This approach creates separate header rules for each application (e.g., rule!App1Header, rule!App2Header), which contradicts the goal of consistency. While housed in the common application, it introduces variability (e.g., different colors or sizes per rule), defeating the purpose. Appian's governance guidelines advocate for a single, shared rule to maintain uniformity, making this less efficient and unnecessary.
D . In each individual application, create a rule that can be used for section headers, and update each application to reference its respective rule:
Creating separate rules in each application (e.g., rule!App1Header in App 1, rule!App2Header in App 2) leads to duplication and inconsistency, as each rule could differ in design. This approach increases maintenance effort and risks diverging styles, violating the client's requirement for a "consistent user experience." Appian's best practices discourage duplicating UI logic, favoring centralized rules in a common application instead.
Best Practices:
} #17
You are reviewing log files that can be accessed in Appian to monitor and troubleshoot platform-based issues.
For each type of log file, match the corresponding Information that it provides. Each description will either be used once, or not at all.
Note: To change your responses, you may deselect your response by clicking the blank space at the top of the selection list.
𰸣
}f
* design_errors.csv # Errors in start forms, task forms, record lists, enabled environments
* devops_infrastructure.csv # Metrics such as the total time spent evaluating a plug-in function
* login-audit.csv # Inbound requests using HTTP basic authentication
Comprehensive and Detailed In-Depth Explanation:Appian provides various log files to monitor and troubleshoot platform issues, accessible through the Administration Console or exported as CSV files. These logs capture different aspects of system performance, security, and user interactions. The Appian Monitoring and Troubleshooting Guide details the purpose of each log file, enabling accurate matching.
* design_errors.csv # Errors in start forms, task forms, record lists, enabled environments:The design_errors.csv log file is specifically designed to track errors related to the design and runtime behavior of Appian objects such as start forms, task forms, and record lists. It alsoincludes information about issues in enabled environments, making it the appropriate match. This log helps developers identify and resolve UI or configuration errors, aligning with its purpose of capturing design-time and runtime issues.
* devops_infrastructure.csv # Metrics such as the total time spent evaluating a plug-in function:The devops_infrastructure.csv log file provides infrastructure and performance metrics for Appian Cloud instances. It includes data on system performance, such as the time spent evaluating plug-in functions, which is critical for optimizing custom integrations. This matches the description, as it focuses on operational metrics rather than errors or security events, consistent with Appian's infrastructure monitoring approach.
* login-audit.csv # Inbound requests using HTTP basic authentication:The login-audit.csv log file tracks user authentication and login activities, including details about inbound requests using HTTP basic authentication. This log is used to monitor security events, such as successful and failed login attempts, making it the best fit for this description. Appian's security logging emphasizes audit trails for authentication, aligning with this use case.
Unused Description:
* Number of enabled environments:This description is not matched to any log file. While it could theoretically relate to system configuration logs, none of the listed files (design_errors.csv, devops_infrastructure.csv, login-audit.csv) are specifically designed to report the number of enabled environments. This might be tracked in a separate administrative report or configuration log not listed here.
Matching Rationale:
* Each description is either used once or not at all, as specified. The matches are based on Appian's documented log file purposes: design_errors.csv for design-related errors, devops_infrastructure.csv for performance metrics, and login-audit.csv for authentication details.
* The unused description suggests the question allows for some descriptions to remain unmatched, reflecting real-world variability in log file content.
References:Appian Documentation - Monitoring and Troubleshooting Guide, Appian Administration Console - Log File Reference, Appian Lead Developer Training - Platform Diagnostics.
} #18
As part of an upcoming release of an application, a new nullable field is added to a table that contains customer data. The new field is used by a report in the upcoming release and is calculated using data from another table.
Which two actions should you consider when creating the script to add the new field?
  • A. Create a rollback script that clears the data from the field.
  • B. Create a script that adds the field and then populates it.
  • C. Add a view that joins the customer data to the data used in calculation.
  • D. Create a script that adds the field and leaves it null.
  • E. Create a rollback script that removes the field.
𰸣B,E
}f
Comprehensive and Detailed In-Depth Explanation:As an Appian Lead Developer, adding a new nullable field to a database table for an upcoming release requires careful planning to ensure data integrity, report functionality, and rollback capability. The field is used in a report and calculated from another table, so the script must handle both deployment and potential reversibility. Let's evaluate each option:
* A. Create a script that adds the field and leaves it null:Adding a nullable field and leaving it null is technically feasible (e.g., using ALTER TABLE ADD COLUMN in SQL), but it doesn't address the report's need for calculated data. Since the field is used in a report and calculated from another table, leaving it null risks incomplete or incorrect reporting until populated, delaying functionality. Appian's data management best practices recommend populating data during deployment for immediate usability, making this insufficient as a standalone action.
* B. Create a rollback script that removes the field:This is a critical action. In Appian, database changes (e.g., adding a field) must be reversible in case of deployment failure or rollback needs (e.g., during testing or PROD issues). A rollback script that removes the field (e.g., ALTER TABLE DROP COLUMN) ensures the database can return to its original state, minimizing risk. Appian's deployment guidelines emphasize rollback scripts for schema changes, making this essential for safe releases.
* C. Create a script that adds the field and then populates it:This is also essential. Since the field is nullable, calculated from another table, and used in a report, populating it during deployment ensures immediate functionality. The script can use SQL(e.g., UPDATE table SET new_field = (SELECT calculated_value FROM other_table WHERE condition)) to populate data, aligning with Appian's data fabric principles for maintaining data consistency. Appian's documentation recommends populating new fields during deployment for reporting accuracy, making this a key action.
* D. Create a rollback script that clears the data from the field:Clearing data (e.g., UPDATE table SET new_field = NULL) is less effective than removing the field entirely. If the deployment fails, the field's existence with null values could confuse reports or processes, requiring additional cleanup. Appian's rollback strategies favor reverting schema changes completely (removing the field) rather than leaving it with nulls, making this less reliable and unnecessary compared to B.
* E. Add a view that joins the customer data to the data used in calculation:Creating a view (e.g., CREATE VIEW customer_report AS SELECT ... FROM customer_table JOIN other_table ON ...) is useful for reporting but isn't a prerequisite for adding the field. The scenario focuses on the field addition and population, not reporting structure. While a view could optimize queries, it's a secondary step, not a primary action for the script itself. Appian's data modeling best practices suggest views as post-deployment optimizations, not script requirements.
Conclusion: The two actions to consider are B (create a rollback script that removes the field) and C (create a script that adds the field and then populates it). These ensure the field is added with data for immediate report usability and provide a safe rollback option, aligning with Appian's deployment and data management standards for schema changes.
* Appian Documentation: "Database Schema Changes" (Adding Fields and Rollback Scripts).
* Appian Lead Developer Certification: Data Management Module (Schema Deployment Strategies).
* Appian Best Practices: "Managing Data Changes in Production" (Populating and Rolling Back Fields).
} #19
׌^øЩ ACD301 JCԇ@ȡ Appian JCÿλxITИIĹˆTؽ֮·ֻЫ@ȡ˹˾Ҫ@Cȿɫ@üнwęC Appian ڿ}ԇۺԴ춘IIĴ֧֡ǧҹ˾Ӛ Appian ˜ʁṩһɿĆTIu⣬ʮғԼ}Ĺ˾Ҳdzه Appian ACD301 }Դ_T߂ļܹסeԞ鹫˾ʡĕrg_N
ACD301ԇ俼: https://www.kaoguti.com/ACD301_exam-pdf.html
ܶ˶ͨ^ACD301TCտԇʹԼĹDž^ ACD301 JCԇ˶֪ͨ^ACD301JCԇǺܺΣϮǰĿ򞣬KaoGuTi AppianACD301ԇJCԇ}ļgF꠵κ׃rµĆ}ʹ𰸣҂ҲǽÑĆ}ֵһЩhĶ_KaoGuTi AppianACD301ԇJCyԇYϣʹ҂KaoGuTiʼKߵƷ|⣬ԇrwBԇTȵȣ@Щһ̶Ӱ푵KACD301 ԇYKaoGuTi ACD301ԇ俼ǂܶITPJCԇĿṩľWվ
Ŷѻ֪꣬Ҫд°lܶ˶ͨ^ACD301TCտԇʹԼĹDž^ ACD301 JCԇ˶֪ͨ^ACD301JCԇǺܺΣϮǰĿ򞣬KaoGuTi AppianACD301ԇJCԇ}ļgF꠵κ׃rµĆ}ʹ𰸣҂ҲǽÑĆ}ֵһЩhĶ_KaoGuTi AppianACD301ԇJCyԇYϣʹ҂KaoGuTiʼKߵƷ|
ACD301}µAppianJCACD301ԇָ⣬ԇrwBԇTȵȣ@Щһ̶Ӱ푵KACD301 ԇYKaoGuTiǂܶITPJCԇĿṩľWվھWϿܶѶ뿼Lead DeveloperڌACD301}@ƿ}ĺyҵܶѶʾ]ҵ԰^Ŀ}
Posted at 1/16/2026 09:39:23        Only Author  2#
The content is just that goodinstant like from me. The C-P2WIE-2404 latest visual cert test helped me achieve career growth with a promotion and pay raise. Now, it's available for free. Best of luck to everyone!
Posted at 2/14/2026 23:45:57        Only Author  3#
Marketing-Cloud-Email-SpecialistԇYˆ}ϤϡoϤΥǥӑƤ¤Marketing-Cloud-Email-SpecialistԇYȥȤϡΘIǤ赤ģǤꡢޤޤʳ̶ȤԇYY򤱤_ʥƥĤ˜Ƥޤ¤Marketing-Cloud-Email-SpecialistԇYȥȤνY@ۤ@٤ΤǡԇYYߤ98ϤĿˤo¤_ɤޤޤMarketing-Cloud-Email-SpecialistƥȥפˤꡢNν̲ĤξȤdz˸ߤȤ^ޤ
Posted at 2/21/2026 04:42:04        Only Author  4#
The article is so insightful and inspiring, thanks for sharing! Wishing you all the best on your exams! Free DevOps-SRE test syllabus questions available now!
