[General] C-S4TM-2023ƥȡC-S4TM-2023`
87
General C-S4TM-2023ƥȡC-S4TM-2023`
Posted at 1/16/2026 10:04:20      View127 | Replies0        Print      Only Author   [Copy Link] 1#
oϤǥ饦ɥȥ`¤Tech4Exam C-S4TM-2023 PDFפ`ɤ룺https://drive.google.com/open?id=1h8LSi-t5Z_mM5g0lxiKzSNxxUPH51koY
Tech4ExamSAPJ^C-S4TM-2023ԇYĩ`ΥȤ_k}ϤȤƤSAPJ^ԇYYmäޤTech4Examṩޥĩ`뤬ԵĤʤΤǾFؤʕrgȥͥ륮`򹝼sǤޤ
SAP C-S4TM-2023 JԇYγ}죺
ȥԥå}
ȥԥå 1
  • ݔӋ: ǤΥ֥ȥԥåˤϡͥåȥ`Υåȥåסץե똋ɡԄӋΤ VSR ץƥޥ`{ʤɤꡢϤ٤ƄʵĤݔӋ˲ǷǤ
ȥԥå 2
  • ` ι: ΥȥԥåǤϡERP ƥοԤ󻯤pΥ٩`٤뤿Υ` ԭtumäˤĤhޤ
ȥԥå 3
  • SAP Transportation Management θҪȻA: ΥȥԥåǤϡⲿƥȽMzߥƥ򺬤ࡢSAP Transportation Management һĤʥץșCIˤĤhޤޤݔͥȤιˤĤƤhޤ
ȥԥå 4
  • ޥ` ǩ`: ǩ`ؔեǩ`򺬤ޥ` ǩ`ζxϡĤݔ͹˲ǷǤꡢhޤ
ԇYΜʂ䷽-˩`C-S4TM-2023ƥԇY-һC-S4TM-2023`Tech4ExamC-S4TM-2023ѧ̲Ĥϳ˸ߤϸʤS֤Ƥ뤳Ȥ狼äƤޤ̲Ĥ|θߤˤΤǤ뤳Ȥg`ޤ󡣺ϸʤϡC-S4TM-2023ȥ`˥󥰥ե^Ҫʘ˜ʤǤȤΤϳRΆ}Ǥ̲ĤθߤϸʤϡuƷ٤ƤˡC-S4TM-2023ԇY˺ϸ񤷡vBJȡä뤿˷dz˄ĤäǤ뤳ȤζޤΤᡢ礫C-S4TM-2023ԇY}ُ뤹ȡ̕rgJYȡäǤޤ
SAP Certified Associate - SAP S/4HANA Cloud Private Edition - Transportation Management J C-S4TM-2023 ԇY} (Q79-Q84):| # 79
To which of the following can you assign a dimensional weight profile?
  • A. Charge type
  • B. Calculation base
  • C. Calculation profile
  • D. Charges profile
⣺C
| # 80
You have defined several means of transport MT combinations.
If food is loaded on the truck, you cannot transport hazardous goods in a coupled trailer, furthermore, these hazardous goods cannot be transported on certain means of transport.
Which of the following incmpatibility types do you use to model this scenario? (2 correct answer)
  • A. FU - FU ( compartment level)
  • B. FU - FU (vehicle level)
  • C. FU - vehicle resource
  • D. FU - FU (MT combination level)
⣺AB
| # 81
You want to use advanced shipping and receiving. What must you define?
Note: There are 2 correct answers to this question
  • A. Location with type 1200 (loading point)
  • B. Location with type 1011 (vendor)
  • C. Location with type 1001 (production plant)
  • D. Location with type 1003 (shipping point)
⣺BD
| # 82
A discrepancy is configured with tolerance and blocking.
Which of the following blocks are set when a discrepancy outside the configured tolerance is reported for a freight order? Note: There are 3 correct answers to this question.
  • A. An invoicing block for the freight unit
  • B. An execution block for the freight unit
  • C. An invoicing block for the freight order
  • D. A planning block for the freight order
  • E. An execution block for the freight order
⣺BCE
h
Freight Order Management
| # 83
You add an assessorial charge to a freight order after the freight settlement document (FSD) has been posted and accruals have been booked in SAP Materials Management. The background report to create FSDs determines change strategy "Reverse and Repost with new FSD" for this freight order. What will you see in SAP Transportation Management and SAP Materials Management?
Note; There are 2 correct answers to this question
  • A. 3 service entry sheets in SAP Materials Management
  • B. 1 purchase order in SAP Materials Management
  • C. 3 FSDs in SAP Transportation Management
  • D. 2 FSDs and 1 credit memo in SAP Transportation Management
⣺CD
| # 84
աǤθϤ꼤T֪Rʤиʵλռ뤳ȤǤ뤳Ȥ⤢ޤƥC-S4TM-2023J˺ϸ񤹤ȡһηҰܤˤʤꡢPЈǸϤ΃λԤ@äǤޤ C-S4TM-2023ѧ̲Ĥُ뤹ȡC-S4TM-2023ƥȤ˥`˺ϸ񤷤ޤSAPuƷ϶यߤᡢƥȤΜʂ򤹤ΤmǤ C-S4TM-2023ѧʂϡһΌTҥ`ˤäƥѥ뤵졢gHԇYܽӤ˥󥯤Ƥޤ
C-S4TM-2023`: https://www.tech4exam.com/C-S4TM-2023-pass-shiken.html
