[Hardware] Microsoft AZ-104 Certification Practice | AZ-104 Pass Guaranteed
90
【Hardware】 Microsoft AZ-104 Certification Practice | AZ-104 Pass Guaranteed
Posted at 1/16/2026 11:08:53      View:197 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free & New AZ-104 dumps are available on Google Drive shared by Actual4test: https://drive.google.com/open?id=1dbZ2BAatTjbMY8iQJPRPV7XJlhYMBf2r
This is a Microsoft AZ-104 practice exam software for Windows computers. This AZ-104 practice test will be similar to the actual AZ-104 exam. If user wish to test the Microsoft Azure Administrator (AZ-104) study material before joining Actual4test, they may do so with a free sample trial. This AZ-104 Exam simulation software can be readily installed on Windows-based computers and laptops. Since it is desktop-based AZ-104 practice exam software, it is not necessary to connect to the internet to use it.
Microsoft AZ-104 Certification Exam is designed for individuals who have experience managing and administering Azure cloud services. Microsoft Azure Administrator certification validates the skills and knowledge necessary to manage Azure resources, monitor and optimize Azure services, and implement security and governance measures. AZ-104 exam covers a variety of topics, including Azure identity and governance, Azure compute, Azure storage, Azure networking, and Azure monitoring and optimization.
Module 2: Storage Implementation and ManagementThe second domain throws light on the Azure implementation and storage, including the administration of storage accounts, setting up blob storage alongside Azure files, and handling data management tasks for Azure Storage. The details include the replication implementation, Azure account generation, import as well as export from Azure jobs, utilizing AZCopy, the configuration of blob object replication and lifecycle management, etc.
What is the duration, language, and format of AZ-104:Microsoft Azure Administrator Exam
  • Type of Questions: This test format is multiple choice.
  • Number of Questions: 40 to 60 questions(Since Microsoft does not publish this information, the number of exam questions may change without notice.)
Free PDF Quiz 2026 Microsoft The Best AZ-104 Certification PracticeAs long as you study with our AZ-104 exam braindumps, the benefits are more than you can consider, you are bound to pass the AZ-104 exam, let along various opportunities like getting promotion, being respected by surrounding people on your profession’s perspective. All those beneficial outcomes come from your decision of our AZ-104 simulating questions. We are willing to be your side offering whatever you need compared to other exam materials that malfunctioning in the market.
Microsoft Azure Administrator Sample Questions (Q25-Q30):NEW QUESTION # 25
You implement the planned changes for NSG1 and NSG2.
NEW QUESTION # 26
You have two Azure App Service apps named App1 and App2. Each app has a production deployment slot and a test deployment slot. The Backup Configuration settings for the production slots are shown in the following table.
On January 15, 2021, App1 will have only one backup in storage. Yes, this is correct. According to the table, App1 has a backup every 1 day, starting from January 6, 2021, with a retention of 0 days. This means that each backup will be deleted after 0 days, or as soon as the next backup is created. Therefore, on January 15,
2021, App1 will have only one backup in storage, which is the one created on that day1.
On February 6, 2021, you can access the backup of the App2 test slot from January 15, 2021. No, this is not correct. According to the table, App2 has a backup every 1 day, starting from January 6, 2021, with a retention of 30 days. This means that each backup will be deleted after 30 days, or when the storage limit is reached. However, the table also shows that App2 has a setting of "Keep at least one backup" set to Yes. This means that the oldest backup will be retained even if it exceeds the retention period or the storage limit2.
Therefore, on February 6, 2021, you can access the backup of the App2 test slot from January 6, 2021, but not from January 15, 2021.
On January 15, 2021, you can restore the App2 production slot backup from January 6 to the App2 test slot. Yes, this is correct. According to the web search results, you can restore a backup by overwriting an existing app or by restoring to a new app or slot3. You can also restore a backup from a different slot or app as long as they are in the same subscription and region4. Therefore, on January 15, 2021, you can restore the App2 production slot backup from January 6 to the App2 test slot.
NEW QUESTION # 27
You have a windows 11 device named Device1 and an Azure subscription that contains the resources shown in the following table.
Device 1 has Azure PowerShell and Azure Command-Line Interface (CLI) installed.
From Device1, you need to establish a Remote Desktop connection to VM1.
https://learn.microsoft.com/en-u ... tive-client-windows
NEW QUESTION # 28
You have an Azure Storage accounts as shown in the following exhibit.
NEW QUESTION # 29
You have an Azure Active Directory (Azure AD) tenant named adatum.com. Adatum.com contains the groups in the following table.
You create two user accounts that are configured as shown in the following table.
To which groups do User1 and User2 belong? To answer. select the appropriate options in the answer area.
Box 1: Group 1 only
First rule applies
Box 2: Group1 and Group2 only
Both membership rules apply.
References: https://docs.microsoft.com/en-us ... /create-collections
NEW QUESTION # 30
Our AZ-104 study tool can help you obtain the AZ-104 certification and own a powerful weapon for your interview. Our AZ-104 qualification test will help you gain recognition with true talents and better adapted to society. Now, I would like to give you a brief introduction in order to make you deepen your impression of our AZ-104 test guides. Our AZ-104 test guides have a higher standard of practice and are rich in content. If you are anxious about how to get AZ-104 certification, considering purchasing our AZ-104 study tool is a wise choice and you will not feel regretted. Our learning materials will successfully promote your acquisition of certification.
AZ-104 Pass Guaranteed: https://www.actual4test.com/AZ-104_examcollection.html
What's more, part of that Actual4test AZ-104 dumps now are free: https://drive.google.com/open?id=1dbZ2BAatTjbMY8iQJPRPV7XJlhYMBf2r
Posted at 2/12/2026 13:19:08        Only Author  2#
弊社はCIPT問題集の英語版と日本語版をリリースしています。英語版と日本語版の内容は同じですけど、言語だけ違いがあります。それなので、CIPTに関する英語試験や日本語試験に参加する予定があるご客様は安心に問題集を購入できます。CIPT試験のために、気楽に準備したり、参加したりしています。その他、我々のCIPT日本語問題集を購入すると、英語版を送ります。
Posted at 2/23/2026 20:43:36        Only Author  3#
This content is exceptional—clicking like now. New study ACNS questions has great content, and it’s provided to you without any fees.
