1z0-1104-25題庫更新資訊 & 1z0-1104-25真題
Posted at 1/16/2026 12:28:04
BONUS!!! 免費下載VCESoft 1z0-1104-25考試題庫的完整版:https://drive.google.com/open?id=1VdVFp-L8Q2uYWhOlsEKjSxqXBrukDNCK
近來,隨著IT技術的不斷快速發展,學習IT技術的人越來越多。這也導致在IT行業工作的人越來越多。於是,IT行業的競爭愈發激烈了。同樣在IT行業工作,並且有著IT夢的你,肯定不希望被別人趕上甚至超過吧?那麼,這就需要你不斷提升自己的技能,向別人證明你自己的實力。那麼怎樣才能證明你自己的能力呢?越來越多的人選擇參加IT認定考試取得認證資格來證明自己的實力。你也想获得认证资格吗?首先来参加Oracleの1z0-1104-25认定考试吧。这是Oracle的最重要的考试,同时也是被业界广泛认证的资格。
Oracle 1z0-1104-25 考試大綱:| 主題 | 簡介 | | 主題 1 | - Detecting, Remediating, and Monitoring OCI Resources: This section of the exam measures the skills of OCI Administrators and emphasizes monitoring and maintaining security posture across cloud resources. It focuses on the use of Cloud Guard, security zones, and the Security Advisor. Candidates also need to understand how to identify rogue users with threat intelligence, as well as use monitoring, logging, and event services for continuous visibility into performance and security.
| | 主題 2 | - Protecting Infrastructure - Network and Applications: This section of the exam measures the skills of Cloud Security Professionals and covers methods for securing networks and applications on OCI. Topics include network security groups, firewalls, and security lists, while also focusing on the use of load balancers for availability. The section further addresses the configuration of OCI certificates and web application firewalls to strengthen infrastructure security.
| | 主題 3 | - Implementing OS and Workload Protection: This section of the exam measures the skills of OCI Administrators and looks at securing workloads and operating systems. It includes the use of OCI Bastion for time-limited access, vulnerability scanning of hosts and containers, and the use of OS management for automated updates. The goal is to ensure that workloads remain resilient and well-protected.
| | 主題 4 | - OCI Security Introduction: This section of the exam measures the skills of Cloud Security Professionals and covers the basics of security in Oracle Cloud Infrastructure. It introduces the shared security responsibility model, the core principles of security design, and the use of foundational security services to secure deployments on OCI.
| | 主題 5 | - Implementing Identity and Access Management (IAM): This section of the exam measures skills of OCI Administrators and focuses on identity and access controls. It covers IAM domains, users, groups, and compartments, as well as the use of IAM policies to manage access to resources. Candidates are also tested on configuring dynamic groups, network sources, and tag-based access control, along with managing MFA, sign-on policies, and activity monitoring.
1z0-1104-25真題 & 1z0-1104-25題庫分享我們VCESoft Oracle的1z0-1104-25考試認證資料是全球所有網站不能夠媲美的,當然這不僅僅是品質的問題,我們的品質肯定是沒得說,更重要的是我們VCESoft Oracle的1z0-1104-25考試認證資料適合所有的IT考試認證,它的使用性達到各個IT領域,所以我們VCESoft網站得到很多考生的關注,他們相信我們,依賴我們,這也是我們VCESoft網站所擁有的實力所體現之處,我們的考試培訓資料能讓你買了之後不得不向你的朋友推薦,並讚不絕口,因為它真的對你們有很大的幫助。
最新的 Oracle Cloud Infrastructure 1z0-1104-25 免費考試真題 (Q15-Q20):問題 #15
"Your company is building a highly available and secure web application on OCI. Because of increasing malicious web-based attacks, the security team has mandated that web servers should not be exposed directly to the Internet.
How should you architect the solution while ensuring fault tolerance and security?
- A. Deploy at least three web servers in different fault domains within a public subnet, each with a public IP address. Deploy Web Application Firewall (WAF), and configure an origin for each public IP.
- B. Deploy at least three web servers in different fault domains within a public subnet. Use OCI Traffic Management service for DNS-based load balancing."
- C. Deploy at least three web servers in different fault domains within a private subnet. Place a public load balancer in a public subnet and configure a back-end set for all web servers. Deploy Web Application Firewall (WAF) and set the load balancer public IP address as the origin.
- D. Deploy at least three web servers in different fault domains within a private subnet. Place a public load balancer in a public subnet, but skip WAF configuration.
答案:C
問題 #16
"Your company is in the process of migrating its sensitive data to Oracle Cloud Infrastructure (OCI) and is prioritizing the strongest possible security measures. Encryption is a key part of this strategy, but you are particularly concerned about the physical security of the hardware where your encryption keys will be stored.
Which characteristic of OCI Key Management Service (KMS) helps ensure the physical security of your encryption keys?
- A. Utilization of FIPS 140-2 validated Hardware Security Modules (HSMs)"
- B. Granular customer control over key access permissions
- C. Centralized key management for simplified administration
- D. Seamless integration with other OCI services for streamlined workflows
答案:A
問題 #17
Based on the provided diagram, you have a group of critical compute instances in a private subnet that require vulnerability using the Oracle Cloud Infrastructure(OCI) Vulnerability Scanning Service (VSS).
"What additional configuration is required to enable VSS to scan instances in the private subnet
- A. Use an OCI Bastion session to establish connectivity and forward scan results from the private instances."
- B. VSS cannot scan private instances. You need to move them to a public subnet for vulnerability scanning.
- C. No additional configuration is needed. VSS can access private instances by default.
- D. Configure a service gateway in the VCN and a route rule to direct traffic for the VSS service through the gateway.
答案:D
問題 #18
Within OCI IAM identity domains, the AD Bridge component serves a critical role. How does the AD Bridge functionality specifically enhance Identity and Access Management (IAM) practices?
- A. It facilitates delegated administration, allowing authorized AD users to manage specific resources within the OCI identity domain.
- B. It directly integrates with OCI MFA providers, allowing for seamless enforcement of MFA for users authenticated through AD credentials.
- C. It strengthens access security by providing an additional layer of authentication through AD integration.
- D. It simplifies user provisioning by enabling automated synchronization of user accounts and group memberships from an existing Microsoft Active Directory (AD) environment.
答案:D
問題 #19
Task 3: Create a Master Encryption Key
Note: OCI Vault to store the key required by this task is created in the root compartment as PBI_Vault_SP Create an RSA Master Encryption Key (MEK), where:
Key name: PBT-CERT-MEK-01-<username>
For example, if your username is 99008677-lab.user01, then the MEK name should be PBT-CERT-MEK-
01990086771abuser01
Ensure you eliminate special characters from the user name.
Key shape: 4096 bits
Enter the OCID of the Master Encryption Key created in the provided text box:
答案:
解題說明:
See the solution below in Explanation.
Step 1: Access the OCI Vault
* Log in to the OCI Console.
* Navigate toIdentity & Security>Vault.
* Select the root compartment.
* Locate and click on the vault named PBI_Vault_SP.
Step 2: Create the Master Encryption Key
* In the PBI_Vault_SP vault details page, underResources, clickKeys.
* ClickCreate Key.
* Enter the following details:
* Name: Replace <username> with your username (e.g., if your username is 99008677-lab.user01, remove special characters like - and . to get 99008677labuser01, then use PBT-CERT-MEK-
0199008677labuser01).
* Key Shape: SelectRSAwith4096 bits.
* Protection Mode: SelectHSM(Hardware Security Module) if available, orSoftwareif HSM is not required (based on vault capabilities).
* Compartment: Ensure it's set to the root compartment (where PBI_Vault_SP resides).
* Leave other settings (e.g., key usage) as default unless specified.
* ClickCreate Keyand wait for the key to be generated.
Step 3: Retrieve and Enter the OCID
* After the key is created, go to theKeyssection under PBI_Vault_SP.
* Click on the key named PBT-CERT-MEK-01<username> (e.g., PBT-CERT-MEK-
* Copy theOCID(a long string starting with ocid1.key., unique to your tenancy) from the key details page.
* Enter the copied OCID exactly as it appears into the provided text box.
問題 #20
當你進入VCESoft網站,你看到每天進入VCESoft網站的人那麼多,不禁感到意外。其實這很正常的,我們VCESoft網站每天給不同的考生提供培訓資料數不勝數,他們都是利用了我們的培訓資料才順利通過考試的,說明我們的Oracle的1z0-1104-25考試認證培訓資料真起到了作用,如果你也想購買,那就不要錯過我們VCESoft網站,你一定會非常滿意的。
1z0-1104-25真題: https://www.vcesoft.com/1z0-1104-25-pdf.html
- 1z0-1104-25考題免費下載 👈 1z0-1104-25題庫資訊 🍲 1z0-1104-25題庫更新資訊 👾 在【 tw.fast2test.com 】上搜索“ 1z0-1104-25 ”並獲取免費下載1z0-1104-25考題資源
- Oracle 1z0-1104-25題庫更新資訊和Newdumpspdf - 資格考試的領導者和1z0-1104-25真題 👸 「 [url]www.newdumpspdf.com 」網站搜索▶ 1z0-1104-25 ◀並免費下載1z0-1104-25證照資訊[/url]
- 受信任的1z0-1104-25題庫更新資訊&保證Oracle 1z0-1104-25考試成功與有效的1z0-1104-25真題 🎌 ➤ [url]www.testpdf.net ⮘提供免費✔ 1z0-1104-25 ️✔️問題收集1z0-1104-25資料[/url]
- 1z0-1104-25考題資源 🐙 1z0-1104-25資料 👕 1z0-1104-25考題資源 😌 ⏩ [url]www.newdumpspdf.com ⏪是獲取“ 1z0-1104-25 ”免費下載的最佳網站1z0-1104-25考試指南[/url]
- 1z0-1104-25考題免費下載 ❇ 1z0-1104-25資料 🍌 1z0-1104-25證照資訊 🧧 ▶ [url]www.newdumpspdf.com ◀是獲取[ 1z0-1104-25 ]免費下載的最佳網站1z0-1104-25資訊[/url]
- 1z0-1104-25考試證照 🏉 1z0-1104-25考試重點 💑 1z0-1104-25考題免費下載 🔴 透過⏩ [url]www.newdumpspdf.com ⏪輕鬆獲取“ 1z0-1104-25 ”免費下載1z0-1104-25考證[/url]
- 1z0-1104-25題庫最新資訊 🙌 1z0-1104-25題庫資訊 😀 1z0-1104-25指南 🙊 透過[ [url]www.newdumpspdf.com ]輕鬆獲取( 1z0-1104-25 )免費下載1z0-1104-25題庫最新資訊[/url]
- 有效的1z0-1104-25題庫更新資訊和資格考試中的領先提供商和值得信賴的1z0-1104-25真題 🔋 到☀ [url]www.newdumpspdf.com ️☀️搜索⏩ 1z0-1104-25 ⏪輕鬆取得免費下載1z0-1104-25資訊[/url]
- 最新的1z0-1104-25學習資料 🦓 ▷ [url]www.vcesoft.com ◁上的✔ 1z0-1104-25 ️✔️免費下載只需搜尋1z0-1104-25考試證照[/url]
- 1z0-1104-25考題 🍐 1z0-1104-25測試引擎 🤾 1z0-1104-25考題 🐶 透過{ [url]www.newdumpspdf.com }輕鬆獲取➤ 1z0-1104-25 ⮘免費下載1z0-1104-25考題[/url]
- 最新1z0-1104-25題庫資訊 🤹 1z0-1104-25考試重點 🍑 1z0-1104-25考題資源 📕 請在➽ tw.fast2test.com 🢪網站上免費下載➤ 1z0-1104-25 ⮘題庫1z0-1104-25題庫資訊
- zhezhukoxana.alboompro.com, www.stes.tyc.edu.tw, app.parler.com, www.stes.tyc.edu.tw, learn.vrccministries.com, backloggd.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
從Google Drive中免費下載最新的VCESoft 1z0-1104-25 PDF版考試題庫:https://drive.google.com/open?id=1VdVFp-L8Q2uYWhOlsEKjSxqXBrukDNCK
