[General] New AWS-Solutions-Associate Dumps Sheet | Mock AWS-Solutions-Associate Exam
79
【General】 New AWS-Solutions-Associate Dumps Sheet | Mock AWS-Solutions-Associate Exam
Posted at 1/16/2026 14:53:29      View:151 | Replies:2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of DumpsMaterials AWS-Solutions-Associate dumps for free: https://drive.google.com/open?id=1qylsVhrcDYDrAK_dEZA3DpgiMvxh_vPH
The software keeps track of the previous AWS Certified Solutions Architect - Associate (SAA-C03) (AWS-Solutions-Associate) practice exam attempts and shows the changes of each attempt. You don't need to wait days or weeks to get your performance report. The software displays the result of the Amazon AWS-Solutions-Associate Practice Test immediately, which is an excellent way to understand which area needs more attention.
Upon passing the AWS-Solutions-Associate Exam, you will receive the AWS Certified Solutions Architect - Associate (SAA-C02) certification. AWS Certified Solutions Architect - Associate (SAA-C03) certification is valid for three years and can be renewed by passing a recertification exam or earning a higher-level AWS certification. With this certification, you will be able to demonstrate your expertise in AWS cloud computing and be recognized as a skilled AWS solutions architect.
To prepare for the AWS-Solutions-Architect-Associate certification exam, candidates can take online courses, attend instructor-led training, and read AWS documentation. They can also use practice exams and study guides to test their knowledge and identify areas where they need to improve. AWS offers a variety of resources to help candidates prepare for the exam, including sample questions, whitepapers, and FAQs.
Mock AWS-Solutions-Associate Exam | AWS-Solutions-Associate Flexible Learning ModeIf you want to be a leader in some industry, you have to continuously expand your knowledge resource. Our DumpsMaterials always updates the exam dumps and the content of our exam software in order to ensure the AWS-Solutions-Associate exam software that you have are the latest and comprehensive version. No matter which process you are preparing for AWS-Solutions-Associate Exam, our exam software will be your best helper. As the collection and analysis of our AWS-Solutions-Associate exam materials are finished by our experienced and capable IT elite.
Amazon AWS Certified Solutions Architect - Associate (SAA-C03) Sample Questions (Q193-Q198):NEW QUESTION # 193
A company currently stores symmetric encryption keys in a hardware security module (HSM). A solution architect must design a solution to migrate key management to AWS. The solution should allow for key rotation and support the use of customer provided keys.
Where should the key material be stored to meet these requirements?
  • A. AWS Secrets Manager
  • B. AWS Systems Manager Parameter store
  • C. AWS Key Management Service (AWS KMS)
  • D. Amazon S3
https://aws.amazon.com/cloudhsm/
NEW QUESTION # 194
How many relational database engines does RDS currently support?
  • A. Three: MySQL, Oracle and Microsoft SQL Server.
  • B. Just two: MySQL and Oracle.
  • C. Five: MySQL, PostgreSQL, MongoDB, Cassandra and SQLite.
  • D. Just one: MySQL.
NEW QUESTION # 195
Please select the most correct answer regarding the persistence of the Amazon Instance Store
  • A. The data on an instance store volume persists only during the life of the associated Amazon EC2 instance
  • B. The data on an instance store volume is lost when the security group rule of the associated instance is changed.
  • C. The data on an instance store volume persists even after associated Amazon EC2 instance is deleted
NEW QUESTION # 196
A company is hosting a web application on AWS using a single Amazon EC2 instance that stores user-uploaded documents in an Amazon EBS volume For better scalability and availability the company duplicated the architecture and created a second EC2 instance and EBS volume in another Availability Zone:
placing both behind an Application Load Balancer After completing this change users reported that each time they refreshed the website they could see one subset of their documents or the other but never all of the documents at the same time What should a solutions architect propose to ensure users see all of their documents at once?
  • A. Copy the data from both EBS volumes to Amazon EFS Modify the application to save new documents to Amazon EFS
  • B. Configure the Application Load Balancer to send the request to both servers Return each document from the correct server
  • C. Configure the Application Load Balancer to direct a user to the server with the documents
  • D. Copy the data so both EBS volumes contain all the documents
https://docs.aws.amazon.com/efs/ ... ml#how-it-works-ec2 Amazon EFS provides file storage in the AWS Cloud. With Amazon EFS, you can create a file system, mount the file system on an Amazon EC2 instance, and then read and write data to and from your file system. You can mount an Amazon EFS file system in your VPC, through the Network File System versions 4.0 and 4.1 (NFSv4) protocol. We recommend using a current generation Linux NFSv4.1 client, such as those found in the latest Amazon Linux, Redhat, and Ubuntu AMIs, in conjunction with the Amazon EFS Mount Helper. For instructions, see Using the amazon-efs-utils Tools.
For a list of Amazon EC2 Linux Amazon Machine Images (AMIs) that support this protocol, see NFS Support. For some AMIs, you'll need to install an NFS client to mount your file system on your Amazon EC2 instance. For instructions, see Installing the NFS Client.
You can access your Amazon EFS file system concurrently from multiple NFS clients, so applications that scale beyond a single connection can access a file system. Amazon EC2 instances running in multiple Availability Zones within the same AWS Region can access the file system, so that many users can access and share a common data source.
How Amazon EFS Works with Amazon EC2
NEW QUESTION # 197
A Solutions Architect is designing an application that will run on Amazon ECS behind an Application Load Balancer (ALB). For security reasons, the Amazon EC2 host instances for the ECS cluster are in a private subnet.
What should be done to ensure that the incoming traffic to the host instances is from the ALB only?
  • A. Modify the security group used by the EC2 cluster to allow incoming traffic from the security group used by the ALB only.
  • B. Create network ACL rules for the private subnet to allow incoming traffic on ports 32768 through
    61000 from the IP address of the ALB only.
  • C. Enable AWS WAF on the ALB and enable the ECS rule.
  • D. Update the EC2 cluster security group to allow incoming access from the IP address of the ALB only.
NEW QUESTION # 198
Considering all customers’ sincere requirements, AWS-Solutions-Associate test question persist in the principle of “Quality First and Clients Supreme” all along and promise to our candidates with plenty of high-quality products, considerate after-sale services as well as progressive management ideas. To be out of the ordinary and seek an ideal life, we must master an extra skill to get high scores and win the match in the workplace. Our AWS-Solutions-Associate Exam Question can help make your dream come true. What’s more, you can have a visit of our website that provides you more detailed information about the AWS-Solutions-Associate guide torrent.
Mock AWS-Solutions-Associate Exam: https://www.dumpsmaterials.com/AWS-Solutions-Associate-real-torrent.html
P.S. Free 2026 Amazon AWS-Solutions-Associate dumps are available on Google Drive shared by DumpsMaterials: https://drive.google.com/open?id=1qylsVhrcDYDrAK_dEZA3DpgiMvxh_vPH
Posted at 2/6/2026 04:12:28        Only Author  2#
Your article was really impressive, thank you for this insight. Strengthen your IT skills with free Arch-301 exam syllabus. Wishing you the best of luck!
Posted at 2/17/2026 16:33:04        Only Author  3#
Mit Salesforce AP-211 Zertifikat können Sie Ihre Berufsaussichten verbessern und viele neuen Chancen erschließen. Pass4Test ist eine geeignete Website für die Kandidaten, die an der Salesforce AP-211 Zertifizierungsprüfung teilnehmen. Es wird nicht nur alle Informationen zur Salesforce AP-211 Zertifizierungsprüfung, sondern Ihnen auch eine gute Lernchance bieten. Pass4Test wird Ihnen helfen, die Salesforce AP-211 Zertifizierungsprüfung ganz einfach zu bestehen.
