[General] Pdf Plat-Admn-202 Torrent, Latest Plat-Admn-202 Dumps Book
93
General Pdf Plat-Admn-202 Torrent, Latest Plat-Admn-202 Dumps Book
Posted at 1/16/2026 16:52:59      View203 | Replies2        Print      Only Author   [Copy Link] 1#
As a thriving multinational company, we are always committed to solving the problem that our customers may have. For example, the Plat-Admn-202 learning engine we developed can make the Plat-Admn-202 exam easy and easy, and we can confidently say that we did this. A large number of buyers pouring into our website every day can prove this. Just look at it and let yourself no longer worry about the Plat-Admn-202 Exam.
VCE4Plus also offers simple and easy-to-use Salesforce Certified Platform App Builder (Plat-Admn-202) Dumps PDF files of real Salesforce Plat-Admn-202 exam questions. It is easy to download and use on smart devices. Since it is a portable format, it can be used on a smartphone, tablet, or any other smart device. This Salesforce Certified Platform App Builder (Plat-Admn-202) PDF file contains the most probable actual Salesforce Certified Platform App Builder (Plat-Admn-202) exam questions. The print option of this format allows you to carry a hard copy with you at your leisure.
Latest Plat-Admn-202 Dumps Book - Latest Plat-Admn-202 Dumps PptThe objective of the VCE4Plus is to give you quick access to Salesforce Certified Platform App Builder (Plat-Admn-202) actual questions. Offering Salesforce Plat-Admn-202 updated dumps is the only factor behind the dominance of VCE4Plus in the market. Our customers will see our Salesforce Certified Platform App Builder (Plat-Admn-202) questions in the final certification test. We have a devoted team who puts in a lot of effort to keep the Plat-Admn-202 questions updated.
Salesforce Certified Platform App Builder Sample Questions (Q280-Q285):NEW QUESTION # 280
Cloud Kicks Is redefining its entire business process to convert the Manager Notes field from a long text area files. The goal is to encourage managers to be more concise In their comments and stay at 255 characters or less. There is preexisting information In the Manager Notes field that often is well beyond the character limit.
What would happen to any existing information if the app builder tries to convert a preexisting long text area field to text area'
  • A. Preexisting Information in the field will be completely lost.
  • B. Preexisting information will remain even if it was over 255 characters.
  • C. Preexisting information will truncate to the first 255 characters.
  • D. Preexisting information will cause an error message to pop up.
Preexisting information will remain even if it was over 255 characters if the app builder tries to convert a preexisting long text area field to text area. However, users will not be able to edit or save records with more than 255 characters in that field until they reduce the number of characters. Preexisting information will not truncate, be lost, or cause an error message.
NEW QUESTION # 281
The marketing team at UVC has a list of 400 leads it wants to upload to Salesforce. The team need to avoid creating duplicate records. Which two actions should be taken to meet this requirement? Choose 2 answers
  • A. Utilize a Lead Matching Rule and corresponding Duplicate Rule to block newly created duplicate leads.
  • B. Upload the lead list using the import wizard and select a Matching type to prevent duplicate lead creation.
  • C. Enable Duplicate Matching in the Data Management section in Setup and activate the Lead-to_Lead scenario.
  • D. Use Data Loader's update function to import lead and match to existing records based on e-mail address.
The best actions to take to avoid creating duplicate leads when uploading a list of 400 leads are to utilize a Lead Matching Rule and corresponding Duplicate Rule to block newly created duplicate leads, and to upload the lead list using the import wizard and select a Matching type to prevent duplicate lead creation. The Lead Matching Rule defines the criteria for identifying duplicate leads, and the Duplicate Rule defines the actions to take when a duplicate is detected. The import wizard allows users to choose a Matching type based on the Lead Matching Rule and block or allow duplicates. Using Data Loader's update function or enabling Duplicate Matching in the Data Management section will not prevent duplicate lead creation.
NEW QUESTION # 282
Service Agents are required to confirm a user's identity before providing support information over the phone.
Which feature can an app builder use to help agents meet this requirement?
  • A. Add Path to the top of the Case layout
  • B. Guided Action Flows on the record page
  • C. Case Validation Rules
  • D. Include Surveys as a Case related list
Guided Action Flows (Screen Flows embedded in Lightning record pages) can walk agents through required steps - such as verifying identity - before proceeding.
Why A (Guided Action Flows) is correct:Exact Extract:"Use Guided Action Flows in Lightning App Builder to help agents complete processes in a step-by-step format directly on a record page." - Salesforce Help | Guided Action FlowsThe app builder can embed a Screen Flow that prompts the agent to verify identity (e.g., asking security questions), then allows access or marks verification complete.
Why not Bath helps users track record stages, not enforce procedural steps.
Why not C:Surveys are used for feedback collection after cases, not real-time identity verification.
Why not D:Validation Rules enforce data quality on record save, not process guidance.
Salesforce Platform App Builder Exam Guide | Business Logic and Process Automation
NEW QUESTION # 283
An App Builder has been asked to integrate Salesforce with an external web service. The web service must be notified every time an Opportunity is Won. Which two can satisfy this requirement?
  • A. Use a process and Apex Code
  • B. Use a process and an outbound message
  • C. Use a workflow rule and an outbound message
  • D. Use a flow and an outbound message
Workflow rule and an outbound message or Process Builder and Apex Code are two ways to integrate Salesforce with an external web service. Workflow rule can define criteria and actions for triggering an outbound message, which is an XML message sent to a designated endpoint URL. Process Builder can invoke Apex Code, which is a programming language that can make callouts to external web services using HTTP requests. Flow Builder and an outbound message or Process Builder and an outbound message are not possible combinations.
NEW QUESTION # 284
Cloud Kicks has created accustom object called Interests which is joined to Accounts by way of a junction object called Account Interest.
What is the impact to users attempting to view an Account and the associated Account Interest records if they are without read access to the Interest object?
  • A. Users will be able to view the Account Interest record, but unable to view the field or any information relating back to the Interest record.
  • B. Users will be able to view the Account Interest records and will have read-only access to the Interest records.
  • C. Users will be unable to view the Account Interest records or the Interest records.
  • D. Users will be unable to view Account records that have a related Account Interest record.
Users will be unable to view the Account Interest records or the Interest records because they do not have read access to the Interest object. This is a standard behavior of Salesforce when a user does not have access to a related object.
NEW QUESTION # 285
The PDF version of our Plat-Admn-202 study tool is very practical, which is mainly reflected on the special function. As I mentioned above, our company are willing to provide all people with the demo for free. You must want to know how to get the trial demo of our Plat-Admn-202 question torrent; the answer is the PDF version. You can download the free demo form the PDF version of our Plat-Admn-202 Exam Torrent. If you download our study materials successfully, you can print our study materials on pages by the PDF version of our Plat-Admn-202 exam torrent.
Latest Plat-Admn-202 Dumps Book: https://www.vce4plus.com/Salesforce/Plat-Admn-202-valid-vce-dumps.html
Salesforce Pdf Plat-Admn-202 Torrent At work if you can create a lot of value for the boss, the boss of course care about your job, including your salary, Our Plat-Admn-202 exam questions are your best choice, Both PDF and software format demos for Salesforce Developer Plat-Admn-202 exam dumps are offered by VCE4Plus for free, Why do most people to choose VCE4Plus Latest Plat-Admn-202 Dumps Book ?
Say that you run a sales organization, Become Plat-Admn-202 a bridge-builder yourself and help create trust between your team and the product owner, At work if you can create a lot of Pdf Plat-Admn-202 Torrent value for the boss, the boss of course care about your job, including your salary.
Pass Guaranteed Quiz Valid Salesforce - Pdf Plat-Admn-202 TorrentOur Plat-Admn-202 Exam Questions are your best choice, Both PDF and software format demos for Salesforce Developer Plat-Admn-202 exam dumps are offered by VCE4Plus for free, Why do most people to choose VCE4Plus ?
- Money back guarantee of Salesforce Plat-Admn-202 braindumps.
Posted at 1/18/2026 10:06:34        Only Author  2#
Im deeply moved by your article, thank you for sharing this insight! Improve your IT skillsfree Reliable 220-1201 APP simulations is shared! Best of luck with everything!
Posted at 1/20/2026 00:32:25        Only Author  3#
θˤꡢʤŬФȤޤITšTˤȤäơGCP-GCX-JPNԇYJϤʤΌg^ǤҪʥĩ`Ǥ顢GenesysGCP-GCX-JPNԇY˺ϸ񤹤Ҫޤǡ|ߤGCP-GCX-JPNԇYYϤ]ᤵƤ
