Free PDF 2026 Oracle Newest 1z0-076 New Dumps Files
Posted at 1/16/2026 17:20:01
View215
Replies3
BONUS!!! Download part of GuideTorrent 1z0-076 dumps for free: https://drive.google.com/open?id=1C-d5Ktv7jd4R17DgxNNt5Y6K9AfECpOg
The price for 1z0-076 training materials is reasonable, and no matter you are a student or you are an employee, you can afford the expense. In addition, 1z0-076 exam brindumps are high-quality, and you can pass the exam just one time. 1z0-076 exam materials cover most of knowledge points for the exam, and they will help you pass the exam as well as improve your ability in the process of learning. We also pass guarantee and money back guarantee for 1z0-076 and if you fail to pass the exam, we will give you full refund.
As old saying goes, no pains, no gains. You must depend on yourself to acquire what you want. No one can substitute you with the process. Of course, life has shortcut, which can ensure you have a bright future. Our 1z0-076 study materials will become your new hope. If you are ambitious and diligent, our study materials will lead you to the correct road. Thousands of people have regain hopes for their life after accepting the guidance of our 1z0-076 Study Materials. You should never regret for the past.
Valid Oracle 1z0-076 New Dumps Files & Professional GuideTorrent - Leader in Certification Exam MaterialsPlease dont worry about the purchase process because its really simple for you. The first step is to select the 1z0-076 test guide, choose your favorite version, the contents of different version are the same, but different in their ways of using. The second step: fill in with your email and make sure it is correct, because we send our Oracle Database 19c: Data Guard Administration learn tool to you through the email. Later, if there is an update, our system will automatically send you the latest Oracle Database 19c: Data Guard Administration version. At the same time, choose the appropriate payment method, such as SWREG, DHpay, etc. Next, enter the payment page, it is noteworthy that we only support credit card payment, do not support debit card. Generally, the system will send the 1z0-076 Certification material to your mailbox within 10 minutes. If you dont receive it please contact our after-sale service timely.
Oracle Database 19c: Data Guard Administration Sample Questions (Q94-Q99):NEW QUESTION # 94
Which THREE are among the various tasks performed by the Data Guard Monitor (DMON) process?
- A. communicating with dkon processes in other database instances that are part of the broker configuration
- B. maintaining information about all members of the broker configuration in binary configuration files.
- C. performing role transitions when switchover requests are made
- D. communicating with the DMON process of the observer to monitor a primary database in case a fast start failover is required
- E. activating role-based services appropriately in the various database instances of the configuration, based on the database role
Answer: B,C,E
The Data Guard Monitor (DMON) process is a key component of Oracle Data Guard. It plays a crucial role in managing and monitoring the state of both the primary and standby databases in a Data Guard configuration.
* Performing role transitions when switchover requests are made (A): DMON is responsible for coordinating the switchover process between the primary and standby databases. This involves safely transitioning the roles of the databases to ensure data protection and availability.
* Maintaining information about all members of the broker configuration in binary configuration files (B): DMON maintains detailed information about the databases in the Data Guard configuration, including their roles, states, and network addresses. This information is stored in binary configuration files, which are used by the Data Guard Broker to manage the Data Guard environment.
* Activating role-based services appropriately in the various database instances of the configuration, based on the database role (C): DMON activates services that are appropriate for the role of each database in the Data Guard configuration. For example, it may activate different services on a primary database than on a standby database, based on the specific requirements of each role.
* Oracle Data Guard Concepts and Administration
* Oracle Data Guard Broker documentation
NEW QUESTION # 95
There are currently 6 applief. and 6 pfepafef processes running and no idle applier processes on y logical standby database.
The max_SERVERS SQL apply parameter and number of archiver processes are both set to 12.
Identify two changes, each of which would allow you to increase the number of applier processes.
- A. Increase the parallel_max_server initialization parameter.
- B. Increase the processes initialization parameter. D Decrease the number of FREPARER processes.
- C. Increase the value for the MAX_SERVERS SQL apply parameter.
- D. Decrease the number of archiver processes on the standby database.
- E. Increase the RECOVERY_PARALLEL initialization parameter.
To increase the number of applier processes on a logical standby database, the following changes can be made:
C: Increasing the value for the MAX_SERVERS SQL apply parameter would allow for more applier processes to be initiated, assuming that system resources permit.
D: Increasing the PARALLEL_MAX_SERVERS initialization parameter would allow for more parallel execution processes, which can be used by SQL apply to increase the number of applier processes.
Option A is incorrect as decreasing the number of archiver processes will not necessarily increase the number of applier processes; these are unrelated components.
Option B is incorrect because the 'FREPARER' processes do not exist, it seems to be a typographical error, and the 'REPARER' is not a valid Oracle process or parameter.
Option E is incorrect because the RECOVERY_PARALLELISM parameter controls the number of processes used for instance recovery and media recovery, not for SQL apply.
NEW QUESTION # 96
Your Data Guard environment consists of these components and settings:
1. A primary database
2. Two remote physical standby databases
3. The redo transport mode is set to sync
4. Real-time query is enabled for both standby databases
5. The DB_BLOCK_CHECKING parameter is set to TRUE on both standby databases You notice an increase in redo apply lag time on both standby databases.
Which two would you recommend to reduce the redo apply lag on the standby databases?
- A. Increase the number of standby redo log files on the standby databases.
- B. Increase the size of the buffer cache on the physical standby database instances.
- C. Increase the size of standby redo log files on the standby databases.
- D. Lower DB_BLOCK_CHECKING to MEDIUM or low on the standby databases.
- E. Decrease the redo log file size on the primary database.
To reduce the redo apply lag on standby databases, one could increase the size of the standby redo log files.
Larger redo log files can accommodate more redo data, which may reduce the frequency of log switches and allow for more continuous application of redo data. Additionally, lowering the DB_BLOCK_CHECKING parameter to MEDIUM or LOW on the standby databases can help improve redo apply performance. High block checking can impose additional CPU overhead during the application of redo data, potentially increasing apply lag times. By reducing the level of block checking, you can lessen this overhead and help reduce the apply lag .
NEW QUESTION # 97
Which two are true about managing and monitoring Oracle container databases in a Data Guard environment using the broker?
- A. If the primary database is a container database, then a physical standby may be a non-container database.
- B. After a role change, the broker opens all Pluggable databases (pdbb) on the new primary.
- C. If the primary database is not a container database, then a standby may be a container database.
- D. All broker actions execute at the root container for container databases.
- E. If the primary database is a container database, then a logical standby may be a non-container database.
In the context of Oracle Data Guard and container databases (CDBs) managed by Data Guard Broker:
All broker actions execute at the root container for container databases (D): When using Data Guard Broker to manage a CDB, the actions performed by the broker are executed at the level of the root container. This is because the root container maintains the control and configuration information that applies to the entire CDB, including all of its pluggable databases (PDBs).
After a role change, the broker opens all Pluggable databases (PDBs) on the new primary (E): Following a role transition such as a switchover or a failover, Data Guard Broker ensures that all PDBs within the CDB of the new primary database are opened, which is essential to resume operations of the PDBs without manual intervention.
Oracle Multitenant Administrator's Guide
NEW QUESTION # 98
You are licensed to use Oracle Active Data Guard.
Which TWO statements are true after enabling block change tracking on a physical standby database?
- A. It starts the CTWR process on the primary database instance.
- B. It allows fast incremental backups to be offloaded to a snapshot standby database, when the physical standby database is converted.
- C. It starts the CTWR process on the physical standby database instance.
- D. It allows fast incremental backups to be taken on the primary database.
- E. It allows fast incremental backups to be offloaded to the physical standby database.
- F. It starts the RVWR process on the physical standby database instance.
Answer: E,F
Block change tracking is a feature that enhances the efficiency of incremental backups by recording changed blocks in a tracking file. When used with Oracle Active Data Guard:
It starts the RVWR process on the physical standby database instance (A): When block change tracking is enabled on a physical standby database, the Recovery Writer (RVWR) process is initiated. This process is responsible for recording the changes to blocks in the block change tracking file, which is then used to optimize incremental backups.
It allows fast incremental backups to be offloaded to the physical standby database (E): With block change tracking enabled on the physical standby database, fast incremental backups can be offloaded from the primary database. This reduces the workload on the primary database and utilizes the standby database for backup operations, improving overall system performance and efficiency.
Oracle Database Backup and Recovery User's Guide
Oracle Active Data Guard documentation
NEW QUESTION # 99
GuideTorrent 1z0-076 practice material can be accessed instantly after purchase, so you won't have to face any excessive issues for preparation of your desired Oracle 1z0-076 certification exam. The Oracle 1z0-076 Exam Dumps of GuideTorrent has been made after seeking advice from many professionals. Our objective is to provide you with the best learning material to clear the 1z0-076 exam.
Trustworthy 1z0-076 Exam Content: https://www.guidetorrent.com/1z0-076-pdf-free-download.html
Oracle 1z0-076 New Dumps Files As is known to us that pass rate is one of the most important standards when candidate choose the practice materials, Oracle 1z0-076 New Dumps Files And every version can apply in different conditions so that you can use your piecemeal time to learn, and every minute will have a good effect, Oracle 1z0-076 New Dumps Files Action is better than hesitation!
Case Study: Route Reflectors as Route Servers, Reliable 1z0-076 Exam Braindumps Depending on the size of the organization, information-processing facilities can range from a closet with one server to an entire 1z0-076 New Dumps Files complex of buildings with several thousand or even hundreds of thousands of computers.
Top 1z0-076 New Dumps Files Free PDF | High-quality Trustworthy 1z0-076 Exam Content: Oracle Database 19c: Data Guard AdministrationAs is known to us that pass rate is one of the 1z0-076 New Dumps Files most important standards when candidate choose the practice materials, And every version can apply in different conditions so that Reliable 1z0-076 Exam Braindumps you can use your piecemeal time to learn, and every minute will have a good effect.
Action is better than hesitation, Before Trustworthy 1z0-076 Exam Content scheduling your Oracle Database 19c Collaboration Exam, it's better to confirm exam & dump valid or invalid with GuideTorrent consultant 1z0-076 and then make your further Oracle Database 19c Collaboration preparation study guide.
Whether you will be able to pass or not may simply depend on one point.
- Useful 1z0-076 New Dumps Files - Passing 1z0-076 Exam is No More a Challenging Task ⭐ Immediately open ⇛ [url]www.prep4sures.top ⇚ and search for 1z0-076 to obtain a free download ⚓1z0-076 New Cram Materials[/url]
- 1z0-076 Interactive Questions 📏 1z0-076 High Passing Score ⏪ 1z0-076 Exam Overview 🐽 The page for free download of 1z0-076 on ⇛ [url]www.pdfvce.com ⇚ will open immediately 🖼1z0-076 Valid Test Forum[/url]
- 1z0-076 New Cram Materials ⏺ 1z0-076 Test Registration 📹 New APP 1z0-076 Simulations 🗣 Open { [url]www.validtorrent.com } enter ⏩ 1z0-076 ⏪ and obtain a free download 💯1z0-076 Real Exam Questions[/url]
- 1z0-076 High Passing Score 🛳 Exam Dumps 1z0-076 Provider 💾 Fresh 1z0-076 Dumps 🅾 ➠ [url]www.pdfvce.com 🠰 is best website to obtain ▛ 1z0-076 ▟ for free download 🚪1z0-076 High Passing Score[/url]
- Valid 1z0-076 prep4sure vce - Oracle 1z0-076 dumps pdf - 1z0-076 latest dumps 👷 Easily obtain free download of 1z0-076 by searching on [url]www.troytecdumps.com 🥮1z0-076 Exam Overviews[/url]
- Exam Dumps 1z0-076 Provider 👯 Pass 1z0-076 Guaranteed ➡ New 1z0-076 Test Blueprint ☘ Easily obtain [ 1z0-076 ] for free download through ☀ [url]www.pdfvce.com ️☀️ 🍇1z0-076 Exam Overview[/url]
- Free PDF Quiz 1z0-076 - Accurate Oracle Database 19c: Data Guard Administration New Dumps Files 👠 Search for ☀ 1z0-076 ️☀️ and download it for free immediately on ➡ [url]www.troytecdumps.com ️⬅️ 👲Fresh 1z0-076 Dumps[/url]
- Valid 1z0-076 prep4sure vce - Oracle 1z0-076 dumps pdf - 1z0-076 latest dumps 🕍 Search for ☀ 1z0-076 ️☀️ and obtain a free download on [url]www.pdfvce.com 😼
ass 1z0-076 Guaranteed[/url] - Exam Dumps 1z0-076 Provider 📹 Exam Dumps 1z0-076 Provider 🏘 1z0-076 New Cram Materials 🚍 Simply search for 1z0-076 for free download on [url]www.torrentvce.com 🆒1z0-076 Interactive Questions[/url]
- 1z0-076 Exam Overview 🈺 1z0-076 New Cram Materials 📭 Pass 1z0-076 Guaranteed 🎹 Easily obtain { 1z0-076 } for free download through { [url]www.pdfvce.com } ✌Study 1z0-076 Group[/url]
- Study 1z0-076 Group 🎶 Pass 1z0-076 Guaranteed 🔗 1z0-076 New Cram Materials 🦓 Immediately open ➽ [url]www.torrentvce.com 🢪 and search for ☀ 1z0-076 ️☀️ to obtain a free download 📞1z0-076 High Passing Score[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, kumu.io, paidforarticles.in, www.stes.tyc.edu.tw, mpgimer.edu.in, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free 2026 Oracle 1z0-076 dumps are available on Google Drive shared by GuideTorrent: https://drive.google.com/open?id=1C-d5Ktv7jd4R17DgxNNt5Y6K9AfECpOg
