[General] The Best Accurate Online UiPath-TAEPv1 Bootcamps - Win Your UiPath Certificate w
86
【General】 The Best Accurate Online UiPath-TAEPv1 Bootcamps - Win Your UiPath Certificate w
Posted at 1/16/2026 21:38:51      View:133 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New UiPath-TAEPv1 dumps are available on Google Drive shared by Braindumpsqa: https://drive.google.com/open?id=1ggIYSnLZsOkSiQLWToPJh8Z_TuPdGsnG
Regular practice can give you the skills and confidence needed to perform well on your UiPath-TAEPv1 exam. By practicing your UiPath Test Automation Engineer Professional v1.0 (UiPath-TAEPv1) exam regularly, you can increase your chances of success and make sure that all of your hard work pays off when it comes time to take the test. We understand that every UiPath Test Automation Engineer Professional v1.0 (UiPath-TAEPv1) exam taker has different preferences. To make sure that our UiPath UiPath-TAEPv1 preparation material is accessible to everyone, we made it available in three different formats.
UiPath UiPath-TAEPv1 Exam Syllabus Topics:
  • Testing Process: This section of the exam measures the skills of Test Automation Engineers and focuses on applying best practices in test case design and execution. It outlines the importance of structured application testing in UiPath and emphasizes quality assurance through automation.
  • UiPath Robot: This section of the exam measures the skills of RPA Developers and explains the role of testing robots and their connectivity with UiPath Orchestrator. It discusses the execution of test cases using both on-premises and cloud-based robots and highlights how different robot types support automation testing in a scalable environment.
  • CI
  • CD Implementation: This section of the exam measures the skills of RPA Developers and introduces the concepts of Continuous Integration and Continuous Delivery (CI
  • CD). It covers how to implement pipelines and perform tasks using the UiPath Command Line Interface (CLI) for streamlined and automated deployments of test workflows and processes.
  • UiPath Test Suite Architecture and API Integrations: This section of the exam measures the skills of Test Automation Engineers and covers the fundamental capabilities of UiPath Test Suite in automating different types of testing such as UI, API, and data-driven testing. It includes an overview of Test Suite tools and how they integrate with each other, as well as with third-party application lifecycle management (ALM) tools through APIs. Candidates are expected to understand API testing concepts and how external tools can be connected for requirement synchronization, defect management, and test case tracking.
Topic 5
  • UiPath Test Manager: This section of the exam measures the skills of Test Automation Engineers and focuses on using UiPath Test Manager for managing test lifecycles. It includes actions like defining custom fields, managing access, importing
  • exporting projects, and documenting manual steps using UiPath Task Capture. It also explains how to analyze test results, handle execution re-runs, manage KPIs, and create defects for failed test cases, along with troubleshooting common errors.:
Topic 6
  • UiPath Studio - Data-driven Testing: This section of the exam measures the skills of RPA Developers and centers around managing test data variations using data-driven testing approaches. It explains how to add test data through queues, activities, or data sources, and how to create reusable test cases based on this data. The section also highlights connecting UiPath Studio projects to Test Manager to enhance traceability and visibility of test progress.
UiPath UiPath-TAEPv1 Exam | Online UiPath-TAEPv1 Bootcamps - High-quality Real UiPath-TAEPv1 Dumps Free for youThese UiPath-TAEPv1 PDF Questions are being presented in practice test software and PDF dumps file formats. The UiPath UiPath-TAEPv1 desktop practice test software is easy to use and install on your desktop computers. Whereas the other UiPath-TAEPv1 web-based practice test software is concerned, this is a simple browser-based application that works with all operating systems. Both practice tests are customizable, simulate actual exam scenarios, and help you overcome mistakes.
UiPath Test Automation Engineer Professional v1.0 Sample Questions (Q17-Q22):NEW QUESTION # 17
What type(s) of license should be used in order to be able to connect Studio to Test Manager?
  • A. Just Test Manager license.
  • B. Just Task Capture license
  • C. Studio license and Test Manager license.
  • D. Studio license and Orchestrator license.
To connect UiPath Studio to Test Manager, both a Studio license and a Test Manager license are required. This ensures that Studio can interact with Test Manager for managing and executing test cases.
NEW QUESTION # 18
What is the main purpose of conducting Regression Testing in application development?
  • A. Regression Testing is conducted to ensure that changes in the code have not affected existing functionalities.
  • B. Regression Testing is conducted to ensure the application's performance under high load conditions.
  • C. Regression Testing is conducted to ensure the application's compatibility with different environments.
  • D. Regression Testing is conducted to validate whether the software application is secure from threats.
The main purpose of Regression Testing is to ensure that recent changes or additions to the code have not negatively impacted existing functionality. It helps maintain application stability after updates.
NEW QUESTION # 19
What is Descriptor Coverage panel used for in UiPath Studio?
  • A. The Descriptor Coverage panel is used to store the selectors and Object Repository Ul elements that will be needed for different test cases.
  • B. The Descriptor Coverage panel is only used when there are failed selectors, it has no use during successful test case runs.
  • C. The Descriptor Coverage panel is used to view Ul elements that have been covered during execution and to analyze selector coverage or debug workflows with failed coverage.
  • D. The Descriptor Coverage panel is used for inputting Ul elements for object recognition, that are required to be covered during the execution process.
The Descriptor Coverage panel in UiPath Studio is used to view UI elements covered during test execution and to analyze selector coverage, helping identify elements that were or were not interacted with. It's also useful for debugging workflows where coverage may be incomplete or missing.
NEW QUESTION # 20
What kind of changes can be made to test sets linked from Orchestrator in Test Manager?
  • A. The description can not be edited, but the name and version can be edited in Test Manager.
  • B. The name description, or version can not be edited. Any changes need to be made in Orchestrator.
  • C. The name can not be edited, but the version and description can be edited in Test Manager.
  • D. The version can not be edited, but the name and description can be edited in Test Manager.
When test sets are linked from Orchestrator in Test Manager, the version cannot be edited in Test Manager. However, the name and description of the test set can be modified within Test Manager to support better project documentation or categorization.
NEW QUESTION # 21
Considering the provided configuration for Workflow Analyzer Settings, which of the testing rules applied will be classified as a "Warning"?
  • A. Unused Mocking
  • B. Activity Restrictions
  • C. Test Case Without Annotations
  • D. Test Case Name not unique within the Project
According to the Workflow Analyzer Settings shown in the image "Unused Mocking" (code TA-DBP-004) has its Default action set to "Warning".
NEW QUESTION # 22
Our online resources and events enable you to focus on learning just what you want on your timeframe. You get access to every UiPath-TAEPv1 exams files and there continuously update our UiPath-TAEPv1 Study Materials; these exam updates are supplied free of charge to our valued customers. Get the best UiPath-TAEPv1 exam Training; as you study from our exam-files.
Real UiPath-TAEPv1 Dumps Free: https://www.braindumpsqa.com/UiPath-TAEPv1_braindumps.html
BONUS!!! Download part of Braindumpsqa UiPath-TAEPv1 dumps for free: https://drive.google.com/open?id=1ggIYSnLZsOkSiQLWToPJh8Z_TuPdGsnG
