[General] Exam 1Z1-771 Labs | Test 1Z1-771 Centres
104
【General】 Exam 1Z1-771 Labs | Test 1Z1-771 Centres
Posted at 1/16/2026 23:08:47      View:142 | Replies:2        Print      Only Author   [Copy Link] 1#
2026 Latest Pass4sureCert 1Z1-771 PDF Dumps and 1Z1-771 Exam Engine Free Share: https://drive.google.com/open?id=1Jg-giF3b6aWeBr2zgiXOexv4YnwKAv4a
Not withstanding zeroing in on our material, expecting that you went after in the Oracle 1Z1-771 exam, you can guarantee your cash back as per systems. By seeing your goofs you can work on your show continually for the 1Z1-771 Exam approach. You can give vast phony tests to make them ideal for Oracle APEX Cloud Developer Professional (1Z1-771) exam and can check their past given exams. Oracle 1Z1-771 Dumps will give reliable free updates to our clients generally all the Oracle 1Z1-771 certifications.
Oracle 1Z1-771 Exam Syllabus Topics:
  • Implementing Navigation in Your Application: This section assesses the skills of UX Designers in designing smooth application navigation. It includes configuring shared components, setting up search functionalities, and enhancing user experience with intuitive navigation structures.
  • Adding Computations, Processes, Validations, and Branches: This section measures the knowledge of Backend Developers in implementing application logic. It focuses on configuring computations, processes, validations, and page branches to automate workflows and ensure data integrity.
  • Creating and Using Dynamic Actions and Plug-ins: This section tests the expertise of Developers in implementing dynamic actions. It covers configuring event-driven behaviors and integrating plug-ins to create responsive and interactive application features.
  • Creating an APEX Application: This section tests the abilities of Application Developers in building APEX applications. It focuses on creating applications from existing tables and external files, providing a fundamental understanding of the App Builder tool and its role in application development.
Topic 5
  • Getting Started with Oracle APEX on the Oracle Autonomous Database: This section of the exam measures the skills of APEX Developers in understanding Oracle APEX and its core components. It covers the creation and management of workspaces, providing an overview of how APEX integrates with the Oracle Autonomous Database to streamline application development.
Topic 6
  • Managing Application Data: This section evaluates the expertise of Data Engineers in handling application data. It covers using collections, managing REST-enabled SQL references, integrating REST Data Sources, and synchronizing data across different environments.
Topic 7
  • Creating and Using Forms: This section evaluates the proficiency of Form Developers in designing user-friendly forms. It covers creating interactive grids, developing simple forms linked to reports, and implementing master-detail forms for effective data management.
Topic 8
  • Creating Application Page Controls: This section tests the abilities of Frontend Developers in implementing interactive page elements. It includes creating page-level items, buttons, and controls that enhance navigation and user interaction within APEX applications.
Topic 9
  • Managing Pages and Regions: This section measures the knowledge of UI Designers in structuring application layouts. It covers creating different types of pages and regions, managing page components within Page Designer, and ensuring an optimized user interface for applications.
Topic 10
  • Using Themes and Theme Styles: This section tests the abilities of UI Designers in applying visual themes to applications. It involves selecting and customizing themes, using Theme Roller for design adjustments, and creating template components for consistent branding.
Topic 11
  • Managing Workflows and Tasks: This section evaluates the proficiency of Process Automation Specialists in workflow management. It covers customizing workflows, using approval processes, and handling unified task lists to streamline business processes within applications.
Topic 12
  • Using SQL Workshop: This section evaluates the expertise of Database Developers in managing database objects using SQL Workshop. It includes creating and modifying database structures, running SQL commands and scripts, and efficiently loading and unloading data through the Data Workshop utility to simplify database interactions.
Test 1Z1-771 Centres - Pdf Demo 1Z1-771 DownloadPass4sureCert helps you in doing self-assessment so that you reduce your chances of failure in the examination of Oracle APEX Cloud Developer Professional (1Z1-771) certification. Similarly, this desktop 1Z1-771 practice exam software of Pass4sureCert is compatible with all Windows-based computers. You need no internet connection for it to function. The Internet is only required at the time of product license validation.
Oracle APEX Cloud Developer Professional Sample Questions (Q52-Q57):NEW QUESTION # 52
Which statement is true about the Data Workshop utility?
  • A. You cannot load data from an XLSX file with multiple worksheets.
  • B. You can load or unload multiple tables at a time.
  • C. The wizards load and unload all types of schema objects.
  • D. The wizards load and unload table data only.
The Data Workshop utility in APEX is designed to load and unload table data only, not other schema objects like procedures or views. Option A is false because XLSX files with multiple worksheets are supported (each worksheet can be mapped to a table). Option B is incorrect as it's limited to table data. Option D is partially true but not the most precise answer, as "multiple tables at a time" depends on the process, whereas C is universally accurate.
NEW QUESTION # 53
Which two actions does the Create Application Wizard allow?
  • A. Changing the application authorization.
  • B. Uploading JavaScript or CSS files required for an application.
  • C. Reordering application pages.
  • D. Adding or deleting application pages.
The Create Application Wizard streamlines app creation with:
Adding or deleting application pages: Allows users to define initial pages (e.g., Home, Reports) and remove unwanted ones during the wizard process.
Reordering application pages: Provides drag-and-drop or list-based reordering of pages to set the navigation sequence.
Uploading JavaScript or CSS: This occurs post-creation in Shared Components, not within the wizard.
Changing the application authorization: Authorization schemes are set after creation, not during the wizard.
This wizard is a time-saver for rapid prototyping, offering a guided yet flexible setup.
NEW QUESTION # 54
Which two approaches can be used to create custom stored procedures in SQL Workshop?
  • A. Using Data Workshop
  • B. Using Quick SQL
  • C. Using Object Browser
  • D. Using SQL Scripts
In SQL Workshop, custom stored procedures can be created using:
SQL Scripts: Allows developers to write and execute PL/SQL code directly to define stored procedures.
Object Browser: Provides a GUI to create and edit database objects, including stored procedures, by defining their specifications and bodies.
Quick SQL is for generating table DDL, not stored procedures, and Data Workshop is for loading/unloading data, not creating procedures.
NEW QUESTION # 55
In a faceted search page, facets can be displayed as different UI types. Which two facet item types are supported in the faceted search region?
  • A. Popup LOV
  • B. Range
  • C. Date Picker
  • D. Checkbox Group
In Oracle APEX, a faceted search page allows users to filter data using facets, which are displayed as UI components in the Faceted Search region. According to the Oracle APEX documentation, the supported facet item types include:
Range: Used for numeric or date ranges, allowing users to filter data within a specified range (e.g., salary or hire date).
Checkbox Group: Used for multi-select options, enabling users to select multiple values from a list (e.g., departments).
Other types like Popup LOV and Date Picker are valid item types in APEX but are not natively supported as facet types in the Faceted Search region. Popup LOV is typically used for single-value selection in forms, and Date Picker is a standalone item type, not a facet-specific UI.
NEW QUESTION # 56
Which is NOT an available Geometry Column data type for the map region?
  • A. SDO_GEOMETRY
  • B. JSON OBJECT
  • C. Latitude/Longitude
  • D. GeoJSON
The Map Region in APEX supports spatial data via:
GeoJSON: A JSON-based standard for geographic data (e.g., points, polygons).
SDO_GEOMETRY: Oracle's native spatial data type for storing geometry (e.g., SDO_GEOMETRY(2001, 4326, SDO_POINT_TYPE(-122, 37, NULL), NULL, NULL)).
Latitude/Longitude: Separate columns for lat/long coordinates, mapped to points.
JSON OBJECT: Not a supported geometry type; while JSON can store data, it's not a specific spatial format recognized by the Map Region without GeoJSON structure.
This ensures compatibility with Oracle Spatial and common GIS standards.
NEW QUESTION # 57
The only aim of our company is to help each customer pass their exam as well as getting the important certification in a short time. If you want to pass your exam and get the 1Z1-771 certification which is crucial for you successfully, I highly recommend that you should choose the 1Z1-771 certification preparation materials from our company so that you can get a good understanding of the exam that you are going to prepare for. We believe that if you decide to buy the 1Z1-771 Exam Materials from our company, you will pass your exam and get the certification in a more relaxed way than other people.
Test 1Z1-771 Centres: https://www.pass4surecert.com/Oracle/1Z1-771-practice-exam-dumps.html
P.S. Free 2026 Oracle 1Z1-771 dumps are available on Google Drive shared by Pass4sureCert: https://drive.google.com/open?id=1Jg-giF3b6aWeBr2zgiXOexv4YnwKAv4a
Posted at 2/3/2026 16:44:51        Only Author  2#
The content is so good, I’m liking it immediately. I earned my promotion and salary increase with the Free HPE0-J68 sample. Now, it's free for everyone. Wishing you all early promotions!
Posted at 3/5/2026 20:12:31        Only Author  3#
Your article is absolutely remarkable, I truly appreciate you sharing it! Get access to the Archer-Expert latest test tips exam that helped me earn a promotion and pay raise—today, it’s free for all! Good luck on your career path.
