[General] 4A0-D01 Reliable Test Online | Latest 4A0-D01 Exam Topics
96
【General】 4A0-D01 Reliable Test Online | Latest 4A0-D01 Exam Topics
Posted at 1/17/2026 01:06:39      View:146 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of FreeCram 4A0-D01 dumps for free: https://drive.google.com/open?id=1eD0gibmmGVvCcTf0wQPXUcsJn-hls5p3
Passing the 4A0-D01 exam has never been so efficient or easy when getting help from our 4A0-D01 training materials. This way is not only financially accessible, but time-saving and comprehensive to deal with the important questions emerging in the real exam. All exams from different suppliers will be easy to handle. Actually, this 4A0-D01 Exam is not only practical for working or studying conditions, but a manifest and prestigious show of your personal ability.
Nokia 4A0-D01 Exam Syllabus Topics:
  • Module 5 – EDA (Event Driven Automation) Introduction
  • SR Linux Configuration and Routing: This section of the exam measures skills of a Network Automation Specialist and focuses on configuring and managing SR Linux systems. It examines the YANG-driven CLI, JSON output, environment variables, and static and dynamic routing. Learners also explore BGP, ECMP, IP-VRF, MAC-VRF, and the use of VXLAN with EVPN to implement both Layer 2 and Layer 3 overlays, including symmetric and asymmetric models.
  • SR Linux Logging, Monitoring, and Filtering: This section of the exam measures skills of a Data Center Network Engineer and addresses how to implement logging, monitoring, and traffic filtering in SR Linux. It explains log file usage, ACL types, CPM filtering, and packet capture filters. Configuration tasks involve applying ACLs and monitoring network activity using capture tools.
Pass Your Nokia 4A0-D01 Exam with ExamsOur specialists check whether the contents of 4A0-D01 real exam are updated every day. If there are newer versions, they will be sent to users in time to ensure that users can enjoy the latest resources in the first time. In such a way, our 4A0-D01 Guide materials can have such a fast update rate that is taking into account the needs of users. And we will always send our customers with the latest and accurate 4A0-D01 exam questions.
Nokia Data Center Fabric Fundamentals Exam Sample Questions (Q12-Q17):NEW QUESTION # 12
Examine the exhibit. What type of information is NOT included in the IMET route advertised by VTEP1?
  • A. IP address of VTEP1
  • B. Route distinguisher of VTEP1's MAC-VRF
  • C. VXLAN network identifier (VNI)
  • D. Flooding list
The IMET route includes the VNI, flooding list, and IP address of the originating VTEP, but it does not include the route distinguisher of the VTEP's MAC-VRF.
NEW QUESTION # 13
Which of the following statements about SR Linux interfaces is FALSE?
  • A. Only one management interface is allowed.
  • B. Layer 2 parameters such as MTU are configured at the SR Linux interface level while Layer 3 parameters are configured at the subinterface level.
  • C. The loopback interface is a physical interface directly connected to another interface on the same chassis.
  • D. Network interfaces are associated with physical ports on the linecards.
The loopback interface in SR Linux is a logical, virtual interface used for management and routing purposes; it is not a physical interface directly connected to another interface on the same chassis.
NEW QUESTION # 14
How are LLDP frames advertised between two Nokia SR Linux routers?
  • A. They are forwarded to the destination node based on the MAC VRF table.
  • B. They are periodically flooded to the broadcast MAC address on each interface.
  • C. They are routed to the destination node based on the IP VRF forwarding table.
  • D. They are forwarded to the destination node based on the MAC VRF table.
LLDP frames are periodically sent to a well-known multicast MAC address on each interface to discover directly connected devices.
NEW QUESTION # 15
Which of the following statements about the IRB subinterface configuration in Nokia SR Linux is FALSE?
  • A. One IRB subinterface is configured in a MAC-VRF network instance.
  • B. An IP address is configured under the IRB's subinterface.
  • C. One IRB subinterface is configured for each interface within a MAC-VRF network instance.
  • D. An IRB subinterface is configured in an IP-VRF network instance.
In Nokia SR Linux, IRB subinterfaces are configured one per MAC-VRF network instance, not one for each interface within that instance. Multiple IRB subinterfaces per interface are not typical.
NEW QUESTION # 16
A static route is configured in two steps in Nokia's SR Linux. Which of the following items CANNOT be configured in the static-routes container?
  • A. Preference value
  • B. Next-hop group
  • C. IPv4 destination prefix
  • D. blackhole
The static-routes container in Nokia SR Linux does not support configuring a blackhole route directly; it is used to configure destination prefixes, preference values, and next-hop groups for static routing.
NEW QUESTION # 17
Customizable Nokia Data Center Fabric Fundamentals Exam (4A0-D01) exam conditions in such a way that you can create your desired 4A0-D01 exam with pre-determined questions and exam duration. You will be able to see instant results after going through the 4A0-D01 Practice Exam To confirm the product licence. For customer satisfaction, FreeCram has also designed a Nokia Data Center Fabric Fundamentals Exam (4A0-D01) demo version so the candidate can assure the reliability of the Nokia PDF Dumps.
Latest 4A0-D01 Exam Topics: https://www.freecram.com/Nokia-certification/4A0-D01-exam-dumps.html
DOWNLOAD the newest FreeCram 4A0-D01 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1eD0gibmmGVvCcTf0wQPXUcsJn-hls5p3
