[General] Get High Hit Rate Test OGBA-101 Vce Free and Pass Exam in First Attempt
76
General Get High Hit Rate Test OGBA-101 Vce Free and Pass Exam in First Attempt
Posted at 1/17/2026 01:16:20      View139 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free & New OGBA-101 dumps are available on Google Drive shared by CertkingdomPDF: https://drive.google.com/open?id=1khp7-THqph22Gt9IwyqkvJA2_1zVAkCK
Many times getting a right method is important and more efficient than spending too much time and money in vain. Our CertkingdomPDF team devote themselves to studying the best methods to help you pass OGBA-101 exam certification. From the time when you decide whether to purchase our OGBA-101 exam software or not, we have provided you with comprehensive guarantees, including free demo download before buying, payment guarantee in purchase process, one-year free update service after you purchased OGBA-101 Exam software, and full refund guarantee of dump cost if you fail OGBA-101 exam certification, which are all our promises to ensure customer interests.
The Open Group OGBA-101 Exam Syllabus Topics:
  • TOGAF Business Scenario method: The focal point of this OGBA-101 exam topic is the application of the TOGAF Business Scenario method.
  • Development of a Business Architecture: This topic explains how a Business Architecture is developed with the TOGAF ADM.
  • Information Mapping: The topic is all about applying information mapping when developing a TOGAF Business Architecture.
  • TOGAF ADM: This topic of the OGBA-101 Exam gives TOGAF business architects an introduction to the TOGAF ADM, its objectives, and usage.
Quiz 2026 OGBA-101: TOGAF Business Architecture Foundation Exam CUpdated Test Vce FreeIt is our consistent aim to serve our customers wholeheartedly. Our OGBA-101 real exam try to ensure that every customer is satisfied, which can be embodied in the convenient and quick refund process. Although the passing rate of our OGBA-101 training quiz is close to 100%, if you are still worried, we can give you another guarantee: if you don't pass the exam, you can get a full refund. So there is nothing to worry about, just buy our OGBA-101 exam questions.
The Open Group TOGAF Business Architecture Foundation Exam Sample Questions (Q31-Q36):NEW QUESTION # 31
Consider the following chart:
Which important concept for Enterprise Architecture Practitioners does it illustrate?
  • A. An Enterprise Architecture must be developed in phases with a limited fixed duration.
  • B. ADM phases must be run simultaneously until the relevant information has been produced
  • C. Enterprise Architects must use Gantt charts to communicate with Stakeholders.
  • D. ADM phases must be run in a sequenced approach to produce the Architecture
The chart depicted is a Gantt chart, which typically represents the schedule for project activities. In the context of TOGAF's ADM, it is used to illustrate the sequence and interdependencies of tasks across different phases of architecture development. The ADM is an iterative cycle that includes various phases, from the preliminary phase, through architecture vision, business, information systems, and technology architectures, to opportunities and solutions, migration planning, implementation governance, and architecture change management. Each phase must be conducted in a sequence to ensure that the outputs of one phase feed into the next, thereby producing a coherent and structured architecture.
NEW QUESTION # 32
Consider the following:
You need to analyze a new value stream within the scope of a project.
Which of the following would you use?
  • A. Combining information mapping with a business process model.
  • B. An organization chart showing the business units that work with the enterprise and their value.
  • C. Heat mapping by value stream stages.
  • D. Converting the value stream stages to entities and then building a logical data model
A new or existing value stream can be analyzed within the scope of a project through heat mapping by value stream stages4. Heat mapping is a technique that can be used to show a range of different perspectives on a value stream map, such as maturity, effectiveness, performance, and value or cost contribution of each activity in the value stream4. Different attributes determine the colors of each activity on the value stream map. Heat mapping can help to identify strengths, weaknesses, opportunities, and threats in the value stream.
NEW QUESTION # 33
Consider the following example using the Business Model Canvas:
What are the segments labeled A, D and I?
  • A. Customer Segments, Value Add Services, Profit Channels.
  • B. Customer Relationships, Value Propositions, Market Segments.
  • C. Key Resources. Revenue Streams. Cost Structure
  • D. Key Partners, Customer Relationships, Revenue Streams.
The segments labeled A, D and I in the Business Model Canvas are Key Partners, Customer Relationships, and Revenue Streams respectively1. The Business ModelCanvas is a tool that can be used to describe how an organization creates, delivers, and captures value for its stakeholders1. The Business Model Canvas consists of nine segments that cover four main areas: customers (segments B,C,D), offer (segment E), infrastructure (segments A,F,G), and financial viability (segments H,I)1. The segments are defined as follows:
* Key Partners (segment A): The network of suppliers and partners that make the business model work1. Key partners can provide resources, activities, or support that enable the organization to offer its value proposition1.
* Customer Relationships (segment D): The type of relationship that the organization establishes with its customer segments1. Customer relationships can be driven by customer acquisition, retention, or loyalty objectives1. Customer relationships can also influence the customer experience and satisfaction1.
* Revenue Streams (segment I): The sources of income that the organization generates from each customer segment1. Revenue streams can be derived from different pricing mechanisms, such as asset sale, subscription, fee, commission, or advertising1. Revenue streams can also reflect the value that customers are willing to pay for the organization's offer1.
NEW QUESTION # 34
Consider the following business capability map. where cells of a model are given different colors to represent maturity levels (note the letters G, R. Y. P also denote the colors used = Green, Red. Yellow and Purple):
Which of the following best describes this technique?
  • A. Capability Mapping
  • B. Heat Mapping
  • C. Perspective Analysis
  • D. Gap Analysis
The technique shown in the example is called heat mapping. It is a technique that can be used to show a range of different perspectives on a business capability map, such as maturity, effectiveness, performance, and value or cost contribution of each capability to the business2. Different attributes determine the colors of each capability on the business capability map. Heat mapping can help to identify strengths, weaknesses, opportunities, and threats in the business architecture.
https://governance.foundation/as ... ess%20Capbility.pdf Table 3: Heat Map for ABC Company's Business Capabilities
NEW QUESTION # 35
What are the following activities part of?
* Initial risk assessment
* Risk mitigation and residual risk assessment
* Risk monitoring
  • A. Risk Management
  • B. Security Architecture
  • C. Phase C
  • D. Phase A
NEW QUESTION # 36
Do you want to obtain your OGBA-101 study materials as quickly as possible? If you do, then we will be your best choice. You can receive downloading link and password with ten minutes after buying. In addition, OGBA-101 exam dumps are high quality, because we have experienced experts to edit, and you can pass your exam by using OGBA-101 Exam Materials of us. In addition, we are pass guarantee and money back guarantee, if you fail to pass the exam by using OGBA-101 study materials of us, we will give you full refund. And the money will be returned to your payment account.
OGBA-101 Valid Exam Materials: https://www.certkingdompdf.com/OGBA-101-latest-certkingdom-dumps.html
DOWNLOAD the newest CertkingdomPDF OGBA-101 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1khp7-THqph22Gt9IwyqkvJA2_1zVAkCK
Posted at 1/21/2026 09:52:53        Only Author  2#
This article has been very helpful to me, and many of the ideas have been very inspiring. ITIL4-DPI reliable test lab questions test questions are now free. Good luck with your exams!
