[General] ISQI CTFL-ATԇY & CTFL-ATԇY
103
General ISQI CTFL-ATԇY & CTFL-ATԇY
Posted at 1/17/2026 03:23:49      View158 | Replies2        Print      Only Author   [Copy Link] 1#
2026JapancertCTFL-AT PDFפCTFL-ATԇY󥸥ΟoϹУhttps://drive.google.com/open?id=1GyOl5UthaPs6feILSOEfYY30dEDRgvza
CTFL-ATԇY}ˤꡢ3ĤΥЩ`PDFЩ`PCЩ`APP饤Щ`󤬏ޤѧCTFL-ATѧɤmʥЩ`xkǤޤ CTFL-ATȥ`˥󥰜ʂθЩ`ϡޤޤԤȤޤޤʹ÷ѺޤȤСCTFL-ATɥȥȤAPP饤Щ`ϡWeb֥饦˻ŤʹäOӋƤꡢ֥饦䤨CʹäǤޤԇYߥ`󡢕rgԇYg`ΙCܤ򏊻ޤ
ISQI CTFL -ATISTQBJƥ` - A٥뒈 - 㥤ƥ`JԇYϡ㥤뷽Փ˽򵱤Ƥեȥƥ`Υ`ХJ줿JǤJϡTҤ㥤ƥȤԭtȌgȫ⤹Τ֧Ԯ褦OӋƤޤϡ㥤ƥȤ֪Rȥ򒈴󤷡եȥƥȘIΥꥢҊͨƤˤmǤ
ISQI CTFL -ATISTQBJƥ` - A٥뒈 - 㥤ƥ`JԇYϡ㥤_khǤΥƥȤ˽򵱤ƤĤJ줿JǤJϡ㥤ƥȼgĩ`롢ӷՓˤ֪Rȥg^T򤱤OӋƤޤ CTFL-ATJԇYϡˤꥢҊͨ򏊻㥤ƥȤΌT֪Rg^ΤmʷǤ
CTFL-ATԇYCTFL-ATձZ饤Ȥϡ֧BˤȤˡuƷ`ɤCTFL-ATѧ̲ĤʹäǤޤ˽Υƥϡ֧BɹƤ5〜10CTFL-ATѧʂ`ʽǥ饤ȤŤޤ`ϥ󥯤ṩޤ饤ȤΤߤ󥯤򥯥åȡ˥եȥ˥󤷤CTFL-ATYϤѧǤޤ饤ȤCTFL-ATȥ`˥󥰥ُ뤹ޤꡢJapancertuƷʹäƕrg򹝼sǤޤ
ISQI CTFL-ATԇYϡ㥤ʥƥַˤ֪Rȥ򒈴󤷤եȥƥ`ˤȤäƃ줿JYǤJYϥեȥƥȘIǸߤuܤƤꡢߤ¤ʥꥢ󥹤⤿餹ȤǤޤ
ISQI ISTQB Certified Tester - Foundation Level Extension - Agile Tester J CTFL-AT ԇY} (Q48-Q53):| # 48
Which of the following statements about the Planning poker test estimate technique are CORRECT?
1) Planning poker is a consensus based technique using a deck of cards.
2) A low test estimate usually means the story should be broken down into multiple smaller stories.
3) A high test estimate usually means the story should be broken down into multiple smaller stories.
4) One poker round is played and then consensus has to be reached.
5) The risk level of each backlog item should be decided before the poker session.
  • A. 1, 2, 3
  • B. 1, 2, 4
  • C. 2, 3, 4
  • D. 1, 3, 5
⣺D
h
Planning poker is a consensus-based technique for agile estimation, using a deck of cards with predefined numerical values, usually based on the Fibonacci sequence or a modified version12. Therefore, statement 1 is correct. A high test estimate usually means that the user story or task is too complex, ambiguous, or risky, and should be broken down into multiple smaller stories that are easier to understand and estimate13. Therefore, statement 3 is correct. The risk level of each backlog item should be decided before the poker session, as it can affect the estimation process and the prioritization of the work14. Therefore, statement 5 is correct. Statement 2 is incorrect, as a low test estimate usually means that the user story or task is simple, clear, and well-defined, and does not need to be broken down further13. Statement 4 is incorrect, as planning poker can involve multiple rounds of estimation, reveal, and discussion, until the team reaches a consensus or agrees to defer the item12. References: 1: ISTQB Foundation Level Agile Tester Syllabus, Section 3.3.1, Test Automation1; 2: ASTQB Agile Tester Certification Resources, Section 3.3.1, Test Automation2; 3:
Planning Poker: An Agile Estimating and Planning Technique3; 4: Planning poker: The all-in strategy for Agile estimation - Asana4
| # 49
Which of the following statements about the benefits of the Agile processes promoting early and frequent feedback is NOT true?
  • A. Feedback from well-conducted Agile retrospectives can be used to positively affect the development process over the course of the next iteration.
  • B. Increasing the frequency of feedback and communication between all the stakeholders involved in Agile projects eliminates all communication problems.
  • C. Early and frequent feedback enables the team to deliver the features that represent the highest business value to the customer first.
  • D. In Agile projects where feedback is provided early and frequently, defects and incorrect requirements are caught earlier and those problems can be fixed faster.
⣺B
| # 50
Which of the following statements is FALSE regarding early and frequent feedback?
  • A. Early feedback helps to deliver a product that better reflects what the customer wants.
  • B. Early feedback promotes early discovery and resolution of quality problems.
  • C. Early feedback decreases the amount of time needed for system testing.
  • D. Early feedback provides the Agile team with information on its productivity.
⣺C
h
Early and frequent feedback is one of the core values of Agile development. It helps the Agile team to deliver features with the highest business value first, to discover and resolve quality problems as soon as possible, to provide information on the team's productivity and progress, and to ensure that the product meets the customer's expectations and needs. However, early feedback does not necessarily decrease the amount of time needed for system testing, as system testing is still an important activity in Agile projects to verify the integration and functionality of the whole system. Early feedback may reduce the number of defects found in system testing, but it does not eliminate the need for system testing. References: ISTQB Foundation Level Agile Tester Extension Syllabus1, page 10; ISTQB Agile Tester Sample Exam2, question 11.
| # 51
Which of the following sentences about the integration of development and testing activities in Agile projects is INCORRECT?
  • A. While developers develop automated unit test scripts, testers write automated system level tests.
  • B. Developers write acceptance criteria and test cases, together with testers.
  • C. Developers and testers may work as a pair to develop and test a feature.
  • D. Testers replace developers in writing unit test automation scripts.
⣺D
h
Testers replace developers in writing unit test automation scripts. Comprehensive Explanation: The integration of development and testing activities in Agile projects is based on the principle of cross-functional teamwork, where all team members collaborate and share their skills and knowledge to achieve a common goal. In the context of testing, this means that testing is not seen as a separate activity or phase, but as an integral part of the development process. Therefore, the following sentences are correct:
While developers develop automated unit test scripts, testers write automated system level tests. This is an example of how developers and testers can work in parallel and complement each other's testing efforts. Developers can focus on testing the internal quality of the code, while testers can focus on testing the external quality of the product.
Developers write acceptance criteria and test cases, together with testers. This is an example of how developers and testers can work together to define and verify the user requirements and expectations.
Developers can provide their technical expertise and input, while testers can provide their business and user perspective and feedback.
Developers and testers may work as a pair to develop and test a feature. This is an example of how developers and testers can work closely and interactively to deliver a feature. Developers and testers can exchange ideas, suggestions, and information, and support each other in the coding and testing tasks.
The following sentence is incorrect:
Testers replace developers in writing unit test automation scripts. This is not a valid example of the integration of development and testing activities in Agile projects, because it implies that testers take over the responsibility of developers, rather than collaborate with them. Testers should not replace developers in writing unit test automation scripts, because developers have more knowledge and experience in coding and debugging, and because unit testing is an essential part of the development process. Testers should instead work with developers to ensure that the unit test automation scripts are adequate, effective, and maintainable. References: ISTQB Foundation Level Agile Tester Syllabus1, Section 1.2.1, page 9; ISTQB Glossary of Testing Terms2, version 4.0, pages 16 and 55.
| # 52
⣺C
h
| # 53
CTFL-ATԇY: https://www.japancert.com/CTFL-AT.html
oϤǥ饦ɥȥ`¤Japancert CTFL-AT PDFפ`ɤ룺https://drive.google.com/open?id=1GyOl5UthaPs6feILSOEfYY30dEDRgvza
Posted at 2/7/2026 11:10:04        Only Author  2#
Die Prfungsfragen und Antworten zur PMI PMI-PMOCP Zertifizierungsprfung von EchteFrage wird von unserem Expertenteam nach ihren umfangreichen Kenntnissen und Erfahrungen berarbeitet. Sie können die Bedrfnisse der Kandidaten abdecken. Sie finden vielleicht in anderen Bchern oder auf anderen Websites auch die PMI PMI-PMOCP Schulungsunterlagen. Aber die Schulungsunterlagen von EchteFrage sind die umfassendste unter ihnen und zugleich kann Ihnen die beste Garantie geben. Bitte wählen Sie die PMI PMI-PMOCP Prfungsfragen und Antworten von EchteFrage.
Posted at 2/17/2026 05:05:15        Only Author  3#
I feel much more knowledgeable after reading it. Upgrade your IT skills with free PTCE latest test sample. Best wishes for your success!
