PDII Sample Test Online - PDII Exams Training
Posted at 1/17/2026 04:06:47
DOWNLOAD the newest Test4Sure PDII PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1_4mS6E1EBtk59_2Xim6J30wOUDt0E7I0
The Platform Developer II (PDII) questions are being offered in three easy-to-use and different formats. These formats are Salesforce Dumps PDF, desktop-based Salesforce PDII practice test software, and web-based PDII practice exam. All these three PDII Exam Dumps formats contain real, valid, and updated PDII exam questions that surely repeat in the upcoming PDII exam and you can easily pass the Salesforce PDII exam on the first attempt.
Earning the Platform Developer II (PDII) exam credential is undoubtedly a big achievement. No matter how hard the Platform Developer II (PDII) test of this certification is, it serves the important purpose to validate skills in the Salesforce industry. Once you crack the Platform Developer II (PDII) exam, a whole new career scope opens up for you. Candidates for the Platform Developer II (PDII) exam dumps usually don't have enough time to study for the test. To prepare successfully in a short time, you need a trusted platform of real and updated Platform Developer II (PDII) exam dumps.
Salesforce PDII Exams Training & Valid PDII Guide FilesThe Salesforce PDII web-based practice test software is very user-friendly and simple to use. It is accessible on all browsers (Chrome, Firefox, MS Edge, Safari, Opera, etc). It will save your progress and give a report of your mistakes which will surely be beneficial for your overall exam preparation.
Salesforce Platform Developer II Sample Questions (Q131-Q136):NEW QUESTION # 131
Account object has a field, Audit_Code__, that is used to specify what type of auditing the Account needs and a Lookup to user, Auditor__ that is the assigned auditor.
When an Account is initially created, the user specifies the Audit_Code__. Each User in the org has a unique text field, that is used to automatically assign the correct user to the Account Auditor__ field.
What should be changed to most optimize the code's efficiency?
Choose 2 answers
- A. Add an initial SOQL query to get all distinct audit codes.
- B. Add a WHERE clause to the SOQL query to filter On audit codes.
- C. Build a Map <Id, List<String>> of Account Id to audit codes.
- D. Build a Map<String, List<Account>> of audit code to accounts.
NEW QUESTION # 132
A company has a native iOS order placement app that needs to connect to Salesforce to retrieve consolidated information from many different objects in a JSON format.
Which is the optimal method to implement this in Salesforce?
- A. Apex SOAP callout
- B. Apex REST web service
- C. Apex SOAP web service
- D. Apex REST callout
Apex REST web services are the best method for creating custom endpoints that return data in a specific format, such as JSON, which is perfect for a native iOS application that needs to integrate with Salesforce for retrieving data.
References: Apex Developer Guide - Exposing Apex Methods as REST Web Services
NEW QUESTION # 133
As part of a custom development, a developer creates a Lightning Component to show how a particular opportunity progresses over time. The component must display the date stamp when any of the following fields change:
* Amount Probability, Stage, or Close Date
What is the most efficient way to Query such information?
- A. ('StageName', Probability',Amount /CloseDate')];
- B. [Select Amount CloseDate. StageName, Probability FROM Opportunity_History WHERE Opportunityld -
ppId]; - C. [Select Amount, CloseDate, StageName, Probability FROM OpportunityHistory WHERE Opportunityld
= ppId]; - D. [Select NewValue, Oldvalue FROM Opportunity FieldHistory WHERE Opportunityld =
ppId AND Field IN - E. [Select Newvalue, Oldvalue From OpportunityField_History Where Oppportunity = oppid AND Field IN
NEW QUESTION # 134
A developer created three Rollup Summary fields: Total_timesheets_c, Total_Approved_timesheet_c and Total_project_Timesheet_c in the custom object, project _c Now, the developer is tasked with created a new field to show the ratio between and approved
- A. A formula field will calculate the value retroactively for existing records.
- B. Using a formula field reduces maintenance overhead.
- C. A test class that validates the formula field is needed for deployment.
- D. No test methods will be executed during deployment.
NEW QUESTION # 135
A company uses Dpportunities to track sales to their customers and their org has millions of Opportunities.
They want to begin to track revenue over time through a related Revenue object.
As part of their initial implementation, they want to perform a one-time seeding of their data by automatically creating and populating Revenue records for Opportunities, based on complex logic.
They estimate that roughly 100,000 Opportunities will have Revenue records created and populated.
What is the optimal way to automate this?
- A. Use system, enqueuJob (| to invoke a gueusable class.
- B. Use Database. executeBatch () to invoke a Queueable class.
- C. Use system, acheduladeb() to schedule a patakape.Scheduleable class.
- D. Use Database. =executeBatch() to invoke a Database. Batchable class.
For a one-time bulk operation on a large data set, using a Database.Batchable class is the best approach. This allows complex logic to be processed in manageable chunks and efficiently manages system resources.References: Apex Developer Guide - Using Batch Apex
NEW QUESTION # 136
In modern society, you cannot support yourself if you stop learning. That means you must work hard to learn useful knowledge in order to survive especially in your daily work. Our PDII learning questions are filled with useful knowledge, which will broaden your horizons and update your skills. Lack of the knowledge cannot help you accomplish the tasks efficiently. But our PDII Exam Questions can help you solve all of these probelms. And our PDII study guide can be your work assistant.
PDII Exams Training: https://www.test4sure.com/PDII-pass4sure-vce.html
Updating: you will be allowed to free update PDII Exams Training - Platform Developer II exam pdf one-year after you buy, Salesforce PDII Sample Test Online In fact, you just suffer from inadequate capacity, Countless PDII exam software users of our Test4Sure let us have the confidence to tell you that using our test software, you will have the most reliable guarantee to pass PDII exam, If for any reason, a candidate fails in PDII exam then he will be refunded his money after the refund process.
Once the ground rules are established, it is time to identify PDII potential sources of evidence, At any rate, it is best to get into the habit of creating valid and well-formed documents.
Updating: you will be allowed to free update Platform Developer II exam pdf one-year after you buy, In fact, you just suffer from inadequate capacity, Countless PDII Exam software users of our Test4Sure let us have the confidence to tell you that using our test software, you will have the most reliable guarantee to pass PDII exam.
Salesforce - PDII - Pass-Sure Platform Developer II Sample Test OnlineIf for any reason, a candidate fails in PDII exam then he will be refunded his money after the refund process, Your life will be even more exciting.
- Updated Salesforce PDII PDF Dumps For Quick Preparation 🔯 The page for free download of ➤ PDII ⮘ on 《 [url]www.examcollectionpass.com 》 will open immediately 🐯
DII Vce Exam[/url] - Free PDF Salesforce PDII First-grade Platform Developer II Sample Test Online 🥾 Easily obtain ⮆ PDII ⮄ for free download through ➤ [url]www.pdfvce.com ⮘ 👛
DII Test Dumps Pdf[/url] - Salesforce Reliable PDII Sample Test Online – Pass PDII First Attempt 🐠 Easily obtain free download of ➠ PDII 🠰 by searching on ➤ [url]www.practicevce.com ⮘ 🛣Download PDII Demo[/url]
- PDII Free Braindumps 🥔 PDII Passing Score 🔩 PDII Test Engine 🪕 Easily obtain ( PDII ) for free download through ▶ [url]www.pdfvce.com ◀ ❓Valid Test PDII Bootcamp[/url]
- Real Salesforce Exam Questions And Answers From PDII 😎 【 [url]www.prepawaypdf.com 】 is best website to obtain 「 PDII 」 for free download 🥵
DII Dump Check[/url] - Updated Salesforce PDII PDF Dumps For Quick Preparation 💟 Open “ [url]www.pdfvce.com ” enter ▛ PDII ▟ and obtain a free download 🌄
DII Test Dumps Pdf[/url] - Reliable PDII Braindumps Files 🤶 PDII Latest Exam Dumps 🚄 Reliable PDII Braindumps Files 🦐 Open ✔ [url]www.troytecdumps.com ️✔️ enter ➡ PDII ️⬅️ and obtain a free download 🎫Reliable PDII Braindumps Files[/url]
- Free PDF 2026 PDII: Platform Developer II –Trustable Sample Test Online 🌏 Search for ➡ PDII ️⬅️ and obtain a free download on ☀ [url]www.pdfvce.com ️☀️ 🖋
DII Related Exams[/url] - Real Salesforce Exam Questions And Answers From PDII ⛺ Search for ⇛ PDII ⇚ on { [url]www.prepawayexam.com } immediately to obtain a free download 🤓
DII Free Braindumps[/url] - 2026 PDII Sample Test Online | Excellent 100% Free PDII Exams Training 🔙 Enter 【 [url]www.pdfvce.com 】 and search for ▶ PDII ◀ to download for free 😚Download PDII Demo[/url]
- New PDII Exam Pdf 🧶 PDII Free Braindumps 🥱 PDII Test Dumps Pdf 🪕 Easily obtain free download of ☀ PDII ️☀️ by searching on ➠ [url]www.examdiscuss.com 🠰 🌏Reliable Exam PDII Pass4sure[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, hearthis.at, www.wcs.edu.eu, kurs.aytartech.com, doxaglobalnetwork.org, www.stes.tyc.edu.tw, bbs.810706.cn, Disposable vapes
