[Android] Modifying Kernel Command Line on Android12.0
19
Android Modifying Kernel Command Line on Android12.0
Posted at 12/6/2022 02:08:14      View3535 | Replies3        Print      Only Author   [Copy Link] 1#
  • Type: Self-Compiled Firmware
  • SDK Package Name: Android12.0 (Linux v5.10)
  • Last Commit: 0000-00-00 00:00:00
  • Modification Content: No modifications
  • Log: dmesg-cmdline.zip
Hello everyone!
I would like to modify kernel command line (i.e. parameter) on ROC-RK3588S-PC running Android12.0 (Linux v5.10).
I have tried adding CONFIG_CMDLINE in its config file, but it unfortunately doesn't work
Could anyone give me some directions on how I should modify the command line? (perhaps thorugh bootloader?)
FYI, I have self-compiled Android12.0 SDK provided by Firefly without making any modifications.
Any help would be appreciated!
dmesg-cmdline.zip
537 Bytes, Down times: 3
Posted at 12/6/2022 15:22:41        Only Author  2#
If you want to add the content of command line, you could try to add it here
./kernel-5.10/arch/arm64/boot/dts/rockchip/rk3588-android.dtsi
chosen: chosen {
                bootargs = "earlycon=uart8250,mmio32,0xfeb50000 console=ttyFIQ0 irqchip.gicv3_pseudo_nmi=0";
Posted at 1/20/2026 18:19:29        Only Author  3#
What an extraordinary piece of writing, thank you for sharing! Im sharing the Fire-Inspector-II detailed study dumps test that helped me achieve a promotion and raise. It's free for you todaybest of luck in reaching your career goals!
Posted at 1/28/2026 06:06:37        Only Author  4#
Your article is nothing short of incredible, I truly appreciate it! Enhance your IT expertisefree Reliable C-P2WFI-2023 dumps ppt available now! Best wishes for success!
