[General] Premium JN0-363 Exam | JN0-363 Questions Pdf
98
【General】 Premium JN0-363 Exam | JN0-363 Questions Pdf
Posted at 1/17/2026 05:54:35      View:135 | Replies:3        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest PassLeaderVCE JN0-363 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1QfkFFlPeV9jCsk9fWuZPG5hDqpMKYkhb
As the captioned description said, our JN0-363 practice materials are filled with the newest points of knowledge about the exam. With many years of experience in this line, we not only compile real test content into our JN0-363 practice materials, but the newest in to them. Allowing for there is a steady and growing demand for our JN0-363 practice materials with high quality at moderate prices, we never stop the pace of doing better. All newly supplementary updates will be sent to your mailbox one year long. And we shall appreciate it if you choose any version of our JN0-363 practice materials for exam and related tests in the future.
How to realize your dream? PassLeaderVCE Juniper JN0-363 braindump is the royal road to success when preparing for Juniper JN0-363 test. PassLeaderVCE provide you with exam prep, which will pass the exam with assurance.
JN0-363 exam torrent pdf & JN0-363 latest vce & JN0-363 training vceAll these three Juniper JN0-363 exam questions formats are easy to use and perfectly work with all devices, operating systems, and the latest web browsers. The Service Provider Routing and Switching, Specialist (JNCIS-SP) (JN0-363) PDF dumps file is the collection of real and updated Service Provider Routing and Switching, Specialist (JNCIS-SP) (JN0-363) exam questions that are being presented in PDF format. You can install JN0-363 Pdf Dumps file on your desktop computer, laptop, tab, or even on your smartphone devices. Just install the JN0-363 PDF dumps file and start Service Provider Routing and Switching, Specialist (JNCIS-SP) (JN0-363) exam preparation anywhere and anytime.
Juniper JN0-363 exam is designed for individuals who want to become experts in service provider routing and switching. It is a specialist-level certification exam that focuses on the advanced knowledge and skills required to manage and configure Juniper Networks routers and switches in a service provider environment. Passing JN0-363 Exam will demonstrate your expertise in routing and switching technologies and your ability to design and implement complex network solutions.
Juniper Service Provider Routing and Switching, Specialist (JNCIS-SP) Sample Questions (Q44-Q49):NEW QUESTION # 44
Click the Exhibit.
Referring to the configuration in the exhibit, which two statements are true? (Choose two.)
  • A. The next-hop 172.16.1.2 must be part of an active route in route table inet 0 for route 192.168.5.0/24 to be active.
  • B. The next-hop 172.16.1.2 must respond to ping commands for the route 192.168.5.0/24 to be active.
  • C. The next-hop 172.16.1.2 must be active in route table inet 3 for the route 192.168.5.0/24 to be active.
  • D. The next-hop 172.16.1.2 must be directly connected to the router for route
NEW QUESTION # 45
You are asked to configure an LSP which uses the OSPF link state database for path computations. Which two statements are correct in this scenario? (Choose two.)
  • A. You must use the policing parameter in the label-switched-path configuration.
  • B. Traffic engineering extensions are not enabled by default in OSPF.
  • C. Traffic engineering extensions ate enabled by default In OSPF.
  • D. You must use the no-cspf parameter in the label-switched-path configuration.
In Junos OS, traffic engineering extensions for OSPF, which are required for an LSP to use the OSPF link state database for path computations, are not enabled by default. They must be explicitly enabled in the OSPF configuration. Therefore, answer C is correct. Answer B is incorrect and contradicts C. The 'no-cspf' command would disable CSPF (Constrained Shortest Path First), which is used for path computations in MPLS traffic engineering, so it should not be used if you want the LSP to utilize OSPF's link state database for path computations. Therefore, answer A is incorrect. The 'policing' parameter is not relevant to enabling traffic engineering extensions in OSPF, so answer D is incorrect.
Juniper Networks documentation on OSPF and Traffic Engineering: Configuring OSPF Traffic Engineering
https://www.juniper.net/document ... ng-ospf-support-for
NEW QUESTION # 46
Exhibit
Which prefix in the output shown in the exhibit is an external prefix injected by an OSPF router?
  • A. 172.26.4.0730
  • B. 192.108.1.4
  • C. 192.168.1.3
  • D. 172.18.1.0/24
NEW QUESTION # 47
What are three well-known mandatory BGP attributes? (Choose three.)
  • A. next hop
  • B. MED
  • C. AS path
  • D. community
  • E. origin
Answer: A,C,E
There are four categories of BGP attributes:
Well-known mandatory: Recognized by all BGP peers, passed to all peers, and present in all Update messages. Well-known mandatory attributes include:- Next- hop- Origin- AS PATH Well-known discretionary: Recognized by all routers, passed to all peers, and optionally included in the Update message. Well-known discretionary attributes include:- Local Preference - Atomic Aggregate Optional transitive: Possibly recognized by BGP routers and passed to BGP peers. Optional transitive attributes are marked as partial when not recognized.
Optional transitive attributes include: - Aggregator - Community
Optional non-transitive: Possibly recognized by BGP routers but not passed to peers. Optional non-transitive attributes include:- Multi-exit discriminator (MED) - Originator ID -Cluster-ID
NEW QUESTION # 48
Click the Exhibit button. Which two topologies shown in the exhibit could be implemented without a spanning-tree protocol? (Choose two.)
  • A. star
  • B. mesh
  • C. tree
  • D. ring
NEW QUESTION # 49
According to our information there is a change for JN0-363, I advise you to take a look at our latest Juniper JN0-363 reliable exam guide review rather than pay attention on old-version materials. You can regard old-version materials as practice questions to improve your basic knowledge. If you are searching the valid JN0-363 Reliable Exam Guide review which includes questions and answer of the real test, our products will be your only choice.
JN0-363 Questions Pdf: https://www.passleadervce.com/JNCIS-SP/reliable-JN0-363-exam-learning-guide.html
Posted at 1/30/2026 12:37:15        Only Author  2#
This content is worth every like. Reasonable MB-280 exam price provides superb materials free of charge.
Posted at 2/1/2026 08:00:25        Only Author  3#
Your article left me in awe, I’m grateful for your share! Improve your IT abilities—free Discount DA0-001 code now available! Good luck!
Posted at 2/15/2026 21:24:17        Only Author  4#
This article is absolutely stunning, thank you for sharing! Here’s a free share of JN0-650 exam certification cost exam resources—good luck to you all!
