[General] HP HPE6-A78 Latest Exam Dumps - HPE6-A78 Valid Exam Practice
72
【General】 HP HPE6-A78 Latest Exam Dumps - HPE6-A78 Valid Exam Practice
Posted at 1/17/2026 06:50:11      View:144 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 HP HPE6-A78 dumps are available on Google Drive shared by DumpsMaterials: https://drive.google.com/open?id=1RzIIaxY0bgTBi6ZzToCYamPzcUIizbbE
We stick to the principle "Credit management first and first class service". While purchasing our HPE6-A78 exma questions, not only you have no need to worry about the quality of our HPE6-A78 exam materials quality but also our service is satisfying on the HPE6-A78 study guide. We promise buyers “Pass Guaranteed” and we only offer the latest HPE6-A78 Training Materials. If you would like to choose safely high passing rate of HPE6-A78 exam torrent materials, our HPE6-A78 learning guide will be the first choice for you.
HP HPE6-A78 exam is a certification exam for individuals who want to become Aruba Certified Network Security Associates. Aruba is a subsidiary of Hewlett Packard Enterprise that specializes in wireless networking equipment and software. HPE6-A78 Exam focuses on testing an individual's knowledge and skills in implementing and configuring Aruba's network security solutions.
HPE6-A78 Valid Exam Practice | HPE6-A78 Valid Test TopicsWith these mock exams, it is easy to track your progress by monitoring your marks each time you go through the HPE6-A78 practice test. Our HPE6-A78 practice exams will give you an experience of attempting the HPE6-A78 original examination. You will be able to deal with the actual exam pressure better when you have already experienced it in our HP HPE6-A78 practice exams.
HP HPE6-A78 Exam is designed for IT professionals who have experience in securing enterprise-level networks. It is an Aruba Certified Network Security Associate exam that validates the skills and knowledge required to configure and manage Aruba ClearPass Policy Manager and Aruba AirWave. HPE6-A78 exam tests the candidates' ability to identify and mitigate network security threats, configure and manage firewalls, and implement secure network access policies.
HPE6-A78 certification exam is part of the Aruba Certified Network Security Associate (ACNSA) certification program. This program is designed to provide professionals with the knowledge and skills needed to secure Aruba network infrastructures. It is an important credential for network security professionals who work with Aruba products and solutions.
HP Aruba Certified Network Security Associate Exam Sample Questions (Q102-Q107):NEW QUESTION # 102
What is a difference between radius and TACACS+?
  • A. RADIUS encrypts the complete packet, white TACACS+ only offers partial encryption.
  • B. RADIUS uses Attribute Value Pairs (AVPs) in its messages, while TACACS+ does not use them.
  • C. RADIUS combines the authentication and authorization process while TACACS+ separates them.
  • D. RADIUS uses TCP for Its connection protocol, while TACACS+ uses UDP tor its connection protocol.
RADIUS and TACACS+ are both protocols used for networking authentication, but they handle the processes of authentication and authorization differently. RADIUS (Remote Authentication Dial-In User Service) combines authentication and authorization into a single process, whereas TACACS+ (Terminal Access Controller Access-Control System Plus) separates these processes. This separation in TACACS+ allows more flexible policy enforcement and better control over commands a user can execute. This difference is well-documented in various network security resources, including Cisco's technical documentation and security protocol manuals.
NEW QUESTION # 103
A company has an Aruba Instant AP cluster. A Windows 10 client is attempting to connect a WLAN that enforces WPA3-Enterprise with authentication to ClearPass Policy Manager (CPPM). CPPM is configured to require EAP-TLS. The client authentication fails. In the record for this client's authentication attempt on CPPM, you see this alert.
What is one thing that you check to resolve this issue?
  • A. whether EAP-TLS is enabled in the SSID Profile settings for the WLAN on the IAP cluster
  • B. whether EAP-TLS is enabled in the AAA Profile settings for the WLAN on the IAP cluster
  • C. whether the client has a third-party 802.1 X supplicant, as Windows 10 does not support EAP-TLS
  • D. whether the client has a valid certificate installed on it to let it support EAP-TLS
In the context of WPA3-Enterprise with EAP-TLS authentication, the error message "Client doesn't support configured EAP methods" suggests that the client is not able to complete the EAP-TLS authentication process. EAP-TLS requires that both the server (in this case, CPPM) and the client have a valid certificate for mutual authentication. Windows 10 does support EAP-TLS natively, so options A, C, and D can be ruled out.
The most likely reason for the authentication failure is that the client device does not have the correct client certificate installed, which is required to establish a TLS session with the server. Therefore, ensuring that the client has a valid certificate installed that matches the server's requirements is the correct step to resolve this issue.
NEW QUESTION # 104
Device A is establishing an HTTPS session with the Arubapedia web sue using Chrome. The Arubapedia web server sends the certificate shown in the exhibit What does the browser do as part of vacating the web server certificate?
  • A. It uses the public key in the DigCen SHA2 Secure Server CA certificate to check the certificate's signature.
  • B. It uses the public key in the DigCert root CA certificate to check the certificate signature
  • C. It uses the private key in the DigiCert SHA2 Secure Server CA to check the certificate's signature.
  • D. It uses the private key in the Arubapedia web site's certificate to check that certificate's signature
NEW QUESTION # 105
A company is deploying ArubaOS-CX switches to support 135 employees, which will tunnel client traffic to an Aruba Mobility Controller (MC) for the MC to apply firewall policies and deep packet inspection (DPI).
This MC will be dedicated to receiving traffic from the ArubaOS-CX switches.
What are the licensing requirements for the MC?
  • A. one AP license per-switch
  • B. one PEF license per-switch. and one WCC license per-switch
  • C. one AP license per-switch. and one PEF license per-switch
  • D. one PEF license per-switch
When deploying ArubaOS-CX switches that tunnel client traffic to an Aruba Mobility Controller (MC), the licensing requirements typically involve Policy Enforcement Firewall (PEF) licenses. These licenses enable the MC to enforce firewall policies and perform deep packet inspection (DPI). Therefore, for each switch tunneling traffic to the MC, a PEF license would be necessary.
NEW QUESTION # 106
What is a guideline for managing local certificates on an ArubaOS-Switch?
  • A. Generate the certificate signing request (CSR) with a program offline, then, install both the certificate and the private key on the switch in a single file.
  • B. Before installing the local certificate, create a trust anchor (TA) profile with the root CA certificate for the certificate that you will install
  • C. Install an Online Certificate Status Protocol (OCSP) certificate to simplify the process of enrolling and re-enrolling for certificate
  • D. Create a self-signed certificate online on the switch because ArubaOS-Switches do not support CA-signed certificates.
NEW QUESTION # 107
HPE6-A78 Valid Exam Practice: https://www.dumpsmaterials.com/HPE6-A78-real-torrent.html
Posted at 2/12/2026 07:53:47        Only Author  2#
Thank you for your article, it’s truly overwhelming! Here’s a free share of Valid FC0-U71 exam experience exam resources—good luck to you all!
