[General] SAP C_S4TM_2023 Exam Registration, C_S4TM_2023 Test Questions
95
【General】 SAP C_S4TM_2023 Exam Registration, C_S4TM_2023 Test Questions
Posted at 1/17/2026 07:13:51      View:116 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Prep4sures C_S4TM_2023 dumps from Cloud Storage: https://drive.google.com/open?id=1j83xqrudTNzYtHa_ha1-lVU0MoIJhnOj
In recent years, our C_S4TM_2023 Test Torrent has been well received and have reached 99% pass rate with all our dedication. As a powerful tool for a lot of workers to walk forward a higher self-improvement, our C_S4TM_2023 certification training continue to pursue our passion for advanced performance and human-centric technology. As a matter of fact, our company takes account of every client’s difficulties with fitting solutions. As long as you need help, we will offer instant support to deal with any of your problems about our SAP Certified Associate - SAP S/4HANA Cloud Private Edition - Transportation Management guide torrent. Any time is available; our responsible staff will be pleased to answer your questions.
Windows computers support the desktop practice test software. Prep4sures has a complete support team to fix issues of SAP C_S4TM_2023 PDF QUESTIONS software users. Prep4sures practice tests (desktop and web-based) produce score report at the end of each attempt. So, that users get awareness of their SAP Certified Associate - SAP S/4HANA Cloud Private Edition - Transportation Management (C_S4TM_2023) preparation status and remove their mistakes.
Pass Guaranteed Quiz C_S4TM_2023 - Pass-Sure SAP Certified Associate - SAP S/4HANA Cloud Private Edition - Transportation Management Exam RegistrationIf you still have questions with passing the exam, choose us, and we will help you pass the exam successfully. Our C_S4TM_2023 training materials contain the both the questions and answers. You can have a practice through different versions. If you prefer to practice on paper, then C_S4TM_2023 Pdf Version will satisfy you. If you want to have a good command of the C_S4TM_2023 exam dumps, you can buy all three versions, which can assist you for practice.
SAP Certified Associate - SAP S/4HANA Cloud Private Edition - Transportation Management Sample Questions (Q42-Q47):NEW QUESTION # 42
Which of the following attributes are used to define a business partner with role Driver? Note: There are
2 correct answers to this question.
  • A. Validity period
  • B. Planning profile
  • C. Non-working times and absences
  • D. Fixed assignment to a vehicle resource
Master Data
NEW QUESTION # 43
A carrier has responded to your request for quotation but was NOT automatically assigned to the freight order. What could be reasons for this? Note: There are 2 correct answers to this question.
  • A. The program to evaluate freight quotations was NOT executed.
  • B. The tendering process was set to "Direct Tendering - Send Freight Order Directly".
  • C. The tendering profile contains a subsequent step.
  • D. The carrier responded after the response time had expired.
In SAP S/4HANA Transportation Management, automatic carrier assignment during the tendering process depends on specific conditions being met. According to the SAP documentation:
* The carrier responded after the response time had expired (A)prevents automatic assignment because the tendering process only considers responses received within the defined time window. Late responses are ignored for automatic assignment.
* The program to evaluate freight quotations was NOT executed (C)means that the system did not process the carrier's response to assign it to the freight order. The evaluation program (e.g., a background job) is required to analyze quotations and assign the carrier based on criteria like cost or priority.
The other options are incorrect:
* Direct Tendering - Send Freight Order Directly (B)bypasses the quotation process and assigns the freight order directly to a carrier, so it would not prevent automatic assignment.
* The tendering profile contains a subsequent step (D)affects the sequence of tendering but does not inherently prevent automatic assignment if the response is valid and evaluated.
SAP S/4HANA Cloud Private Edition, Transportation Management Study Guide: Unit 4 - Freight Order Management, Section on Tendering and Carrier Assignment.
SAP Help Portal: Transportation Management - Tendering Process ().
NEW QUESTION # 44
What is created manually in SAP TM and assigned to the shipping point location? Please choose the correct answer.
  • A. Connecting existing manufacturing control systems
  • B. Data receivers are networked without integration gaps.
  • C. The business partner for the shipping point
NEW QUESTION # 45
In a buyer's consolidation scenario, which of the following ratios of export forwarding orders to import forwarding orders is valid?
  • A. N export forwarding orders to 1 import forwarding order
  • B. 1 export forwarding order to 1 import forwarding order
  • C. 1 export forwarding order to N import forwarding orders
  • D. N export forwarding orders to N import forwarding orders
NEW QUESTION # 46
What happens if you unassign a freight unit that has blocked a freight order because of a discrepancy?
  • A. The block remains on the freight order but is removed from the freight unit.
  • B. The block is removed from both the freight unit and the freight order.
  • C. The block remains on the freight unit and the freight order.
  • D. The block remains on the freight unit but is removed from the freight order.
In SAP S/4HANA Transportation Management, when a discrepancy (e.g., weight or quantity mismatch) is reported for a freight unit, it can trigger a block on both the freight unit and the associated freight order to prevent further processing until resolved. According to the SAP documentation, if you unassign the freight unit from the freight order, the block remains on the freight unit because the discrepancy is tied to the freight unit's data (e.g., goods details). However, the block is removed from the freight order, as the freight order is no longer associated with the discrepant freight unit and can proceed with other freight units or be replanned.
Thus,the block remains on the freight unit but is removed from the freight order (C).
* Ais incorrect because the block is tied to the freight unit's discrepancy, not the freight order after unassignment.
* Bis incorrect because the block persists on the freight unit due to the unresolved discrepancy.
* Dis incorrect because unassigning the freight unit removes the block from the freight order.
SAP S/4HANA Cloud Private Edition, Transportation Management Study Guide: Unit 1 - Transportation Management Overview and Fundamentals, Section on Discrepancy Handling and Blocking.
SAP Help Portal: Transportation Management - Discrepancy Management ().
NEW QUESTION # 47
Prep4sures C_S4TM_2023 test questions materials will guide you and help you to pass the certification exams in one shot. If you want to know our C_S4TM_2023 test questions materials, you can download our free demo now. Our demo is a small part of the complete charged version. Also you can ask us any questions about SAP C_S4TM_2023 Exam any time as you like.
C_S4TM_2023 Test Questions: https://www.prep4sures.top/C_S4TM_2023-exam-dumps-torrent.html
It is of no exaggeration to say that sometimes C_S4TM_2023 certification is exactly a stepping-stone to success, especially when you are hunting for a job, In addition, we offer you free demo for you to have a try before buying C_S4TM_2023 exam dumps, so that you can have a deeper understanding of what you are going to buy, SAP C_S4TM_2023 Exam Registration You can test the features and then place an order.
I believe that the exam price has not been set yet, Advanced Composition Settings, It is of no exaggeration to say that sometimes C_S4TM_2023 certification is exactly a stepping-stone to success, especially when you are hunting for a job.
Pass C_S4TM_2023 Exam with Pass-Sure C_S4TM_2023 Exam Registration by Prep4suresIn addition, we offer you free demo for you to have a try before buying C_S4TM_2023 Exam Dumps, so that you can have a deeper understanding of what you are going to buy.
You can test the features and then place an order, We deeply believe that the C_S4TM_2023 test torrent of our company will help you pass the C_S4TM_2023 exam and get your certification successfully in a short time too.
Using a smartphone, you may go through the SAP C_S4TM_2023 exam questions whenever and wherever you desire.
