JN0-224 Premium Exam & JN0-224 Certification Practice
101
Posted at 1/17/2026 08:21:54      View131 | Replies2        Print      Only Author   [Copy Link] 1#
The world is rapidly moving forward due to the prosperous development of information. Our company is also making progress in every side. The first manifestation is downloading efficiency. A lot of exam candidates these days are facing problems like lacking of time, or lacking of accessible ways to get acquainted with high efficient JN0-224 Guide question like ours. To fill the void, we simplify the procedures of getting way, just place your order and no need to wait for arrival of our JN0-224 exam dumps or make reservation in case people get them all, our practice materials can be obtained with five minutes.
Juniper JN0-224 Exam Syllabus Topics:
  • Python
  • PyEZ: This domain examines Python programming with PyEZ library for Junos automation, including JSNAPy, Jinja2 templates, RPC calls, exception handling, and device configuration management.
  • Junos Automation Stack and DevOps Concepts: This domain covers fundamental automation tools, frameworks, APIs, and DevOps culture applicable to Junos platform operations and network management.
  • NETCONF
  • XML API: This domain focuses on XML syntax, XPath expressions, NETCONF protocol, and XML API functionality for programmatic device configuration and communication.
  • Rest API: This domain covers Junos REST API implementation, REST API Explorer tool, and cURL usage for HTTP-based device management and configuration.
Topic 5
  • Data Serialization: This domain addresses YAML and JSON formats used for structured data representation and exchange in network automation workflows.
Juniper JN0-224 Certification Practice & JN0-224 Cert GuideExamsReviews is a leading platform that has been helping the JN0-224 exam candidates for many years. Over this long time period, countless JN0-224 exam candidates have passed their dream Automation and DevOps, Associate (JNCIA-DevOps) certification and they all got help from valid, updated, and Real JN0-224 Exam Questions. So you can also trust the top standard of ExamsReviews JN0-224 exam dumps and start JN0-224 practice questions preparation without wasting further time.
Juniper Automation and DevOps, Associate (JNCIA-DevOps) Sample Questions (Q42-Q47):NEW QUESTION # 42
Using the set rest control configuration command, what are two ways to control access to the REST API running on a Junos device? (Choose two.)
  • A. Limit the number of simultaneous connections.
  • B. Limit management access to specific users.
  • C. Limit access to only certain source IP addresses
  • D. Limit management access to only SSH
When using the set rest control configuration command on a Junos device, you have several options to control access to the REST API. Two effective methods include:
Limiting the number of simultaneous connections: This ensures that the REST API is not overwhelmed by too many concurrent requests, which could potentially lead to performance issues or denial of service.
Limiting access to certain source IP addresses: This method restricts API access to specific IP addresses, enhancing security by ensuring that only trusted sources can interact with the REST API.
Option A (Limit management access to only SSH) is unrelated to controlling REST API access specifically.
Option B (Limit management access to specific users) might be relevant in a different context, but it is not directly tied to REST API control via the specific command mentioned.
Supporting Reference:
Juniper Networks REST API Documentation: This documentation explains how to configure and control access to the REST API on Junos devices, including connection limits and IP-based access control.
NEW QUESTION # 43
Which two data structures are used in JSON? (Choose two.)
  • A. tuples
  • B. arrays
  • C. dictionaries
  • D. objects
In JSON (JavaScript Object Notation), the two primary data structures are:
Objects: These are collections of key-value pairs, where each key is a string, and the value can be a string, number, array, boolean, or another object. In Python, this structure is analogous to a dictionary.
Arrays: These are ordered lists of values, where each value can be of any data type, including another array or object. In Python, this structure is similar to a list.
Option A (tuples) and Option D (dictionaries) refer to Python-specific data structures and are not directly used in JSON.
JSON Documentation and Tutorials: JSON objects and arrays are the standard data structures used in this format, as described in many tutorials and the official JSON documentation.
NEW QUESTION # 44
What is an example of correct XML syntax?
  • A. <Devices><hostname>vMX1</ho3tnameX/Device3>
  • B. <Device3><ho3tname>vMX1</hostname><Devices/>
  • C. <Devices><hostname>vMX1<Devices/>
  • D. <Devices><hostname>vMX1<De vices/X/hostname>
NEW QUESTION # 45
Which HTTP status code indicates a response to a successful request?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
Reference: https://www.juniper.net/document ... ce-sdk/13.1/apiref/ com.juniper.junos_space.sdk.help/html/reference/Commonbehav.html
NEW QUESTION # 46
Which process is responsible for XML automation requests?
  • A. mgd
  • B. rpd
  • C. jsrpd
  • D. jsd
The mgd (Management Daemon) process in Junos is responsible for handling XML automation requests. This daemon manages the configuration and operational commands received via NETCONF, which uses XML for data exchange. The mgd process parses the XML data and applies the necessary configuration or retrieves the requested information.
Option B is correct because mgd is the process that handles XML-based requests in Junos.
Options A (jsrpd), C (rpd), and D (jsd) are incorrect because they are responsible for different functions, such as routing protocols and services, not XML automation.
Juniper Networks Management Daemon (mgd) Documentation: Provides an overview of the responsibilities of the mgd process, including handling XML requests.
NEW QUESTION # 47
We are equipped with excellent materials covering most of knowledge points of JN0-224 pdf torrent. Our learning materials in PDF format are designed with JN0-224 actual test and the current exam information. Questions and answers are available to download immediately after you purchased our JN0-224 Dumps PDF. The free demo of pdf version can be downloaded in our exam page.
JN0-224 Certification Practice: https://www.examsreviews.com/JN0-224-pass4sure-exam-review.html
Posted at 1/30/2026 23:40:50        Only Author  2#
It offered a wealth of insights I hadnt considered before. This ISTQB-CTFL test questions and answers helped me climb the career ladder and secure a raise. Now, its free for everyone. Wishing you all success in your careers!
Posted at 2/14/2026 20:20:47        Only Author  3#
This article really expanded my views, thank you for the fantastic share! I hope the Massachusetts-Real-Estate-Salesperson exam dumps pdf content helps, and it comes at no cost.
