[Hardware] Testing 800-150 Center, Reliable 800-150 Exam Cost
72
Hardware Testing 800-150 Center, Reliable 800-150 Exam Cost
Posted at 1/17/2026 08:30:03      View153 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of DumpExam 800-150 dumps from Cloud Storage: https://drive.google.com/open?id=1hEbDyoPUfj8jsndRRW-YNGWlRcQJkRC_
As you know, we are now facing very great competitive pressure. We need to have more strength to get what we want, and 800-150 exam dumps may give you these things. After you use our study materials, you can get 800-150 certification, which will better show your ability, among many competitors, you will be very prominent. The 99% pass rate is the proud result of our study materials. If you join, you will become one of the 99%. I believe that pass rate is also a big criterion for your choice of products, because your ultimate goal is to obtain 800-150 Certification. In 800-150 exam dumps, you can do it.
New developments in the tech sector always bring new job opportunities. These new jobs have to be filled with the Supporting Cisco Devices for Field Technicians (800-150) certification holders. So to fill the space, you need to pass the Cisco 800-150 exam. Earning the Supporting Cisco Devices for Field Technicians (800-150) certification helps you clear the obstacles you face while working in the Cisco field. To get prepared for the Supporting Cisco Devices for Field Technicians (800-150) certification exam, applicants face a lot of trouble if the study material is not updated.
Reliable 800-150 Exam Cost & Exam 800-150 QuestionIn the world of industry, Cisco Certified Field Technician (CCT) certification is the key to a successful career. If you have achieved credential such as Cisco then it means a bright future is waiting for you. Avail the opportunity of 800-150 dumps at DumpExam that helps you in achieving good scores in the exam. Due to these innovative methodologies students get help online. The 800-150 Exam Questions Answers are very effective and greatly helpful in increasing the skills of students. They can easily cover the exam topics with more practice due to the unique set of 800-150 exam dumps. The 800-150 certification learning is getting popular with the passage of time.
Cisco 800-150 Exam Syllabus Topics:
  • Cisco Software: This section of the exam measures the skills of a Network Engineer and discusses Ciscos software systems and licensing. It explains the difference between IOS install and bundle modes and gives an overview of different licensing models. Students learn how to manage Cisco software images, including backing up, transferring, and installing images via FTP, TFTP, or USB. It also covers how to handle configuration files to keep devices running properly and ensure smooth upgrades or replacements.
  • Cisco Infrastructure and Collaboration Infrastructure: This section of the exam measures the skills of a Collaboration Engineer and focuses on Cisco infrastructure devices, endpoints, and collaboration technologies. It introduces network devices, collaboration endpoints like IP phones and video systems, and explains on-premises collaboration deployments using tools like Cisco Unified Communications Manager. It also covers how video systems integrate into collaboration environments and highlights Ciscos cloud services for enterprise communication, including Webex Meetings, Webex Teams, and hosted collaboration solutions.
  • Cisco UCS and Data Center Architecture: This section of the exam measures the skills of a Data Center Engineer and introduces Ciscos UCS and data center solutions. It explains the devices found in a data center, including switches, UCS servers, and director switches, and describes different server deployment models. Students will also learn about virtualization components like virtual machines, hypervisors, cloud computing concepts, and deployment models. The section covers how Cisco UCS devices fit into campus networks, edge locations, and data centers, and explains the key components and connections used in UCS architecture.
  • Cisco Hardware Replacement: This section of the exam measures the skills of a Technical Support Engineer and teaches how to safely and correctly replace Cisco hardware. It explains safety procedures such as creating safe work zones and handling electrostatic discharge. Students learn the step-by-step processes to replace a wide range of Cisco devices, from switches and routers to firewalls, UCS servers, and collaboration endpoints. It also covers configuring Cisco NX-OS software, including understanding operating modes, boot procedures, and password recovery, and introduces Cisco collaboration endpoint solutions like IP phones and video systems.
Topic 5
  • Networking Foundations: This section of the exam measures the skills of a Network Engineer and covers the basic building blocks of computer networking. It explains different types of networks like local area networks and wireless networks, and introduces lightweight wireless LANs. It describes the layers of communication models like the OSI model and TCP
  • IP stack, and explains how data moves across networks. It also discusses the physical cabling used in networks, such as Ethernet and fiber optics. Students will learn about network switching, IP addressing, subnetting, and routing at Layer 3. The section also introduces Ciscos campus network devices, data center switches, UCS servers, and collaboration devices, describing their roles and functions in the network.
Cisco Supporting Cisco Devices for Field Technicians Sample Questions (Q37-Q42):NEW QUESTION # 37
What is the primary reason for placing heavier devices toward the bottom of the rack when installing replacement hardware?
  • A. To maintain rack stability
  • B. To simplify device maintenance
  • C. To facilitate easier cable management
  • D. To improve air circulation
Theprimary reasonfor placing heavier equipment, such as UPS units or core switches, at thebottom of a rack is tomaintain stability. A lower center of gravity reduces the risk of tipping, especially when the rack is not yet bolted or braced.
This is a standard safety precaution in network hardware installation and is particularly important when racks are being serviced or relocated.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Safety and ESD Precautions Explanation:
The primary reason for placing heavier devices toward the bottom of the rack is to maintain rack stability.
This helps ensure the rack remains balanced and prevents tipping, especially when multiple devices are installed.
NEW QUESTION # 38
Why is the midplane-free design of the X9508 Modular Chassis significant in the context of Cisco UCS X-Series compute node replacement?
  • A. It enables direct front-to-rear airflow, improving cooling efficiency during node replacement.
  • B. It enables hot-swapping of compute nodes without powering down the chassis.
  • C. It allows for easier future upgrades to faster connectivity standards.
  • D. It reduces the overall power consumption of the chassis.
TheCisco UCS X9508 Modular Chassis, part of the UCS X-Series architecture, is designedwithout a midplane, which marks a major shift from previous UCS models. Themidplane-free designis critical because:
#Direct front-to-rear airflowis made possible without obstruction.
#This airflow architectureenhances thermal efficiency, especially important duringcompute node replacementsor upgrades.
#It allowsmodules to communicate via side-plane connectors, which are located on the sides rather than a fixed midplane.
This architecture:
* Simplifies mechanical design
* Reduces cooling complexity
* Improvesmodularityandaccessibility
#Why the other options are incorrect:
* A.Hot-swapping is supported, but notbecauseof midplane-free design-it's a UCS standard feature.
* C.Upgrades to faster interconnects are enabled by side-plane I/O, not by midplane absence alone.
* D.Power efficiency is a broader chassis feature, not specifically driven by the midplane design.
NEW QUESTION # 39
What must be considered when installing a new fan module in a fixed-configuration Cisco Nexus switch?
  • A. The fan module must be from the same manufacturing batch as the others.
  • B. The airflow direction must be consistent with other installed modules.
  • C. The size of the fan module must match the power supply.
  • D. Fan modules can be installed only when the switch is powered off
When installing a fan module in a Cisco Nexus fixed-configuration switch, it's crucial to ensure that the airflowdirection of the new fan matches the existing airflow configuration. Mismatched airflow directions can lead to inefficient cooling or even overheating of components, potentially affecting the performance or lifespan of the switch.
Cisco offers fan modules infront-to-backorback-to-frontairflow variants, and consistency is required for proper thermal management. These modules are also typically hot-swappable, meaning powering down the switch is not necessary.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Maintenance and RMA Procedures
NEW QUESTION # 40
Which hardware platform is Cisco UnifiedCommunications Manager typically deployed on?
  • A. Cisco ISR routers
  • B. Cisco ASR routers
  • C. Cisco Catalyst switches
  • D. Cisco UCS C-Series servers
Cisco Unified Communications Manager (CUCM) is typically deployed onCisco UCS C-Series servers.
These rack-mount servers provide the necessary computing resources to support CUCM's call control and session management functions in enterprise environments. The UCS C-Series servers offer scalability, reliability, and integration capabilities essential for unified communications deployments.
Options A (Cisco ASR routers), B (Cisco Catalyst switches), and C (Cisco ISR routers) are networking devices designed for routing and switching functions and are not intended as platforms for deploying CUCM.
Reference:Supporting Cisco Devices for Field Technicians (FLDTEC) - Cisco Equipment and Related Hardware
NEW QUESTION # 41
Which pod-based deployment model provides the most flexibility and scalability in a modern data center topology?
  • A. Spine-and-Leaf
  • B. Fabric Extender model
  • C. Top of Rack (ToR)
  • D. End of Row (EoR)
TheSpine-and-Leafarchitecture is the preferredpod-based deployment modelin modern data centers because of itshigh scalability and flexibility. In this topology:
* Leaf switchesconnect to servers and act as the access layer.
* Spine switchesfunction as the core layer, interconnecting all leaf switches.
This non-blocking, highly redundant model supportspredictable latency, easy horizontal scaling, and load balancing, making it ideal for cloud-scale and virtualized environments.
* Top of Rack (ToR)andEnd of Row (EoR)are physical cabling layouts that do not inherently provide the same level of architectural scalability.
* Fabric Extender modelsextend switch ports but depend on upstream switches for intelligence, limiting flexibility.
NEW QUESTION # 42
After passing the Cisco 800-150 certification exam, you can take advantage of a number of extra benefits. With the correct concentration, commitment, and 800-150 exam preparation, you could ace this Supporting Cisco Devices for Field Technicians 800-150 test with ease. DumpExam is a trusted and leading platform that is committed to preparing the Cisco 800-150 exam candidates in a short time period.
Reliable 800-150 Exam Cost: https://www.dumpexam.com/800-150-valid-torrent.html
DOWNLOAD the newest DumpExam 800-150 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1hEbDyoPUfj8jsndRRW-YNGWlRcQJkRC_
