[General] Changing u-boot serial
31
【General】 Changing u-boot serial
Posted at 12/28/2022 22:26:47      View:3305 | Replies:6        Print      Only Author   [Copy Link] 1#
Hello,
I'm trying to change u-boot console from default UART2 to UART1, changed name in device tree and parameters in configuration, still cant see any output. Can it be changed easily?
Also, can someone share full console output of booting process, starting from bootloader to loading kernel, this might help me.
Posted at 12/29/2022 10:28:38        Only Author  2#
If you just need to debug the device, refer to the following:
https://wiki.t-firefly.com/en/ROC-RK3308-CC/serial_debug.html
https://wiki.t-firefly.com/en/ROC-RK3308B-CC-PLUS/debug.html
Change the  debug serial is not a good idear.
已有 1评分Contribution +3 Pack up reason
vitech + 3
View all ratings
Posted at 12/30/2022 14:36:31        Only Author  3#
I managed to set U-boot output to UART1, the reason was that I tried to program u-boot image to default rk3308 cfg address 0x4000 in RKDEVTool. After I changed it to 0x2000, all worked well.
Next step for me to connect to U-boot with JTAG (SWJ), seems like some peripheral re-init those pins, cause connection to cpu not working in u-boot unlike MaskRom, to which I can connect with OpenOCD. Anyway, work continues
Posted at 1/8/2026 22:22:42        Only Author  4#
自宅にいても外にいても、CMMC-CCPテストトレントを勉強できます。 CMMC-CCP学習ツールの指導の下では、試験の準備に20〜30時間しかかからないため、他にやることがあるので、時間を心配する必要はありません。 CMMC-CCP試験資料を使用して、独自に学習できます。毎日多くの時間を費やす必要はなく、試験に合格し、最終的には証明書を取得します。 CMMC-CCP認定は、就職面接の重要なタグになる可能性があり、他の人よりも競争上の優位性があります。
Posted at 1/10/2026 04:51:45        Only Author  5#
This is a truly extraordinary piece of work, thank you for sharing. Exam C-SEC-2405 braindumps test questions are the key to career success—available for free!
Posted at 1/20/2026 12:52:23        Only Author  6#
It truly opened my eyes to a new world of ideas. Free Test C_THR96_2505 quiz resources for exam success. Wishing you the best!
Posted at 2/4/2026 23:28:45        Only Author  7#
Databricks-Certified-Data-Engineer-Professional-JPNのDatabricks試験問題の高い合格率は98%〜100%であるため、正確かつ最新のDatabricks-Certified-Data-Engineer-Professional-JPN試験トレントで市場に並ぶものがないと誇らしげに主張できます。 成功をもたらす当社の強みと、取得する意図のある認定を疑うことはありません。 Databricks-Certified-Data-Engineer-Professional-JPN実践教材を使用して、候補者の勝利をますます証明しています。Jpshiken あなたは彼らのような勝者の一人になると信じています。 Databricks Certified Data Engineer Professional Exam (Databricks-Certified-Data-Engineer-Professional日本語版)のDatabricks-Certified-Data-Engineer-Professional-JPN学習教材を購入するだけで、より明るい未来を手にすることができます。
