ADA-C01 Exam Simulations, ADA-C01 Current Exam Content
113
Posted at 1/17/2026 09:59:39      View136 | Replies4        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Snowflake ADA-C01 dumps are available on Google Drive shared by PrepAwayExam: https://drive.google.com/open?id=18xaK4KF-LSjCz3FvqeSNj2pKirStek6B
The ADA-C01 study materials from our company are very convenient for all people, including the convenient buying process, the download way and the study process and so on. Upon completion of your payment, you will receive the email from us in several minutes, and then you will have the right to use the ADA-C01 Study Materials from our company. In addition, there are three different versions for all people to choose. According to your actual situation, you can choose the suitable version from our ADA-C01 study materials.
It is carefully edited and reviewed by our experts. The design of the content conforms to the examination outline. Through the practice of our ADA-C01 study materials, you can grasp the intention of the examination organization accurately. The number of its test questions is several times of the traditional problem set, which basically covers all the knowledge points to be mastered in the exam. You only need to review according to the content of our ADA-C01 Study Materials, no need to refer to other materials. With the help of our ADA-C01 study materials, your preparation process will be relaxed and pleasant.
Excellent Snowflake ADA-C01 Exam Simulations - ADA-C01 Free DownloadThe Channel Partner Program SnowPro Advanced Administrator ADA-C01 certification enables you to move ahead in your career later. With the Snowflake ADA-C01 certification exam you can climb up the corporate ladder faster and achieve your professional career objectives. Do you plan to enroll in the SnowPro Advanced Administrator ADA-C01 Certification Exam? Looking for a simple and quick way to crack the Snowflake ADA-C01 test?
Snowflake SnowPro Advanced Administrator Sample Questions (Q49-Q54):NEW QUESTION # 49
What are characteristics of Dynamic Data Masking? (Select TWO).
  • A. A masking policy that is currently set on a table can be dropped.
  • B. A single masking policy can be applied to columns with different data types.
  • C. A masking policy can be applied to the VALUE column of an external table.
  • D. The role that creates the masking policy will always see unmasked data in query results.
  • E. A single masking policy can be applied to columns in different tables.
Answer: B,E
According to the Using Dynamic Data Masking documentation, Dynamic Data Masking is a feature that allows you to alter sections of data in table and view columns at query time using a predefined masking strategy. The following are some of the characteristics of Dynamic Data Masking:
*         A single masking policy can be applied to columns in different tables. This means that you can write a policy once and have it apply to thousands of columns across databases and schemas.
*         A single masking policy can be applied to columns with different data types. This means that you can use the same masking strategy for columns that store different kinds of data, such as strings, numbers, dates, etc.
*         A masking policy that is currently set on a table can be dropped. This means that you can remove the masking policy from the table and restore the original data visibility.
*         A masking policy can be applied to the VALUE column of an external table. This means that you can mask data that is stored in an external stage and queried through an external table.
*         The role that creates the masking policy will always see unmasked data in query results. This is not true, as the masking policy can also apply to the creator role depending on the execution context conditions defined in the policy. For example, if the policy specifies that only users with a certain custom entitlement can see the unmasked data, then the creator role will also need to have that entitlement to see the unmasked data.
NEW QUESTION # 50
Which tasks can be performed by the ORGADMIN role? (Select THREE).
  • A. View usage information for all accounts in the organization.
  • B. Perform zero-copy cloning on account data.
  • C. Create a reader account to share data with another organization.
  • D. Create secure views on application tables within the organization.
  • E. Create one or more accounts in the organization.
  • F. View a list of all regions enabled for the organization.
Answer: A,E,F
A user with the ORGADMIN role can perform the following tasks1:
*Create one or more accounts in the organization.
*View a list of all regions enabled for the organization.
*View usage information for all accounts in the organization.
Option C is incorrect because creating secure views on application tables is not a function of the ORGADMIN role, but rather a function of the roles that have access to the tables and schemas within the accounts. Option E is incorrect because performing zero-copy cloning on account data is not a function of the ORGADMIN role, but rather a function of the roles that have the CLONE privilege on the objects within the accounts. Option F is incorrect because creating a reader account to share data with another organization is not a function of the ORGADMIN role, but rather a function of the roles that have the CREATE SHARE privilege on the objects within the accounts.
NEW QUESTION # 51
Which type of listing in the Snowflake Marketplace can be added and queried immediately?
  • A. Regional listing
  • B. Standard listing
  • C. Personalized listing
  • D. Monetized listing
According to the Snowflake documentation1, a standard listing is a type of listing that provides free access to the full data product, with no payment required. A standard listing can be added and queried immediately by the consumer, as long as they accept the terms and conditions of the listing. A monetized listing is a type of listing that charges for access to the data product, using the pricing models offered by Snowflake. A monetized listing requires the consumer to provide payment information and agree to the billing terms before accessing the data product. A regional listing is not a type of listing, but a way to specify the regions where the listing is available. A personalized listing is a type of listing that provides limited trial access to the data product, with unlimited access to the full data product available upon request. A personalized listing requires the consumer to request access from the provider and wait for the provider to grant access before accessing the data product. Therefore, the only type of listing that can be added and queried immediately is the standard listing.
NEW QUESTION # 52
A Snowflake Administrator is investigating why a query is not re-using the persisted result cache.
The Administrator found the two relevant queries from the SNOWFLAKE. ACCOUNT_USAGE. QUERY_HISTORY view:
Why is the second query re-scanning micro-partitions instead of using the first query's persisted result cache?
  • A. The second query includes a CURRENT_TIMESTAMP () function.
  • B. The queries are executed with two different roles.
  • C. The queries are executed with two different virtual warehouses.
  • D. The second query includes a CURRENT_DATE () function.
The inclusion of the CURRENT_TIMESTAMP() function in the second query prevents it from re-using the first query's persisted result cache because this function makes each execution unique due to the constantly changing timestamp. According to the Snowflake documentation, "The query does not include non-reusable functions, which return different results for successive runs of the same query. UUID_STRING, RANDOM, and RANDSTR are good examples of non-reusable functions." The CURRENT_TIMESTAMP() function is another example of a non-reusable function, as it returns the current date and time at the start of query execution, which varies for each run. Therefore, the second query is not identical to the first query, and the result cache is not reused. The other options are either incorrect or irrelevant to the question. Option B is incorrect, as the CURRENT_DATE() function is a reusable function, as it returns the same value for all queries executed within the same day. Option C is irrelevant, as the virtual warehouse used to execute the query does not affect the result cache reuse. Option D is also irrelevant, as the role used to execute the query does not affect the result cache reuse, as long as the role has the necessary access privileges for all the tables used in the query.
NEW QUESTION # 53
For Snowflake network policies, what will occur when the account_level and user_level network policies are both defined?
  • A. A network policy error will be generated with no definitions provided.
  • B. The user_level policy will override the account_level policy.
  • C. The account_level policy will override the user_level policy.
  • D. The user_level network policies will not be supported.
According to the Network Policies documentation, a network policy can be applied to an account, a security integration, or a user. If there are network policies applied to more than one of these, the most specific network policy overrides more general network policies. The following summarizes the order of precedence:
*Account: Network policies applied to an account are the most general network policies. They are overridden by network policies applied to a security integration or user.
*Security Integration: Network policies applied to a security integration override network policies applied to the account, but are overridden by a network policy applied to a user.
*User: Network policies applied to a user are the most specific network policies. They override both accounts and security integrations.
Therefore, if both the account_level and user_level network policies are defined, the user_level policy will take effect and the account_level policy will be ignored. The other options are incorrect because:
*The account_level policy will not override the user_level policy, as explained above.
*The user_level network policies will be supported, as they are part of the network policyfeature.
*A network policy error will not be generated, as there is no conflict between the account_level and user_level network policies.
NEW QUESTION # 54
We know that you have strong desire for success in your career, now, we recommend you to get the ADA-C01 exam certification. PrepAwayExam will help you and provide you with the high quality Snowflake training material. ADA-C01 questions are selected and edited from the original questions pool and verified by the professional experts. Besides, the updated of ADA-C01 Pdf Torrent is checked every day by our experts and the new information can be added into the ADA-C01 exam dumps immediately.
ADA-C01 Current Exam Content: https://www.prepawayexam.com/Snowflake/braindumps.ADA-C01.ete.file.html
Dumpstep professional provides ACSA the latest study materials, completely covers ADA-C01 test knowledge points, You can ask for our helps by sending us email if you have any problem about Snowflake ADA-C01 Current Exam Content vce pdf, We strive for providing you a comfortable study platform and continuously upgrade ADA-C01 valid training test to meet every customer's requirements, Snowflake ADA-C01 Exam Simulations Over the years, our study materials have helped tens of thousands of candidates successfully pass the exam.
Java is used for the examples because of its widespread use and familiarity, But they forgot to answer the other questions, our ADA-C01 training guide can help you solve this problem and get used to the pace.
Snowflake ADA-C01 Pdf Questions - Exceptional Practice To SnowPro Advanced AdministratorDumpstep professional provides ACSA the latest study materials, completely covers ADA-C01 test knowledge points, You can ask for our helps by sending us email if you have any problem about Snowflake vce pdf.
We strive for providing you a comfortable study platform and continuously upgrade ADA-C01 valid training test to meet every customer's requirements, Over the years, our study ADA-C01 materials have helped tens of thousands of candidates successfully pass the exam.
It is true that even a student customer has to spend much time on other ADA-C01 Current Exam Content things except learning in spare time, not to mention workers those who are usually busy around and can't always have access to computers.
P.S. Free & New ADA-C01 dumps are available on Google Drive shared by PrepAwayExam: https://drive.google.com/open?id=18xaK4KF-LSjCz3FvqeSNj2pKirStek6B
Posted at 1/22/2026 04:54:42        Only Author  2#
In unserem ZertPruefung gibt es viele IT-Fachleute, die EXIN PR2F Zertifizierungsantworten bearbeiten, deren Hit-Rate 100% beträgt. Ohne Zweifel gibt es auch viele ähnliche Websites, die Ihnen vielleicht auch Lernhilfe und Online-Service bieten. Aber wir sind ihnen in vielen Aspekten voraus. Die Grnde dafr liegen darin, dass wir EXIN PR2F Prfungsfragen und Antworten mit hoher Hit-Rate bieten, die sich regelmäßig aktualisieren. So können die an der EXIN PR2F Zertifizierungsprfung teilnehmenden Prflinge unbesorgt bestehen. Wir, ZertPruefung, versprechen Ihnen, dass Sie die EXIN PR2F ZertifizierungsPrfung 100% bestehen können.
Posted at 1/27/2026 06:20:17        Only Author  3#
Your article is truly outstanding, thank you for sharing it with us! H19-619_V1.0 free vce dumps delivers top-quality content, completely free to you.
Posted at 2/2/2026 02:09:04        Only Author  4#
That article opened up a whole new world of ideas for me. I used the AAIA pass guarantee to secure a promotion and raise. Now, Im offering it for free. Wishing you all success in your careers!
Posted at 2/2/2026 03:14:07        Only Author  5#
This article is so encouraging, thanks for sharing it! I owe my career success to the Salesforce-MuleSoft-Associate valid test discount voucher test, and now Im sharing it with you free of charge!
