Amazon AWS-Certified-Developer-Associate Latest Exam Notes - AWS-Certified-Devel
Posted at 1/17/2026 10:42:11
View168
Replies2
What's more, part of that ITCertMagic AWS-Certified-Developer-Associate dumps now are free: https://drive.google.com/open?id=1Zw_cQ6Ioi5IwAbdyzdB8Cr0xJL2GQWTt
Maybe there are so many candidates think the AWS-Certified-Developer-Associate exam is difficult to pass that they be beaten by it. But now, you dont worry about that anymore, because we will provide you an excellent exam material. Our AWS-Certified-Developer-Associate exam materials are very useful for you and can help you score a high mark in the test. It also boosts the function of timing and the function to simulate the AWS-Certified-Developer-Associate Exam so you can improve your speed to answer and get full preparation for the test. Trust us that our AWS-Certified-Developer-Associate exam torrent can help you pass the exam and find an ideal job.
To help candidates overcome this challenge, ITCertMagic offers authentic, accurate, and genuine Amazon AWS-Certified-Developer-Associate PDF Dumps. When preparing for the AWS Certified Developer Associate Exam (DVA-C02) (AWS-Certified-Developer-Associate) certification exam, candidates need not worry about their preparation notes or the format of the AWS-Certified-Developer-Associate Exam because ITCertMagic offers updated AWS Certified Developer Associate Exam (DVA-C02) (AWS-Certified-Developer-Associate) practice test material.
Amazon AWS-Certified-Developer-Associate Valid Test Online - AWS-Certified-Developer-Associate New Exam MaterialsIf you are remain an optimistic mind all the time when you are preparing for the AWS-Certified-Developer-Associate exam, we deeply believe that it will be very easy for you to successfully pass the AWS-Certified-Developer-Associate exam, and get the related AWS-Certified-Developer-Associate certification in the near future. Of course, we also know that how to keep an optimistic mind is a question that is very difficult for a lot of people to answer. As is known to us, where there is a will, there is a way. We believe you will get wonderful results with the help of our AWS-Certified-Developer-Associate Exam Questions as we have been professional in this field.
The AWS-Developer exam is an important certification for developers who want to demonstrate their expertise in developing and maintaining applications on AWS. Passing AWS-Certified-Developer-Associate Exam can help you stand out in a competitive job market and demonstrate your ability to work with AWS services effectively.
Amazon AWS Certified Developer Associate Exam (DVA-C02) Sample Questions (Q325-Q330):NEW QUESTION # 325
A customer is using ABC Telecom as a network provider. The customer has 10 different offices connected
to ABC Telecom's MPLS backbone. The customer is setting up an AWS Direct Connect connection to
AWS and has provided the LOA-CFA to ABC Telecom. ABC Telecom has terminated the Direct Connect
circuit into their MPLS backbone. To uniquely identify the customer's traffic over the MPLS backbone, the
customer must encapsulate all traffic with VLAN tag 100. The customer wants to send traffic to multiple
VPCs.
Which two steps should be taken to meet the customer's requirement? (Select two.)
- A. ABC Telecom removes the other tag before sending the packet to AWS.
- B. Send the traffic for all VPCs with the same VLAN tag 100 and use BGP to ensure that proper routing
takes place to the appropriate VPC. - C. The customer performs Q-in-Q tunneling, with the AWS-required VLAN tag in the inside and VLAN 100
as the outside tag. - D. Create a support ticket with AWS to request the removal of the outer VLAN tag 100 as the traffic
reaches AWS routers. - E. ABC Telecom creates a support ticket with AWS to exchange MPLS labels and include the AWS port
as part of their MPLS network.
Answer: B,E
NEW QUESTION # 326
Is it possible to create an S3 bucket accessible only by a certain IAM user, using policies in a
CloudFormation template?
- A. Yes, all these resources can be created using a CloudFormation template
- B. No, you can only create the S3 bucket but not the IAM user.
- C. No, in the same template you can only create the S3 bucket and the realtive policy.
- D. S3 is not supported by CloudFormation.
With AWS Identity and Access Management (IAM), you can create IAM users to control who has access
to which resources in your AWS account. You can use IAM with AWS CloudFormation to control what
AWS CloudFormation actions users can perform, such as view stack templates, create stacks, or delete
stacks.
In addition to AWS CloudFormation actions, you can manage what AWS services and resources are
available to each user.
NEW QUESTION # 327
A company has an application that is deployed on AWS Elastic Beanstalk. The application generates user- specific PDFs and stores the PDFs in an Amazon S3 bucket. The application then uses Amazon Simple Email Service (Amazon SES) to send the PDFs by email to subscribers.
Users no longer access the PDFs 90 days after the PDFs are generated. The S3 bucket is not versioned and contains many obsolete PDFs.
A developer must reduce the number of files in the S3 bucket by removing PDFs that are older than 90 days.
Which solution will meet this requirement with the LEAST development effort?
- A. Create an S3 Lifecycle rule for the S3 bucket to expire objects after 90 days.
- B. Create an AWS Lambda function. Program the Lambda function to scan all the objects in the S3 bucket every day and to delete objects after 90 days.
- C. Update the application code. In the code, add a rule to scan all the objects in the S3 bucket every day and to delete objects after 90 days.
- D. Partition the S3 objects with a <year>/<month>/<day> key prefix. Create an AWS Lambda function to remove objects that have prefixes that have reached the expiration date.
NEW QUESTION # 328
A Developer is building a three-tier web application that should be able to handle a minimum of 5000 requests per minute. Requirements state that the web tier should be completely stateless while the application maintains session state for the users.
How can session data be externalized, keeping latency at the LOWEST possible value?
- A. Create an Amazon RDS instance, then implement session handling at the application level to leverage a database inside the RDS database instance for session data storage
- B. Create an Amazon DynamoDB table, then implement session handling at the application level to leverage the table for session data storage
- C. Implement a shared file system solution across the underlying Amazon EC2 instances, then implement session handling at the application level to leverage the shared file system for session data storage
- D. Create an Amazon ElastiCache Memcached cluster, then implement session handling at the application level to leverage the cluster for session data storage
https://aws.amazon.com/caching/session-management/
NEW QUESTION # 329
A user has created a queue named "myqueue" with SQS. There are four messages published to queue
which are not received by the consumer yet. If the user tries to delete the queue, what will happen?
- A. It will ask user to delete the messages first
- B. It will initiate the delete but wait for four days before deleting until all messages are deleted
automatically. - C. A user can never delete a queue manually. AWS deletes it after 30 days of inactivity on queue
- D. It will delete the queue
SQS allows the user to move data between distributed components of applications so they can perform
different tasks without losing messages or requiring each component to be always available. The user can
delete a queue at any time, whether it is empty or not. It is important to note that queues retain
messages for a set period of time. By default, a queue retains messages for four days.
http://docs.aws.amazon.com/AWSSi ... de/SQSConcepts.html
NEW QUESTION # 330
In the major environment, people are facing more job pressure. So they want to get Amazon certification rise above the common herd. How to choose valid and efficient AWS-Certified-Developer-Associate guide torrent should be the key topic most candidates may concern. So now, it is right, you come to us. Our company is famous for its high-quality AWS-Certified-Developer-Associate Exam Questions in this field especially for Amazon certification exams. It has been accepted by thousands of candidates who practice our AWS-Certified-Developer-Associate study materials for their exam.
AWS-Certified-Developer-Associate Valid Test Online: https://www.itcertmagic.com/Amazon/real-AWS-Certified-Developer-Associate-exam-prep-dumps.html
- AWS-Certified-Developer-Associate Exam Dumps - AWS-Certified-Developer-Associate Dumps Guide - AWS-Certified-Developer-Associate Best Questions 🏸 Search for ⇛ AWS-Certified-Developer-Associate ⇚ and obtain a free download on [url]www.examcollectionpass.com 🌾AWS-Certified-Developer-Associate Practice Exam Pdf[/url]
- AWS-Certified-Developer-Associate Exam Dumps - AWS-Certified-Developer-Associate Dumps Guide - AWS-Certified-Developer-Associate Best Questions 🚙 Open website ⇛ [url]www.pdfvce.com ⇚ and search for AWS-Certified-Developer-Associate for free download 🛃Valid AWS-Certified-Developer-Associate Test Pass4sure[/url]
- Exam AWS-Certified-Developer-Associate Training 🕛 AWS-Certified-Developer-Associate Test Prep 🕌 Detailed AWS-Certified-Developer-Associate Answers 🐈 Immediately open [ [url]www.dumpsmaterials.com ] and search for { AWS-Certified-Developer-Associate } to obtain a free download 🍭
ractice AWS-Certified-Developer-Associate Test[/url] - AWS-Certified-Developer-Associate Valid Exam Discount 🐷 AWS-Certified-Developer-Associate Reliable Test Book 📘 AWS-Certified-Developer-Associate Latest Materials 🦼 Search for ▶ AWS-Certified-Developer-Associate ◀ and obtain a free download on [url]www.pdfvce.com 😗Valid AWS-Certified-Developer-Associate Test Pass4sure[/url]
- Exam AWS-Certified-Developer-Associate Exercise 🥰 Exam AWS-Certified-Developer-Associate Labs ➡️ Examcollection AWS-Certified-Developer-Associate Dumps Torrent 🥻 Enter ⮆ [url]www.prepawayete.com ⮄ and search for ⮆ AWS-Certified-Developer-Associate ⮄ to download for free 🏕AWS-Certified-Developer-Associate Valid Exam Discount[/url]
- AWS-Certified-Developer-Associate Latest Test Cram 👡 AWS-Certified-Developer-Associate Valid Exam Discount 🕌 AWS-Certified-Developer-Associate Latest Materials 🐘 Open [url]www.pdfvce.com enter [ AWS-Certified-Developer-Associate ] and obtain a free download 🤐AWS-Certified-Developer-Associate Test Prep[/url]
- New Soft AWS-Certified-Developer-Associate Simulations 🅾 AWS-Certified-Developer-Associate Valid Exam Discount 😖 Best AWS-Certified-Developer-Associate Practice 🐕 Enter ✔ [url]www.prepawayexam.com ️✔️ and search for AWS-Certified-Developer-Associate to download for free 🥼AWS-Certified-Developer-Associate Reliable Test Book[/url]
- AWS-Certified-Developer-Associate Latest Test Cram 😙 AWS-Certified-Developer-Associate Certification Sample Questions 👉 Best AWS-Certified-Developer-Associate Practice 🔒 Search on [url]www.pdfvce.com for ⏩ AWS-Certified-Developer-Associate ⏪ to obtain exam materials for free download 🩸AWS-Certified-Developer-Associate Valid Examcollection[/url]
- AWS-Certified-Developer-Associate Test Prep 🏊 AWS-Certified-Developer-Associate Latest Test Cram 👘 Examcollection AWS-Certified-Developer-Associate Dumps Torrent 🐫 Search for ☀ AWS-Certified-Developer-Associate ️☀️ on ▷ [url]www.troytecdumps.com ◁ immediately to obtain a free download 🧽AWS-Certified-Developer-Associate Reliable Test Book[/url]
- Practice AWS-Certified-Developer-Associate Test 🌜 AWS-Certified-Developer-Associate Practice Exam Pdf 😩 AWS-Certified-Developer-Associate Latest Dumps Ebook 🔸 Search for AWS-Certified-Developer-Associate and easily obtain a free download on ➥ [url]www.pdfvce.com 🡄 🏯Best AWS-Certified-Developer-Associate Practice[/url]
- Free PDF Quiz 2026 Newest Amazon AWS-Certified-Developer-Associate: AWS Certified Developer Associate Exam (DVA-C02) Latest Exam Notes 🏇 Go to website ➥ [url]www.examdiscuss.com 🡄 open and search for AWS-Certified-Developer-Associate to download for free ⛷AWS-Certified-Developer-Associate Test Prep[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, paidforarticles.in, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, justpaste.me, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
