[Android] Enable Google Play Services ROC-RK3588S-PC
15
Android Enable Google Play Services ROC-RK3588S-PC
Posted at 1/12/2023 03:17:11      View6637 | Replies6        Print      Only Author   [Copy Link] 1#
  • Type: Self-Compiled Firmware
  • SDK Package Name: firefly_rk3588_android12.0_git_20220311
  • Last Commit: 0000-00-00 00:00:00
  • Modification Content: Enable Google Play
  • Log: FireflyLogs.zip
I am trying to compile the Android 12 firmware using the instructions found here: https://wiki.t-firefly.com/en/RO ... 12.0_firmware.html.
I have completed upto step 3.1.1.1 without error. After that step I make a change.
I would like to Enable Google Play Services. To do this I tried changing line 86 in /RK3588_Android12.0/device/rockchip/rk3588/BoardConfig.mk.
From
  1. "BUILD_WITH_GOOGLE_MARKET  := false"
Copy the code
To
  1. "BUILD_WITH_GOOGLE_MARKET := true"
Copy the code
After making this change I try running  step 3.2.1.1:
  1. ./FFTools/make.sh -d roc-rk3588s-pc-mipi101-M101014-BE45-A1 -j8 -l roc_rk3588s_pc_mipi-userdebug
Copy the code
When I execute this command I am given the error :
  1. device/rockchip/common/modules/gms.mk:40: warning: Please set clinet id with your own MADA ID!
Copy the code
How can I go about enabling Google Play Services on a ROC-RK3588S-PC?
FireflyLogs.zip
488 Bytes, Down times: 2
vip
Rank: 6Rank: 6
Posted at 1/12/2023 10:17:25        Only Author  2#
The sdk does not contain the Google Play Services , Also add the GMS framework in the following patches https://drive.google.com/file/d/ ... view?usp=share_link
Posted at 10/13/2023 17:07:03        Only Author  3#
jpchen Posted at 1/12/2023 10:17
The sdk does not contain the Google Play Services , Also add the GMS framework in the following patc ...
I tried to add this patch, but Google Play still doesn't work, and it still prompts "Google Framework service has stopped running repeatedly."
Posted at 5/27/2025 16:33:26        Only Author  4#
have you solved this?
I found that somehow when I install a fresh android12 from firefly, i download 3 files in my download folder-
GMS, Framework and playstore.
But after installig it just I only get developer notification " failed to post notification on channel null"
Posted at 9/10/2025 18:09:20        Only Author  5#
From silly outfits to over-the-top transformations, labubu clicker keeps rewarding you with fresh layers of humor the more you play.
Posted at 12/26/2025 11:21:33        Only Author  6#
Jetpacks and propeller hats can assist you in navigating doodle jump challenging sections. Utilize them to soar over groups of enemies or unstable platforms.
Posted at 1/15/2026 08:29:38        Only Author  7#
Instant likethis is fantastic. The Reliable L5M7 exam topics questions are free! Best of luck with your exams and preparations!
