Hardware
Adobe AD0-E137 Exam Dumps.zip - Braindumps AD0-E137 Torrent
Posted at 1/17/2026 11:50:07
View209
Replies2
We value every customer who purchases our AD0-E137 test material and we hope to continue our cooperation with you. Our AD0-E137 test questions are constantly being updated and improved so that you can get the information you need and get a better experience. Our AD0-E137 test questions have been following the pace of digitalization, constantly refurbishing, and adding new things. I hope you can feel the AD0-E137 Exam Prep sincerely serve customers. We also attach great importance to the opinions of our customers. As long as you make reasonable recommendations for our AD0-E137 test material, we will give you free updates to the system's benefits. The duration of this benefit is one year, and AD0-E137 exam prep look forward to working with you.
Adobe AD0-E137 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - AEM Development: This section of the exam measures the skills of Technical Consultants and covers implementing a single-page application (SPA) structure, building components using HTL, sling models, and services, writing unit tests and mapping mock data, integrating third-party APIs, developing OSGi services or servlets, and choosing appropriate JCR queries in context.
| | Topic 2 | - Environment Maintenance: This section of the exam measures the skills of Implementation Specialists and covers managing AEM environment configurations, release management, synchronizing content and configurations across environments via package manager, and applying maintenance tools to support environments.
| | Topic 3 | - Configurations: This section of the exam measures skills of AEM Developers and covers how to select and configure dispatcher rules based on scenario, set up multi-tenant environments, integrate SAML and LDAP for authentication, configure replication agents, and manage editable templates or content fragment models.
| | Topic 4 | - Build and Deployment: This section of the exam measures the skills of AEM Developers and covers front-end and back-end dependency management, creating a project via Maven archetype, crafting custom run modes, configuring workflows, and creating and managing custom Oak indexes.
Three formats of Adobe AD0-E137 practice exams meet the diverse needsWe are committed to provide you the best and the latest AD0-E137 training materials for you. Quality of the AD0-E137 exam dumps has get high evaluation among our customers, they think highly of it, since we help them pass the exam easily. Furthermore if we have the updated version, our system will send the Latest AD0-E137 Exam Dumps to your email address automatically, you dont need to worry about missing the latest version, you just need to concentrate your attention on practicing, and we will do the rest for you.
Adobe Experience Manager Sites Developer Expert Sample Questions (Q39-Q44):NEW QUESTION # 39
The customer noticed their search query was not giving the expected results. The following query is being used:
select * from [dam:Asset]
where isdescendantnode('/content/dam/customerFolder')
AND [jer:content/dateModified] >= CAST("2024-01-01T00:00:00.000Z")
- A. Use the Query Debugger tool to check the query cost and the index used.
- B. Use the Explain Query Tool to check the query cost and index used.
- C. Update Lucene index with the missing property.
NEW QUESTION # 40
A customer has the requirement to use SAML authentication on AEM using their SAML 2.0 compatible IDP.
Example:
AEM: www.wknd.com/content/siteB/index.html
IDP: https://www.idpB.com
How should an AEM Developer configure their SAML Authentication Handler?
- A. com.adobe.granite.auth.saml.SamlAuthenticationHandler.userIntermediatePath : /content/siteB com.adobe.granite.auth.saml.SamlAuthenticationHandler.serviceProviderEntityId : https://www.idpB.com
- B. com.adobe.granite.auth.saml.SamlAuthenticationHandler.userIntermediatePath : /content/siteBcom.adobe.granite.auth.saml.SamlAuthenticationHandler.assertionConsumerServiceURL : https://www.idpB.com
- C. com.adobe.granite.auth.saml.SamlAuthenticationHandler.path : /content/siteB com.adobe.granite.auth.saml.SamlAuthenticationHandler.idpUrl : https://www.idpB.com
NEW QUESTION # 41
A developer needs to use the mode in Template Editor which allows template authors to define grid settings for different devices.
Which mode should the developer use?
- A. Page Policy
- B. Structure
- C. Layout
NEW QUESTION # 42
An Adobe Experience Manager project requires to 'deny' all XML and JSON requests under the /path2 and /path3 context paths.
Which configuration will work?
- A. /0001 {/type "deny" extension '(XML|JSON)' /path '(/path2|JSON/*)'}
- B. /0001 {/type "deny" extension [XML|JSON]'/path[/path2|/path3/*]'}
- C. /0001 {/type "deny" extension "[XML|JSON]' /path'[/path2|/path3/*]"}
NEW QUESTION # 43
A website hosted on AEM as a Cloud Service features site page content search as part of their user experience. The search internally uses JCR Queries for content search based on tags. The content has been indexed adequately.
Which approach is recommended to make the index available across all the environments?
- A. Create Index Package from Package Manager and replicate over other environments
- B. Create fully custom index and deploy with Maven configurations and CI/CD Pipelines
- C. Customize out-of-the-box index and deploy with Maven configurations and CI/CD Pipelines
NEW QUESTION # 44
Our valid AD0-E137 practice questions are created according to the requirement of the certification center based on the real questions. Our team always checked and revised AD0-E137 dumps pdf to ensure the accuracy of our preparation study materials. We guarantee that our AD0-E137 Exam Prep is cost-efficient and affordable for most candidates who want to get certification quickly in their first try.
Braindumps AD0-E137 Torrent: https://www.dumps4pdf.com/AD0-E137-valid-braindumps.html
- AD0-E137 Learning Materials 🤭 Test AD0-E137 Dumps Pdf 🤞 Valid AD0-E137 Test Guide 🐉 Search for AD0-E137 and download it for free on [url]www.examdiscuss.com website 🕓AD0-E137 Exam Papers[/url]
- Free PDF 2026 Trustable Adobe AD0-E137 Exam Dumps.zip 🚬 Easily obtain free download of AD0-E137 by searching on [url]www.pdfvce.com ✏Valid AD0-E137 Test Discount[/url]
- High Pass-Rate AD0-E137 Exam Dumps.zip | 100% Free Braindumps AD0-E137 Torrent 🕚 Download AD0-E137 for free by simply searching on ⮆ [url]www.testkingpass.com ⮄ 👋AD0-E137 Dumps Download[/url]
- Latest AD0-E137 Test Labs 👟 Dump AD0-E137 Collection 🍽 Reliable AD0-E137 Exam Blueprint 👯 Go to website ▛ [url]www.pdfvce.com ▟ open and search for ➽ AD0-E137 🢪 to download for free 🎤AD0-E137 Reliable Dumps Free[/url]
- AD0-E137 Guaranteed Success ⚠ Valid AD0-E137 Braindumps 🔵 AD0-E137 Learning Materials 📞 Search on [url]www.practicevce.com for [ AD0-E137 ] to obtain exam materials for free download 🚛AD0-E137 Exam Papers[/url]
- Interactive Adobe AD0-E137 Online Practice Test Engine 😦 Open website [url]www.pdfvce.com and search for ➠ AD0-E137 🠰 for free download 📥Valid Braindumps AD0-E137 Free[/url]
- AD0-E137 Exam Study Questions - AD0-E137 Vce Training Material - AD0-E137 Latest Pdf Vce 🐋 Open [ [url]www.testkingpass.com ] and search for AD0-E137 to download exam materials for free 🧄Reliable AD0-E137 Exam Blueprint[/url]
- AD0-E137 Reliable Dumps Free 👸 Latest AD0-E137 Test Labs 😫 Valid AD0-E137 Test Guide 🐹 Search for AD0-E137 on [url]www.pdfvce.com immediately to obtain a free download 🚲AD0-E137 Exam Labs[/url]
- Valid Braindumps AD0-E137 Free 📥 Valid AD0-E137 Test Guide 👸 Valid AD0-E137 Braindumps 🦈 Simply search for ➽ AD0-E137 🢪 for free download on ➠ [url]www.exam4labs.com 🠰 🚓New AD0-E137 Dumps Files[/url]
- Valid AD0-E137 Braindumps 🎄 New AD0-E137 Dumps Files 🚴 Test AD0-E137 Dumps Pdf 🐞 Search on ➤ [url]www.pdfvce.com ⮘ for ⇛ AD0-E137 ⇚ to obtain exam materials for free download 🧮AD0-E137 Learning Materials[/url]
- Pass Guaranteed Quiz High-quality Adobe - AD0-E137 - Adobe Experience Manager Sites Developer Expert Exam Dumps.zip ⏏ Download ☀ AD0-E137 ️☀️ for free by simply searching on [ [url]www.prep4away.com ] 🧪AD0-E137 Exam Labs[/url]
- pct.edu.pk, www.stes.tyc.edu.tw, www.zazzle.com, gettr.com, study.stcs.edu.np, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
