[Hardware] MB-800 Real Torrent | Exam MB-800 Assessment
96
Hardware MB-800 Real Torrent | Exam MB-800 Assessment
Posted at 1/17/2026 11:57:46      View282 | Replies5        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Microsoft MB-800 dumps are available on Google Drive shared by Dumpexams: https://drive.google.com/open?id=1LzE8_d29k-NROiST_KBv-KQl7vSLkGix
Are you planning to attempt the Microsoft Dynamics 365 Business Central Functional Consultant (MB-800) exam of the MB-800 certification? The first hurdle you face while preparing for the Microsoft Dynamics 365 Business Central Functional Consultant (MB-800) exam is not finding the trusted brand of accurate and updated MB-800 exam questions. If you don't want to face this issue then you are at the trusted Dumpexams is offering actual and latest Microsoft Dynamics 365 Business Central Functional Consultant (MB-800) Exam Questions that ensure your success in the Microsoft Dynamics 365 Business Central Functional Consultant (MB-800) certification exam on your maiden attempt.
To pass the Microsoft MB-800 exam, individuals must demonstrate their ability to implement and configure Microsoft Dynamics 365 Business Central solutions that meet the needs of clients. MB-800 exam includes scenario-based questions that require candidates to apply their knowledge and skills to real-world situations. Candidates must also demonstrate their understanding of the various components of Microsoft Dynamics 365 Business Central and how they work together to provide a comprehensive solution for clients. By passing MB-800 Exam, individuals can demonstrate their expertise and differentiate themselves in the competitive field of Microsoft Dynamics 365 Business Central consulting.
Exam MB-800 Assessment - MB-800 Valid Braindumps PdfMost experts agree that the best time to ask for more dough is after you feel your MB-800 performance has really stood out. To become a well-rounded person with the help of our MB-800 study questions, reducing your academic work to a concrete plan made up of concrete actions allows you to streamline and gain efficiency, while avoiding pseudo work and guilt. Our MB-800 Guide materials provide such a learning system where you can improve your study efficiency to a great extent.
Microsoft Dynamics 365 Business Central Functional Consultant Sample Questions (Q190-Q195):NEW QUESTION # 190
A company uses Dynamics 365 Business Central. You are recording incoming payments from customers.
You must record a payment of $500 for customer 2030 with a posting date of November 16. 2022. The payment must be recorded against bank account No. 1010 with general ledger (G/l) account No. 10100.
You need to populate the cash receipt journal batch in Business Central to properly record the incoming payment to a bank account Which value should you use? To answer, select the appropriate options in the answer area.
NEW QUESTION # 191
You are implementing Dynamics 365 Business Central for a client.
You need to ensure that the user interface (UI) meets the client's requirements.
Which approach should you use? To answer, drag the appropriate approaches to the correct requirements. Each approach may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NEW QUESTION # 192
A company uses Dynamics 365 Business Central to manage accounts payables. The company uses exact cost reversing when returning products to vendors.
Returns use current costs at the time of the return. Exact cost reversing must be enforced manually for current orders and automatically applied to all future orders.
You need to configure the system.
Which configuration options should you use? To answer, select the appropriate options in the answer area.
https://community.dynamics.com/b ... 65-business-central
NEW QUESTION # 193
You need to configure the system for receiving produce from the vendors.
What should you do?
  • A. Set up a Payment Tolerance percentage.
  • B. Set the Dampener Quantity to a value greater than zero.
  • C. Configure an Over-Receipt code with Tolerance percentage.
  • D. Apply a Default Deferral template.
The case study states:
* The company often receives a higher quantity of produce items than ordered because vendors allow for spoilage/damage during transit.
* The company wants to allow over-receipt only for produce but not for non-produce items.
In Dynamics 365 Business Central, this requirement is handled by Over-Receipt Codes:
* You define a code with a tolerance percentage (e.g., 5% or 10%).
* The code can be assigned to specific items (e.g., produce) or vendors.
* This allows receiving slightly more than ordered, while blocking over-receipt for other items.
Why not the other options?
* B. Payment Tolerance % # relates to differences in payment amounts (e.g., customer underpaying by a few cents), not receiving inventory.
* C. Default Deferral Template # used to defer revenue/expense recognition over time, unrelated to item receipt.
* D. Dampener Quantity # used in demand planning/MRP to avoid unnecessary changes to supply orders; not for receiving more items.
So the correct configuration is Over-Receipt Code with Tolerance %.
Allow Over-Receipt in Purchase Orders
Topic 2, Wide World Importers
This is a case study. Case studies are not timed separately. You can use as much exam time as you would like to complete each case. However, there may be additional case studies and sections on this exam. You must manage your time to ensure that you are able to complete all questions included on this exam in the time provided.
To answer the questions included in a case study, you will need to reference information that is provided in the case study. Case studies might contain exhibits and other resources that provide more information about the scenario that is described in the case study. Each question is independent of the other questions in this case study.
At the end of this case study, a review screen will appear. This screen allows you to review your answers and to make changes before you move to the next section of the exam. After you begin a new section, you cannot return to this section.
To start the case study
To display the first question in the case study, click the Next button. Use the buttons in the left pane to explore the content of the case study before you answer the questions. Clicking these buttons displays information such as business requirements, existing environment, and problem statements. When you are ready to answer a question, click the Question button to return to the question.
Background
Wide World Importers is a family-owned importer of specialty cooking ingredients and prepackaged foods from the Mediterranean. When first established, the company's products were sold at farmers markets, All sales were on a cash-only basis.
Products are now sold locally to restaurant owners and chefs in a family-owned building with a warehouse.
Products are no longer sold at farmers markets. Cash and carry sales generate most of the revenue for the company.
The founder of Wide World Importers is turning over control of the company to the younger generation in the family. These family members want to use Dynamics 365 Business Central to support their efforts to grow and diversify the business. They recently started to build a new line of business selling and shipping products to specialty retailers outside their local area through a network of brokers and representatives.
The company uses QuickBooks, but the family is concerned that QuickBooks is not capable of supporting their new business model.
There are 30 full-time and part-time employees who work in sales, purchasing, shipping, customer service, accounts payable, accounts receivable, and finance. The family does not plan to hire additional personnel to support the new line of business.
Current environment
When a customer makes a purchase at the company's cash and carry desk, the sale is handwritten on a three- part form.
The cash and carry associate retrieves the items listed on the order from the warehouse.
Special prices and discounts are used to move products that will expire soon or that are overstocked.
Cash is accepted for payments.
The cash drawer is balanced at the end of every day. A deposit is created for the cash and given to the accountant.
Brokered sales orders
Brokered sales are called in to customer service by the brokers and sometimes directly by customers. The sales are entered into QuickBooks.
Because inventory is not tracked in QuickBooks, the generic item Brokered Item is used.
Two copies of the packing slip and printed from QuickBooks and sent to the warehouse.
Order picking
The warehouse manager provides a container and the two copies of the packing slip to a picker.
Items that are out of stock are marked on both copies of the packing slip.
The shipping amount is determined and written on the packing slips.
One copy of the completed packing slip is placed in a basket for customer service.
Completed orders are boxed up with a copy of the invoice and shipped to customers.
Order invoicing
Throughout the day, the customer service manager collects the packing slip copies and updates the invoices in QuickBooks.
The customer service manager adds a line for shipping with the amount provided by the packer.
The customer service manager prints a copy of the final invoice and sends it to the warehouse.
The accountant uses Microsoft Word to create weekly invoices for all shipments invoiced in QuickBooks during the week for some customers.
One-line sales invoices are saved in QuickBooks for each cash and carry sale to a miscellaneous customer.
Customer details for cash and carry sales are not kept in QuickBooks.
Deposits
The accountant receives the deposit bag from the cash and carry sales desk at the end of every day.
Receipts are recorded in QuickBooks against cash and carry and brokered sales based on the deposit slips.
Brokers commission
Brokers fees are paid as a percentage of sales.
A Sales by Product/Service Summary report is run in QuickBooks every month for Brokered Item to calculate what is owned.
Requirements
Customers
Users with permission must be able to quickly add new customers.
The original source of all customers in the accounting system must be identified to be from cash and carry or brokered sales.
The company needs to keep a record of special price promotions given to specific customers.
Customers must be identified with a unique general business posting group so that the correct freight G/L account is used in sales transactions.
Sales
The customer source must be used to identify the business line, and the customer source must be indicated on every sales transactions.
Customer service and cash and carry desk associates must be able to enter sales into Dynamics 365 Business Central by customer.
Excess paper must be eliminated, and paper management must be reduced.
If a customer is not already listed in the system, a cash and carry associate or customer service associate must be able to quickly add the new customer in the process of recording the first sale.
A point-of-sale system is not needed, but users must be able to record which items are purchased by customers, accept and record their payment, and print receipts indicating paid in full.
Items
The sales manager and warehouse manager must be able to set a specific timeframe for special promotion discounts on items.
For special promotions, discounts must be consistent for all items in a product line using a single discount calculation.
Special pricing may be given to a retail chain or buying group. This pricing must be automatically applied when an order is taken for any of these customers. The original price must be recorded with each sale.
Customers must always be charged the lowest amount for an item at the time of the sale. For example, an overstocked olive oil has a regular price of $20 per unit. Customers in a buying group for restaurants can buy it for $18 per unit. There is an autumn promotion price for the item at $19 per unit. However, on a specific day only, there is an overstock special at a 15 percent discount off the regular price.
Sales invoices
Warehouse workers must be able to indicate the following in the system for each order:
1. the items picked
2. the shipping charges
3. notifications, if any, that customer service needs to provide to the customer Items sold at a discount must show the original price, discount, and net amount on each line of the invoice.
Invoices must be posted at the cash and carry desk at the time of sale. For orders, accounting must post invoices and send them to customers.
Warehouse employees must be able to indicate what has been shipped on an order. They will use the G/L account for shipping charges. They need to use the correct G/L account for sales versus cost through proper assignment of sales and purchase accounts in the general posting setup.
Some of the brokered customers require one invoice per week regardless of the number of orders or shipments.
Accounts
Payment terms vary by customer.
The amount paid to brokers must be calculated from sales after invoice discounts.
Broker vendors must be easily identifiable from other vendors in lists
Commission paid on sales not collected within 120 days must be deducted from brokers' next compensation payment.
Reporting
Wide World Importers requires reporting on the following:
the overall profitability of each line of business at any time for any given period the cost of outbound shipping in the overall profitability of sales by business line in all related reports freight sales and cost by account in the trial balance the cost of brokers' compensation in reporting the overall profitability of sales by business line the effect of item discount promotions in financial statements.
Issues
Pricing
Spreadsheets are used to maintain special item pricing and discounts. The only source of product line discount information is a whiteboard in the warehouse. The price charged is frequently incorrect.
Customers complain when they think they think they have not received the best price available. Promotions are sometimes applied in error after a special pricing event ends, for example, when discounts are offered temporarily to reduce overstock.
Management cannot see original versus actual price on all sales. Discounts given by brokers requires spreadsheets and comparison between price list and price on sales invoice. Management needs to be able to quickly see the discount given on each sale.
Payment terms
Agreed-upon payment terms are frequently entered incorrectly on orders, causing cashflow issues.
Invoices already paid in full exist on the sales aging reports. The frequent cause of this issue is that sales from the cash and carry desk are not indicated as cash sales and are not posted as paid in full.
Some buying groups require that all invoices sent during a month be due on the 20th of the following month.
Invoicing
Paperwork is frequently misplaced between the warehouse, customer service, and accounting.
Invoices that are posted in the accounting system based on shipments and invoices that are sent to customers weekly do not match due to errors transferring the data from one document to another.
Users are selecting the incorrect freight type (expense versus sales) on purchase and sales transactions, making it difficult to reconcile freight costs.
Sales placed from the cash and carry desk by customers originally acquired through a broker are not being recognized with the correct customer source. Reporting by business line is inaccurate.
Accounts
Users often forget which fields to use to enter information when they add new customers to QuickBooks. This results in errors and inconsistencies in data and affects sales reporting. Confidence in sales reporting accuracy is low.
Adding new brokers is a different process than adding other purchase vendors. Users often forget which fields to select and how to correctly assign the vendor number to add new brokers.
Manual entries to certain G/L accounts cause reconciliation issues.
NEW QUESTION # 194
The company's funds are limited and some invoices that are due cannot be paid on time.
You need to prioritize vendors when you suggest vendor payments.
https://docs.microsoft.com/en-us ... ness-central/2-prio
NEW QUESTION # 195
Learning at electronic devices does go against touching the actual study. Although our MB-800 exam dumps have been known as one of the worlds leading providers of exam materials, you may be still suspicious of the content. For your convenience, we especially provide several demos for future reference and we promise not to charge you of any fee for those downloading. Therefore, we welcome you to download to try our MB-800 Exam for a small part. Then you will know whether it is suitable for you to use our MB-800 test questions. There are answers and questions provided to give an explicit explanation. We are sure to be at your service if you have any downloading problems.
Exam MB-800 Assessment: https://www.dumpexams.com/MB-800-real-answers.html
What's more, part of that Dumpexams MB-800 dumps now are free: https://drive.google.com/open?id=1LzE8_d29k-NROiST_KBv-KQl7vSLkGix
Posted at 1/18/2026 14:55:55        Only Author  2#
Thank you for the wonderful share, the article is truly eye-opening! Career growth is within reach with the free Valid test 350-501 dumps pdf questionsboost your salary and promotion!
Posted at 1/24/2026 20:24:54        Only Author  3#
This article is absolutely amazing, thank you for sharing! Free access to XSIAM-Engineer valid test dumps files content is provided, hoping it will benefit your studies.
Posted at 1/30/2026 03:34:30        Only Author  4#
I really appreciate your article, it has made a big impression on me. The Test CPRE-FL_Syll_3.0 guide exam is right around the corner. Wish me success!
Posted at 2/6/2026 09:42:13        Only Author  5#
Your article was truly insightful, Im sincerely thankful. The Latest CIS-SM exam questions pdf test was the key to unlocking my promotion and raise. Grab it for free today!
Posted at 3/8/2026 23:05:25        Only Author  6#
I gained a lot from reading that article. Wishing you all the best! Heres the free New N16300GC10 test preparation material.
