JN0-336 Exam Discount Voucher & New JN0-336 Test Syllabus
87
Posted at 1/17/2026 13:19:55      View143 | Replies4        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest RealValidExam JN0-336 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=16bnP_jAejXn7gz6s8e8qus0iKFAmtTH2
There is an irreplaceable trend that an increasingly amount of clients are picking up JN0-336 study materials from tremendous practice materials in the market. There are unconquerable obstacles ahead of us if you get help from our JN0-336 Exam Questions. So many exam candidates feel privileged to have our JN0-336 practice braindumps. And our website is truly very famous for the hot hit in the market and easy to be found on the internet.
It is a common sense that in terms of a kind of Security, Specialist (JNCIS-SEC) test torrent, the pass rate would be the best advertisement, since only the pass rate can be the most powerful evidence to show whether the JN0-336 Guide Torrent is effective and useful or not. We are so proud to tell you that according to the statistics from the feedback of all of our customers, the pass rate among our customers who prepared for the exam under the guidance of our Security, Specialist (JNCIS-SEC) test torrent has reached as high as 98%to 100%, which definitely marks the highest pass rate in the field. Therefore, you can carry out the targeted training to improve yourself in order to make the best performance in the real exam, most importantly, you can repeat to do the situation test as you like.
Professional JN0-336 Exam Discount Voucher to Obtain Juniper CertificationOur company is a professional exam dumps material providers, with occupying in this field for years, and we are quite familiar with compiling the JN0-336 exam materialls. If you choose us, we will give you free update for one year after purchasing. Besides, the quality of JN0-336 Exam Dumps is high, they contain both questions and answers, and you can practice first before seeing the answers. Choosing us means you choose to pass the exam successfully.
Juniper Security, Specialist (JNCIS-SEC) Sample Questions (Q13-Q18):NEW QUESTION # 13
Click the Exhibit button.
You are asked to create a security policy that will automatically add infected hosts to the infected hosts feed and block further communication through the SRX Series device.
What needs to be added to this configuration to complete this task?
  • A. Add logging to the permit portion of the security policy.
  • B. Add a security intelligence policy to the permit portion of the security policy.
  • C. Add an action to the permit portion of the security policy.
  • D. Add a match rule to the security policy with an appropriate threat level.
To create a security policy that will automatically add infected hosts to the infected hosts feed and block further communication through the SRX Series device, you need to add a security intelligence policy to the permit portion of the security policy. A security intelligence policy is a policy that allows you to block or monitor traffic from malicious sources based on threat intelligence feeds from Juniper ATP Cloud or other providers. One of the feeds that you can use is the Infected-Hosts feed, which contains IP addresses of hosts that are infected with malware and communicate with command-and-control servers.
You can create a profile and a rule for the Infected-Hosts feed and specify the threat level and the action to take for the infected hosts. Then, you can link the security intelligence policy with the firewall policy and apply it to the traffic that you want to protect. Reference: = Security Intelligence Overview, Configuring Security Intelligence Policy, Configure the Security Intelligence Policy on the SRX Series Device
NEW QUESTION # 14
Your manager asks you to provide firewall and NAT services in a private cloud.
Which two solutions will fulfill the minimum requirements for this deployment? (Choose two.)
  • A. a single cSRX
  • B. a vSRX for firewall services and a separate vSRX for NAT services
  • C. a cSRX for firewall services and a separate cSRX for NAT services
  • D. a single vSRX
A single vSRX instance is capable of handling both firewall and NAT services simultaneously. This solution provides a streamlined and resource-efficient way to secure and manage network traffic within a private cloud environment.
Similar to the vSRX, a single cSRX can also provide both firewall and NAT services. The cSRX, being a containerized version of the SRX, is particularly suited for environments where high density and microservices architectures are used, offering high performance in a compact form factor.
NEW QUESTION # 15
Which two statements about the DNS ALG are correct? (Choose two.)
  • A. The DNS ALG does not support NAT.
  • B. The DNS ALG supports DDNS.
  • C. The DNS ALG supports VPN tunnels.
  • D. The DNS ALG performs DNS doctoring.
The DNS Application Layer Gateway (ALG) is designed to manage and facilitate the successful passage of DNS traffic through a network device such as a firewall or NAT. Here are the correct statements regarding DNS ALG:
DNS doctoring is indeed a function of the DNS ALG where it modifies the payload of DNS responses to ensure that the information is aligned with the NAT policy. For example, it can rewrite the IP addresses in DNS responses to match the internal or external NAT'd IP address that the client should use.
DNS ALG can function across VPN tunnels by managing DNS traffic that traverses the tunnel, ensuring that the DNS queries and responses are correctly handled in environments where IP address translation occurs due to the VPN.
NEW QUESTION # 16
You want to use IPS signatures to monitor traffic.
Which module in the AppSecure suite will help in this task?
  • A. AppQoS
  • B. AppFW
  • C. AppTrack
  • D. APPID
The AppFW module in the AppSecure suite provides IPS signatures that can be used to monitor traffic and detect malicious activities. AppFW also provides other security controls such as Web application firewall, URL filtering, and application-level visibility.
NEW QUESTION # 17
Exhibit
You are asked to ensure that servers running the Ubuntu OS will not be able to update automatically by blocking their access at the SRX firewall. You have configured a unified security policy named Blockuburrtu, but it is not blocking the updates to the OS.
Referring to the exhibit which statement will block the Ubuntu OS updates?
  • A. Move the Blockubuntu policy after the Allowweb policy.
  • B. Configure the Blockubuntu policy with the junos-https application parameter.
  • C. Configure the Allowweb policy to have a dynamic application of any.
  • D. Change the default policy to permit-all.
NEW QUESTION # 18
Are you ready to take your career to the next level with the Security, Specialist (JNCIS-SEC) (JN0-336)? Look no further than RealValidExam for all of your Security, Specialist (JNCIS-SEC) (JN0-336) exam needs. Our comprehensive and cost-effective solution includes regularly updated Juniper JN0-336 Exam Questions, available in a convenient PDF format that can be downloaded on any device, including PC, laptop, mac, tablet, and smartphone.
New JN0-336 Test Syllabus: https://www.realvalidexam.com/JN0-336-real-exam-dumps.html
If you want to clear the JN0-336 exam in the best way, then you can utilize the best quality products and services provided by us, Information is changing all the time, but you dont need to worry that our New JN0-336 Test Syllabus - Security, Specialist (JNCIS-SEC) valid practice material becomes outdated, But you are lucky, we can provide you with well-rounded services on JN0-336 practice braindumps to help you improve ability, In case there are any changes happened to the Juniper JN0-336 exam, the experts keep close eyes on trends of it and compile new updates constantly.
Part of the wildly popular My, The Ethernet frame JN0-336 headers take on the appropriate values as the packet makes its way back to client A, If you want to clear the JN0-336 Exam in the best way, then you can utilize the best quality products and services provided by us.
Good News! 100% Success Rate On Juniper JN0-336 Exam Questions [2026]Information is changing all the time, but you Valid JN0-336 Exam Syllabus dont need to worry that our Security, Specialist (JNCIS-SEC) valid practice material becomes outdated, But you are lucky, we can provide you with well-rounded services on JN0-336 practice braindumps to help you improve ability.
In case there are any changes happened to the Juniper JN0-336 exam, the experts keep close eyes on trends of it and compile new updates constantly, Trust them completely as they can fulfill your needs most appropriately for sure.
P.S. Free 2026 Juniper JN0-336 dumps are available on Google Drive shared by RealValidExam: https://drive.google.com/open?id=16bnP_jAejXn7gz6s8e8qus0iKFAmtTH2
Posted at 1/23/2026 10:48:32        Only Author  2#
FڤFortinetFCP_FML_AD-7.4ԇYܤ뤳ȤǤޤShikenPASSFortinetFCP_FML_AD-7.4ԇYΥեЩ`󤬤ޤ顢¤FortinetFCP_FML_AD-7.4Υȥ`˥YϤ򤢤̽ҪʤǤShikenPASSä顢ʤϤ⤦FortinetFCP_FML_AD-7.4Υȥ`˥YϤҊĤΤǤ|ȽĤˤäʤϤäFortinetFCP_FML_AD-7.4ԇY˺ϸǤޤ顣
Posted at 1/30/2026 02:09:52        Only Author  3#
Thank you for sharing this breathtaking article, its truly amazing! Get free access to Exam dumps H19-410_V1.0 provider exam questionsgood luck to everyone!
Posted at 2/14/2026 17:29:51        Only Author  4#
Your article has truly left me speechless, thank you for sharing! Free MS-721 latest exam testking exam resources are available nowgood luck!
Posted at 2/23/2026 08:12:02        Only Author  5#
Your article truly impressed me, Im grateful for it. Wish me all the success I can get for the XSOAR-Engineer Dumps Torrent exam!
