[General] Valid Dumps Cisco 300-535 Questions, 300-535 Free Pdf Guide
80
General Valid Dumps Cisco 300-535 Questions, 300-535 Free Pdf Guide
Posted at 1/17/2026 14:02:20      View119 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New 300-535 dumps are available on Google Drive shared by RealExamFree: https://drive.google.com/open?id=1wzVJS9D8E7zdOzT7IAB_hm9eKkOPm4Ph
Our 300-535 Test Torrent keep a look out for new ways to help you approach challenges and succeed in passing the Automating and Programming Cisco Collaboration Solutions exam. To be recognized as the leading international exam bank in the world through our excellent performance, our Automating and Programming Cisco Collaboration Solutions qualification test are being concentrated on for a long time and have accumulated mass resources and experience in designing study materials.There is considerable skilled and motivated stuff to help you obtain the Automating and Programming Cisco Collaboration Solutions exam certificate. We sincerely wish you trust and choose us wholeheartedly.
Understanding functional and technical aspects of Automation APIs and Protocols Cisco Service Provider Solutions (300-535 SPAUTO)The following will be asked from you in the CISCO 300-535 exam dumps:
  • Describe common HTTP authentication mechanisms (basic, token, and oauth)
  • Identify the XML instance based on a YANG model
  • Describe and configure model-driven telemetry on Cisco devices
  • Describe how to automate service provider WAN with Cisco WAE
  • Describe how to automate virtualized resources with Cisco ESC
  • Automate service provider network configuration with Cisco NSO
  • Use NETCONF and RESTCONF programmability protocols on Cisco devices
  • Identify the JSON instance based on a YANG model
  • Implement configuration and operation management using NETCONF protocol
  • Interpret a YANG module tree generated by pyang
  • Describe the characteristics and use of YANG Data Models (OpenConfig, IETF, and Vendor)
  • Describe and use tools to validate YANG data models on Cisco devices
  • Implement configuration and operation management using RESTCONF protocol
  • Compare the NETCONF datastores
  • Describe and use network automation tools that utilize SSH
Cisco 300-535 Exam covers a range of topics related to automation and programming in Cisco collaboration solutions. These topics include network programmability, APIs, scripting languages, automation tools, and collaboration platforms. Candidates will be tested on their understanding of these concepts and their ability to use them to develop and deploy automated solutions for Cisco collaboration technologies.
Cisco 300-535 certification exam is a challenging exam that requires a great deal of preparation and study. Candidates need to have a strong understanding of networking and collaboration technologies, as well as a solid grasp of programming concepts and scripting languages. Cisco provides a range of resources, including courses, study materials, and practice exams, to help candidates prepare for the exam. Passing 300-535 exam is an excellent way for IT professionals to validate their skills and knowledge in automating and programming Cisco Collaboration Solutions, making them more valuable to their organizations.
Latest updated Valid Dumps 300-535 Questions & The Best Assstant to help you pass 300-535: Automating and Programming Cisco Collaboration SolutionsRealExamFree offers the best self-assessment software for the 300-535 exam. This desktop-based practice exam provides valid and up-to-date 300-535 practice test questions. You can customize the software by adjusting the time and number of Automating and Programming Cisco Collaboration Solutions (300-535) questions to your preferences. Additionally, you can try a free demo of the 300-535 Practice Test. This software keeps track of all your 300-535 practice exam attempts, allowing you to monitor your progress and improve your Automating and Programming Cisco Collaboration Solutions (300-535) exam preparation.
Cisco Automating and Programming Cisco Collaboration Solutions Sample Questions (Q53-Q58):NEW QUESTION # 53
What are two fundamental design constraints of a RESTful API? (Choose two.)
  • A. It is dependent on the communication protocol being HTTP.
  • B. Each interaction is independent from all others on the server side.
  • C. It exposes procedures or functions for a client call.
  • D. It is a client-server communication model where the client and the server are independent of one another.
  • E. It includes a series of interactions to the API that are dependent on one another.
Section: Automation and Orchestration Platforms
NEW QUESTION # 54
A Cisco NSO service has just been deployed. Which Cisco NSO CLI command is used to inspect the resulting device configuration changes before the changes are pushed to the network?
  • A. show service impact
  • B. commit dry-run outformat native
  • C. show dry-run output
  • D. pseudo-commit
Section: 2.0 Automation APIs and Protocols
NEW QUESTION # 55
Refer to the exhibit. Which lines of code need to be placed on the snippet where the code is missing to configure the disjoint path in Cisco SR-PCE?
  • A. lsp 1 pee ipv4 10.200.2.77 lsp-name PEl_PE3
    lsp 2 pcc ipv4 192.168.217.32 lsp-name PE2_PE4
  • B. group 1 pcc ipv4 10.200.2.77 lsp-name PE1_PE3
    group 2 pcc ipv4 192.168.217.32 lsp-name PE2_PE4
  • C. group 1 pce ipv4 10.200.2.77 lsp-name PE1_PE3
    group 2 pce ipv4 192.168.217.32 lsp-name PE2_PE4
  • D. lsp 1 pcc ipv4 10.200.2.77 lsp-name PE1_PE3
The correct syntax for associating LSPs with a disjoint path group in Cisco SR-PCE is to use the lsp keyword, specify the LSP number, pcc, the IPv4 address, and the LSP name.
NEW QUESTION # 56
Which NETCONF datastore is locked while the network device configuration is edited?
  • A. running
  • B. working
  • C. startup
  • D. common
NEW QUESTION # 57
In which scenario does using a network configuration tool such as Ansible benefit configuration deployment and compliance?
  • A. when implementing configuration changes on equipment that lacks supporting protocols such as SSH or Telnet
  • B. when configuring several network devices that require the same or similar configuration
  • C. when orchestrating networking equipment that must be documented, templated, and automated
  • D. when provisioning greenfield networking equipment configurations by using Cisco Prime Infrastructure
Using a network configuration tool such as Ansible is most beneficial when orchestrating networking equipment that must be documented, templated, and automated, as it enables consistent, automated, and scalable configuration management.
NEW QUESTION # 58
Our 300-535 exam torrent is compiled by experts and approved by experienced professionals and updated according to the development situation in the theory and the practice. Our Automating and Programming Cisco Collaboration Solutions guide torrent can simulate the exam and boosts the timing function. The language is easy to be understood and makes the learners have no learning obstacles. So our 300-535 Exam Torrent can help you pass the exam with high possibility.
300-535 Free Pdf Guide: https://www.realexamfree.com/300-535-real-exam-dumps.html
2026 Latest RealExamFree 300-535 PDF Dumps and 300-535 Exam Engine Free Share: https://drive.google.com/open?id=1wzVJS9D8E7zdOzT7IAB_hm9eKkOPm4Ph
