[Hardware] AIO-3568j CAN Bus RX Errors
17
Hardware AIO-3568j CAN Bus RX Errors
Posted at 1/27/2023 16:12:58      View3348 | Replies4        Print      Only Author   [Copy Link] 1#
Hi, we are testing out integrating an AIO-3568j board into our product. Our product has a CAN with a 500,000bps bus, but when we attempt to connect this board to our bus we are receiving packets but almost all of them are being received as errors (we only need to receive messages). We are also testing a Debix SOM A + IO board, when we connect this Debix board it is working correctly with no errors, we are connecting both boards to our bus in the same way with the same cables.
We noted that both boards seem to have a 120 olm resistor, so this shouldnt be the problem.
We are running the official ubuntu: AIO-3568J_Ubuntu18.04-MLU220-r21199_v1.3.0a_220817
To setup the CAN bus in Ubuntu we run these commands
'ip link set can0 type can bitrate 500000'
'ip link set can0 up'
we also tried setting the qdisc to default as we noticed the Debix board uses the default, while this firefly defaults to fq_codel.
'tc qdisc replace dev can0 root pfifo_fast'
We tested both can0 and can1 with the same settings and received the same results.
I will attach a screen shot showing the ifconfig read out. It shows both can bus interfaces with lots of errors but note they werent connected at the same time, the interfaces were tested separately.
We also tested building our own ubuntu image to change the CAN clock rate, we tested 300M and 400M clock rates but achieved the same result.
Do you have any ideas on what the issue could be?
Thanks!
Posted at 2/10/2023 11:27:30        Only Author  2#
Update the sdk to the latest version and then make the following changes,
Change the can module when using it in the device tree:
-compatible = "rockchip,can-1.0";
+compatible = "rockchip,rk3568-can-2.0";
Posted at 1/12/2026 06:24:39        Only Author  3#
Your article was so insightful, Ill carry it with me. Sharing the GR7 latest test sample test papers for free. Best of luck!
Posted at 1/22/2026 08:33:24        Only Author  4#
Im deeply moved by your article, thank you for sharing it. I owe my success to the Vce PSE-Cortex-Pro-24 test simulator exam, and now Im giving you the chance to access it for free!
Posted at 1/25/2026 05:12:22        Only Author  5#
The article gave me so many new ideas. The Braindumps C_P2W12_2311 downloads test questions are now available for freeyour career success is just a step away!
