[Linux] Correct way to use provided Ubuntu rootfs(64-bit) image?
49
Linux Correct way to use provided Ubuntu rootfs(64-bit) image?
Posted at 2/5/2023 04:49:45      View5772 | Replies7        Print      Only Author   [Copy Link] 1#
I have successfully flashed the provided firmware image here: https://en.t-firefly.com/doc/download/page/id/165.html
This is the file: AIO-3588SJD4-KYLIN_Kylin-20230113_v1.0.6c_230129.7z
However, this installs Kylin, which is a fork of Ubuntu.  I need to install an official ubuntu image due to dependency considerations for another package.  I see what looks to be an Ubuntu 20.04 image on the downloads page.  This image is in the "Image" section, whereas the Kylin image is in the "Firmware" section.
What is the procedure to flash the Ubuntu 20.04 image onto the board?  I tried using the RkDevTool v2.93, however it is not possible to use the Ubuntu image (Loading Firmware Failed!) which isn't a surprise since I believe it does not contain firmware for the board, just the image.  I would like the board to boot into Ubunto 20.04, assuming there is a way to use that provided image.  Any help would be greatly appreciated.
log.zip
22 Bytes, Down times: 0
Posted at 2/6/2023 09:52:54        Only Author  2#
Posted at 2/7/2023 06:13:26        Only Author  3#
zooora111 Posted at 2/6/2023 09:52
This wiki may help: https://wiki.t-firefly.com/en/Firefly-Linux-Guide/manual_ubuntu.html
Thanks for your reply.  I have reviewed this document, but it looks like this is instructions relating to after you have already successfully installed the Ubuntu image to the hardware.  I am still missing the first step, how to install the provided Ubuntu 20.04 image to the hardware so that the system boots up.
super moderator
Rank: 8Rank: 8
Posted at 2/7/2023 10:12:07        Only Author  4#
Firmware has been updated.  https://en.t-firefly.com/doc/download/165.html
Posted at 2/7/2023 10:29:08        Only Author  5#
799959745 Posted at 2/7/2023 10:12
Amazing, this is exactly what I needed.  Thank you very much!
Posted at 1/13/2026 23:26:51        Only Author  6#
l⤬ˤޤϱŮˤΥꥢˤƳɹԤޤŮԤǤ뤳ȤǤޤäơضηҰnjgõĤ֪Rߤ뤳Ȥ^뤿ᡢAxisJ줿ҪANVE-JPN^Ф뤳ȤϱˤˤȤäƷdzҪǤ ANVE-JPNJ˺ϸ񤹤ȡˤϳɹ뤳ȤǤޤ⤷ʤ1ˤǤʤ顢ANVE-JPNԇYȥȤُ뤷Ƥ
Posted at 3/4/2026 16:02:54        Only Author  7#
IIA인증 IIA-CIA-Part2시험패스 공부방법을 찾고 있다면 제일 먼저assTIP를 추천해드리고 싶습니다. IIA인증 IIA-CIA-Part2시험이 많이 어렵다는것은 모두 알고 있는 것입니다. PassTIP에서 출시한 IIA인증 IIA-CIA-Part2덤프는 실제시험을 대비하여 연구제작된 멋진 작품으로서 IIA인증 IIA-CIA-Part2시험적중율이 최고입니다. IIA인증 IIA-CIA-Part2시험패스를 원하신다면assTIP의 제품이 고객님의 소원을 들어줄것입니다.
Posted at 4/20/2026 00:55:36        Only Author  8#
This article has helped me understand many complex concepts, and Ive gained a lot. Ready to face the Practice GCX-AI-GPE Online exam! Pray for good results!
